| 01-IGMP Snooping Commands | 227.41 KB |
IGMP snooping configuration commands
display igmp-snooping statistics
dot1p-priority (IGMP-snooping view)
drop-unknown (IGMP-snooping view)
fast-leave (IGMP-snooping view)
group-policy (IGMP-snooping view)
host-aging-time (IGMP-snooping view)
host-tracking (IGMP-snooping view)
igmp-snooping general-query source-ip
igmp-snooping last-member-query-interval
igmp-snooping max-response-time
igmp-snooping overflow-replace
igmp-snooping report source-ip
igmp-snooping router-aging-time
igmp-snooping router-port-deny
igmp-snooping special-query source-ip
igmp-snooping static-router-port
last-member-query-interval (IGMP-snooping view)
max-response-time (IGMP-snooping view)
overflow-replace (IGMP-snooping view)
report-aggregation (IGMP-snooping view)
reset igmp-snooping statistics
router-aging-time (IGMP-snooping view)
display igmp-snooping group
display igmp-snooping group [ vlan vlan-id ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan vlan-id: Displays the IGMP snooping group information in the specified VLAN, where vlan-id is in the range of 1 to 4094. If you do not specify a VLAN, this command displays the IGMP snooping group information in all VLANs.
verbose: Displays the detailed IGMP snooping group information.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display igmp-snooping group to display IGMP snooping group information, including both dynamic entries and static entries.
# Display detailed IGMP snooping group information in VLAN 2.
<Sysname> display igmp-snooping group vlan 2 verbose
Total 1 IP Group(s).
Total 1 IP Source(s).
Total 1 MAC Group(s).
Port flags: D-Dynamic port, S-Static port, C-Copy port, P-PIM port
Subvlan flags: R-Real VLAN, C-Copy VLAN
Vlan(id):2.
Router port(s):total 1 port(s).
GE1/0/1 (D) ( 00:01:30 )
IP group(s):the following ip group(s) match to one mac group.
IP group address:224.1.1.1
(1.1.1.1, 224.1.1.1):
Attribute: Host Port
Host port(s):total 1 port(s).
GE1/0/2 (D) ( 00:03:23 )
MAC group(s):
MAC group address:0100-5e01-0101
GE1/0/2
Total 1 IP Group(s). |
Total number of IP multicast groups |
Total 1 IP Source(s). |
Total number of multicast sources |
Total 1 MAC Group(s). |
Total number of MAC multicast groups |
Port flags: D-Dynamic port, S-Static port, C-Copy port, P-PIM port |
Port flags: · D—A dynamic port · S—A static port · C—A port copied from a (*, G) entry to an (S, G) entry · P—A port added by PIM snooping |
Subvlan flags: R-Real VLAN, C-Copy VLAN |
Sub-VLAN flags: · R—Real egress sub-VLAN under the current entry · C—Sub-VLAN copied from a (*, G) entry to an (S, G) entry |
Router port(s) |
Number of router ports |
( 00:01:30 ) |
Remaining time of the aging timer for the dynamic member port or router port |
IP group address |
Address of IP multicast group |
MAC group address |
Address of MAC multicast group |
Attribute |
Attribute of IP multicast group |
Host port(s) |
Number of member ports |
display igmp-snooping host
display igmp-snooping host vlan vlan-id group group-address [ source source-address ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan vlan-id: Displays information about the hosts tracked by IGMP snooping in the specified VLAN, where vlan-id is in the range of 1 to 4094.
group group-address: Displays information about the hosts tracked by IGMP snooping that are in the specified IGMP snooping group. The value of group-address ranges from 224.0.1.0 to 239.255.255.255.
source source-address: Displays information about the hosts tracked by IGMP snooping that are in the specified multicast source, where source-address is a valid unicast address or 0.0.0.0. A source IP address of 0.0.0.0 specifies all multicast sources.
Use display igmp-snooping host to display information about the hosts tracked by IGMP snooping.
# Display information about the hosts tracked by IGMP snooping in VLAN 2 that are in multicast group 224.1.1.1.
<Sysname> display igmp-snooping host vlan 2 group 224.1.1.1
VLAN(ID) : 2
(0.0.0.0, 224.1.1.1)
Port : GE1/0/1
Host Uptime Expires
1.1.1.1 00:02:20 00:00:40
2.2.2.2 00:02:21 00:00:39
Port : GE1/0/2
Host Uptime Expires
3.3.3.3 00:02:20 00:00:40
VLAN(ID) |
VLAN ID |
(0.0.0.0, 224.1.1.1) |
(S, G) entry, where "0.0.0.0" indicates all multicast sources |
Port |
Member port |
Host |
Host IP address |
Uptime |
Host running duration |
Expires |
Host expiration time, where "timeout" means that the host has expired |
display igmp-snooping statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display igmp-snooping statistics to display the statistics information of IGMP messages learned through IGMP snooping.
# Display the statistics information of IGMP messages learned through IGMP snooping.
<Sysname> display igmp-snooping statistics
Received IGMP general queries:0.
Received IGMPv1 reports:0.
Received IGMPv2 reports:19.
Received IGMP leaves:0.
Received IGMPv2 specific queries:0.
Sent IGMPv2 specific queries:0.
Received IGMPv3 reports:1.
Received IGMPv3 reports with right and wrong records:0.
Received IGMPv3 specific queries:0.
Received IGMPv3 specific sg queries:0.
Sent IGMPv3 specific queries:0.
Sent IGMPv3 specific sg queries:0.
Received error IGMP messages:19.
general queries |
General query messages |
specific queries |
Group-specific query messages |
reports |
Report messages |
leaves |
Leave messages |
reports with right and wrong records |
Report messages with correct and incorrect records |
specific sg query packet(s) |
Group-and-source-specific query message or messages |
error IGMP messages |
IGMP messages with errors |
dot1p-priority priority-number
undo dot1p-priority
View
IGMP-snooping view
Default level
2: System level
priority-number: Specifies 802.1p precedence for IGMP messages, in the range of 0 to 7. The higher the number, the higher the precedence.
Use dot1p-priority to configure 802.1p precedence for IGMP messages globally.
Use undo dot1p-priority to restore the default.
The default 802.1p precedence for IGMP messages is 0.
# Set 802.1p precedence for IGMP messages to 3 globally.
[Sysname] igmp-snooping
[Sysname-igmp-snooping] dot1p-priority 3
drop-unknown
undo drop-unknown
View
IGMP-snooping view
Default level
2: System level
None
Use drop-unknown to enable the function of dropping unknown multicast data globally.
Use undo drop-unknown to disable the function of dropping unknown multicast data globally.
By default, this function is disabled. That is, unknown multicast data is flooded.
Related commands: igmp-snooping drop-unknown.
# Enable the device to drop unknown multicast data globally.
[Sysname-igmp-snooping] drop-unknown
fast-leave [ vlan vlan-list ]
undo fast-leave [ vlan vlan-list ]
View
IGMP-snooping view
Default level
2: System level
vlan vlan-list: Specifies one or multiple VLANs. You can provide up to 10 VLAN lists. For each list, you can specify an individual VLAN in the form of vlan-id, or a VLAN range in the form of start-vlan-id to end-vlan-id, where the end VLAN ID must be greater than the start VLAN ID. The effective range of a VLAN ID is 1 to 4094. If you do not specify any VLAN, the command takes effect for all VLANs. If you specify one or more VLANs, the command takes effect for the specified VLANs only.
Use fast-leave to enable IGMP snooping fast-leave processing globally. With this function enabled, when the access controller receives an IGMP leave message on a port, it directly removes that port from the multicast forwarding entry of the specific group.
Use undo fast-leave to disable IGMP snooping fast-leave processing globally.
By default, IGMP snooping fast-leave processing is disabled.
This command works on IGMP snooping–enabled VLANs.
Related commands: igmp-snooping fast-leave.
# Enable IGMP snooping fast-leave processing globally in VLAN 2.
[Sysname-igmp-snooping] fast-leave vlan 2
group-policy acl-number [ vlan vlan-list ]
undo group-policy [ vlan vlan-list ]
View
IGMP-snooping view
Default level
2: System level
acl-number: Specifies a basic or advanced ACL number, in the range of 2000 to 3999.
Use group-policy to configure a global multicast group filter, namely, to control the multicast groups that a host can join.
Use undo group-policy to remove the configured global multicast group filter.
By default, no global multicast group filter is configured. Namely, a host can join any multicast group.
If the specified ACL does not exist or the ACL rule is null, all multicast groups are filtered out.
You can configure different ACL rules for a port in different VLANs. For a given VLAN, a newly configured ACL rule overrides the existing one.
Related commands: igmp-snooping group-policy.
# Apply ACL 2000 as a multicast group filter in VLAN 2 so that hosts in this VLAN can join 225.1.1.1 only.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 225.1.1.1 0
[Sysname-acl-basic-2000] quit
[Sysname-igmp-snooping] group-policy 2000 vlan 2
host-aging-time interval
undo host-aging-time
View
IGMP-snooping view
Default level
2: System level
interval: Specifies an aging timer for the dynamic member ports in seconds. The value ranges from 200 to 1000.
Use host-aging-time to configure the aging timer for the dynamic member ports globally.
Use undo host-aging-time to restore the default.
By default, the aging timer of the dynamic member ports is 260 seconds.
Related commands: igmp-snooping host-aging-time.
# Set the aging time for the dynamic member ports to 300 seconds globally.
[Sysname-igmp-snooping] host-aging-time 300
host-tracking
undo host-tracking
View
IGMP-snooping view
Default level
2: System level
None
Use host-tracking to enable the IGMP snooping host tracking function globally.
Use undo host-tracking to disable the IGMP snooping host tracking function globally.
This command works only on IGMP snooping–enabled VLANs.
Related commands: igmp-snooping host-tracking.
# Enable the IGMP snooping host tracking function globally.
[Sysname-igmp-snooping] host-tracking
igmp-snooping
igmp-snooping
undo igmp-snooping
View
Default level
2: System level
None
Use igmp-snooping to enable IGMP snooping globally and enter IGMP-snooping view.
Use undo igmp-snooping to disable IGMP snooping globally.
By default, IGMP snooping is disabled.
Related commands: igmp-snooping enable.
# Enable IGMP snooping globally and enter IGMP-snooping view.
igmp-snooping dot1p-priority
igmp-snooping dot1p-priority priority-number
undo igmp-snooping dot1p-priority
View
VLAN view
Default level
2: System level
Use igmp-snooping dot1p-priority to configure 802.1p precedence for IGMP messages in a VLAN.
Use undo igmp-snooping dot1p-priority to restore the default.
Before you configure this command in a VLAN, enable IGMP snooping in the VLAN.
# Enable IGMP snooping in VLAN 2 and set 802.1p precedence for IGMP messages in the VLAN to 3.
[Sysname-igmp-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping enable
[Sysname-vlan2] igmp-snooping dot1p-priority 3
undo igmp-snooping drop-unknown
View
VLAN view
Default level
2: System level
None
Use igmp-snooping drop-unknown to enable the function of dropping unknown multicast data in the current VLAN.
Use undo igmp-snooping drop-unknown to disable the function of dropping unknown multicast data in the current VLAN.
This command takes effect only if IGMP snooping is enabled in the VLAN.
Related commands: drop-unknown and igmp-snooping enable.
# In VLAN 2, enable IGMP snooping and the function of dropping unknown multicast data.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping drop-unknown
undo igmp-snooping enable
View
VLAN view
Default level
2: System level
None
Use igmp-snooping enable to enable IGMP snooping in the current VLAN.
Use undo igmp-snooping enable to disable IGMP snooping in the current VLAN.
By default, IGMP snooping is disabled in a VLAN.
IGMP snooping must be enabled globally before it can be enabled in a VLAN.
Related commands: igmp-snooping.
# Enable IGMP snooping in VLAN 2.
[Sysname] vlan 2
igmp-snooping fast-leave [ vlan vlan-list ]
undo igmp-snooping fast-leave [ vlan vlan-list ]
View
Layer 2 Ethernet interface view, Layer 2 aggregate interface view, port group view
Default level
2: System level
Use igmp-snooping fast-leave to enable IGMP snooping fast-leave processing on the current port. When this function is enabled on a port and the access controller receives an IGMP leave message through a port, it directly removes that port from the multicast forwarding entry of the specific group.
Use undo igmp-snooping fast-leave to disable IGMP snooping fast-leave processing on the current port.
If you do not specify any VLAN when using this command in Layer 2 Ethernet interface view or Layer 2 aggregate interface view, the command takes effect for all VLANs that the interface belongs to. If you specify one or more VLANs, the command takes effect for the specified VLANs that the interface belongs to.
If you do not specify any VLAN when using this command in port group view, the command takes effect on all the ports in this group. If you specify one or more VLANs, the command takes effect only on those ports in this group that belong to the specified VLANs.
Related commands: fast-leave.
NOTE: Support for this command depends on the device model. For the command matrixes, see About the WX Series Access Controllers Command References. |
# Enable IGMP snooping fast-leave processing on GigabitEthernet 1/0/1 in VLAN 2.
[Sysname] interface Gigabitethernet 1/0/1
[Sysname-GigabitEthernet1/0/1] igmp-snooping fast-leave vlan 2
igmp-snooping general-query source-ip { ip-address | current-interface }
undo igmp-snooping general-query source-ip
View
VLAN view
Default level
2: System level
ip-address: Specifies the source address of IGMP general queries, which can be any legal IP address.
current-interface: Sets the source address of IGMP general queries to the address of the current VLAN interface. If the current VLAN interface does not have an IP address, the default IP address 0.0.0.0 is used as the source IP address of IGMP general queries.
Use igmp-snooping general-query source-ip to configure the source address of IGMP general queries.
Use undo igmp-snooping general-query source-ip to restore the default.
By default, the source IP address of IGMP general queries is 0.0.0.0.
# In VLAN 2, enable IGMP snooping and specify 10.1.1.1 as the source IP address of IGMP general queries.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping general-query source-ip 10.1.1.1
igmp-snooping group-limit
igmp-snooping group-limit limit [ vlan vlan-list ]
undo igmp-snooping group-limit [ vlan vlan-list ]
View
Default level
2: System level
limit: Specifies the maximum number of multicast groups that a port can join. The value range depends on the device model. For more information, see About the WX Series Access Controllers Command References.
vlan vlan-list: Specifies one or multiple VLANs. You can provide up to 10 VLAN lists. For each list, you can specify an individual VLAN in the form of vlan-id, or a VLAN range in the form of start-vlan-id to end-vlan-id, where the end VLAN ID must be greater than the start VLAN ID. The effective range of a VLAN ID is 1 to 4094. If the vlan vlan-list option is not provided, this configuration limits the maximum number of multicast groups that a port can join in each VLAN that the port belongs to.
Use igmp-snooping group-limit to set the maximum number of multicast groups that a port can join.
Use undo igmp-snooping group-limit to restore the default.
The default upper limit depends on the device model. For more information, see About the WX Series Access Controllers Command References.
Related commands: igmp group-limit.
# Allow GigabitEthernet 1/0/1 in VLAN 2 to join up to 10 multicast groups.
[Sysname-GigabitEthernet1/0/1] igmp-snooping group-limit 10 vlan 2
igmp-snooping group-policy acl-number [ vlan vlan-list ]
undo igmp-snooping group-policy [ vlan vlan-list ]
View
Default level
2: System level
acl-number: Specifies a basic ACL number, in the range of 2000 to 3999.
Use igmp-snooping group-policy to configure a multicast group filter on the current port, namely, to control the multicast groups that the port can join.
Use undo igmp-snooping group-policy to remove a multicast group filter on the current port.
By default, no multicast group filter is configured on an interface. Namely a host can join any valid multicast group.
If you do not specify any VLAN when using this command in Layer 2 Ethernet interface view or Layer 2 aggregate interface view, the command takes effect for all VLANs the interface belongs to. If you specify one or more VLANs, the command takes effect for the specified VLANs that the interface belongs to.
Related commands: group-policy.
# Apply ACL 2000 as a multicast group filter so that hosts on GigabitEthernet 1/0/1 in VLAN 2 can join 225.1.1.1 only.
[Sysname-GigabitEthernet1/0/1] igmp-snooping group-policy 2000 vlan 2
igmp-snooping host-aging-time interval
undo igmp-snooping host-aging-time
View
VLAN view
Default level
2: System level
Use igmp-snooping host-aging-time to configure the aging timer for the dynamic member ports in the current VLAN.
Use undo igmp-snooping host-aging-time to restore the default.
Related commands: host-aging-time and igmp-snooping enable.
# Enable IGMP snooping and set the aging timer for the dynamic member ports to 300 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping host-aging-time 300
igmp-snooping host-join
igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
View
Default level
2: System level
group-address: Specifies the address of the multicast group that the simulated host will join, in the range of 224.0.1.0 to 239.255.255.255.
source-address: Specifies the address of the multicast source that the simulated host will join. This argument must be a valid unicast address or 0.0.0.0. A source IP address of 0.0.0.0 specifies all multicast sources.
vlan vlan-id: Specifies the VLAN that comprises the port, where vlan-id is in the range of 1 to 4094.
Use igmp-snooping host-join to enable simulated joining on a port. Namely, you configure the current port as a simulated member host for the specified multicast group or multicast source group.
Use undo igmp-snooping host-join to remove the simulated member host from the specified multicast group or source and group.
The source-ip source-address option in the command is meaningful only for IGMPv3 snooping. If IGMPv2 snooping is running, the source-ip source-address option does not take effect although you can include source-ip source-address in the command.
In Layer 2 Ethernet interface view or Layer 2 aggregate interface view, this command takes effect only if the interface belongs to the specified VLAN.
In port group view, this command takes effect only on those ports in this port group that belong to the specified VLAN.
# Configure GigabitEthernet 1/0/1 as a simulated member host in VLAN 2 for multicast source and group (1.1.1.1, 224.1.1.1).
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping version 3
[Sysname-vlan2] quit
[Sysname-GigabitEthernet1/0/1] igmp-snooping host-join 224.1.1.1 source-ip 1.1.1.1 vlan 2
undo igmp-snooping host-tracking
View
VLAN view
Default level
2: System level
None
Use igmp-snooping host-tracking to enable the IGMP snooping host tracking function in a VLAN.
Use undo igmp-snooping host-tracking to disable the IGMP snooping host tracking function in a VLAN.
Before you configure this command, enable IGMP snooping in the VLAN first.
Related commands: host-tracking and igmp-snooping enable.
# Enable IGMP snooping and IGMP snooping host tracking in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping host-tracking
igmp-snooping last-member-query-interval interval
undo igmp-snooping last-member-query-interval
View
VLAN view
Default level
2: System level
interval: Specifies an interval between IGMP last-member queries, in seconds. The value ranges from 1 to 5.
Use igmp-snooping last-member-query-interval to configure the interval between IGMP last-member queries in the VLAN.
Use undo igmp-snooping last-member-query-interval to restore the default.
By default, the IGMP last-member query interval is 1 second.
Related commands: igmp-snooping enable and last-member-query-interval.
# Enable IGMP snooping and set the interval between IGMP last-member queries to 3 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping last-member-query-interval 3
igmp-snooping leave source-ip
igmp-snooping leave source-ip { ip-address | current-interface }
undo igmp-snooping leave source-ip
View
VLAN view
Default level
2: System level
ip-address: Specifies a source address for the IGMP leave messages sent by the IGMP snooping proxy, which can be any legal IP address.
current-interface: Specifies the IP address of the current VLAN interface as the source address of IGMP leave messages sent by the IGMP snooping proxy. If no IP address has been assigned to the current VLAN interface, the default IP address 0.0.0.0 is used.
Use igmp-snooping leave source-ip to configure the source IP address of the IGMP leave messages that the IGMP snooping proxy sends.
Use undo igmp-snooping leave source-ip to restore the default.
By default, the source IP address of the IGMP leave messages that the IGMP snooping proxy sends is 0.0.0.0.
The source IP address configured in the igmp-snooping leave source-ip command also applies when the simulated host sends IGMP leave messages.
# Enable IGMP snooping in VLAN 2 and configure the source IP address of IGMP leave messages sent by the IGMP snooping proxy in VLAN 2 to 10.1.1.1.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping leave source-ip 10.1.1.1
igmp-snooping max-response-time interval
undo igmp-snooping max-response-time
View
VLAN view
Default level
2: System level
interval: Specifies the maximum response time for IGMP general queries, in seconds. The value ranges from 1 to 25.
Use igmp-snooping max-response-time to configure the maximum response time for IGMP general queries in the VLAN.
Use undo igmp-snooping max-response-time to restore the default.
By default, the maximum response time for IGMP general queries is 10 seconds.
Related commands: igmp-snooping enable, igmp-snooping query-interval, and max-response-time.
# Enable IGMP snooping and set the maximum response time for IGMP general queries to 5 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping max-response-time 5
igmp-snooping overflow-replace [ vlan vlan-list ]
undo igmp-snooping overflow-replace [ vlan vlan-list ]
View
Default level
2: System level
Use igmp-snooping overflow-replace to enable the multicast group replacement function on the current port.
Use undo igmp-snooping overflow-replace to disable the multicast group replacement function on the current port.
By default, the multicast group replacement function is disabled.
Related commands: overflow-replace.
# Enable the multicast group replacement function on GigabitEthernet 1/0/1 in VLAN 2.
[Sysname-GigabitEthernet1/0/1] igmp-snooping overflow-replace vlan 2
igmp-snooping proxying enable
undo igmp-snooping proxying enable
View
VLAN view
Default level
2: System level
None
Use igmp-snooping proxying enable to enable the IGMP snooping proxying function in a VLAN.
Use undo igmp-snooping proxying enable to disable the IGMP snooping proxying function in a VLAN.
By default, IGMP snooping proxying is disabled in all VLANs.
# Enable IGMP snooping and then IGMP snooping proxying in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping proxying enable
igmp-snooping querier
undo igmp-snooping querier
View
VLAN view
Default level
2: System level
None
Use igmp-snooping querier to enable the IGMP snooping querier function.
Use undo igmp-snooping querier to disable the IGMP snooping querier function.
By default, the IGMP snooping querier function is disabled.
# Enable IGMP snooping and the IGMP snooping querier function in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping querier
igmp-snooping query-interval interval
undo igmp-snooping query-interval
View
VLAN view
Default level
2: System level
interval: Specifies the interval between IGMP general queries in seconds. The value ranges from 2 to 300.
Use igmp-snooping query-interval to configure the interval between IGMP general queries.
Use undo igmp-snooping query-interval to restore the default.
By default, the IGMP general query interval is 60 seconds.
Related commands: igmp-snooping enable, igmp-snooping max-response-time, igmp-snooping querier, and max-response-time.
# Enable IGMP snooping and set the interval between IGMP general queries to 20 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping query-interval 20
igmp-snooping report source-ip { ip-address | current-interface }
undo igmp-snooping report source-ip
View
VLAN view
Default level
2: System level
ip-address: Specifies a source address for the IGMP reports sent by the IGMP snooping proxy, which can be any legal IP address.
current-interface: Specifies the IP address of the current VLAN interface as the source address of IGMP reports sent by the IGMP snooping proxy. If no IP address has been assigned to the current VLAN interface, the default IP address 0.0.0.0 is used.
Use igmp-snooping report source-ip to configure the source IP address of the IGMP reports that the IGMP snooping proxy sends.
Use undo igmp-snooping report source-ip to restore the default.
By default, the source IP address of the IGMP reports that the IGMP snooping proxy sends is 0.0.0.0.
The source IP address configured in the igmp-snooping report source-ip command also applies when the simulated host sends IGMP reports.
# Enable IGMP snooping in VLAN 2 and configure the source IP address of IGMP reports sent by the IGMP snooping proxy in VLAN 2 to 10.1.1.1.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping report source-ip 10.1.1.1
igmp-snooping router-aging-time interval
undo igmp-snooping router-aging-time
View
VLAN view
Default level
2: System level
interval: Specifies an aging timer for the dynamic router ports in seconds. The value ranges from 1 to 1000.
Use igmp-snooping router-aging-time to configure the aging timer for the dynamic router ports in the current VLAN.
Use undo igmp-snooping router-aging-time to restore the default.
By default, the aging timer of the dynamic router ports is 105 seconds.
Related commands: igmp-snooping enable and router-aging-time.
# Enable IGMP snooping and set the aging timer for the dynamic router ports to 100 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping router-aging-time 100
igmp-snooping router-port-deny [ vlan vlan-list ]
undo igmp-snooping router-port-deny [ vlan vlan-list ]
View
Default level
2: System level
Use igmp-snooping router-port-deny to disable a port from becoming a dynamic router port.
Use undo igmp-snooping router-port-deny to restore the default.
By default, a port can become a dynamic router port.
# Disable GigabitEthernet 1/0/1 from becoming a dynamic router port in VLAN 2.
[Sysname-GigabitEthernet1/0/1] igmp-snooping router-port-deny vlan 2
igmp-snooping special-query source-ip { ip-address | current-interface }
undo igmp-snooping special-query source-ip
View
VLAN view
Default level
2: System level
ip-address: Specifies a source address for IGMP group-specific queries.
current-interface: Specifies the IP address of the current VLAN interface as the source address of IGMP group-specific queries. If the current VLAN interface does not have an IP address, the default IP address 0.0.0.0 is used as the source IP address of IGMP group-specific queries.
Use igmp-snooping special-query source-ip to configure the source IP address of IGMP group-specific queries.
Use undo igmp-snooping special-query source-ip to restore the default.
By default, the source IP address of IGMP group-specific queries is 0.0.0.0.
# In VLAN 2, enable IGMP snooping and specify 10.1.1.1 as the source IP address of IGMP group-specific queries.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping special-query source-ip 10.1.1.1
igmp-snooping static-group
igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
View
Default level
2: System level
group-address: Specifies the address of the multicast group that the port will join statically, in the range of 224.0.1.0 to 239.255.255.255.
source-address: Specifies the address of the multicast source that the port will join statically. This argument must be a valid unicast address or 0.0.0.0. A source IP address of 0.0.0.0 specifies all multicast sources.
Use igmp-snooping static-group to configure the static member ports. Namely, you can configure the current port as a static member port of a multicast group or multicast source-group.
Use undo igmp-snooping static-group to remove the port from the multicast group or multicast source-group.
By default, no ports are static member ports.
# Configure GigabitEthernet 1/0/1 in VLAN 2 to be a static member port of (1.1.1.1, 232.1.1.1).
[Sysname] vlan 2
[Sysname-GigabitEthernet1/0/1] igmp-snooping static-group 224.1.1.1 source-ip 1.1.1.1 vlan 2
igmp-snooping static-router-port vlan vlan-id
undo igmp-snooping static-router-port vlan vlan-id
View
Default level
2: System level
vlan vlan-id: Specifies a VLAN, where vlan-id is in the range of 1 to 4094.
Use igmp-snooping static-router-port to configure the current port as a static router port.
Use undo igmp-snooping static-router-port to cancel the configuration.
By default, no ports are static router ports.
This command does not take effect in a sub-VLAN of a multicast VLAN.
# Enable the static router port function on GigabitEthernet 1/0/1 in VLAN 2.
[Sysname-GigabitEthernet1/0/1] igmp-snooping static-router-port vlan 2
igmp-snooping version version-number
undo igmp-snooping version
View
VLAN view
Default level
2: System level
version-number: Specifies an IGMP snooping version, in the range of 2 to 3.
Use igmp-snooping version to configure the IGMP snooping version.
Use undo igmp-snooping version to restore the default.
By default, the IGMPv2 snooping is used.
This command can take effect only if IGMP snooping is enabled in the VLAN.
# Enable IGMP snooping in VLAN 2, and specify IGMPv3 snooping.
[Sysname] vlan 2
undo last-member-query-interval
View
IGMP-snooping view
Default level
2: System level
interval: Specifies an interval between IGMP last-member queries in seconds. The value ranges from 1 to 5.
Use last-member-query-interval to configure the interval between IGMP last-member queries globally.
Use undo last-member-query-interval to restore the default.
By default, the interval between IGMP last-member queries is 1 second.
Related commands: igmp-snooping last-member-query-interval.
# Set the interval between IGMP last-member queries to 3 seconds globally.
[Sysname-igmp-snooping] last-member-query-interval 3
undo max-response-time
View
IGMP-snooping view
Default level
2: System level
Use max-response-time to configure the maximum response time for IGMP general queries globally.
Use undo max-response-time to restore the default.
Related commands: igmp-snooping max-response-time and igmp-snooping query-interval.
# Set the maximum response time for IGMP general queries to 5 seconds globally.
[Sysname-igmp-snooping] max-response-time 5
undo overflow-replace [ vlan vlan-list ]
View
IGMP-snooping view
Default level
2: System level
Use overflow-replace to enable the multicast group replacement function globally.
Use undo overflow-replace to disable the multicast group replacement function globally.
If you do not specify any VLAN, the command takes effect for all VLANs; if you specify a VLAN or multiple VLANs, the command takes effect for the specified VLANs only.
Related commands: igmp-snooping overflow-replace.
# Enable the multicast group replacement function globally in VLAN 2.
[Sysname-igmp-snooping] overflow-replace vlan 2
report-aggregation
undo report-aggregation
View
IGMP-snooping view
Default level
2: System level
None
Use report-aggregation to enable IGMP report suppression.
Use undo report-aggregation to disable IGMP report suppression.
By default, IGMP report suppression is enabled.
# Disable IGMP report suppression.
[Sysname-igmp-snooping] undo report-aggregation
reset igmp-snooping group
reset igmp-snooping group { group-address | all } [ vlan vlan-id ]
View
Default level
2: System level
group-address: Specifies an IGMP snooping group. The value range of group-address is 224.0.1.0 to 239.255.255.255.
all: Specifies all IGMP snooping groups.
Use reset igmp-snooping group to remove the dynamic group entries of a specific IGMP snooping group or all IGMP snooping groups.
This command cannot remove the static group entries of IGMP snooping groups.
# Remove the dynamic group entries of all IGMP snooping groups.
<Sysname> reset igmp-snooping group all
View
Default level
2: System level
None
Use reset igmp-snooping statistics to clear the statistics information of IGMP messages learned through IGMP snooping.
# Clear the statistics information of all kinds of IGMP messages learned through IGMP snooping.
<Sysname> reset igmp-snooping statistics
undo router-aging-time
View
IGMP-snooping view
Default level
2: System level
interval: Specifies an aging timer for the dynamic router port in seconds. The value ranges from 1 to 1000.
Use router-aging-time to configure the aging timer for the dynamic router ports globally.
Use undo router-aging-time to restore the default.
By default, the aging timer of dynamic router ports is 105 seconds.
Related commands: igmp-snooping router-aging-time.
# Set the aging timer for the dynamic router ports to 100 seconds globally.
[Sysname-igmp-snooping] router-aging-time 100
