- 01-Fundamentals Configuration Guide
- 01-CLI configuration
- 02-Login management configuration
- 03-RBAC configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-ISSU configuration
- 09-Emergency shell configuration
- 10-Device management configuration
- 11-Tcl configuration
- 12-Python configuration
- 13-License management
- 14-Preprovisioning feature configuration
- 15-Automatic configuration
08-ISSU configuration | 206.42 KB |
Identifying availability of ISSU and licensing requirements
Verifying the device operating status
Determining the upgrade procedure
Logging in to the device through the console port
Saving the running configuration
Performing an ISSU by using issu commands·
Upgrading a multichassis IRF fabric
Upgrading a single-chassis IRF fabric
Performing an ISSU by using install commands
Installing or upgrading software images
Uninstalling feature or patch images
Rolling back the running software images
Aborting a software activate/deactivate operation
Removing inactive software images
Displaying and maintaining ISSU
ISSU examples for using issu commands·
Software image upgrade to a compatible version
Software image upgrade to an incompatible version
Software image rollback example
ISSU examples for using install commands
Software image upgrade example
Software image patching example
Performing an ISSU
ISSU overview
The In-Service Software Upgrade (ISSU) feature upgrades software with a minimum amount of downtime.
ISSU is implemented on the basis of the following design advantages:
· Separation of service features from basic functions—Device software is segmented into boot, system, and feature images. The images can be upgraded individually.
· Independence between service features—Features run independently. One feature can be added or upgraded without affecting the operation of the system or other features.
· Support for hotfix—Patch images are available to fix system bugs without a system reboot.
· Hardware redundancy—In an IRF fabric, one member device can be upgraded while other member devices are providing services.
For more information about images, see "Upgrading software."
ISSU methods
ISSU supports the following upgrade types:
· Compatible upgrade—The running software version is compatible with the upgrade software version. This upgrade type supports the ISSU methods in Table 1.
· Incompatible upgrade—The running software version is incompatible with the upgrade software version. The two versions cannot run concurrently.
This upgrade type supports only one upgrade method (also called incompatible upgrade). This method requires a cold reboot. It is service disruptive if hardware redundancy is not available.
Table 1 ISSU methods for compatible upgrade
ISSU method |
Incremental upgrade: · Service Upgrade · File Upgrade |
Upgrades only segments that contain differences between the new and old software versions. · Service upgrade—Upgrades service features. The upgrade does not affect the operation of features that are not being upgraded. · File upgrade—Upgrades hidden system program files. The system can provide services during the upgrade. |
ISSU Reboot |
Reboots CPUs to complete software upgrade. During the reboot, the data plane can still forward traffic. This method saves all data (running, configuration, and hardware) and status to memory before rebooting CPUs. For services that require regular communication with their peers, this method uses protocol agents to maintain their connectivity and status. After the reboot, all data is restored to CPU. |
Reboot |
The Reboot method is service disruptive if the device stands alone. As a best practice, schedule the downtime carefully to minimize the upgrade impact on the services. This method reboots both the control and data planes to complete the software upgrade. |
ISSU commands
ISSU provides the install and issu command sets. After you identify the ISSU method, use Table 2 to choose the command set you want to use.
Table 2 Command set comparison
Item |
issu commands |
install commands |
Upgrade types |
· Compatible. · Incompatible. |
Compatible. |
Patch install/uninstall |
Not supported. |
Supported. |
Upgrade mode |
Chassis by chassis. |
Impact on the system |
Large. |
Small. |
Technical skill requirements |
Low. As a best practice, use this command set. |
High. Administrators must have extensive system knowledge and understand the impact of each upgrade task on the network. |
Preparing for ISSU
To perform a successful ISSU, make sure all the preparation requirements are met.
Read the software release notes to identify the following items:
· Support of the device for ISSU.
· Licensing requirements for the upgrade software images.
If the upgrade software images require licenses, make sure the device has the required licenses before ISSU. For more information about license installation, see "Managing licenses."
Use the display device command to verify that all member devices are operating correctly.
Preparing the upgrade images
1. Use the dir command to verify that all member devices has sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete command. For more information, see "Managing the file system."
2. Use FTP or TFTP to transfer upgrade image files to the root directory of any storage medium in the IRF fabric.
Identifying the ISSU method
1. Execute the display version comp-matrix file command for the upgrade image version.
2. Check the Version compatibility list field.
¡ If the running software version is in the list, a compatible upgrade is required.
¡ If the running software version is not in the list, an incompatible upgrade is required.
3. Identify the ISSU method:
¡ If a compatible upgrade is required, check the Upgrade Way field to identify the ISSU method. For more information about ISSU methods, see Table 1.
¡ If an incompatible upgrade is required, check the end of command output for the Incompatible upgrade string.
Verifying feature status
For service continuity during ISSU, configure the following feature settings:
Feature |
Setting requirements |
GR/NSR |
Enable GR or NSR for protocols including LDP, RSVP, OSPF, ISIS, BGP, and FSPF. |
BFD |
Disable BFD for protocols including LDP, RSVP, OSPF, ISIS, RIP, BGP, VRRP, and NQA. |
Ethernet link aggregation |
Use the long LACP timeout interval (the lacp period short command is not configured) on all member ports in dynamic aggregation groups. |
IRF |
Configure IRF bridge MAC persistence as follows: · Compatible upgrade—Configure the irf mac-address persistent timer or irf mac-address persistent always command. · Incompatible upgrade—Configure the irf mac-address persistent always command if the bridge MAC address is the MAC address of the device for which you want to execute the issu load command. |
For an ISSU Reboot upgrade on a single-member IRF fabric, also verify that the following features are disabled:
Feature |
Remarks |
Spanning tree feature |
If the spanning tree feature is enabled, service discontinuity might occur during the upgrade because the feature advertises the network topology change. |
Dynamic Ethernet link aggregation |
During an ISSU reboot, only static aggregation is supported, and dynamic aggregate interfaces might not be able to provide services. |
CFD |
If CFD is enabled, the CFD CC feature will be disabled during an ISSU reboot, which results in traffic abnormality. |
DLDP |
If DLDP is enabled, the peer device might consider a link a unidirectional link and shut down the port because it cannot receive probe packets. |
Loop detection |
If loop detection is enabled, the peer device might enable looped ports because of false loop removal detection. |
1. Use Table 2 to choose an upgrade command set, depending on the ISSU method.
2. Identify the hardware redundancy condition.
ISSU can maintain service continuity only when the IRF fabric has multiple members and uses the ring topology.
IMPORTANT: If hardware redundancy is not available, service discontinuity is not avoidable. Make sure you understand the impact of the upgrade on the network. |
3. Choose the correct procedure from the procedures described in "Performing an ISSU by using issu commands" or "Performing an ISSU by using install commands."
Understanding ISSU guidelines
During an ISSU, use the following guidelines:
· In a multiuser environment, make sure no other administrators access the device while you are performing the ISSU.
· Do not perform any of the following tasks during an ISSU:
¡ Reboot, add, or remove member devices.
¡ Execute commands that are not related to the ISSU.
¡ Modify, delete, or rename image files.
· You cannot use both install and issu commands for an ISSU. However, you can use display issu commands with both command sets.
· The following protocols will recalculate topology after an ISSU reboot if a peer keepalive timeout has occurred:
¡ Multicast protocols—PIM, IGMP, MLD, IGMP snooping, and MLD snooping.
¡ Routing protocols—OSPF, IS-IS, and BGP.
¡ FCoE—FIP snooping and FSPF.
After an ISSU, you must log in to the device again before you can configure the device.
Log in to the device through the console port after you finish all the preparation tasks and understand all the ISSU guidelines. If you use Telnet or SSH, you might be disconnected from the device before the ISSU is completed.
Use the save command to save the running configuration.
The ISSU procedure varies depending on whether the IRF fabric has a single or multiple members.
Performing a compatible upgrade
For a compatible upgrade on a multichassis IRF fabric, upgrade a subordinate member first. Then, upgrade the master and the other subordinate members.
To perform a compatible upgrade:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. (Optional.) Set the automatic rollback timer. |
issu rollback-timer minutes |
By default, the automatic rollback timer is set to 45 minutes. This timer starts when you execute the issu run switchover command. If you do not execute the issu accept or issu commit command before this timer expires, the system automatically rolls back to the original software images. |
3. Return to user view. |
quit |
N/A |
4. Load the upgrade images as main startup software images on subordinate members. |
Use .bin files: ·
Use an .ipe file: |
Specify the member ID of a subordinate member for the slot-number argument. |
5. Perform a master/subordinate switchover. |
issu run switchover |
N/A |
6. (Optional.) Accept the upgrade and delete the automatic rollback timer. |
issu accept |
N/A |
7. Upgrade the remaining members to complete the ISSU. |
issu commit chassis chassis-number |
After executing the command for one member, you must wait for the member to restart and join the IRF fabric before you execute the command for another member. Repeat the issu commit command to upgrade the remaining members one by one, including the original master. To manually roll back to the original software images during this ISSU process, use the issu rollback command. For more information about rollback, see Fundamentals Command Reference. |
Performing an incompatible upgrade
For an incompatible upgrade on a multichassis IRF fabric, upgrade one or more subordinate members first. As a best practice, upgrade half of the subordinate members first. Then, upgrade the master and the other subordinate members.
Perform this task in user view.
Step |
Command |
Remarks |
1. Load the upgrade images as main startup software images on subordinate members. |
Use .bin files: ·
Use an .ipe file: |
Specify the member ID of a subordinate member for the slot-number argument. As a best practice on a ring-topology IRF fabric, specify half of the subordinate members for this command to reduce service interruption. Make sure the specified subordinate members are physically connected. |
2. Perform a master/subordinate switchover to complete the ISSU process. |
To roll back to the original software images during this ISSU process, use the issu rollback command. This ISSU process does not support automatic rollback. For more information about rollback, see Fundamentals Command Reference. |
3. Verify that the ISSU is finished. |
display issu state |
If the ISSU state field displays Init, the ISSU is finished. |
Performing a service upgrade or file upgrade
Step |
Command |
Remarks |
1. Load the upgrade images as main startup software images. |
Use .bin files: ·
Use an .ipe file: |
Specify the member ID of the device for the slot-number argument. |
2. Complete the ISSU process. |
issu commit slot slot-number |
Specify the member ID of the device for the slot-number argument. To roll back to the original software images during this ISSU process, use the issu rollback command. This ISSU process does not support automatic rollback. For more information about rollback, see Fundamentals Command Reference. |
Performing a reboot/ISSU reboot/incompatible upgrade
Step |
Command |
Remarks |
Use .bin files: ·
Use an .ipe file: |
2. Verify that the ISSU is finished. |
ISSU task list
Tasks at a glance |
Remarks |
(Optional.) Decompressing an .ipe file |
To use install commands for upgrade, you must use .bin image files. If the upgrade file is an .ipe file, perform this task before you use install commands for upgrade. |
(Required.) Perform one of the following tasks to update software: · Installing or upgrading software images ¡ Installing or upgrading images except for patches |
Perform an activate operation to install new images or upgrade existing images. Perform an inactivate operation to uninstall feature or patch images. An image is added to or removed from the current software image list when it is activated or deactivated. |
(Optional.) Rolling back the running software images |
Perform this task to roll back running software image status after activate or deactivate operations. A commit operation removes all rollback points. You can perform this task only before software changes are committed. |
(Optional.) Aborting a software activate/deactivate operation |
You can perform this task while an image is being activated or deactivated. This task is available only for service upgrade or file upgrade. |
(Optional.) Committing software changes |
This task updates the main startup image list with the changes. If service upgrade or file upgrade is performed, you must perform this task for the changes to take effect after a reboot. |
(Optional.) Verifying software images |
Perform this task to verify that the software changes are correct. |
(Optional.) Removing inactive software images |
Perform this task to remove images |
Step |
Command |
1. (Optional.) Identify images that are included in the .ipe file. |
display install ipe-info |
2. Decompress the .ipe file. |
install add ipe-filename medium-name: |
Use one of the following methods to perform this task:
· Chassis by chassis—Activate all the images on one member device, and then move to the next member device.
· Image by image—Activate one image on all member devices before activating another image.
To install an image, you must begin with the master device. To upgrade an image, you must begin with a subordinate device.
You can install up to 32 .bin files on the device, including one boot image file, one system image file, and up to 30 feature or patch image files.
Step |
Command |
1. (Optional.) Identify the ISSU method and possible impacts of the upgrade. |
install activate { boot filename | system filename | feature filename&<1-30> } * slot slot-number test |
2. Activate images. |
install activate { boot filename | system filename | feature filename&<1-30> } * slot slot-number |
Installing patch images
Before installing patch images, check whether the device is already running patch images.
· If not, install patch images.
· If yes, read the release notes to identify the functionality differences between the running patch images and the new patch images.
¡ If the new patch images cover all functions provided by the old patch images, loading the patch images overwrites the old patch images. After installing the new patch images, delete the old patch images from the storage medium to release the storage space.
¡ If the new patch images do not cover one or more functions provided by the old patch images, loading the patch images does not affect the old patch images. The device uses both the new patch images and the old patch images. Do not uninstall or delete the old patch images.
Task |
Command |
Activate patch images. |
install activate patch filename { all | slot slot-number } |
The uninstall operation only removes images from the current software image list. For the change to take effect after a reboot, you must perform a commit operation to remove the images from the main startup image list.
Uninstalled images are still stored on the storage medium. To permanently remove the images, execute the install remove command. For more information, see "Removing inactive software images."
Boot and system images cannot be uninstalled.
Uninstalling feature images
Task |
Command |
Deactivate feature images. |
install deactivate feature filename&<1-30> slot slot-number |
Uninstalling patch images
Task |
Command |
Deactivate patch images. |
install deactivate patch { all | filename slot slot-number } |
For each service or file upgrade performed through activate or deactivate operation, the system creates a rollback point. The rollback points are retained until any of the following event occurs:
· An ISSU reboot or reboot upgrade is performed.
· The install commit command is executed.
After an ISSU reboot or reboot upgrade is performed, you can roll back the running software images only to the status before any activate or deactivate operations are performed.
After a commit operation is performed, you cannot perform a rollback.
For a rollback to take effect after a reboot, you must perform a commit operation to update the main startup software image list.
To roll back the software, execute the following commands in user view:
Step |
Command |
Remarks |
1. (Optional.) Display available rollback points. |
display install rollback |
A maximum of 50 rollback points are available for service and file upgrades. The earliest rollback point is removed if this limit has been reached when a rollback point is created. |
2. Roll back the software. |
install rollback to { point-id | original } |
N/A |
This task is available only for service upgrade or file upgrade performed through activate or deactivate operation. After the operation is aborted, the system runs with the software images that it was running with before the operation.
Step |
Command |
1. Press Ctrl+C while a software image is being activated or deactivated. |
N/A |
2. Abort a software activate/deactivate operation in user view. |
install abort [ job-id ] |
If the ISSU method is service upgrade or file upgrade for an activate or deactivate operation, the main startup image list does not update with the changes. The software changes are lost at reboot. For the changes to take effect after a reboot, you must commit the changes.
Task |
Command |
Remarks |
Commit the software changes. |
install commit |
This command commits all software changes. |
Perform this task to verify the following items:
· Integrity—Verify that the boot, system, and feature images are integral.
· Consistency—Verify that the same active images are running across the entire system.
· Software commit status—Verify that the active images are committed as needed.
If an image is not integral, consistent, or committed, use the install activate, install deactivate, and install commit commands as appropriate to resolve the issue.
Task |
Command |
Verify software images. |
install verify |
Removing a software image deletes the image file permanently. You cannot use the install rollback to command after the operation.
Task |
Command |
Remove inactive software images. |
install remove [ slot slot-number ] { filename | inactive } |
The display issu state command applies only to an ISSU that uses the issu series commands. All the other display commands and all reset commands can be used during an ISSU, regardless of whether the install or issu commands are used.
Task |
Command |
Display version compatibility information. |
display version comp-matrix |
Display ISSU status information. |
Display automatic rollback timer information. |
Display active software images. |
display install active [ slot slot-number ] [ verbose ] |
Display inactive software images. |
display install inactive [ slot slot-number ] [ verbose ] |
Display main startup software images. |
display install committed [ slot slot-number ] [ verbose ] |
Display backup startup software images. |
display install backup [ slot slot-number ] [ verbose ] |
Display ongoing ISSU activate, deactivate, and rollback operations. |
display install job |
Display ISSU log entries. |
display install log [ verbose ] |
Display software image file information. |
display install package { filename | all } [ verbose ] |
Display the software images included in an .ipe file. |
display install ipe-info ipe-filename |
Display rollback point information. |
Display all software image files that include a specific component or file. |
display install which { component name | file filename } [ slot slot-number ] |
Clear ISSU log entries. |
reset install log-history oldest log-number |
Clear ISSU rollback points. |
reset install rollback oldest point-id |
Troubleshooting ISSU
Failure to execute the issu load/issu run switchover/issu commit/install activate/install deactivate command
Symptom
The following commands cannot be executed:
· issu commands—issu load, issu run switchover, and issu commit.
· install commands—install activate and install deactivate.
Solution
To resolve this issue:
1. Use the display device command to verify that all cards are not in Fault state.
2. Use the display system internal ha service-group command to verify that the Action field is 0 for each service.
3. If the problem persists, contact H3C Support.
Upgrade requirements
As shown in Figure 1, the IRF fabric has two members.
Upgrade feature1 from R0201 to R0202. The two versions are compatible.
Upgrade procedure
# Save the running configuration.
# Download the image file that contains the feature1 image from the TFTP server.
<Sysname> tftp 2.2.2.2 get feature1-r0202.bin
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 256 100 256 0 0 764 0 --:--:-- --:--:-- --:--:-- 810
# Display active software images.
<Sysname> display install active
Active packages on slot 1:
flash:/boot-r0201.bin
flash:/system-r0201.bin
flash:/feature1-r0201.bin
Active packages on slot 2:
# Identify the ISSU method to be used for the upgrade and view the possible impact of the upgrade.
<Sysname> display version comp-matrix file feature flash:/feature1-r0202.bin
Feature image: flash:/feature1-r0202.bin
Version:
V700R001B31D002
Version Compatibility List:
V700R001B31D001
V700R001B31D002
Version Dependency System List:
V700R001B31D001
V700R001B31D002
Slot Upgrade Way
1 Service Upgrade
2 Service Upgrade
Influenced service according to following table on slot 1:
feature1
Influenced service according to following table on slot 2:
feature1
The output shows that an incremental upgrade is recommended. The feature1 module will be rebooted during the upgrade process.
# Upgrade feature1 on the subordinate member.
<Sysname> issu load file feature flash:/feature1-r0202.bin slot 2
This operation will delete the rollback point information for the previous upgrade and maybe get unsaved configuration lost. Continue? [Y/N]:y
Copying file flash:/feature1-r0202.bin to slot2#flash:/feature1-r0202.bin......Done.
Running Version New Version
Alpha 0201 Alpha 0202
Slot Upgrade Way
2 Service Upgrade
This operation might take several minutes, please wait...Done.
# Perform a master/subordinate switchover.
<Sysname> issu run switchover
Slot Switchover Way
1 Active standby process switchover
# Upgrade the feature on the original master.
<Sysname> issu commit slot 1
Slot Upgrade Way
1 Service Upgrade
# Verify that both members are running the new image.
As shown in Figure 2, the IRF fabric has two members.
Upgrade feature1 from R0201 to R0202. The two versions are incompatible.
Upgrade procedure
<Sysname> save
# Download the image file that contains the R0202 feature1 image from the TFTP server.
Version:
V700R001B31D002
V700R001B31D002
V700R001B31D001
V700R001B31D002
Incompatible upgrade.
The output shows that the two versions are incompatible. The cards will be rebooted for the upgrade.
Slot Upgrade Way
2 Reboot
Upgrading software images to incompatible versions. Continue? [Y/N]:y
# Upgrade feature1 on the original master.
Slot Upgrade Way
1 Reboot
Active packages on slot2:
Rollback requirement
As shown in Figure 3, the IRF fabric has two members.
Roll back feature1 from R0202 to R0201 after upgrading it from R0201 to R0202. The two versions are compatible.
Rollback procedure
<Sysname> save
100 256k 100 256k 0 0 764k 0 --:--:-- --:--:-- --:--:-- 810k
Version:
V700R001B31D002
V700R001B31D001
V700R001B31D002
V700R001B31D001
V700R001B31D002
Slot Upgrade Way
1 Service Upgrade
2 Service Upgrade
feature1
feature1
The output shows that an incremental upgrade is recommended, and the feature1 module will be rebooted during the upgrade process.
Slot Upgrade Way
2 Service Upgrade
Slot Switchover Way
# Roll back feature1 to R0201.
<Sysname> issu rollback
This command will quit the ISSU process and roll back to the previous version. Continue? [Y/N]:Y
# Verify that both members are running the old image.
As shown in Figure 4, the IRF fabric has two members.
Upgrade procedure
<Sysname> save
# Download the .ipe file that contains the R0202 feature1 image from the TFTP server.
<Sysname> tftp 2.2.2.2 get feature1-r0202.ipe
# Decompress the .ipe file.
<Sysname> install add flash:/feature1-r0202.ipe flash:
# Identify the ISSU methods for the upgrade and view the possible impact of the upgrade.
<Sysname> install activate feature flash:/feature1-r0202.bin slot 2 test
Slot Upgrade Way
2 Service Upgrade
feature1
<Sysname> install activate feature flash:/feature1-r0202.bin slot 1 test
Slot Upgrade Way
1 Service Upgrade
feature1
The output shows that both members require a service upgrade and the feature1 module will be rebooted during the upgrade process.
# Activate the new feature1 image to upgrade feature1.
flash:/feature1-r0202.bin already exists on slot 2.
Overwrite it?[Y/N]:y
Slot Upgrade Way
2 Service Upgrade
Slot Upgrade Way
1 Service Upgrade
# Confirm the software change.
<Sysname> install commit
As shown in Figure 4, the IRF fabric has two members. The feature1 feature has been upgraded from R0201 to R0202, but the software change has not been confirmed.
Roll back feature1 from R0202 to R0201.
Rollback procedure
# Display available rollback points.
<Sysname> display install rollback
Install rollback information 1 on slot 1:
Updating from flash:/feature1-r0201.bin
to flash:/feature1-r0202.bin.
Install rollback information 2 on slot 2:
<Sysname> install rollback to original
Patching requirements
As shown in Figure 5, the IRF fabric has two members.
Patch the software images running on the members.
Patching procedure
# Download the patch images boot-patch.bin and system-patch.bin from the TFTP server to the root directory of the flash memory on the master.
<Sysname> tftp 2.2.2.2 get boot-patch.bin
File will be transferred in binary mode
Downloading file from remote TFTP server, please wait...|
TFTP: 100752 bytes received in 11 second(s)
File downloaded successfully.
<Sysname> tftp 2.2.2.2 get system-patch.bin
TFTP: 100112 bytes received in 9 second(s)
flash:/boot.bin
flash:/system.bin
flash:/boot.bin
flash:/system.bin
The output shows that the patch images are not active.
# Activate the patch images on the member devices.
<Sysname> install activate patch flash:/boot-patch.bin slot 1
<Sysname> install activate patch flash:/system-patch.bin slot 1
<Sysname> install activate patch flash:/boot-patch.bin slot 2
<Sysname> install activate patch flash:/system-patch.bin slot 2
flash:/boot.bin
flash:/system.bin
flash:/boot.bin
flash:/system.bin
# Display the main startup software images.
<Sysname> display install committed
Committed packages on slot 1:
flash:/boot.bin
flash:/system.bin
Committed packages on slot 2:
flash:/boot.bin
flash:/system.bin
The output shows that the patch images have been specified as the startup software images.
