| 02-QoS commands | 296.17 KB |
display qos policy control-plane
display qos policy control-plane pre-defined
qos apply policy (interface view, control plane view)
qos apply policy (user profile view)
reset qos policy control-plane
Congestion management commands
display qos queue sp interface
display qos queue wrr interface
qos wrr { byte-count | weight }
display qos queue wfq interface
qos wfq { byte-count | weight }
Queue scheduling profile commands
display qos qmprofile configuration
display qos qmprofile interface
Queue-based accounting commands
QoS policy commands
Traffic class commands
display traffic classifier
Use display traffic classifier to display traffic classes.
user-defined: Specifies user-defined traffic classes.
classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays traffic classes on all member devices.
# Display all user-defined traffic classes.
User-defined classifier information:
Classifier: 1 (ID 100)
Operator: AND
Rule(s) :
If-match acl 2000
Classifier: 2 (ID 101)
Operator: AND
Rule(s) :
If-match protocol ipv6
Classifier: 3 (ID 102)
Operator: AND
Rule(s) :
-none-
Classifier |
Traffic class name and its match criteria. |
Operator |
Match operator you set for the traffic class. If the operator is AND, the traffic class matches the packets that match all its match criteria. If the operator is OR, the traffic class matches the packets that match any of its match criteria. |
Rule(s) |
Match criteria. |
if-match
Use if-match to define a match criterion.
Use undo if-match to delete a match criterion.
if-match match-criteria
undo if-match match-criteria
No match criterion is configured.
Traffic class view
match-criteria: Specifies a match criterion. Table 2 shows the available match criteria.
Table 2 Available match criteria
Option |
acl [ ipv6 ] { acl-number | name acl-name } |
Matches an ACL. The acl-number argument has the following value ranges: · 2000 to 3999 for IPv4 ACLs. · 2000 to 3999 for IPv6 ACLs. · 4000 to 4999 for Ethernet frame header ACLs. · 5000 to 5999 for user-defined ACLs. The acl-name argument is a case-insensitive string of 1 to 63 characters, which must start with an English letter. To avoid confusion, the argument cannot be all. |
any |
Matches all packets. |
Matches control plane protocols. The protocol-name&<1-8> argument specifies a space-separated list of up to eight system-defined control plane protocols. For available system-defined control plane protocols, see Table 3. |
control-plane protocol-group protocol-group-name |
Matches a control plane protocol group. The protocol-group-name argument can be critical, important, management, monitor, normal, or redirect. |
customer-dot1p dot1p-value&<1-8> |
Matches 802.1p priority values in inner VLAN tags of double-tagged packets. The dot1p-value&<1-8> argument specifies a space-separated list of up to eight 802.1p priority values. The value range for the dot1p-value argument is 0 to 7. |
customer-vlan-id vlan-id-list |
Matches VLAN IDs in inner VLAN tags of double-tagged packets. The vlan-id-list argument specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094. |
destination-mac mac-address |
Matches a destination MAC address. |
dscp dscp-value&<1-8> |
Matches DSCP values. The dscp-value&<1-8> argument specifies a space-separated list of up to eight DSCP values. The value range for the dscp-value argument is 0 to 63 or keywords shown in Table 5. |
ip-precedence ip-precedence-value&<1-8> |
Matches IP precedence values. The ip-precedence-value&<1-8> argument specifies a space-separated list of up to eight IP precedence values. The value range for the ip-precedence-value argument is 0 to 7. |
protocol protocol-name |
Matches a protocol. The protocol-name argument can be ip or ipv6. |
qos-local-id local-id-value |
Matches a local QoS ID in the range of 1 to 4095. The switch supports local QoS IDs in the range of 1 to 3999. |
service-dot1p dot1p-value&<1-8> |
Matches 802.1p priority values in outer VLAN tags. The dot1p-value&<1-8> argument specifies a space-separated list of up to eight 802.1p priority values. The value range for the dot1p-value argument is 0 to 7. |
service-vlan-id vlan-id-list |
Matches VLAN IDs in outer VLAN tags. The vlan-id-list argument specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094. |
source-mac mac-address |
Matches a source MAC address. |
traffic-type { broadcast | multicast | unicast | unknown-unicast } |
Matches the packet type: · broadcast—Matches broadcast packets. · multicast—Matches multicast packets. · unicast—Matches known unicast packets. · unknown-unicast—Matches unknown unicast packets. For a traffic class to match multiple packet types, you must specify the OR operator when creating the class. The if-match traffic-type multicast command matches only Layer 2 known multicast packets. The if-match traffic-type unicast command matches only Layer 2 known unicast packets. |
Table 3 Available system-defined control plane protocols
Protocol |
ARP packets |
ARP snooping packets |
bfd |
BFD packets |
BGP packets |
IPv6 BGP packets |
dhcp |
DHCP packets |
DHCP snooping packets |
IPv6 DHCP packets |
DLDP packets |
802.1X packets |
MVRP packets |
hop limit expires |
ICMPv6 time exceeded packets |
HTTP packets |
HTTPS packets |
ICMP packets |
ICMPv6 packets |
IGMP packets |
IPv4 packets with the Options field |
IPv6 packets with the Options field |
IS-IS packets |
LACP packets |
LLDP packets |
OSPF multicast packets |
OSPF unicast packets |
OSPFv3 multicast packets |
OSPFv3 unicast packets |
radius |
RADIUS packets |
snmp |
SNMP packets |
ssh |
SSH packets |
STP packets |
tacacs |
TACACS packets |
Telnet packets |
ttl expires |
ICMP time exceeded packets |
VRRP packets |
IPv6 VRRP packets |
If any traffic class in a QoS policy includes the customer-vlan-id match criterion, the QoS policy can be applied only to interfaces.
If a traffic class includes both the control-plane protocol or control-plane protocol-group criterion and other criteria, the QoS policy that contains the traffic class cannot be applied correctly.
If any traffic class in a QoS policy includes the control-plane protocol or control-plane protocol-group match criterion, the QoS policy can be applied only to a control plane.
For single-tagged packets, you can use the service-vlan-id criterion to match them.
To configure multiple values for a match criterion, perform the following tasks:
· Set the logical operator to OR.
· Configure multiple if-match commands for the match criterion.
For the customer-vlan-id and service-vlan-id match criteria, you can configure multiple values in one if-match command when the logical operator is OR or AND. To delete multiple values configured in one if-match command, the values specified in the undo if-match command must be identical with the configured values. The order of the values can be different.
When you configure ACL-based match criteria for a traffic class, follow these restrictions and guidelines:
· If the ACL used as a match criterion does not exist, the QoS policy that uses the traffic class cannot be applied correctly.
· You can use an ACL twice by its name and number, respectively.
· If the configured logical operator is AND for the traffic class, the actual logical operator for the rules in an ACL is OR.
# Define a match criterion for traffic class class1 to match the packets with a destination MAC address of 0050-ba27-bed3.
# Define a match criterion for traffic class class2 to match the packets with a source MAC address of 0050-ba27-bed2.
# Define a match criterion for traffic class class1 to match double-tagged packets with 802.1p priority 3 in inner VLAN tags.
# Define a match criterion for traffic class class1 to match the packets with 802.1p priority 5 in outer VLAN tags.
[Sysname-classifier-class1] if-match service-dot1p 5
# Define a match criterion for traffic class class1 to match the advanced ACL 3101.
# Define a match criterion for traffic class class1 to match the ACL named flow.
# Define a match criterion for traffic class class1 to match the advanced IPv6 ACL 3101.
# Define a match criterion for traffic class class1 to match the IPv6 ACL named flow.
# Define a match criterion for traffic class class1 to match all packets.
# Define a match criterion for traffic class class1 to match the packets with a DSCP value of 1, 6, or 9.
[Sysname] traffic classifier class1 operator or
[Sysname-classifier-class1] if-match dscp 1
[Sysname-classifier-class1] if-match dscp 6
[Sysname-classifier-class1] if-match dscp 9
# Define a match criterion for traffic class class1 to match the packets with an IP precedence value of 1 or 6.
[Sysname-classifier-class1] if-match ip-precedence 1
[Sysname-classifier-class1] if-match ip-precedence 6
# Define a match criterion for traffic class class1 to match IP packets.
# Define a match criterion for traffic class class1 to match double-tagged packets with VLAN ID 1, 6, or 9 in inner VLAN tags.
# Define a match criterion for traffic class class1 to match the packets with VLAN ID 2, 7, or 10 in outer VLAN tags.
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
# Define a match criterion for traffic class class1 to match the packets with a local QoS ID of 3.
[Sysname-classifier-class1] if-match qos-local-id 3
# Define a match criterion for traffic class class1 to match ARP protocol packets.
[Sysname-classifier-class1] if-match control-plane protocol arp
# Define a match criterion for traffic class class1 to match packets of the protocols in protocol group normal.
[Sysname-classifier-class1] if-match control-plane protocol-group normal
traffic classifier
Use traffic classifier to create a traffic class and enter traffic class view.
Use undo traffic classifier to delete a traffic class.
No traffic class exists.
classifier-name: Specifies the name of the traffic class to be created, a case-sensitive string of 1 to 31 characters.
operator: Sets the operator to logic AND (the default) or OR for the traffic class.
and: Specifies the logic AND operator. The traffic class matches the packets that match all its criteria.
or: Specifies the logic OR operator. The traffic class matches the packets that match any of its criteria.
# Create a traffic class named class1.
Traffic behavior commands
accounting
Use accounting to configure a traffic accounting action in a traffic behavior.
Use undo accounting to delete the action.
accounting { byte | packet }
undo accounting
No traffic accounting action is configured.
Traffic behavior view
byte: Counts traffic in bytes.
packet: Counts traffic in packets.
A QoS policy that contains an accounting action cannot be applied globally.
# Configure a traffic accounting action in traffic behavior database to count traffic in bytes.
[Sysname-behavior-database] accounting byte
car
Use car to configure a CAR action in a traffic behavior.
Use undo car to delete the action.
undo car
No CAR action is configured.
cir [ pps ] committed-information-rate: Specifies the committed information rate (CIR) in kbps or pps, which is an average traffic rate. If you specify the pps keyword, the CIR is specified in pps. If you do not specify the pps keyword, the CIR is specified in kbps. The value range for the committed-information-rate argument is 8 and 160000000 in multiples of 8.
cbs committed-burst-size: Specifies the committed burst size (CBS) in bytes. The value range for the committed-burst-size argument is 512 and 256000000 in multiples of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512. A default value greater than 256000000 is converted to 256000000.
ebs excess-burst-size: Specifies the excess burst size (EBS) in bytes. The value range for the excess-burst-size argument is 0 and 256000000 in multiples of 512, and the default value is 512.
pir peak-information-rate: Specifies the peak information rate (PIR) in kbps or pps. If you specify the pps keyword, the PIR is specified in pps. If you do not specify the pps keyword, the PIR is specified in kbps. The PIR must be specified in the same unit as the CIR. The value range for the peak-information-rate argument is 8 and 160000000 in multiples of 8. If the PIR is configured, two rates are used for traffic policing. Otherwise, one rate is used.
green action: Specifies the action to take on packets that conform to the CIR. The default setting is pass.
red action: Specifies the action to take on packets that conforms to neither CIR nor PIR. The default setting is discard.
yellow action: Action to take on packets that conform to the PIR but not to the CIR. The default setting is pass.
action: Sets the action to take on the packet:
· discard: Drops the packet.
· pass: Permits the packet to pass through.
· remark-dot1p-pass new-cos: Sets the 802.1p priority value of the 802.1p packet to new-cos and permits the packet to pass through. The new-cos argument is in the range of 0 to 7.
· remark-dscp-pass new-dscp: Sets the DSCP value of the packet to new-dscp and permits the packet to pass through. The new-dscp argument is in the range of 0 to 63.
· remark-lp-pass new-local-precedence: Sets the local precedence value of the packet to new-local-precedence and permits the packet to pass through. The new-local-precedence argument is in the range of 0 to 7.
A QoS policy that uses the traffic behavior can be applied in either the inbound direction or outbound direction of an interface.
If you configure the car command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure a CAR action in traffic behavior database as follows:
· Set the CIR to 200 kbps, CBS to 51200 bytes, and EBS to 0.
· Transmit the conforming packets, and mark the excess packets with DSCP value 0 and transmit them.
[Sysname-behavior-database] car cir 200 cbs 51200 ebs 0 green pass red remark-dscp-pass 0
display traffic behavior
Use display traffic behavior to display traffic behaviors.
user-defined: Specifies user-defined traffic behaviors.
behavior-name: Specifies a traffic behavior by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic behavior, this command displays all traffic behaviors.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays traffic behaviors on all member devices.
# Display all user-defined traffic behaviors.
User-defined behavior information:
Behavior: 1 (ID 100)
Marking:
Remark dscp 3
Committed Access Rate:
CIR 128 (kbps), CBS 8192 (Bytes), EBS 512 (Bytes)
Green action : pass
Yellow action : pass
Red action : discard
Behavior: 2 (ID 101)
Accounting enable: Packet
Filter enable: Permit
Marking:
Remark dot1p 4
Redirecting:
Redirect to the CPU
Behavior: 3 (ID 102)
-none-
Behavior |
Name and contents of a traffic behavior. |
Marking |
Information about priority marking. |
Remark dscp |
Action of setting the DSCP value for packets. |
Committed Access Rate |
Information about the CAR action. |
CIR |
CIR in kbps, which specifies the average traffic rate. |
CBS |
CBS in bytes, which specifies the amount of bursty traffic allowed at a time. |
EBS |
EBS in bytes, which specifies the amount of traffic exceeding the CBS when two token buckets are used. |
Green action |
Action to take on green packets. |
Yellow action |
Action to take on yellow packets. |
Red action |
Action to take on red packets. |
Accounting enable |
Traffic accounting action. |
Filter enable |
Traffic filtering action. |
none |
No other traffic behavior is configured. |
filter
Use filter to configure a traffic filtering action in a traffic behavior.
Use undo filter to delete the action.
filter { deny | permit }
undo filter
No traffic filtering action is configured.
deny: Drops packets.
permit: Transmits packets.
# Configure a traffic filtering action as deny in traffic behavior database.
nest top-most
Use nest top-most to configure a VLAN tag adding action in a traffic behavior.
Use undo nest top-most to delete the action.
nest top-most vlan vlan-id
undo nest top-most
No VLAN tag adding action is configured.
vlan-id vlan-id: Specifies the ID of the VLAN tag to be added, in the range of 1 to 4094.
If a QoS policy contains a VLAN tag adding action, apply it only to the incoming traffic of an interface.
If the traffic behavior already contains a VLAN tag adding action, the new one overwrites the old one.
# Configure traffic behavior b1 to add VLAN tag 123.
[Sysname] traffic behavior b1
[Sysname-behavior-b1] nest top-most vlan 123
redirect
Use redirect to configure a traffic redirecting action in a traffic behavior.
Use undo redirect to delete the action.
redirect { cpu | interface interface-type interface-number }
undo redirect { cpu | interface interface-type interface-number }
No traffic redirecting action is configured.
cpu: Redirects traffic to the CPU.
interface: Redirects traffic to an interface.
Redirecting traffic to the CPU and redirecting traffic to an interface are mutually exclusive with each other in the same traffic behavior. The most recently configured redirecting action takes effect.
# Configure redirecting traffic to Ten-GigabitEthernet 1/0/1 in traffic behavior database.
[Sysname-behavior-database] redirect interface Ten-GigabitEthernet 1/0/1
· classifier behavior
· qos policy
· traffic behavior
remark customer-vlan-id
Use remark customer-vlan-id to configure a CVLAN marking action in a traffic behavior.
Use undo remark customer-vlan-id to delete the action.
No CVLAN marking action is configured.
vlan-id: Specifies a CVLAN ID in the range of 1 to 4094.
# Configure traffic behavior b1 to mark matching packets with CVLAN 111.
[Sysname-behavior-b1] remark customer-vlan-id 111
remark dot1p
Use remark dot1p to configure an 802.1p priority marking action or an inner-to-outer tag priority copying action in a traffic behavior.
Use undo remark dot1p to delete the action.
remark [ green | red | yellow ] dot1p dot1p-value
undo remark [ green | red | yellow ] dot1p
undo remark dot1p
No 802.1p priority marking action or inner-to-outer tag priority copying action is configured.
green: Specifies green packets.
red: Specifies red packets.
yellow: Specifies yellow packets.
dot1p-value: Specifies the 802.1p priority to be marked for packets, in the range of 0 to 7.
customer-dot1p-trust: Copies the 802.1p priority value in the inner VLAN tag to the outer VLAN tag after the QoS policy is applied to an interface.
The remark dot1p dot1p-value and remark dot1p customer-dot1p-trust commands are mutually exclusive. The most recent configuration of them takes effect.
The remark dot1p customer-dot1p-trust command does not take effect on single-tagged packets.
# Configure traffic behavior database to mark matching traffic with 802.1p priority 2.
[Sysname-behavior-database] remark dot1p 2
# Configure an inner-to-outer tag priority copying action in traffic behavior database.
[Sysname-behavior-database] remark dot1p customer-dot1p-trust
remark drop-precedence
Use remark drop-precedence to configure a drop priority marking action in a traffic behavior.
Use undo remark drop-precedence to delete the action.
remark drop-precedence drop-precedence-value
No drop priority marking action is configured.
drop-precedence-value: Specifies the drop priority to be marked for packets. This argument is in the range of 0 to 2.
The command applies only to incoming traffic.
# Configure traffic behavior database to mark matching traffic with drop priority 2.
[Sysname-behavior-database] remark drop-precedence 2
remark dscp
Use remark dscp to configure a DSCP marking action in a traffic behavior.
Use undo remark dscp to delete the action.
undo [ green | red | yellow ] remark dscp
No DSCP marking action is configured.
dscp-value: Specifies a DSCP value, which can be a number from 0 to 63 or a keyword in Table 5.
Table 5 DSCP keywords and values
Keyword |
DSCP value (binary) |
DSCP value (decimal) |
default |
000000 |
0 |
af11 |
001010 |
10 |
af12 |
001100 |
12 |
af13 |
001110 |
14 |
af21 |
010010 |
18 |
af22 |
010100 |
20 |
af23 |
010110 |
22 |
af31 |
011010 |
26 |
af32 |
011100 |
28 |
af33 |
011110 |
30 |
af41 |
100010 |
34 |
af42 |
100100 |
36 |
af43 |
100110 |
38 |
cs1 |
001000 |
8 |
cs2 |
010000 |
16 |
cs3 |
011000 |
24 |
cs4 |
100000 |
32 |
cs5 |
101000 |
40 |
cs6 |
110000 |
48 |
cs7 |
111000 |
56 |
ef |
101110 |
46 |
# Configure traffic behavior database to mark matching traffic with DSCP 6.
remark ip-precedence
Use remark ip-precedence to configure an IP precedence marking action in a traffic behavior.
Use undo remark ip-precedence to delete the action.
remark ip-precedence ip-precedence-value
No IP precedence marking action is configured.
ip-precedence-value: Specifies the IP precedence value to be marked for packets, in the range of 0 to 7.
# Set the IP precedence to 6 for packets.
[Sysname-behavior-database] remark ip-precedence 6
remark local-precedence
Use remark local-precedence to configure a local precedence marking action in a traffic behavior.
Use undo remark local-precedence to delete the action.
remark [ green | red | yellow ] local-precedence local-precedence-value
undo remark [ green | red | yellow ] local-precedence
No local precedence marking action is configured.
local-precedence-value: Specifies the local precedence to be marked for packets, in the range of 0 to 7.
# Configure traffic behavior database to mark matching traffic with local precedence 2.
remark qos-local-id
Use remark qos-local-id to configure a local QoS ID marking action in a traffic behavior.
Use undo remark qos-local-id to delete the action.
remark qos-local-id local-id-value
No local QoS ID marking action is configured.
local-id-value: Specifies the local QoS ID to be marked for packets. The value range for this argument is 1 to 4095. The switch supports local QoS IDs in the range of 1 to 3999.
Marking local QoS IDs combines different traffic classes into one new class, which is indicated by a local QoS ID. You can configure a traffic behavior for this new class to implement two levels of actions on a traffic class.
Marking local QoS IDs applies only to incoming traffic.
# Configure the action of marking packets with local QoS ID 2.
[Sysname-behavior-database] remark qos-local-id 2
remark service-vlan-id
Use remark service-vlan-id to configure an SVLAN marking action in a traffic behavior.
Use undo remark service-vlan-id to delete the action.
No SVLAN marking action is configured.
vlan-id: Specifies an SVLAN ID in the range of 1 to 4094.
# Configure traffic behavior b1 to mark matching packets with SVLAN 222.
[Sysname-behavior-b1] remark service-vlan-id 222
traffic behavior
Use traffic behavior to create a traffic behavior and enter traffic behavior view.
Use undo traffic behavior to delete a traffic behavior.
No traffic behavior exists.
behavior-name: Specifies the name of the traffic behavior to be created, a case-sensitive string of 1 to 31 characters.
# Create a traffic behavior named behavior1.
[Sysname-behavior-behavior1]
QoS policy commands
classifier behavior
Use classifier behavior to associate a traffic behavior with a traffic class in a QoS policy.
Use undo classifier to remove a traffic class from the QoS policy.
classifier classifier-name behavior behavior-name [ mode dcbx | insert-before before-classifier-name ] *
No traffic behavior is associated with a traffic class.
QoS policy view
mode dcbx: Specifies that the class-behavior association applies only to DCBX. For more information about DCBX, see Layer 2—LAN Switching Configuration Guide.
insert-before before-classifier-name: Inserts the new traffic class before an existing traffic class in the QoS policy. The before-classifier-name argument specifies an existing traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify the insert-before before-classifier-name option, the new traffic class is placed at the end of the QoS policy.
A traffic class can be associated with only one traffic behavior in a QoS policy.
If the specified traffic class or traffic behavior does not exist, the system defines a null traffic class or traffic behavior.
You cannot change the position of an existing traffic class in a QoS policy.
# Associate traffic class database with traffic behavior test in QoS policy user1.
[Sysname] qos policy user1
# Associate traffic class database with traffic behavior test in QoS policy user1, and insert traffic class database before an existing traffic class named class-a.
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
qos policy
control-plane
Use control-plane to enter control plane view.
# Enter control plane view of IRF member device 1.
[Sysname] control-plane slot 1
[Sysname-cp-slot1]
display qos policy
Use display qos policy to display QoS policies.
user-defined: Specifies user-defined QoS policies.
policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a QoS policy, this command displays all user-defined QoS policies.
classifier classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays QoS policies on all member devices.
# Display all user-defined QoS policies.
User-defined QoS policy information:
Policy: 1 (ID 100)
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Behavior: 2
Marking:
Remark dot1p 4
Behavior: 3
-none-
Use display qos policy control-plane to display the QoS policy applied to a control plane.
# Display the QoS policy applied to the control plane of IRF member device 1.
<Sysname> display qos policy control-plane slot 1
Control plane
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Red packets : 0 (Packets) 0 (Bytes)
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
0 (Packets)
Table 6 Command output
Direction |
Inbound direction on the control plane. |
Green packets |
Statistics about green packets. |
Red packets |
Statistics about red packets. |
For the description of other fields, see Table 1 and Table 4.
Use display qos policy control-plane pre-defined to display the predefined QoS policy applied to a control plane.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays predefined QoS policies applied to control planes on all member devices.
# Display the predefined QoS policy applied to the control plane of IRF member device 1.
<Sysname> display qos policy control-plane pre-defined slot 1
Pre-defined policy information slot 1
Protocol Priority Bandwidth (kbps) Group
IS-IS 37 512 critical
VRRP 40 768 important
OSPF Multicast 35 256 critical
OSPF Unicast 35 256 critical
IGMP 19 512 important
OSPFv3 Unicast 34 256 critical
OSPFv3 Multicast 34 256 critical
VRRPv6 40 768 important
ARP 8 256 normal
DHCP Snooping 17 256 redirect
DHCP 15 256 normal
802.1x 9 128 important
STP 44 256 critical
LACP 38 64 critical
MVRP 11 256 critical
BGP 27 256 critical
ICMP 9 640 monitor
TTL Expires 20 64 normal
IPOPTION 20 64 normal
BGPv6 26 256 critical
Hop Limit Expires 13 64 normal
IPOPTIONv6 13 64 normal
LLDP 25 128 important
DLDP 24 64 critical
TELNET 10 512 management
SSH 10 512 management
HTTP 10 64 management
HTTPS 10 64 management
TACACS 10 64 management
RADIUS 10 64 management
ARP Snooping 10 256 redirect
ICMPv6 1 512 monitor
DHCPv6 12 256 normal
BFD 10 512 critical
Table 7 Command output
Pre-defined policy information |
Contents of the predefined control plane QoS policy. |
Protocol |
System-defined control plane protocol. |
Group |
Control plane protocol group. |
display qos policy global
Use display qos policy global to display QoS policies applied globally.
inbound: Specifies the QoS policy applied globally in the inbound direction.
outbound: Specifies the QoS policy applied globally in the outbound direction.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays QoS policies globally applied on the master device.
If you do not specify a direction, this command displays both inbound and outbound global QoS policies.
# Display the QoS policy applied globally in the inbound direction.
<Sysname> display qos policy global inbound
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
0 (Packets)
Marking:
Remark dot1p 4
Table 8 Command output
Direction |
Direction (inbound or outbound ) in which the QoS policy is applied. |
Green packets |
Red packets |
display qos policy interface
Use display qos policy interface to display QoS policies applied to interfaces.
display qos policy interface [ interface-type interface-number ] [ inbound | outbound ]
inbound: Specifies QoS policies applied in the inbound direction.
outbound: Specifies QoS policies applied in the outbound direction.
If you do not specify a direction, this command displays QoS policies applied in the inbound direction and QoS policies applied in the outbound direction.
# Display the QoS policy applied to the incoming traffic of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos policy interface Ten-GigabitEthernet1/0/1 inbound
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) : If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action: pass
Yellow action: pass
Red action: discard
Green packets: 0 (Packets)
Red packets: 0 (Packets)
Classifier: 2
Operator: AND
Rule(s) : If-match protocol ipv6
Behavior: 2
Accounting Enable:
0 (Packets)
Filter Enable: Permit
Marking:
Remark dot1p 1
Table 9 Command output
Direction |
Direction in which the QoS policy is applied to the interface. |
Green packets |
Traffic statistics for green packets. |
Red packets |
Traffic statistics for red packets. |
display qos vlan-policy
Use display qos vlan-policy to display QoS policies applied to VLANs.
name policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters.
vlan vlan-id: Specifies a VLAN by its ID.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays QoS policies applied to VLANs on the master device.
# Display QoS policies applied to VLAN 2.
<Sysname> display qos vlan-policy vlan 2
Vlan 2
Direction: Outbound
Policy: 1
Classifier: 1
Operator: AND
Behavior: 1
Marking:
Remark dscp 3
Green action: pass
Yellow action: pass
Red action: discard
Green packets: 0(Packets)
Red packets: 0(Packets)
Classifier: 2
Operator: AND
Behavior: 2
Accounting enable:
0 (Packets)
Marking:
Remark dot1p 1
Classifier: 3
Operator: AND
Rule(s) : -none-
Behavior: 3
-none-
Table 10 Command output
Direction |
Direction in which the QoS policy is applied for the VLAN. |
Green packets |
Red packets |
Use qos apply policy to apply a QoS policy to an interface or control plane.
Use undo qos apply policy to remove an applied QoS policy.
undo qos apply policy policy-name { inbound | outbound }
No QoS policy is applied to an interface or control plane.
Control plane view
S-channel aggregate interface view
S-channel interface view
VSI aggregate interface view
VSI interface view
inbound: Applies the QoS policy to the incoming traffic of an interface or control plane.
outbound: Applies the QoS policy to the outgoing traffic of an interface.
Only the mirroring action is supported in the outbound direction of Layer 2 aggregate interfaces.
For information about S-channel interfaces, S-channel aggregate interfaces, VSI interfaces, and VSI aggregate interfaces, see EVB Configuration Guide.
# Apply QoS policy USER1 to the outgoing traffic of Ten-GigabitEthernet 1/0/1.
[Sysname] interface Ten-GigabitEthernet 1/0/1
[Sysname-Ten-GigabitEthernet1/0/1] qos apply policy USER1 outbound
# Apply QoS policy aaa to the incoming traffic of the control plane of IRF member device 3.
[Sysname] control-plane slot 3
[Sysname-cp-slot3] qos apply policy aaa inbound
# Apply QoS policy USER1 to the outgoing traffic of S-Channel 1/0/1:1.
[Sysname] interface S-Channel 1/0/1:1
[Sysname-S-Channel1/0/1:1] qos apply policy USER1 outbound
# Apply QoS policy USER1 to the incoming traffic of Schannel-Aggregation 1:1.
[Sysname] interface Schannel-Aggregation 1:1
[Sysname-Schannel-Aggregation1:1] qos apply policy USER1 inbound
Use qos apply policy to apply a QoS policy to a user profile.
No QoS policy is applied to a user profile.
User profile view
inbound: Applies the QoS policy to the incoming traffic (traffic sent by online users) of a user profile.
outbound: Applies the QoS policy to the outgoing traffic (traffic received by online users) of a user profile.
Deleting a user profile also removes QoS policies applied to it.
The QoS policy applied to a user profile takes effect only after the QoS policy is successfully issued to the driver.
# Apply QoS policy test to the outgoing traffic of user profile user.
[Sysname] user-profile user
[Sysname-user-profile-user] qos apply policy test outbound
qos apply policy global
Use qos apply policy global to apply a QoS policy globally.
Use undo qos apply policy global to remove a globally applied QoS policy.
undo qos apply policy policy-name global { inbound | outbound }
No QoS policy is applied globally.
inbound: Applies the QoS policy in the inbound direction.
outbound: Applies the QoS policy in the outbound direction.
A QoS policy globally applied takes effect on all incoming or outgoing traffic, depending on the direction in which the QoS policy is applied.
# Apply QoS policy user1 globally in the inbound direction.
[Sysname] qos apply policy user1 global inbound
qos policy
Use qos policy to create a QoS policy and enter QoS policy view.
Use undo qos policy to delete a QoS policy.
qos policy policy-name
undo qos policy policy-name
No QoS policy exists.
policy-name: Specifies the name of the QoS policy to be created, a case-sensitive string of 1 to 31 characters.
To use the undo qos policy command to delete a QoS policy that has been applied to an object, you must first remove it from the object.
# Create a QoS policy named user1.
· qos apply policy
· qos apply policy global
· qos vlan-policy
qos vlan-policy
Use qos vlan-policy to apply a QoS policy to the specified VLANs.
Use undo qos vlan-policy to remove a QoS policy from the specified VLANs.
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
No QoS policy is applied to a VLAN.
vlan-id-list: Specifies a space-separated list of up to eight VLAN IDs or a VLAN ID range in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
inbound: Applies the QoS policy to incoming packets.
outbound: Applies the QoS policy to outgoing packets.
# Apply QoS policy test to the incoming traffic of VLAN 200, VLAN 300, VLAN 400, and VLAN 500.
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
Use reset qos policy control-plane to clear statistics for the QoS policy applied to a control plane.
# Clear statistics for the QoS policy applied to the control plane of IRF member device 3.
<Sysname> reset qos policy control-plane slot 3
reset qos policy global
Use reset qos policy global to clear statistics for QoS policies applied globally.
inbound: Specifies the QoS policy applied in the inbound direction.
outbound: Specifies the QoS policy applied in the outbound direction.
If you do not specify a direction, this command clears statistics for the QoS policy applied in the inbound direction and the QoS policy applied in the outbound direction.
# Clear statistics for the QoS policy applied globally in the inbound direction.
<Sysname> reset qos policy global inbound
reset qos vlan-policy
Use reset qos vlan-policy to clear statistics for QoS policies applied to VLANs.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
If you do not specify a direction, this command clears statistics for QoS policies applied in the inbound direction and QoS policies applied in the outbound direction.
# Clear statistics for QoS policies applied to VLAN 2.
<Sysname> reset qos vlan-policy vlan 2
Priority mapping commands
Priority map commands
display qos map-table
Use display qos map-table to display the configuration of priority maps.
display qos map-table [ dot1p-dp | dot1p-exp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | exp-dot1p | exp-dp ]
The switch provides the following types of priority maps.
Priority mapping |
dot1p-dp |
802.1p-drop priority map. |
dot1p-exp |
802.1p-EXP priority map. |
dot1p-lp |
802.1p-local priority map. |
dscp-dot1p |
DSCP-802.1p priority map. |
dscp-dp |
DSCP-drop priority map. |
dscp-dscp |
DSCP-DSCP priority map. |
exp-dot1p |
EXP-802.1p priority map. |
exp-dp |
EXP-to-drop priority map. |
If you do not specify a priority map, this command displays the configuration of all priority maps.
# Display the configuration of the 802.1p-local priority map.
MAP-TABLE NAME: dot1p-lp TYPE: pre-define
IMPORT : EXPORT
0 : 2
1 : 0
2 : 1
3 : 3
4 : 4
5 : 5
6 : 6
7 : 7
Table 12 Command output
MAP-TABLE NAME |
Name of the priority map. |
TYPE |
Type of the priority map. |
IMPORT |
Input values of the priority map. |
EXPORT |
Output values of the priority map. |
import
Use import to configure mappings for a priority map.
Use undo import to restore the specified or all mappings to the default for a priority map.
The default priority maps are used. For more information, see ACL and QoS Configuration Guide.
Priority map view
import-value-list: Specifies a list of input values.
export-value: Specifies the output value.
all: Restores all mappings in the priority map to the default.
# Configure the 802.1p-local priority map to map 802.1p priority values 4 and 5 to local precedence 1.
[Sysname] qos map-table dot1p-lp
[Sysname-maptbl-dot1p-lp] import 4 5 export 1
qos map-table
Use qos map-table to enter the specified priority map view.
qos map-table { dot1p-dp | dot1p-exp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | exp-dot1p | exp-dp }
For the description of the keywords, see Table 11.
# Enter the 802.1p-local priority map view.
· display qos map-table
· import
Port priority commands
qos priority
Use qos priority to change the port priority of an interface.
Use undo qos priority to restore the default.
qos priority priority-value
undo qos priority
The port priority is 0.
priority-value: Specifies the port priority value in the range of 0 to 7.
# Set the port priority of Ten-GigabitEthernet 1/0/1 to 2.
[Sysname-Ten-GigabitEthernet 1/0/1] qos priority 2
display qos trust interface
Priority trust mode commands
Use display qos trust interface to display priority trust mode and port priority information on an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays priority trust mode and port priority information of all interfaces.
# Display the priority trust mode and port priority information of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos trust interface Ten-GigabitEthernet 1/0/1
Port priority information
Port priority: 0
Port priority trust type: none
Table 13 Command output
Interface type and interface number. |
Port priority |
Port priority set for the interface. |
Port priority trust type |
Priority trust mode on the interface: dot1p, dscp, or none. If the trust mode is none, the port priority is used for priority mapping. |
qos trust
Use qos trust to configure the priority trust mode for an interface.
Use undo qos trust to restore the default.
qos trust { dot1p | dscp }
undo qos trust
An interface does not trust any packet priority.
dot1p: Uses the 802.1p priority in incoming packets for priority mapping.
dscp: Uses the DSCP value in incoming packets for priority mapping.
# Set the trusted packet priority type to 802.1p priority on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos trust dot1p
GTS and rate limit commands
GTS commands
display qos gts interface
Use display qos gts interface to display generic traffic shaping (GTS) configuration of interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the GTS configuration of all interfaces.
# Display the GTS configuration of all interfaces.
Rule: If-match queue 1
Rule: If-match queue 2
CIR 256 (kbps), CBS 16384 (Bytes)
Table 14 Command output
Rule |
Match criteria. |
CIR |
CBS |
qos gts
Use qos gts to set GTS parameters for a queue on an interface.
Use undo qos gts to delete the GTS configuration of a queue on an interface.
undo qos gts queue queue-id
No GTS parameters are set for a queue on an interface.
queue queue-id: Specifies a queue by its ID in the range of 0 to 7.
cir committed-information-rate: Specifies the CIR in kbps. The value range for the committed-information-rate argument is 8 to 10485760 for 10-GE interfaces and 8 to 41943040 for 40-GE interfaces. The values must be integral multiples of 8.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for the committed-burst-size argument is 512 and 16777216 in multiples of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. If the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512.
# Shape the packets in queue 1 on Ten-GigabitEthernet 1/0/1. The GTS parameters are as follows: CIR is 6400 kbps and CBS is 51200 bytes.
[Sysname-Ten-GigabitEthernet1/0/1] qos gts queue 1 cir 6400 cbs 51200
Rate limit commands
display qos lr interface
Use display qos lr interface to display the rate limit configuration of interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the rate limit configuration of all interfaces.
# Display the rate limit configuration of all interfaces.
Direction: Outbound
CIR 12800 (kbps), CBS 800256 (Bytes)
Interface: Ten-GigabitEthernet1/0/2
Direction: Outbound
CIR 25600 (kbps), CBS 1600000 (Bytes)
Table 15 Command output
Direction |
Direction to which the rate limit configuration is applied: inbound or outbound. |
CIR |
CBS |
qos lr
Use qos lr to limit the rate of packets on an interface.
Use undo qos lr to remove rate limit settings on an interface.
undo qos lr { inbound | outbound }
Rate limit is not configured on an interface.
inbound: Limits the rate of incoming packets on the interface.
outbound: Limits the rate of outgoing packets on the interface.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for the committed-burst-size argument is 512 and 134217728 in multiples of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. If the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512.
# Limit the rate of outgoing packets on Ten-GigabitEthernet 1/0/1, with CIR 25600 kbps and CBS 512000 bytes.
[Sysname-Ten-GigabitEthernet1/0/1] qos lr outbound cir 25600 cbs 512000
SP commands
Use display qos queue sp interface to display the SP queuing configuration of interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the SP queuing configuration of all interfaces.
# Display the SP queuing configuration of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos queue sp interface Ten-GigabitEthernet 1/0/1
Output queue: Strict Priority queuing
Table 16 Command output
Output queue |
Type of the current output queue. |
qos sp
Use qos sp to enable SP queuing on an interface.
Use undo qos sp to restore the default.
qos sp
undo qos sp
An interface uses the byte-count WRR queuing algorithm.
# Enable SP queuing on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos sp
WRR commands
Use display qos queue wrr interface to display the WRR queuing configuration of interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRR queuing configuration of all interfaces.
# Display the WRR queuing configuration of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos queue wrr interface Ten-GigabitEthernet 1/0/1
Output queue: Weighted Round Robin queuing
Queue ID Group Byte-count
be 1 1
af1 1 2
af2 1 3
af3 1 4
af4 1 5
ef 1 9
cs6 1 13
cs7 1 15
Table 17 Command output
Output queue |
Queue ID |
ID of a queue. |
Group |
Number of the group a queue is assigned to. By default, all queues belong to group 1. |
Weight |
Packet-based queue scheduling weight of a queue. N/A is displayed for a queue that uses the SP queue scheduling algorithm. |
qos wrr
Use qos wrr to enable WRR queuing and specify the weight type for an interface.
Use undo qos wrr to disable WRR queuing and restore the default queue scheduling algorithm for an interface.
undo qos wrr { byte-count | weight }
An interface uses the byte-count WRR queuing algorithm, and queues 0 through 7 have weights of 1, 2, 3, 4, 5, 9, 13, and 15, respectively.
byte-count: Allocates bandwidth to queues in terms of bytes.
weight: Allocates bandwidth to queues in terms of packets.
You must use the qos wrr command to enable WRR queuing before you can configure WRR queuing parameters for a queue on an interface.
# Enable weight-based WRR queuing on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr weight
# Enable byte-count WRR queuing on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr byte-count
Use qos wrr { byte-count | weight } to configure the WRR queuing parameters for a queue on an interface.
Use undo qos wrr to restore the default WRR queuing parameters of a queue on an interface.
qos wrr queue-id group { 1 | 2 } { byte-count | weight } schedule-value
undo qos wrr queue-id
An interface uses the byte-count WRR queuing algorithm, and queues 0 through 7 are in WRR group 1, with their weights of 1, 2, 3, 4, 5, 9, 13, and 15, respectively.
queue-id: Specifies a queue by its ID.
group { 1 | 2 }: Specifies a WRR group. If you do not specify a group, the default is WRR group 1.
schedule-value: Specifies a scheduling weight, in the range of 1 to 15.
The queue-id argument can be either a number or a keyword. Table 18 shows the number-keyword map.
Table 18 The number-keyword map for the queue-id argument
Number |
Keyword |
0 |
be |
1 |
af1 |
2 |
af2 |
3 |
af3 |
4 |
af4 |
5 |
ef |
6 |
cs6 |
7 |
cs7 |
# Enable byte-count WRR queuing on Ten-GigabitEthernet 1/0/1, assign queue 0, with the scheduling weight 10, to WRR group 1, and assign queue 1, with the scheduling weight 5, to WRR group 2.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr 0 group 1 byte-count 10
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr 1 group 2 byte-count 5
· display qos queue wrr interface
· qos wrr
qos wrr group sp
Use qos wrr group sp to assign a queue to the SP group.
Use undo qos wrr group sp to restore the default.
qos wrr queue-id group sp
An interface uses the byte-count WRR queuing algorithm, and all the queues are in WRR group 1.
queue-id: Specifies a queue by its ID. The value is an integer in the range of 0 to 7 or a keyword listed in Table 18.
sp: Assigns a queue to the SP group, which uses the SP queue scheduling algorithm.
You must use the qos wrr command to enable WRR queuing before you can configure this command on an interface.
This command is available only on a WRR-enabled interface. Queues in the SP group are scheduled with SP. The SP group has higher scheduling priority than the WRR group. Queues in a WRR group are scheduled according to user-configured weights, and WRR groups are scheduled at a 1:1 ratio.
# Enable packet-based WRR queuing on Ten-GigabitEthernet 1/0/1, and assign queue 0 to the SP group.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr 0 group sp
· qos wrr
WFQ commands
Use display qos queue wfq interface to display the WFQ configuration of interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WFQ configuration of all interfaces.
# Display the WFQ configuration of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos queue wfq interface Ten-GigabitEthernet 1/0/1
Output queue: Hardware Weighted Fair Queuing
Queue ID Group Byte-count Min-Bandwidth
be 1 1 64
af1 1 1 64
af2 1 1 64
af3 1 1 64
af4 1 1 64
ef 1 1 64
cs6 1 1 64
cs7 1 1 64
Table 19 Command output
Output queue |
Queue ID |
ID of a queue. |
Group |
Number of the WFQ group that holds the queue. By default, all queues are in group 1. |
Byte-count |
Byte-count scheduling weight of the queue. |
Min-Bandwidth |
Minimum guaranteed bandwidth. |
qos bandwidth queue
Use qos bandwidth queue to set the minimum guaranteed bandwidth for a queue on an interface.
Use undo qos bandwidth queue to restore the default.
undo qos bandwidth queue queue-id
The minimum guaranteed bandwidth is 64 kbps.
min bandwidth-value: Specifies the minimum guaranteed bandwidth in kbps. The value range for the bandwidth-value argument is 8 to 10000000 for 10-GE interfaces and 8 to 40000000 for 40-GE interfaces.
You must use the qos wfq command to enable WFQ before you can configure this command on an interface.
# Set the minimum guaranteed bandwidth to 100 kbps for queue 0 on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq weight
[Sysname-Ten-GigabitEthernet1/0/1] qos bandwidth queue 0 min 100
qos wfq
qos wfq
Use qos wfq to enable WFQ and specify the WFQ weight type on an interface.
Use undo qos wfq to disable WFQ and restore the default queuing algorithm on an interface.
undo qos wfq { byte-count | weight }
An interface uses the byte-count WRR queuing algorithm, and all the queues are in the WRR group.
You must use the qos wfq command to enable WFQ before you can configure WFQ queuing parameters for a queue on an interface.
# Enable weight-based WFQ on Ten-GigabitEthernet 1/0/1.
# Enable byte-count WFQ on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq byte-count
Use qos wfq { byte-count | weight } to assign a queue to a WFQ group with a certain scheduling weight.
Use undo qos wfq to restore the default.
qos wfq queue-id group { 1 | 2 } { byte-count | weight } schedule-value
undo qos wfq queue-id
When WFQ queuing is used on an interface, all the queues are in WFQ group 1 and have a weight of 1.
group { 1 | 2 }: Specifies a WFQ group. If you do not specify a group, the default is WFQ group 1.
schedule-value: Specifies a scheduling weight for the specified queue, in the range of 1 to 15.
You must use the qos wfq command to enable WFQ before you configure this command.
# Enable byte-count WFQ on Ten-GigabitEthernet 1/0/1, assign queue 0, with the scheduling weight 10, to WFQ group 1, and assign queue 1, with the scheduling weight 5, to WFQ group 2.
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq 0 group 1 byte-count 10
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq 1 group 2 byte-count 5
· display qos queue wfq interface
· qos bandwidth queue
· qos wfq
qos wfq group sp
Use qos wfq group sp to assign a queue to the SP group.
Use undo qos wfq group sp to restore the default.
qos wfq queue-id group sp
When WFQ queuing is used on an interface, all queues are in WFQ group 1.
With this SP+WFQ queuing method, the system schedules traffic as follows:
1. The system schedules the traffic conforming to the minimum guaranteed bandwidth in each WFQ group and schedules the traffic of the two WFQ groups in the ratio of 1:1 in a round robin manner.
2. The system uses SP to schedule queues in the SP group.
3. If there is remaining bandwidth, the system schedules the traffic of queues in each WFQ group based on their weights and schedules the traffic of the two WFQ groups in the ratio of 1:1 ratio in a round robin manner.
# Enable weight-based WFQ on Ten-GigabitEthernet 1/0/1, and assign queue 0 to the SP group.
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq 0 group sp
· qos wfq
Queue scheduling profile commands
bandwidth
Use bandwidth to configure the minimum guaranteed bandwidth for a WFQ queue.
undo bandwidth queue queue-id
The minimum guaranteed bandwidth of a WFQ queue is 64 kbps.
Queue scheduling profile view
queue-id: Specifies a queue by its ID. The value can be an integer in the range of 0 to 7 or a keyword listed in Table 18.
min bandwidth-value: Specifies the minimum guaranteed bandwidth in the range of 8 to 100000000 kbps.
You must configure a queue as a WFQ queue before you can configure the minimum guaranteed bandwidth for the queue.
The minimum guaranteed bandwidth is the minimum bandwidth guaranteed for a WFQ queue when the interface is congested.
# Configure the minimum guaranteed bandwidth as 100 kbps for queue 0 in queue scheduling profile myprofile.
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile] queue 0 wfq group 1 weight 1
[Sysname-qmprofile-myprofile] bandwidth queue 0 min 100
· display qos qmprofile interface
· qos qmprofile
· queue
display qos qmprofile configuration
Use display qos qmprofile configuration to display the configuration of queue scheduling profiles.
profile-name: Specifies a queue scheduling profile by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a queue scheduling profile, this command displays the configuration of all queue scheduling profiles.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the configuration of queue scheduling profiles on the master device.
# Display the configuration of queue scheduling profile myprofile.
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile (ID 1)
Queue ID Type Group Schedule-unit Schedule-value Bandwidth
be WFQ 1 weight 1 64
af1 WFQ 1 weight 1 64
af2 WFQ 1 weight 1 1000
af3 SP N/A N/A N/A N/A
af4 SP N/A N/A N/A N/A
ef SP N/A N/A N/A N/A
cs6 SP N/A N/A N/A N/A
cs7 SP N/A N/A N/A N/A
Table 20 Command output
Queue management profile |
Queue scheduling profile name. |
Type |
Queue scheduling type: · SP. · WRR. · WFQ. |
Group |
Priority group to which the queue belongs. N/A indicates that this field is ignored. |
Scheduling unit: · weight or byte-count for WRR and WFQ. · N/A for SP. N/A indicates that this field is ignored. |
Schedule value |
This field indicates: · Number of packets for the weight scheduling unit. · Number of bytes for the byte-count scheduling unit. N/A indicates that this field is ignored. |
Bandwidth |
Minimum guaranteed bandwidth for the queue. |
Use display qos qmprofile interface to display queue scheduling profiles applied to interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queue scheduling profiles applied to all interfaces.
# Display the queue scheduling profile applied to Ten-GigabitEthernet 1/0/1.
<Sysname> display qos qmprofile interface Ten-GigabitEthernet 1/0/1
Table 21 Command output
Interface name. |
Name of the queue scheduling profile applied to the interface. |
qos apply qmprofile
Use qos apply qmprofile to apply a queue scheduling profile to the outbound direction of an interface.
Use undo qos apply qmprofile to remove an applied queue scheduling profile from an interface.
No queue scheduling profile is applied to an interface.
You can apply only one queue scheduling profile to an interface.
# Apply queue scheduling profile myprofile to the outbound direction of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply qmprofile myprofile
qos qmprofile
Use qos qmprofile to create a queue scheduling profile and enter queue scheduling profile view.
Use undo qos qmprofile to delete a user-defined queue scheduling profile.
qos qmprofile profile-name
undo qos qmprofile profile-name
No user-defined queue scheduling profile exists.
profile-name: Specifies the name of the queue scheduling profile, a case-sensitive string of 1 to 31 characters.
To delete a queue scheduling profile already applied to an interface, first remove it from the interface.
# Create a queue scheduling profile named myprofile and enter queue scheduling profile view.
· queue
queue
Use queue to configure scheduling parameters for a queue.
Use undo queue to restore the default.
queue queue-id { sp | wfq group group-id { byte-count | weight } schedule-value | wrr group group-id { byte-count | weight } schedule-value }
undo queue queue-id
A queue uses WRR queuing.
sp: Enables SP for the queue.
wfq: Enables WFQ for the queue.
wrr: Enables WRR for the queue.
group group-id: Specifies a WFQ or WRR group by its ID. The value range is 1 and 2.
schedule-value: Specifies the number of bytes or packets sent each time, in the range of 1 to 15.
# Create a queue scheduling profile named myprofile, and configure queue 0 to use SP.
[Sysname-qmprofile-myprofile] queue 0 sp
# Create a queue scheduling profile named myprofile. Configure queue 1 to meet the following requirements:
· The WRR queuing is used.
· The WRR group is group 1.
· The number of packets sent each time is 10.
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 10
· qos qmprofile
Queue aging time commands
qos queue aging-time
Use qos queue aging-time to configure the queue aging time.
Use undo qos queue aging-time to restore the default.
qos queue aging-time time-value
The queue aging time is 0 milliseconds (the aging function is disabled).
time-value: Specifies the queue aging time in the range of 100 to 500 milliseconds. This argument must be an integral multiple of 100.
# Configure the queue aging time as 200 milliseconds.
[Sysname] qos queue aging-time 200
Queue-based accounting commands
display qos queue-statistics interface outbound
Use display qos queue-statistics interface outbound to display queue-based outgoing traffic statistics for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the outgoing traffic statistics for all interfaces.
# Display queue-based outgoing traffic statistics for Ten-GigabitEthernet 1/0/1.
<Sysname> display qos queue-statistics interface Ten-GigabitEthernet 1/0/1 outbound
Interface: Ten-GigabitEthernet 1/0/1
Direction: outbound
Forwarded: 1087 packets, 98466 bytes
Dropped: 0 packets, 0 bytes
Aged: 0 packets
Queue 0
Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
Current queue length: 0 packets
Queue 1
Queue 2
Queue 3
Queue 4
Queue 5
Queue 6
Queue 7
Forwarded: 1087 packets, 98466 bytes, 0 pps, 0 bps
Table 22 Command output
Interface for which queue-based traffic statistics are displayed. |
Direction |
Direction of traffic for which statistics are collected. |
Forwarded |
Forwarded traffic statistics for the interface in packets, bytes, pps, and bps. |
Dropped traffic statistics for the interface in packets and bytes. |
Number of packets dropped on the interface because the queue aging time expires. This field is displayed only when the queue aging time is configured. |
Forwarded: 1087 packets, 98466 bytes, 0 pps, 0 bps Current queue length: 0 packets |
Statistics for a queue: · Forwarded traffic in packets, bytes, pps, and bps. · Dropped traffic in packets and bytes. · Current number of packets in the queue. |
Congestion avoidance commands
WRED commands
display qos wred interface
Use display qos wred interface to display the WRED configuration for an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRED configuration and statistics for all interfaces.
# Display the WRED configuration for all interfaces.
<Sysname> display qos wred interface
Current WRED configuration:
Applied WRED table name: 1
Table 23 Command output
display qos wred table
Use display qos wred table to display the configuration of WRED tables.
name table-name: Specifies a WRED table by its name. If you do not specify a WRED table, this command displays the configuration of all WRED tables.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the configuration of WRED tables on the master device.
# Display the configuration of WRED table 1.
<Sysname> display qos wred table name 1
Table name: 1
Table type: Queue based WRED
QID gmin gmax gprob ymin ymax yprob rmin rmax rprob exponent ECN
0 100 1000 10 100 1000 10 100 1000 10 9 N
1 100 1000 10 100 1000 10 100 1000 10 9 N
2 100 1000 10 100 1000 10 100 1000 10 9 N
3 100 1000 10 100 1000 10 100 1000 10 9 N
4 100 1000 10 100 1000 10 100 1000 10 9 N
5 100 1000 10 100 1000 10 100 1000 10 9 N
6 100 1000 10 100 1000 10 100 1000 10 9 N
7 100 1000 10 100 1000 10 100 1000 10 9 N
Table 24 Command output
QID |
Queue ID. |
gmin |
Lower limit for green packets. |
gmax |
Upper limit for green packets. |
gprob |
Drop probability for green packets. |
ymin |
Lower limit for yellow packets. |
ymax |
Upper limit for yellow packets. |
yprob |
Drop probability for yellow packets. |
rmin |
Lower limit for red packets. |
rmax |
Upper limit for red packets. |
rprob |
Drop probability for red packets. |
exponent |
Exponent for average queue length calculation. |
ECN |
Indicates whether ECN is enabled for the queue: · Y—Enabled. · N—Disabled. |
qos wred apply
Use qos wred apply to apply a WRED table to an interface.
Use undo qos wred apply to restore the default.
qos wred apply [ table-name ]
undo qos wred apply
No WRED table is applied to an interface, and the tail drop mode is used on an interface.
If you do not specify a WRED table, this command applies the default WRED table to the interface.
# Apply queue-based WRED table table1 to Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wred apply table1
· display qos wred interface
· display qos wred table
· qos wred table
qos wred table
Use qos wred table to create a WRED table and enter WRED table view.
Use undo qos wred table to delete a WRED table.
undo qos wred queue table table-name
No WRED table exists.
queue: Creates a queue-based WRED table, which drops packets based on the queue when congestion occurs.
table table-name: Specifies a name for the WRED table.
You cannot delete a WRED table in use. To delete it, first remove it from the specified interface.
# Create a queue-based WRED table named queue-table1.
[Sysname-wred-table-queue-table1]
queue
Use queue to configure the drop-related parameters for a queue in the queue-based WRED table.
queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo queue { queue-id | all }
After a WRED table is created, the lower limit is 100, the upper limit is 1000, and the drop probability is 10%.
WRED table view
drop-level drop-level: Specifies a drop level. This argument is a consideration for dropping packets. The value 0 corresponds to green packets, the value 1 corresponds to yellow packets, and the value 2 corresponds to red packets. If you do not specify a drop level, the subsequent configuration takes effect on the packets in the queue regardless of the drop level.
low limit low-limit: Specifies the lower limit for the average queue length, in the range of 0 to 38000.
high-limit high-limit: Specifies the upper limit for the average queue length. The high-limit argument is in the range of 0 to 38000 and must be greater than the low-limit argument.
discard-probability discard-prob: Specifies the drop probability in percentage, in the range of 0 to 100.
When the average queue size is smaller than the lower limit, no packet is dropped. When the average queue size is between the lower limit and the upper limit, packets are dropped based on the user-configured drop probability. When the average queue size exceeds the upper limit, subsequent packets are dropped.
# In queue-based WRED table queue-table1, configure drop-related parameters for packets in queue 1 as follows:
· The drop level is 1.
· The lower limit for the average queue length is 10.
· The upper limit for the average queue length is 20.
· The drop probability is 30%.
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
· qos wred table
queue ecn
Use queue ecn to enable ECN for a queue.
Use undo queue ecn to restore the default.
queue queue-id ecn
undo queue queue-id ecn
ECN is not enabled on any queue.
WRED table view
When both the receiver and sender support ECN, the device can notify the peer end of the congestion status by identifying and setting the ECN flag. ECN avoids deteriorating congestion.
# In WRED table queue-table1, enable ECN for queue 1.
[Sysname-wred-table-queue-table1] queue 1 ecn
· qos wred table
queue weighting-constant
Use queue weighting-constant to specify an exponent for average queue length calculation for a queue.
Use undo queue weighting-constant to restore the default.
queue queue-id weighting-constant exponent
undo queue queue-id weighting-constant
The exponent for average queue length calculation is 9.
WRED table view
weighting-constant exponent: Specifies the WRED exponent for average queue length calculation, in the range of 0 to 15.
The bigger the exponent is, the less sensitive the average queue size is to real-time queue size changes. The average queue size is calculated using the formula: average queue size = previous average queue size × (1-2-n) + current queue size × 2-n, where n can be configured with the qos wred weighting-constant command.
# In WRED table queue-table1, set the exponent for average queue length calculation to 12 for queue 1.
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
· qos wred table
Aggregate CAR commands
car name
Use car name to use an aggregate CAR action in a traffic behavior.
Use undo car to remove an aggregate CAR action from a traffic behavior.
car name car-name
undo car
No aggregate CAR action is configured in a traffic behavior.
Traffic behavior view
car-name: Specifies the name of an aggregate CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
# Use aggregate CAR action aggcar-1 in traffic behavior be1.
· display qos car name
· display traffic behavior user-defined
Use display qos car name to display the configuration and statistics for an aggregate CAR action.
car-name: Specifies an aggregate CAR action by its name. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify an aggregate CAR action, this command displays the configuration and statistics for all aggregate CAR actions.
# Display the configuration and statistics for all aggregate CAR actions.
<Sysname> display qos car name
Mode: aggregative
CIR 12800 (kbps), CBS 800256 (Bytes), EBS 512 (Bytes)
Green action: pass
Yellow action: pass
Red action: discard
Slot 1:
Green packets: 54641 (Packets)
Red packets: 856 (Packets)
Slot 2:
Green packets: 12541 (Packets)
Red packets: 1235 (Packets)
Table 25 Command output
Name |
Name of the aggregate CAR action. |
Mode |
Type of the aggregate CAR action: aggregative. |
CIR CBS EBS PIR |
Parameters for the CAR action. |
Green action |
Action to take on green packets: · discard—Drops the packets. · pass—Permits the packets to pass through. |
Yellow action |
Action to take on yellow packets: · discard—Drops the packets. · pass—Permits the packets to pass through. |
Red action |
Action to take on red packets: · discard—Drops the packets. · pass—Permits the packets to pass through. |
Green packet |
Red packet |
qos car
Use qos car to configure an aggregate CAR action.
Use undo qos car to remove an aggregate CAR action.
undo qos car car-name
No aggregate CAR action is configured.
car-name: Specifies the name of the aggregate CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
aggregative: Specifies the aggregate CAR action.
cir committed-information-rate: Specifies the CIR in kbps. The value range for the committed-information-rate argument is 8 and 160000000 in multiples of 8.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for the committed-burst-size argument is 512 and 256000000 in multiples of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. If the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512. A default value greater than 256000000 is converted to 256000000.
ebs excess-burst-size: Specifies the EBS in bytes. The value range for the excess-burst-size argument is 0 and 256000000 in multiples of 512, and the default value is 512.
pir peak-information-rate: Specifies the PIR in kbps. The value range for the peak-information-rate argument is 8 and 160000000 in multiples of 8. If the PIR is configured, two rates are used for traffic policing. Otherwise, one rate is used.
green action: Specifies the action to take on packets that conform to the CIR. The default setting is pass.
red action: Specifies the action to take on packets that conforms to neither CIR nor PIR. The default setting is discard.
yellow action: Specifies the action to take on packets that conform to the PIR but not to the CIR. The default setting is pass.
action: Specifies the action to take on packets:
· discard: Drops the packet.
· pass: Permits the packet to pass through.
· remark-dot1p-pass new-cos: Sets the 802.1p priority value of the 802.1p packet to new-cos and permits the packet to pass through. The new-cos argument is in the range of 0 to 7.
· remark-dscp-pass new-dscp: Remarks the packet with a new DSCP value and permits the packet to pass through. The value range is 0 to 63. Alternatively, you can specify the new-dscp argument with af11, af12, af13, af21, af22, af23, af31, af32, af33, af41, af42, af43, cs1, cs2, cs3, cs4, cs5, cs6, cs7, default, or ef.
An aggregate CAR action takes effect only after it is applied to an interface or used in a QoS policy.
# Configure aggregate CAR action aggcar-1, where CIR is 25600, CBS is 512000, and red packets are dropped.
[Sysname] qos car aggcar-1 aggregative cir 25600 cbs 512000 red discard
reset qos car name
Use reset qos car name to clear statistics for an aggregate CAR action.
car-name: Specifies an aggregate CAR action by its name. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify an aggregate CAR action, this command clears the statistics for all aggregate CAR actions.
# Clear statistics for aggregate CAR action aggcar-1.
