| 04-Data buffer commands | 58.61 KB |
Inappropriate data buffer changes can cause system problems. Before manually changing data buffer settings, make sure you understand its impact on your device. As a best practice, use the burst-mode enable command if the system requires large buffer spaces. The burst-mode enable command and the buffer apply command are mutually exclusive.
buffer apply
Use buffer apply to apply manually configured data buffer settings.
Use undo buffer apply to cancel the application.
buffer apply
undo buffer apply
After applying manually configured data buffer settings, you cannot directly modify the applied settings. To modify them, you must cancel the application, reconfigure data buffer settings, and reapply the new settings.
# Apply manually configured data buffer settings.
[Sysname] buffer apply
buffer queue guaranteed
Use buffer queue guaranteed to set the fixed-area ratio for a queue.
Use undo buffer queue guaranteed to restore the default.
buffer egress [ slot slot-number ] cell queue queue-id guaranteed ratio ratio-value
undo buffer egress [ slot slot-number ] cell queue queue-id guaranteed
The fixed-area ratio for a queue is 12.5%, but the default value in the display buffer queue command output is 13%.
egress: Specifies the egress buffer.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command applies to all member devices.
cell: Specifies cell resources.
queue-id: Specifies a queue by its ID in the range of 0 to 7.
ratio ratio-value: Specifies the fixed-area ratio in percentage.
The fixed-area space for a queue cannot be used by other queues. It is also called the minimum guaranteed buffer.
The sum of fixed-area ratios configured for queues cannot be greater than or equal to 100%. Queues 5, 6, and 7 must have available fixed-area space.
After you configure the fixed-area ratios for some queues, the other queues each are assigned an equal share of the remaining part of the fixed area. The display buffer queue command displays the preceding whole number for each assignment result. Therefore, the sum of the ratios for all queues might be less than 100%.
# Configure queue 0 to use 15% fixed-area space of cell resources in the egress buffer of IRF member device 2.
[Sysname] buffer egress slot 2 cell queue 0 guaranteed ratio 15
buffer queue shared
Use buffer queue shared to set the maximum shared-area ratio for a queue.
Use undo buffer queue shared to restore the default.
buffer egress [ slot slot-number ] cell queue queue-id shared ratio ratio-value
undo buffer egress [ slot slot-number ] cell queue queue-id shared
The maximum shared-area ratio for a queue is 33%.
ratio ratio-value: Specifies the maximum shared-area ratio in percentage.
By default, all queues have an equal share of the shared area. You can set the shared-area ratio for a queue. The unconfigured queues use the default setting. The shared-area ratio for each queue is finally determined by the chip based on your configuration and the number of packets to be sent.
For the maximum shared-area ratio for a queue, the percentage values 0 to 100 are divided into 10 ranges. Table 1 shows the effective values that correspond to the configured values of ratio-value.
Table 1 Mapping between configured values of ratio-value and effective values
Configured value of ratio-value |
Effective value |
0 to 1 |
1 |
2 to 3 |
3 |
6 |
8 to 16 |
11 |
17 to 29 |
20 |
30 to 42 |
33 |
43 to 60 |
50 |
61 to 76 |
67 |
77 to 86 |
80 |
87 to 100 |
89 |
# Configure queue 0 to use up to 5% shared-area space of cell resources in the egress buffer of IRF member device 2.
[Sysname] buffer egress slot 2 cell queue 0 shared ratio 5
buffer total-shared
Use buffer total-shared to set the total shared-area ratio.
Use undo buffer total-shared to restore the default.
buffer egress [ slot slot-number ] cell total-shared ratio ratio-value
undo buffer egress [ slot slot-number ] cell total-shared
The total shared-area ratio is 84% of the buffer.
ratio ratio-value: Specifies the ratio of the shared area in percentage.
After you configure the total shared-area ratio, the remaining buffer space is automatically assigned to the fixed area.
# Configure the shared area to use 65% space of cell resources in the egress buffer of IRF member device 2.
[Sysname] buffer egress slot 2 cell total-shared ratio 65
buffer usage threshold
Use buffer usage threshold to set a per-interface buffer usage threshold.
Use undo buffer usage threshold to restore the default.
buffer usage threshold slot slot-number ratio ratio
undo buffer usage threshold slot slot-number
The per-interface buffer usage threshold is 30%.
ratio ratio: Specifies the buffer usage threshold in percentage, in the range of 1 to 100.
After you configure this command, the switch automatically records buffer usage for each interface. When a queue on an interface uses more buffer space than the set threshold, the system counts one threshold violation for the queue.
To display the buffer usage statistics for interfaces, use the display buffer usage interface command.
# Set the per-interface buffer usage threshold to 50% for IRF member device 2.
[Sysname] buffer usage threshold slot 2 ratio 50
burst-mode enable
Use burst-mode enable to enable the Burst feature.
Use undo burst-mode enable to disable the Burst feature.
burst-mode enable
The Burst feature is disabled.
The Burst feature is especially useful for reducing packet losses under the following circumstances:
· Traffic enters a switch from a high-speed interface and goes out of a low-speed interface.
· Traffic enters a switch from multiple same-rate interfaces and goes out of an interface with the same rate.
# Enable the Burst feature.
[Sysname] burst-mode enable
display buffer
Use display buffer to display buffer size settings.
display buffer [ slot slot-number ] [ queue [ queue-id ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays buffer size settings on all member devices.
queue queue-id: Specifies a queue by its ID in the range of 0 to 7.
If you do not specify the queue keyword, this command displays the total shared-area ratio.
If you specify the queue keyword, this command displays the fixed-area ratio and shared-area ratio for all queues.
If you specify a queue, this command displays the fixed-area size and shared-area size for the specified queue.
# Display the total shared-area ratio.
<Sysname> display buffer
Slot Type Eg(Total-shared)
1 cell 25
Eg: Size of the sending buffer
Total-shared: Size of the shared buffer for all ports
Unit: Ratio
# Display the fixed-area ratio and shared-area ratio for each queue.
<Sysname> display buffer queue
Slot Queue Type Eg(Guaranteed , Shared)
2 0 cell 20 , 33
2 1 cell 14 , 33
2 2-7 cell 11 , 33
Guaranteed: Size of the minimum guaranteed buffer per queue
Shared: Size of the maximum shared buffer per queue
Unit: Ratio
Slot |
ID of an IRF member device. |
Type |
Resource type. The device supports only cell resources. |
Queue |
Queue ID in the range of 0 to 7. |
Eg |
Egress buffer. |
(Total-shared) |
Total shared-area size. |
(Guaranteed , Shared) |
· Guaranteed—Fixed-area ratio for a queue. · Shared—Shared-area ratio for a queue. The default fixed-area ratio for a queue is 12.5%, but the default value in the display buffer queue command output is 13%. |
Unit |
Unit for configuring the data buffer. The device supports only ratio. |
Use display buffer usage to display buffer usage.
display buffer usage [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays buffer usage on all member devices.
# Display data buffer usage.
<Sysname> display buffer usage
Egress total-shared cell buffer usage on slot 1 :
Total: 9197 KB
Used: 0 KB
Free: 9197 KB
5sec 1min 5min
Block 1 0% 0% 0%
Ten-GigabitEthernet1/0/1 0% 0% 0%
Ten-GigabitEthernet1/0/2 0% 0% 0%
Ten-GigabitEthernet1/0/3 0% 0% 0%
Ten-GigabitEthernet1/0/4 0% 0% 0%
Ten-GigabitEthernet1/0/5 0% 0% 0%
Ten-GigabitEthernet1/0/6 0% 0% 0%
Ten-GigabitEthernet1/0/7 0% 0% 0%
Ten-GigabitEthernet1/0/8 0% 0% 0%
Ten-GigabitEthernet1/0/9 0% 0% 0%
Ten-GigabitEthernet1/0/10 0% 0% 0%
Ten-GigabitEthernet1/0/11 0% 0% 0%
Ten-GigabitEthernet1/0/12 0% 0% 0%
Ten-GigabitEthernet1/0/13 0% 0% 0%
Ten-GigabitEthernet1/0/14 0% 0% 0%
Ten-GigabitEthernet1/0/15 0% 0% 0%
Ten-GigabitEthernet1/0/16 0% 0% 0%
Ten-GigabitEthernet1/0/17 0% 0% 0%
Ten-GigabitEthernet1/0/18 0% 0% 0%
Ten-GigabitEthernet1/0/19 0% 0% 0%
Ten-GigabitEthernet1/0/20 0% 0% 0%
Ten-GigabitEthernet1/0/21 0% 0% 0%
Ten-GigabitEthernet1/0/22 0% 0% 0%
Ten-GigabitEthernet1/0/23 0% 0% 0%
Ten-GigabitEthernet1/0/24 0% 0% 0%
Ten-GigabitEthernet1/0/25 0% 0% 0%
Ten-GigabitEthernet1/0/26 0% 0% 0%
Ten-GigabitEthernet1/0/27 0% 0% 0%
Ten-GigabitEthernet1/0/28 0% 0% 0%
Ten-GigabitEthernet1/0/29 0% 0% 0%
Ten-GigabitEthernet1/0/30 0% 0% 0%
Ten-GigabitEthernet1/0/31 0% 0% 0%
Ten-GigabitEthernet1/0/32 0% 0% 0%
Ten-GigabitEthernet1/0/33 0% 0% 0%
Ten-GigabitEthernet1/0/34 0% 0% 0%
Ten-GigabitEthernet1/0/35 0% 0% 0%
Ten-GigabitEthernet1/0/36 0% 0% 0%
Ten-GigabitEthernet1/0/37 0% 0% 0%
Ten-GigabitEthernet1/0/38 0% 0% 0%
Ten-GigabitEthernet1/0/39 0% 0% 0%
Ten-GigabitEthernet1/0/40 0% 0% 0%
Ten-GigabitEthernet1/0/41 0% 0% 0%
Ten-GigabitEthernet1/0/42 0% 0% 0%
Ten-GigabitEthernet1/0/43 0% 0% 0%
Ten-GigabitEthernet1/0/44 0% 0% 0%
Ten-GigabitEthernet1/0/45 0% 0% 0%
Ten-GigabitEthernet1/0/46 0% 0% 0%
Ten-GigabitEthernet1/0/47 0% 0% 0%
Ten-GigabitEthernet1/0/48 0% 0% 0%
Egress total-shared cell buffer usage on slot |
Usage of the shared area of cell resources on an IRF member device. |
Total |
Total size of the data buffer. |
Used |
Size of used data buffer. |
Free |
Size of free data buffer. |
Block 1 |
Block where the port resides. The block where the ports on the front panel of the device reside is fixed to Block 1. |
5sec |
Percentage of the buffer that the port uses for the last 5 seconds. |
1min |
Percentage of the buffer that the port uses for the last 1 minute. |
5min |
Percentage of the buffer that the port uses for the last 5 minutes. |
Use display buffer usage interface to display buffer usage statistics for interfaces.
display buffer usage interface [ interface-type [ interface-number ] ]
interface-type [ interface-number ]: Specifies an interface by its type and number. If you do not specify the interface-type argument, this command displays buffer usage statistics for all Ethernet interfaces. If you specify the interface-type argument without the interface-number argument, this command displays buffer usage statistics for all Ethernet interfaces of the specified type.
# Display buffer usage statistics for Ten-GigabitEthernet 1/0/1.
<Sysname> display buffer usage interface ten-gigabitethernet 1/0/1
Interface QueueID Total Used Threshold(%) Violations
XGE1/0/1 0 9418032 0 30 0
1 9418032 0 30 0
2 9418032 0 30 0
3 9418032 0 30 0
4 9418032 0 30 0
5 9418032 0 30 0
6 9418032 0 30 0
7 9418032 0 30 0
Total |
Data buffer size in bytes allowed for a queue. |
Used |
Data buffer size in bytes that has been used by a queue. |
Threshold(%) |
Buffer usage threshold for a queue. The threshold value is the same as the per-interface threshold value. |
Violations |
Number of threshold violations for a queue. The value of this field is reset upon a switch reboot. |
