05-Layer 3 - IP Services Configuration Guide
HomeSupportSwitchesH3C S10500 Switch SeriesConfigure & DeployConfiguration GuidesH3C S10500 Switch Series Configuration Guides-Release757X-6W10005-Layer 3 - IP Services Configuration Guide
05-IP forwarding basics configuration
05-IP forwarding basics configuration 74.74 KB
Configuring IP forwarding basic settings········································ 1
Overview······························································································································ 1
Saving the IP forwarding entries to a file·················································································· 1
Displaying FIB table entries···································································································· 2
Configuring load sharing··························································· 3
Overview······························································································································ 3
Configuring load sharing mode······························································································· 3
Enabling local-first load sharing······························································································ 3
Displaying and maintaining load sharing················································································· 4
Load sharing configuration example························································································ 4
Network requirements····································································································· 4
Configuration procedure································································································· 4
Verifying the configuration······························································································ 5
Overview
The device uses the destination IP address of a received packet to find a match from the forwarding information base (FIB) table. It then uses the matching entry to forward the packet.
FIB table
A device selects optimal routes from the routing table, and puts them into the FIB table. Each FIB entry specifies the next hop IP address and output interface for packets destined for a specific subnet or host.
For more information about the routing table, see Layer 3—IP Routing Configuration Guide.
Use the display fib command to display FIB table entries. The following example displays the entire FIB table.
<Sysname> display fib
Destination count: 4 FIB entry count: 4
Flag:
  R:Relay     F:FRR
Destination/Mask   Nexthop         Flag     OutInterface/Token       Label
10.2.0.0/16        10.2.1.1        U        XGE1/0/1                Null
10.2.1.1/32        127.0.0.1       UH       InLoop0                  Null
127.0.0.0/8        127.0.0.1       U        InLoop0                  Null
127.0.0.1/32       127.0.0.1       UH       InLoop0                  Null
A FIB entry includes the following items:
·          Destination—Destination IP address.
·          Mask—Network mask. The mask and the destination address identify the destination network. A logical AND operation between the destination address and the network mask yields the address of the destination network. For example, if the destination address is 192.168.1.40 and the mask 255.255.255.0, the address of the destination network is 192.168.1.0. A network mask includes a certain number of consecutive 1s. It can be expressed in dotted decimal format or by the number of the 1s.
·          Nexthop—IP address of the next hop.
·          Flag—Route flag.
·          OutInterface—Output interface.
·          Token—MPLS Label Switched Path index number.
·          Label—Inner label.
The feature automatically creates the file if you specify a nonexistent file. If the file already exists, this feature overwrites the file content.
To automatically save the IP forwarding entries periodically, configure a schedule for the device to automatically run the ip forwarding-table save command. For information about scheduling a task, see Fundamentals Configuration Guide.
To save the IP forwarding entries to a file:
Remarks
Specify a file to save the IP forwarding entries.
ip forwarding-table save filename filename
Executing this command triggers one-time saving of the IP forwarding entries.
This command can be executed in any view.
Display FIB entries.
display fib [ vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ]
Overview
If a routing protocol finds multiple equal-cost best routes to the same destination, the device forwards packets over the equal-cost routes to implement load sharing.
In the per-flow load sharing mode, the device forwards flows over equal-cost routes. Packets of one flow travel along the same routes. The device can identify a flow based on the following criteria: source IP address, destination IP address, source port number, destination port number, IP protocol number, and ingress port.
When you configure the load sharing mode, follow these restrictions and guidelines:
·          The following flow identification criteria are supported in the current software version:
¡  Source IP address.
¡  Source IP address and destination IP address.
¡  Source IP address, source port, and destination port.
¡  Source IP address, destination IP address, source port, and destination port.
·          This feature is not available for tunnels.
To configure load sharing mode:
Step
Remarks
1.       Enter system view.
N/A
2.       Configure load sharing mode.
·         In standalone mode:
ip load-sharing mode per-flow [ dest-ip | dest-port | src-ip | src-port ] * { global | slot slot-number }
·         In IRF mode:
ip load-sharing mode per-flow [ dest-ip | dest-port | src-ip | src-port ] * { chassis chassis-number slot slot-number | global }
By default, the device performs per-flow load sharing based on the source IP address, destination IP address, source port number, destination port number, IP protocol number, and ingress port of packets.
Local-first load sharing distributes traffic preferentially across the output interfaces on the receiving IRF member device if output interfaces for multiple equal-cost routes are on different members. This feature enhances packets forwarding efficiency.
When you enable local-first load sharing, follow these restrictions and guidelines:
·          An aggregate interface always participates in the traffic load sharing if it is an output interface of an equal-cost route but does not reside on the IRF member device that receives the traffic.
·          The feature is not available for VXLAN tunnels.
To enable local-first load sharing:
Step
Remarks
N/A
2.       Enable local-first load sharing.
ip load-sharing local-first enable
By default, local-first load sharing is enabled.
(In standalone mode.) Display the load sharing mode in use.
display ip load-sharing mode slot slot-number
(In IRF mode.) Display the load sharing mode in use.
display ip load-sharing mode chassis chassis-number slot slot-number
As shown in Figure 1, Switch A has two equal-cost routes to Switch B. Configure load sharing on Switch A to forward packets through Switch B to the destination IP address 1.2.3.4/24.
Figure 1 Network diagram
# On Switch A, assign GigabitEthernet 1/0/1 to VLAN 10, and GigabitEthernet 1/0/2 to VLAN 20.
[SwitchA] vlan 10
[SwitchA-vlan10] port gigabitethernet 1/0/1
[SwitchA-vlan10] quit
[SwitchA] vlan 20
[SwitchA-vlan20] port gigabitethernet 1/0/2
[SwitchA-vlan20] quit
# On Switch A, configure IP addresses for VLAN-interface 10 and VLAN-interface 20.
[SwitchA-Vlan-interface10] ip address 10.1.1.1 24
[SwitchA-Vlan-interface20] ip address 20.1.1.1 24
# On Switch B, assign GigabitEthernet 1/0/1 to VLAN 10, and GigabitEthernet 1/0/2 to VLAN 20.
[SwitchB] vlan 10
[SwitchB-vlan10] port gigabitethernet 1/0/1
[SwitchB-vlan10] quit
[SwitchB] vlan 20
[SwitchB-vlan20] port gigabitethernet 1/0/2
[SwitchB-vlan20] quit
# On Switch B, configure IP addresses for VLAN-interface 10 and VLAN-interface 20.
[SwitchB-Vlan-interface10] ip address 10.1.1.2 24
[SwitchB] interface vlan-interface 20
[SwitchB-Vlan-interface20] ip address 20.1.1.2 24
[SwitchB-Vlan-interface20] quit
# On Switch A, configure two static routes to the destination IP address.
[SwitchA] ip route-static 1.2.3.4 24 10.1.1.2
[SwitchA] ip route-static 1.2.3.4 24 20.1.1.2
[SwitchA] quit
# On Switch A, display FIB entries matching the destination IP address 1.2.3.4.
<SwitchA> display fib 1.2.3.4
Destination count: 1 FIB entry count: 2
Flag:
  R:Relay     F:FRR
1.2.3.0/24         10.1.1.2        USGR     Vlan10                   Null
1.2.3.0/24         20.1.1.2        USGR     Vlan20                   Null
# On Switch A, configure per-flow load sharing based on the source IP address and destination IP address.
[SwitchA] ip load-sharing mode per-flow dest-ip src-ip global
# Verify that Switch A implements load sharing.
<SwitchA> display counters outbound interface GigabitEthernet
Interface         Total (pkts)   Broadcast (pkts)   Multicast (pkts)  Err (pkts)
GE1/0/1                  1045                  0                  0           0
GE1/0/2                  1044                  0                  0           0
