| 06-Appendix B LEDs | 81.36 KB |
LEDs
(1) 100/1000Base-T autosensing Ethernet port status LEDs |
(2) 100Base-FX/1000Base-X SFP port status LEDs |
(3) 10GBase-R SFP+ port status LEDs |
(4) 100/1000 Base-T out-of-band management Ethernet port status LEDs (LINK/ACT) |
(5) Power module 1 status LED (PWR1) |
(6) Power module 2 status LED (PWR2) |
(7) System status LED (SYS) |
(8) Expansion slot status LED (MOD) |
LED |
Mark |
Status |
Power module 1 status LED |
PWR1 |
Steady green |
Power module 1 is operating correctly. |
Steady yellow |
Power module 1 is faulty |
Off |
No power module is installed to the slot. |
Power module 2 status LED |
PWR2 |
Steady green |
Power module 2 is operating correctly. |
Steady yellow |
Power module 2 is faulty. |
Off |
System status LED |
SYS |
Steady green |
The system is starting up. |
Flashing green |
The system is operating correctly. |
Flashing green |
The system is downloading files. |
Steady yellow |
The system has failed to pass the power on self test (POST) or has detected a serious fault. |
Off |
No power input is present. |
Expansion slot status LED (green/yellow) |
MOD |
Steady green |
An interface card is present. |
Flashing green |
The hard disk is reading or writing data. |
Steady yellow |
A failure has occurred. |
Off |
No interface card is present. |
100/1000 Base-T out-of-band management Ethernet port status LED (green) |
LINK/ACT |
Off |
No link is present. |
Steady green |
A link is present. |
Flashing green |
The port is receiving or transmitting data. |
100/1000 Base-T autosensing Ethernet port status LED |
N/A |
Steady yellow |
A 100 Mbps link is present on the port. |
Flashing yellow |
The port is receiving or transmitting data at 100 Mbps. |
Steady green |
A 1000 Mbps link is present on the port. |
Flashing green |
The port is receiving or transmitting data at 1000 Mbps. |
Off |
No link is present on the port. |
100Base-FX/1000Base-X SFP port status LED |
N/A |
Steady yellow |
Flashing yellow |
Steady green |
Flashing green |
Off |
10GBase-R SFP+ port status LED |
N/A |
Steady green |
A link is present on the port. |
Flashing green |
The port is receiving or transmitting data at 10 Gbps. |
Off |
