| 00-Preface | 55.74 KB |
Preface
The H3C WX5510E Access Controller Installation Guide describes preparing for installation, installing the access controller, troubleshooting, and hardware management and maintenance of the WX5510E access controller.
This preface includes:
· Audience
Audience
· Field technical support and servicing engineers
· Network administrators working with the WX5510E access controller.
Conventions
This section describes the conventions used in this documentation set.
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Convention |
Button names are inside angle brackets. For example, click <OK>. |
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window. |
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder]. |
Symbols
Convention |
NOTE |
Documentation feedback
We appreciate your comments.
