03-Layer 2-LAN Switching Command Reference
HomeSupportSwitchesS5130 SeriesReference GuidesCommand ReferencesH3C S5130-HI Command References-R1118P02[R1122]-6W10203-Layer 2-LAN Switching Command Reference
11-QinQ commands
11-QinQ commands 45.48 KB
QinQ commands
This document uses the following terms:
·     CVLAN—Customer network VLANs, also called inner VLANs, refer to VLANs that a customer uses on the private network.
·     SVLAN—Service provider network VLANs, also called outer VLANs, refer to VLANs that a service provider uses to transmit VLAN tagged traffic for customers.
display qinq
Use display qinq to display the QinQ-enabled interfaces.
display qinq [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays all QinQ-enabled interfaces.
If QinQ is not enabled on any interfaces, this command does not provide any output.
# Enable QinQ on GigabitEthernet 1/0/1. Then, verify that QinQ is enabled on the interface.
[Sysname-GigabitEthernet1/0/1] qinq enable
[Sysname-GigabitEthernet1/0/1] display qinq interface gigabitethernet 1/0/1
# Enable QinQ on GigabitEthernet 1/0/1 and GigabitEthernet 1/0/3. Then, verify that QinQ is enabled on the interfaces.
[Sysname] interface gigabitethernet 1/0/3
[Sysname-GigabitEthernet1/0/3] qinq enable
[Sysname-GigabitEthernet1/0/3] display qinq
Interface name.
QinQ-enabled interface.
qinq enable
qinq enable
Use qinq enable to enable QinQ on an Ethernet interface.
Use undo qinq enable to restore the default.
qinq enable
undo qinq enable
QinQ is disabled on Ethernet interfaces.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
display qinq
qinq ethernet-type customer-tag
Use qinq ethernet-type customer-tag to configure the CVLAN TPID.
Use undo qinq ethernet-type customer-tag to restore the default CVLAN TPID.
qinq ethernet-type customer-tag hex-value
The CVLAN TPID is 0x8100.
hex-value: Sets a hexadecimal TPID value in the range of 0x0001 to 0xFFFF, excluding the reserved EtherType values listed in Table 2.
Table 2 Reserved EtherType values
Protocol type
Value
ARP
0x0806
PUP
0x0200
RARP
0x8035
IP
0x0800
IPv6
0x86DD
PPPoE
0x8863/0x8864
MPLS
0x8847/0x8848
IPX/SPX
0x8137
IS-IS
0x8000
LACP
0x8809
802.1X
0x888E
LLDP
0x88CC
802.1ag
0x8902
Cluster
0x88A7
Reserved
0xFFFD/0xFFFE/0xFFFF
A QinQ-enabled port uses the CLAN TPID to match incoming tagged frames. An incoming frame is handled as an untagged frame if its TPID is different from the CVLAN TPID.
# Set the TPID value in CVLAN tags to 0x8200.
[Sysname] qinq ethernet-type customer-tag 8200
qinq ethernet-type service-tag
Use qinq ethernet-type service-tag to configure the SVLAN TPID.
Use undo qinq ethernet-type service-tag to restore the default SVLAN TPID.
qinq ethernet-type service-tag hex-value
The SVLAN TPID is 0x8100.
Ethernet interface view, aggregate interface view
A service provider-side port uses the SVLAN TPID to replace the TPID in outgoing frames' SVLAN tags, in addition to matching incoming tagged frames.
# Set the SVLAN TPID to 0x9100 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qinq ethernet-type service-tag 9100
qinq transparent-vlan
Use qinq transparent-vlan to enable transparent transmission for a list of VLANs on a port.
Use undo qinq transparent-vlan to disable transparent transmission for a list of VLANs on a port.
qinq transparent-vlan vlan-id-list
undo qinq transparent-vlan { vlan-id-list | all }
Transparent transmission is disabled for all VLANs on a port.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a single VLAN ID or a VLAN ID range in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The end VLAN ID must be equal to or greater than the start VLAN ID.
all: Specifies all existing VLANs.
By default, QinQ tags all incoming frames with the PVID on a port. This command disables QinQ to tag incoming traffic from a list of VLANs. These VLANs are called transparent VLANs.
To ensure successful transmission for a transparent VLAN, follow these configuration guidelines:
·     Set the link type of the port to trunk or hybrid, and assign the port to its PVID and the transparent VLAN.
·     Do not configure any other VLAN manipulation actions for the transparent VLAN on the port.
·     Make sure all ports on the traffic path permit the transparent VLAN to pass through.
# Configure GigabitEthernet 1/0/1 as a trunk port, and assign the port to VLAN 2, VLAN 3, and VLANs 50 through 100. Enable QinQ on GigabitEthernet 1/0/1, and configure the port to transparently transmit frames from VLAN 2.
[Sysname-GigabitEthernet1/0/1] port trunk permit vlan 2 3 50 to 100
[Sysname-GigabitEthernet1/0/1] qinq transparent-vlan 2
