03-Layer 2-LAN Switching Command Reference
HomeSupportSwitchesS5130 SeriesReference GuidesCommand ReferencesH3C S5130-HI Command References-R1118P02[R1122]-6W10203-Layer 2-LAN Switching Command Reference
06-Port isolation commands
06-Port isolation commands 33.31 KB
display port-isolate group
Use display port-isolate group to display port isolation group information.
display port-isolate group [ group-number ]
group-number: Specifies an isolation group by its number in the range of 1 to 8.
# Display all isolation groups.
<Sysname> display port-isolate group
 Port isolation group information:
 Group ID: 2
 Group members:
    GigabitEthernet1/0/1
 Group ID: 5
 Group members:
GigabitEthernet1/0/2
GigabitEthernet1/0/4
# Display information about isolation group 2.
<Sysname> display port-isolate group 2
 Group ID: 2
 Group members:
Group ID
Isolation group number.
Group members
Isolated ports in the isolation group. If the isolation group contains no isolated ports, this field displays No ports.
port-isolate enable
port-isolate enable
Use port-isolate enable to assign a port to an isolation group.
Use undo port-isolate enable to remove a port from an isolation group.
port-isolate enable group group-number
The port is not assigned to any isolation group.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
group group-number: Specifies an isolation group by its number in the range of 1 to 8.
The configuration in Layer 2 Ethernet interface view applies only to the interface.
The configuration in Layer 2 aggregate interface view applies to the Layer 2 aggregate interface and its aggregation member ports. If the device fails to apply the configuration to the aggregate interface, it does not assign any aggregation member port to the isolation group. If the failure occurs on an aggregation member port, the device skips the port and continues to assign other aggregation member ports to the isolation group.
You cannot assign the member ports of a service loopback group to an isolation group, and vice versa.
To assign ports to an isolation group, make sure the isolation group already exists.
One port can be assigned to only one isolation group.
# Assign ports GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to isolation group 2.
[Sysname-GigabitEthernet1/0/1] port-isolate enable group 2
[Sysname-GigabitEthernet1/0/2] port-isolate enable group 2
port-isolate group
Use port-isolate group to create an isolation group.
Use undo port-isolate group to delete isolation groups.
port-isolate group group-number
undo port-isolate group { group-number | all }
No isolation group exists.
all: Deletes all isolation groups.
# Create isolation group 2.
[Sysname] port-isolate group 2
