05-Layer 3 - IP Services Command Reference
HomeSupportSwitchesH3C S7500E-X Switch SeriesReference GuidesCommand ReferencesH3C S7500E-X Switch Series Command References-Release7178-6W10005-Layer 3 - IP Services Command Reference
03-DHCP commands
03-DHCP commands 307.27 KB
DHCP commands· 1
Common DHCP commands· 1
dhcp dscp· 1
dhcp enable· 1
dhcp select 2
DHCP server commands· 3
address range· 3
bims-server 4
bootfile-name· 4
class· 5
dhcp class· 6
dhcp server always-broadcast 7
dhcp server apply ip-pool 8
dhcp server bootp ignore· 8
dhcp server bootp reply-rfc-1048· 9
dhcp server forbidden-ip· 10
dhcp server ip-pool 11
dhcp server ping packets· 11
dhcp server ping timeout 12
dhcp server relay information enable· 13
display dhcp server conflict 13
display dhcp server expired· 14
display dhcp server free-ip· 15
display dhcp server ip-in-use· 16
display dhcp server pool 17
display dhcp server statistics· 20
dns-list 21
domain-name· 22
expired· 23
forbidden-ip· 24
gateway-list 24
if-match· 25
nbns-list 27
netbios-type· 27
network· 28
next-server 29
option· 30
reset dhcp server conflict 31
reset dhcp server expired· 32
reset dhcp server ip-in-use· 32
reset dhcp server statistics· 33
static-bind· 33
tftp-server domain-name· 34
tftp-server ip-address· 35
voice-config· 36
DHCP relay agent commands· 37
dhcp relay check mac-address· 37
dhcp relay check mac-address aging time· 37
dhcp relay client-information record· 38
dhcp relay client-information refresh· 39
dhcp relay client-information refresh enable· 39
dhcp relay information circuit-id· 40
dhcp relay information enable· 42
dhcp relay information remote-id· 43
dhcp relay information strategy· 44
dhcp relay release ip· 44
dhcp relay server-address· 45
display dhcp relay check mac-address· 46
display dhcp relay client-information· 46
display dhcp relay information· 48
display dhcp relay server-address· 49
display dhcp relay statistics· 50
gateway-list 51
reset dhcp relay client-information· 52
reset dhcp relay statistics· 52
DHCP client commands· 53
dhcp client dad enable· 53
dhcp client dscp· 54
dhcp client identifier 54
display dhcp client 55
ip address dhcp-alloc· 57
DHCP snooping commands· 58
dhcp snooping binding database filename· 58
dhcp snooping binding database update interval 60
dhcp snooping binding database update now· 60
dhcp snooping binding record· 61
dhcp snooping check mac-address· 61
dhcp snooping check request-message· 62
dhcp snooping deny· 63
dhcp snooping enable· 63
dhcp snooping information circuit-id· 64
dhcp snooping information enable· 66
dhcp snooping information remote-id· 66
dhcp snooping information strategy· 67
dhcp snooping log enable· 68
dhcp snooping max-learning-num·· 69
dhcp snooping rate-limit 69
dhcp snooping trust 70
display dhcp snooping binding· 71
display dhcp snooping binding database· 72
display dhcp snooping information· 73
display dhcp snooping packet statistics· 74
display dhcp snooping trust 75
reset dhcp snooping binding· 75
reset dhcp snooping packet statistics· 76
BOOTP client commands· 77
display bootp client 77
ip address bootp-alloc· 78
DHCP commands
dhcp dscp
Use dhcp dscp to set the DSCP value for DHCP packets sent by the DHCP server or the DHCP relay agent.
Use undo dhcp dscp to restore the default.
dhcp dscp dscp-value
undo dhcp dscp
The DSCP value in DHCP packets is 56.
dscp-value: Sets the DSCP value for DHCP packets, in the range of 0 to 63.
The DSCP value of a packet specifies the priority level of the packet and affects the transmission priority of the packet. A bigger DSCP value represents a higher priority.
# Set the DSCP value for DHCP packets to 30.
[Sysname] dhcp dscp 30
dhcp enable
Use dhcp enable to enable DHCP.
Use undo dhcp enable to disable DHCP.
dhcp enable
undo dhcp enable
DHCP is disabled.
Enable DHCP before you perform DHCP server or relay agent configurations.
# Enable DHCP.
[Sysname] dhcp enable
dhcp select
Use dhcp select to enable the DHCP server or DHCP relay agent on an interface.
Use undo dhcp select to disable the DHCP server or DHCP relay agent on an interface. The interface discards DHCP packets.
dhcp select { relay | server }
undo dhcp select { relay | server }
The interface operates in DHCP server mode and responds to DHCP requests with configuration parameters.
Layer 3 interface view
relay: Enables the DHCP relay agent on the interface.
server: Enables the DHCP server on the interface.
Before enabling the DHCP relay agent on an interface, use the reset dhcp server ip-in-use command to remove address bindings and authorized ARP entries. These authorized ARP entries might conflict with ARP entries that are created after the DHCP relay agent is enabled.
# Enable the DHCP relay agent on VLAN-interface 2.
[Sysname-Vlan-interface2] dhcp select relay
address range
Use address range to configure an IP address range in a DHCP address pool for dynamic allocation.
Use undo address range to remove the IP address range in the address pool.
undo address range
No IP address range is configured.
DHCP address pool view
start-ip-address: Specifies the start IP address.
end-ip-address: Specifies the end IP address.
If no IP address range is specified, all IP addresses in the subnet specified by the network command in address pool view are assignable. If an IP address range is specified, only the IP addresses in the IP address range are assignable.
After you use the address range command, you cannot use the network secondary command to specify a secondary subnet in the address pool.
If you use the command multiple times, the most recent configuration takes effect.
The address range specified by the address range command must be within the subnet specified by the network command. The addresses out of the address range cannot be assigned.
# Specify an address range of 192.168.8.1 through 192.168.8.150 in address pool 1.
[Sysname] dhcp server ip-pool 1
[Sysname-dhcp-pool-1] address range 192.168.8.1 192.168.8.150
·     class
·     dhcp class
·     display dhcp server pool
·     network
bims-server
Use bims-server to specify the IP address, port number, and shared key of the BIMS server in a DHCP address pool.
Use undo bims-server to remove the specified BIMS server information.
bims-server ip ip-address [ port port-number ] sharekey { cipher | simple } key
undo bims-server
No BIMS server information is specified.
ip ip-address: Specifies the IP address of the BIMS server.
port port-number: Specifies the port number of the BIMS server, in the range of 1 to 65534.
cipher: Sets a ciphertext key.
simple: Sets a plaintext key.
key: Specifies the key string. This argument is case sensitive. If simple is specified, it must be a string of 1 to 16 characters. If cipher is specified, it must be a ciphertext string of 1 to 53 characters. The DHCP client uses the shared key to encrypt packets sent to the BIMS server.
If you use this command multiple times, the most recent configuration takes effect.
For security purposes, all passwords, including passwords configured in plaintext, are saved in ciphertext.
# Specify the BIMS server IP address 1.1.1.1, port number 80, and shared key aabbcc in address pool 0.
[Sysname] dhcp server ip-pool 0
[Sysname-dhcp-pool-0] bims-server ip 1.1.1.1 port 80 sharekey simple aabbcc
bootfile-name
Use bootfile-name to specify a configuration file name or URL.
Use undo bootfile-name to remove the configuration file name or URL.
bootfile-name { bootfile-name | url }
undo bootfile-name
No configuration file name or URL is specified.
bootfile-name: Specifies the configuration file name, a case-sensitive string of 1 to 63 characters.
url: Specifies the configuration file URL in the format of http://. It is a case-sensitive string of 1 to 63 characters.
If you use the bootfile-name command multiple times, the most recent configuration takes effect.
If the configuration file is on a TFTP server, specify the configuration file name, and the IP address or name of the TFTP server.
If the configuration file is on an HTTP server, specify the configuration file URL.
# Specify the configuration file name boot.cfg in DHCP address pool 0.
[Sysname-dhcp-pool-0] bootfile-name boot.cfg
# Specify the configuration file URL http://10.1.1.1/boot.cfg in DHCP address pool 0.
[Sysname-dhcp-pool-0] bootfile-name http://10.1.1.1/boot.cfg
·     next-server
·     tftp-server domain-name
·     tftp-server ip-address
class
Use class to specify an IP address range for a DHCP user class.
Use undo class to remove the IP address range for the DHCP user class.
undo class class-name
No IP address range is specified for a DHCP user class.
class-name: Specifies the name of a DHCP user class, a case-insensitive string of 1 to 63 characters. If the specified user class does not exist, the DHCP server will not assign the addresses in the address range specified for the user class to any client.
The class command enables you to divide an address range into multiple address ranges for different DHCP user classes. The address range for a user class must be within the primary subnet specified by the network command. If the DHCP client does not match any DHCP user class, the DHCP server selects an address in the IP address range specified by the address range command. If the address range has no assignable IP addresses or no address range is configured, the address allocation fails.
You can specify only one address range for a DHCP user class in an address pool. If you use the class command multiple times for a DHCP user class, the most recent configuration takes effect.
After you specify an address range for a user class, you cannot use the network secondary command to specify a secondary subnet in the address pool.
# Specify an IP address range of 192.168.8.1 through 192.168.8.150 for the DHCP user class user in DHCP address pool 1.
[Sysname-dhcp-pool-1] class user range 192.168.8.1 192.168.8.150
·     address range
·     dhcp class
dhcp class
Use dhcp class to create a DHCP user class and enter the DHCP user class view.
Use undo dhcp class to remove the specified user class.
dhcp class class-name
undo dhcp class class-name
No DHCP user class exists.
You can also use this command to enter the view of an existing DHCP user class.
In the DHCP user class view, use the if-match command to configure a match rule to match specific clients. Then use the class command to specify an IP address range for the matching clients.
# Create a DHCP user class test and enter DHCP user class view.
[Sysname] dhcp class test
[Sysname-dhcp-class-test]
·     address range
·     class
·     if-match
Use dhcp server always-broadcast to enable the DHCP server to broadcast all responses.
Use undo dhcp server always-broadcast to restore the default.
The DHCP server reads the broadcast flag in a DHCP request to decide whether to broadcast or unicast the response.
This command enables the DHCP server to ignore the broadcast flag in DHCP requests and broadcast all responses.
The DHCP server always unicasts a response in the following situations, regardless of whether this command is executed:
·     The DHCP request is from a DHCP client that has an IP address (the ciaddr field is not 0).
·     The DHCP request is forwarded by a DHCP relay agent from a DHCP client (the giaddr field is not 0).
# Enable the DHCP server to broadcast all responses.
[Sysname] dhcp server always-broadcast
Use dhcp server apply ip-pool to apply an address pool on an interface.
Use undo dhcp server apply ip-pool to remove the configuration.
No address pool is applied on an interface
pool-name: Specifies the name of a DHCP address pool, a case-insensitive string of 1 to 63 characters.
Upon receiving a DHCP request from the interface, the DHCP server searches for a static binding for the client from all address pools. If no static binding is found, the server assigns configuration parameters from the address pool applied on the interface to the client. If the address pool has no assignable IP address or does not exist, the DHCP client cannot obtain an IP address.
# Apply DHCP address pool 0 on VLAN-interface 2.
[Sysname-Vlan-interface2] dhcp server apply ip-pool 0
dhcp server ip-pool
Use dhcp server bootp ignore to configure the DHCP server to ignore BOOTP requests.
Use undo dhcp server bootp ignore to restore the default.
The DHCP server does not ignore BOOTP requests.
The lease duration of IP addresses obtained by BOOTP clients is unlimited. For scenarios that do not allow unlimited leases, you can configure the DHCP server to ignore BOOTP requests.
# Configure the DHCP server to ignore BOOTP requests.
[Sysname] dhcp server bootp ignore
Use dhcp server bootp reply-rfc-1048 to enable the DHCP server to send BOOTP responses in RFC 1048 format when it receives RFC 1048-incompliant BOOTP requests for statically bound addresses.
Use undo dhcp server bootp reply-rfc-1048 to disable this feature.
This feature is disabled.
Not all BOOTP clients can send requests compliant with RFC 1048. By default, the DHCP server does not process the Vend field of RFC 1048-incompliant requests but copies the Vend field into responses.
This command enables the DHCP server to fill the Vend field in RFC 1048-compliant format in DHCP responses to RFC 1048-incompliant requests sent by BOOTP clients.
This command takes effect only when the BOOTP clients request statically bound addresses.
# Enable the DHCP server to send BOOTP responses in RFC 1048 format upon receiving BOOTP requests incompliant with RFC 1048.
[Sysname] dhcp server bootp reply-rfc-1048
Use dhcp server forbidden-ip to exclude specific IP addresses from dynamic allocation.
Use undo dhcp server forbidden-ip to remove the configuration.
dhcp server forbidden-ip start-ip-address [ end-ip-address ]
undo dhcp server forbidden-ip start-ip-address [ end-ip-address ]
No IP addresses are excluded from dynamic allocation.
end-ip-address: Specifies the end IP address, which cannot be lower than the start-ip-address. If you do not specify this argument, only the start-ip-address is excluded from dynamic allocation.
The IP addresses of some devices such as the gateway and FTP server cannot be assigned to clients. Use this command to exclude such addresses from dynamic allocation.
You can use this command multiple times to exclude multiple IP address ranges from dynamic allocation.
If the excluded IP address is in a static binding, the address can be still assigned to the client.
The address or address range specified in the undo dhcp server forbidden-ip command must be the same as that specified in the dhcp server forbidden-ip command. To remove an IP address from the specified address range, you must remove the entire address range.
# Exclude the IP addresses of 10.110.1.1 through 10.110.1.63 from dynamic allocation.
[Sysname] dhcp server forbidden-ip 10.110.1.1 10.110.1.63
·     forbidden-ip
·     static-bind
dhcp server ip-pool
Use dhcp server ip-pool to create a DHCP address pool and enter its view.
Use undo dhcp server ip-pool to remove the specified DHCP address pool.
dhcp server ip-pool pool-name
undo dhcp server ip-pool pool-name
No DHCP address pool is created.
pool-name: Specifies the name for the DHCP address pool, a case-insensitive string of 1 to 63 characters used to uniquely identify this pool.
You can also use this command to enter the view of an existing DHCP address pool.
A DHCP address pool is used to store the configuration parameters to be assigned to DHCP clients.
# Create a DHCP address pool named pool1.
[Sysname] dhcp server ip-pool pool1
[Sysname-dhcp-pool-pool1]
·     dhcp server apply ip-pool
Use dhcp server ping packets to specify the maximum number of ping packets.
Use undo dhcp server ping packets to restore the default.
The maximum number of ping packets is 1.
number: Specifies the maximum number of ping packets, in the range of 0 to 10. To disable the address conflict detection, set the value to 0.
To avoid IP address conflicts, the DHCP server pings an IP address before assigning it to a DHCP client.
If a ping attempt succeeds, the server considers that the IP address is in use and picks a new IP address. If all the ping attempts are failed, the server assigns the IP address to the requesting DHCP client.
# Specify the maximum number of ping packets as 10.
[Sysname] dhcp server ping packets 10
·     dhcp server ping timeout
·     display dhcp server conflict
·     reset dhcp server conflict
Use dhcp server ping timeout to configure the ping response timeout time on the DHCP server.
Use undo dhcp server ping timeout to restore the default.
The ping response timeout time is 500 milliseconds.
milliseconds: Specifies the timeout time in the range of 0 to 10000 milliseconds. To disable the ping operation for address conflict detection, set the value to 0 milliseconds.
# Specify the response timeout time as 1000 milliseconds.
[Sysname] dhcp server ping timeout 1000
·     dhcp server ping packets
Use dhcp server relay information enable to enable the DHCP server to handle Option 82.
Use undo dhcp server relay information enable to configure the DHCP server to ignore Option 82.
The DHCP server handles Option 82.
Upon receiving a DHCP request that contains Option 82, the server copies the original Option 82 into the response. If the server is configured to ignore Option 82, the response will not contain Option 82.
# Configure the DHCP server to ignore Option 82.
[Sysname] undo dhcp server relay information enable
Use display dhcp server conflict to display information about IP address conflicts.
display dhcp server conflict [ ip ip-address ]
ip ip-address: Displays conflict information about the specified IP address. If you do not specify this option, this command displays information about all IP address conflicts.
The DHCP server generates IP address conflict information in the following situations:
·     Before assigning an IP address to a DHCP client, the DHCP server pings the IP address and discovers that another host is using the address.
·     The DHCP client sends a DECLINE packet to the DHCP server to inform the server of an IP address conflict.
·     The DHCP server discovers that the only assignable address in the address pool is its own IP address.
# Display information about all IP address conflicts.
<Sysname> display dhcp server conflict
IP address          Detect time
4.4.4.1             Apr 25 16:57:20 2007
4.4.4.2             Apr 25 17:00:10 2007
IP address
Conflicted IP address.
Detect time
Time when the conflict was discovered.
Use display dhcp server expired to display the lease expiration information.
display dhcp server expired [ ip ip-address | pool pool-name ]
ip ip-address: Displays lease expiration information about the specified IP address.
pool pool-name: Displays lease expiration information about the specified address pool. The pool name is a case-insensitive string of 1 to 63 characters.
If you do not specify any parameters, this command displays lease expiration information about all address pools.
DHCP assigns these expired IP addresses to DHCP clients when all available addresses have been assigned.
# Display all lease expiration information.
<Sysname> display dhcp server expired
IP address       Client-identifier/Hardware address    Lease expiration
4.4.4.6          3030-3066-2e65-3230-302e-3130-3234    Apr 25 17:10:47 2007
                 -2d45-7468-6572-6e65-7430-2f31
IP address
Expired IP address.
Client ID or MAC address.
Lease expiration
Time when the lease expired.
Use display dhcp server free-ip to display information about assignable IP addresses.
display dhcp server free-ip [ pool pool-name ]
pool pool-name: Displays assignable IP addresses in the specified address pool. The pool name is a case-insensitive string of 1 to 63 characters. If you do not specify an address pool, this command displays all assignable IP addresses for all address pools.
# Display assignable IP addresses in all address pools.
<Sysname> display dhcp server free-ip
Pool name: 1
  Network: 10.0.0.0 mask 255.0.0.0
    IP ranges from 10.0.0.10 to 10.0.0.100
    IP ranges from 10.0.0.105 to 10.0.0.255
  Secondary networks:
    10.1.0.0 mask 255.255.0.0
      IP ranges from 10.1.0.0 to 10.1.0.255
    10.2.0.0 mask 255.255.0.0
      IP Ranges from 10.2.0.0 to 10.2.0.255
Pool name: 2
  Network: 20.1.1.0 mask 255.255.255.0
    IP ranges from 20.1.1.0 to 20.1.1.255
Pool name
Name of the address pool.
Network
Assignable network.
IP ranges
Assignable IP address range.
Secondary networks
Assignable secondary networks.
·     address range
·     dhcp server ip-pool
·     network
Use display dhcp server ip-in-use to display binding information about assigned IP addresses.
display dhcp server ip-in-use [ ip ip-address | pool pool-name ]
ip ip-address: Displays binding information about the specified IP address.
pool pool-name: Displays binding information about the specified IP address pool. The pool name is a case-insensitive string of 1 to 63 characters.
If you do not specify any parameters, this command displays binding information about all assigned DHCP addresses.
If the lease deadline exceeds the year 2100, the lease expiration time is displayed as After 2100.
The binding information can be used by other security modules such as IP source guard only when the DHCP server is configured on the gateway of DHCP clients.
# Display binding information about all assigned DHCP addresses.
<Sysname> display dhcp server ip-in-use
IP address       Client identifier/    Lease expiration      Type
                 Hardware address
10.1.1.1         4444-4444-4444        Not used              Static(F)
10.1.1.2         3030-3030-2e30-3030-  May 1 14:02:49 2009   Auto(C)
                 662e-3030-3033-2d45-
                 7468-6572-6e65-74
10.1.1.3         1111-1111-1111        After 2100            Static(C)
IP address
IP address assigned.
Client identifier/Hardware address
Client ID or hardware address.
Lease expiration
Lease expiration time:
·     Exact time (May 1 14:02:49 2009 in this example)Time when the lease will expire.
·     Not usedThe IP address of the static binding has not been assigned to the specific client.
·     UnlimitedInfinite lease expiration time.
·     After 2100—The lease will expire after 2100.
Binding types:
·     Static(F)—A free static binding whose IP address has not been assigned.
·     Static(O)—An offered  static binding whose IP address has been selected and sent by the DHCP server in a DHCP-OFFER packet to the client. Static(C)—A committed static binding whose IP address has been assigned to the DHCP client.
·     Auto(O)—An offered temporary dynamic binding whose IP address has been dynamically selected by the DHCP server and sent in a DHCP-OFFER packet to the DHCP client.
·     Auto(C)—A committed dynamic binding whose IP address has been dynamically assigned to the DHCP client.
Use display dhcp server pool to display information about a DHCP address pool.
display dhcp server pool [ pool-name ]
pool-name: Displays information about the specified address pool. The pool name is a case-insensitive string of 1 to 63 characters. If you do not specify the pool-name argument, this command displays information about all address pools.
# Display information about all DHCP address pools.
<Sysname> display dhcp server pool
Pool name: 0
  Network 20.1.1.0 mask 255.255.255.0
  class a range 20.1.1.50 20.1.1.60
  bootfile-name abc.cfg
  dns-list 20.1.1.66 20.1.1.67 20.1.1.68
  domain-name www.aabbcc.com
  bims-server ip 192.168.0.51 sharekey cipher $c$3$K13OmQPi791YvQoF2Gs1E+65LOU=
  option 2 ip-address 1.1.1.1
  expired 1 2 3 0
Pool name: 1
  secondary networks:
    20.1.2.0 mask 255.255.255.0
    20.1.3.0 mask 255.255.255.0
  bims-server ip 192.168.0.51 port 50 sharekey cipher $c$3$K13OmQPi791YvQoF2Gs1E+65LOU=
  forbidden-ip 20.1.1.22 20.1.1.36 20.1.1.37
  forbidden-ip 20.1.1.22 20.1.1.23 20.1.1.24
  gateway-list 1.1.1.1 2.2.2.2 4.4.4.4
  nbns-list 5.5.5.5 6.6.6.6 7.7.7.7
  netbios-type m-node
  expired 1 0 0 0
Pool name: 2
  address range 20.1.1.1 to 20.1.1.15
  class departmentA range 20.1.1.20 to 20.1.1.29
  class departmentB range 20.1.1.30 to 20.1.1.40
  next-server 20.1.1.33
  tftp-server domain-name www.dian.org.cn
  tftp-server ip-address 192.168.0.120
  voice-config ncp-ip 10.1.1.2
  voice-config as-ip 10.1.1.5
  voice-config voice-vlan 3 enable
  voice-config fail-over 10.1.1.1 123*
  option 2 ip-address 1.1.1.3
  expired 1 0 0 0
Pool name: 3
  static bindings:
    ip-address 10.10.1.2 mask 255.0.0.0
      hardware-address 00e0-00fc-0001 ethernet
    ip-address 10.10.1.3 mask 255.0.0.0
      client-identifier aaaa-bbbb
  expired unlimited
Table 5 Command output
Pool name
Name of an address pool.
Network
Assignable network.
secondary networks
address range
Assignable address range.
DHCP user class and its address range.
static bindings
Static IP-to-MAC/client ID bindings.
option
Customized DHCP option.
expired
Lease duration: 1 2 3 4 in this example refers to 1 day 2 hours 3 minutes 4 seconds.
bootfile-name
Boot file name
dns-list
DNS server IP address.
domain-name
Domain name suffix.
bims-server
forbidden-ip
IP addresses excluded from dynamic allocation.
gateway-list
Gateway addresses.
nbns-list
WINS server addresses.
netbios-type
NetBIOS node type.
next-server
Next server IP address.
TFTP server name.
TFTP server address.
voice-config ncp-ip
Primary network calling processor address.
voice-config as-ip
Backup network calling processor address.
Voice VLAN.
Failover route.
Use display dhcp server statistics to display the DHCP server statistics.
display dhcp server statistics [ pool pool-name ]
pool pool-name: Specifies an address pool by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, this command displays information about all address pools.
# Display the DHCP server statistics.
<Sysname> display dhcp server statistics
    Pool number:                       1
    Pool utilization:                  0.39%
    Bindings:
      Automatic:                       1
      Manual:                          0
      Expired:                         0
    Conflict:                          1
    Messages received:                10
      DHCPDISCOVER:                    5
      DHCPREQUEST:                     3
      DHCPDECLINE:                     0
      DHCPRELEASE:                     2
      DHCPINFORM:                      0
      BOOTPREQUEST:                    0
    Messages sent:                     6
      DHCPOFFER:                       3
      DHCPACK:                         3
      DHCPNAK:                         0
      BOOTPREPLY:                      0
    Bad Messages:                      0
Table 6 Command output
Pool number
Total number of address pools. This field is not displayed when you display statistics for a specific address pool.
Pool utilization
Pool utilization rate:
·     If you display statistics for all address pools, this field displays the utilization rate of all address pools.
·     If you display statistics for an address pool, this field displays the pool utilization rate of the specified address pool.
Bindings
Bindings include the following types:
·     Automatic—Number of dynamic bindings.
·     Manual—Number of static bindings.
·     Expired—Number of expired bindings.
Conflict
Total number of conflict addresses. This field is not displayed if you display statistics for a specific address pool.
Messages received
DHCP packets received from clients:
·     DHCPDISCOVER.
·     DHCPREQUEST.
·     DHCPDECLINE.
·     DHCPRELEASE.
·     DHCPINFORM.
·     BOOTPREQUEST.
Messages sent
DHCP packets sent to clients:
·     DHCPOFFER.
·     DHCPACK.
·     DHCPNAK.
·     BOOTPREPLY.
This field is not displayed if statistics about a specific address pool are displayed.
Bad Messages
Number of bad messages. This field is not displayed if you display statistics for a specific address pool.
dns-list
Use dns-list to specify DNS server addresses in a DHCP address pool.
Use undo dns-list to remove DNS server addresses from a DHCP address pool.
dns-list ip-address&<1-8>
undo dns-list [ ip-address&<1-8> ]
No DNS server address is specified.
ip-address&<1-8>: Specifies a space-separated list of up to eight DNS servers.
If you use the dns-list command multiple times, the most recent configuration takes effect.
If you do not specify any parameters, the undo dns-list command deletes all DNS server addresses in the DHCP address pool.
# Specify the DNS server address 10.1.1.254 in DHCP address pool 0.
[Sysname-dhcp-pool-0] dns-list 10.1.1.254
domain-name
Use domain-name to specify a domain name in a DHCP address pool.
Use undo domain-name to remove the specified domain name.
domain-name domain-name
undo domain-name
No domain name suffix is specified.
domain-name: Specifies the domain name, a case-sensitive string of 1 to 50 characters.
# Specify the domain name company.com in address pool 0.
[Sysname-dhcp-pool-0] domain-name company.com
expired
Use expired to specify the lease duration in a DHCP address pool.
Use undo expired to restore the default lease duration for a DHCP address pool.
expired { day day [ hour hour [ minute minute [ second second ] ] ] | unlimited }
undo expired
The lease duration of a dynamic address pool is one day.
day day: Specifies the number of days, in the range of 0 to 365.
hour hour: Specifies the number of hours, in the range of 0 to 23.
minute minute: Specifies the number of minutes, in the range of 0 to 59.
second second: Specifies the number of seconds, in the range of 0 to 59.
unlimited: Specifies the unlimited lease duration, which is actually 136 years.
The DHCP server assigns an IP address together with the lease duration to the DHCP client. Before the lease expires, the DHCP client must extend the lease duration.
·     If the lease extension operation succeeds, the DHCP client can continue to use the IP address.
·     If the lease extension operation does not succeed, both of the following events occur:
¡     The DHCP client cannot use the IP address after the lease duration expires.
¡     The DHCP server will label the IP address as an expired address.
# Specify the lease duration as 1 day, 2 hours, 3 minutes, and 4 seconds in DHCP address pool 0.
[Sysname-dhcp-pool-0] expired day 1 hour 2 minute 3 second 4
·     display dhcp server expired
·     reset dhcp server expired
forbidden-ip
Use forbidden-ip to exclude IP addresses from dynamic allocation in an address pool.
Use undo forbidden-ip to cancel the configuration.
forbidden-ip ip-address&<1-8>
undo forbidden-ip [ ip-address&<1-8> ]
No IP addresses are excluded from dynamic allocation in an address pool.
ip-address&<1-8>: Specifies a space-separated list of up to eight excluded IP addresses.
The excluded IP addresses in an address pool are still assignable in other address pools.
You can exclude a maximum of 4096 IP addresses in an address pool.
If you do not specify any parameters, the undo forbidden-ip command deletes all excluded IP addresses.
# Exclude IP addresses 192.168.1.3 and 192.168.1.10 from dynamic allocation in DHCP address pool 0.
[Sysname-dhcp-pool-0] forbidden-ip 192.168.1.3 192.168.1.10
·     dhcp server forbidden-ip
gateway-list
Use gateway-list to specify gateway addresses in a DHCP address pool or a DHCP secondary subnet.
Use undo gateway-list to remove the specified gateway addresses from a DHCP address pool or a DHCP secondary subnet.
gateway-list ip-address&<1-8>
undo gateway-list [ ip-address&<1-8> ]
No gateway address is configured in a DHCP address pool or a DHCP secondary subnet.
DHCP address pool view, DHCP secondary subnet view
ip-address&<1-8>: Specifies a space-separated list of up to eight gateway addresses. Gateway addresses must reside on the same subnet as the assignable IP addresses.
If you do not specify any parameters, the undo gateway-list command deletes all gateway addresses.
The DHCP server assigns gateway addresses to clients on a secondary subnet in the following ways:
·     If gateways are specified in both address pool view and secondary subnet view, DHCP assigns those specified in the secondary subnet view.
·     If gateways are specified in address pool view but not in secondary subnet view, DHCP assigns those specified in address pool view.
# Specify the gateway address 10.1.1.1 in DHCP address pool 0.
[Sysname-dhcp-pool-0] gateway-list 10.1.1.1
if-match
Use if-match to configure a match rule for a DHCP user class.
Use undo if-match to remove the match rule for a DHCP user class.
if-match rule rule-number option option-code [ hex hex-string [ mask mask | offset offset length length ] ]
No match rule is configured for the DHCP user class.
rule rule-number: Assigns the match rule an ID in the range of 1 to 16. A smaller ID represents a higher match priority.
option option-code: Matches a DHCP option by a number in the range of 1 to 254.
hex hex-string: Matches the specified string in the option, which must be a hex string of even numbers in the range of 2 to 256. If you do not specify the hex-string argument, the DHCP server only checks whether the specified option exists in the received packets.
mask mask: Specifies the mask used to match the option content. The mask argument is a hex string of even numbers in the range of 2 to 256. The length of mask must be the same as that of hex-string.
offset offset: Specifies the offset to match the option, in the range of 0 to 254 bytes. If you do not specify the offset argument, the server matches the entire option with the rule.
length length: Matches the specified length of the option, in the range of 1 to 128 bytes. The specified length must be the same as the hex-string length.
You can configure multiple match rules for a DHCP user class. Each match rule is uniquely identified by a rule ID. Different match rules can include the same option code, but they cannot have the same matching criteria.
The DHCP server compares DHCP requests against the match rules. A DHCP client matches a DHCP user class when its request matches one of the specified match rules.
The match operation follows these guidelines:
·     If only the option-code argument is specified in the rule, packets containing the option match the rule.
·     If the option-code and hex-string arguments are specified in the rule, packets that have the specified hex string in the specified option match the rule.
·     If the option-code, hex-string, offset and length arguments are specified in the rule, packets match the rule as long as their content from offset+1 bit to offset+length bit in the specified option is the same as the specified hex string.
·     If the option-code, hex-string, and mask arguments are specified in the rule, the DHCP server ANDs the content from the first bit to the mask-1 bit in the specified option with the mask. Then the server compares the result with the result of the AND operation between hex-string and mask. If the two results are the same, the received packet matches the rule.
# Configure match rule 1 to match DHCP requests that contain Option 82 for DHCP user class exam.
[Sysname] dhcp class exam
[Sysname-dhcp-class-exam] if-match rule 1 option 82
# Configure match rule 2 to match DHCP requests that contain Option 82. Option 82's first three bytes are 0x13ae92 for the DHCP user class exam.
[Sysname-dhcp-class-exam] if-match rule 2 option 82 hex 13ae92 offset 0 length 3
# Configure match rule 3 to match DHCP requests that contain Option 82. Option 82's highest bit of the fourth byte is 1 for the DHCP user class exam.
[Sysname-dhcp-class-exam] if-match rule 3 option 82 hex 00000080 mask 00000080
dhcp class
nbns-list
Use nbns-list to specify WINS server addresses in a DHCP address pool.
Use undo nbns-list to remove the specified WINS server addresses.
nbns-list ip-address&<1-8>
undo nbns-list [ ip-address&<1-8> ]
No WINS server address is specified.
ip-address&<1-8>: Specifies a space-separated list of up to eight WINS server IP addresses.
If you do not specify any parameters, the undo nbns-list command deletes all WINS server addresses.
# Specify the WINS server IP address 10.1.1.1 in DHCP address pool 0.
[Sysname-dhcp-pool-0] nbns-list 10.1.1.1
·     netbios-type
netbios-type
Use netbios-type to specify the NetBIOS node type in a DHCP address pool.
Use undo netbios-type to remove the specified NetBIOS node type.
undo netbios-type
No NetBIOS node type is specified.
b-node: Specifies the broadcast node. A b-node client sends the destination name in a broadcast message to get the name-to-IP mapping from a server.
h-node: Specifies the hybrid node. An h-node client unicasts the destination name to a WINS server. If it does not receive a response, the h-node client broadcasts the destination name to get the mapping from a server.
m-node: Specifies the mixed node. An m-node client broadcasts the destination name. If it does not receive a response, the m-node client unicasts the destination name to the WINS server to get the mapping.
p-node: Specifies the peer-to-peer node. A p-node client sends the destination name in a unicast message to get the mapping from the WINS server.
# Specify the NetBIOS node type as p-node in DHCP address pool 0.
[Sysname-dhcp-pool-0] netbios-type p-node
·     nbns-list
network
Use network to specify the subnet for dynamic allocation in a DHCP address pool.
Use undo network to remove the specified subnet.
network network-address [ mask-length | mask mask ] [ secondary ]
undo network network-address [ mask-length | mask mask ] [ secondary ]
No subnet is specified in a DHCP address pool.
network-address: Specifies the subnet for dynamic allocation. If no mask length or mask is specified, the natural mask will be used.
mask-length: Specifies the mask length in the range of 1 to 30.
mask mask: Specifies the mask in dotted decimal format.
secondary: Specifies the subnet as a secondary subnet. If you do not specify this keyword, this command specifies the primary subnet. If the addresses in the primary subnet are used up, the DHCP server can select addresses from a secondary subnet for clients.
You can use the secondary keyword to specify a secondary subnet and enter its view. In secondary subnet view, you can specify gateways by using the gateway-list command for DHCP clients in the secondary subnet.
You can specify only one primary subnet for a DHCP address pool. If you use the network command multiple times, the most recent configuration takes effect.
You can specify up to 32 secondary subnets for a DHCP address pool.
The primary subnet and secondary subnets in a DHCP address pool must not have the same network address and mask.
If you have used the address range or class command in an address pool, you cannot specify a secondary subnet in the same address pool.
Modifying or removing the network configuration deletes the assigned addresses from the current address pool.
# Specify primary subnet 192.168.8.0/24 and secondary subnet 192.168.10.0/24 in DHCP address pool 0.
[Sysname-dhcp-pool-0] network 192.168.8.0 mask 255.255.255.0
[Sysname-dhcp-pool-0] network 192.168.10.0 mask 255.255.255.0 secondary
[Sysname-dhcp-pool-0-secondary]
·     gateway-list
next-server
Use next-server to specify the IP address of a server in a DHCP address pool.
Use undo next-server to remove the server's IP address from the DHCP address pool.
next-server ip-address
undo next-server
No server's IP address is specified in an address pool.
ip-address: Specifies the IP address of a server.
Upon startup, the DHCP client obtains an IP address and the specified server IP address. Then it contacts the specified server, such as a TFTP server, to get other boot information.
If you use the next-server command multiple times, the most recent configuration takes effect.
# Specify a server's IP address 10.1.1.254 in DHCP address pool 0.
[Sysname-dhcp-pool-0] next-server 10.1.1.254
option
Use option to customize a DHCP option.
Use undo option to remove a customized DHCP option.
undo option code
No DHCP option is customized.
code: Specifies the number of the customized option, in the range of 2 to 254, excluding 50 through 54, 56, 58, 59, 61, and 82.
ascii ascii-string: Specifies an ASCII string of 1 to 255 characters as the option content.
hex hex-string: Specifies a hex string of even numbers from 2 to 256 as the option content.
ip-address ip-address&<1-8>: Specifies a space-separated list of up to eight IP addresses as the option content.
The DHCP server fills the customized option with the specified ASCII string, hex string, or IP addresses, and sends it in a response to the client.
If you use the option command with the same code specified, the most recent configuration takes effect.
You can customize options for the following purposes:
·     Add newly released options.
·     Add options for which the vendor defines the contents, for example, Option 43.
·     Add options for which the CLI does not provide a dedicated configuration command. For example, you can use the option 4 ip-address 1.1.1.1 command to define the time server address 1.1.1.1 for DHCP clients.
·     Add all option values if the actual requirement exceeds the limit for a dedicated option configuration command. For example, the dns-list command can specify up to eight DNS servers. To specify more than eight DNS server, you must use the option 6 command to define all DNS servers.
If a DHCP option is specified by both the dedicated command and the option command, the DHCP server assigns the content specified by the dedicated command. For example, if a DNS server address is specified by both the dns-list command and the option 6 command, the server uses the address specified by the dns-list command.
# Configure Option 7 to specify the log server address 2.2.2.2 in address pool 0.
[Sysname-dhcp-pool-0] option 7 ip-address 2.2.2.2
Use reset dhcp server conflict to clear IP address conflict information.
reset dhcp server conflict [ ip ip-address ]
ip ip-address: Clears conflict information about the specified IP address. If you do not specify this option, this command clears all address conflict information.
Address conflicts occur when dynamically assigned IP addresses have been statically configured for other hosts. After you modify the address pool configuration, the conflicted addresses might become assignable. To assign these addresses, use the reset dhcp server conflict command to clear the conflict information first.
# Clear all IP address conflict information.
<Sysname> reset dhcp server conflict
Use reset dhcp server expired to clear binding information about expired IP addresses.
reset dhcp server expired [ ip ip-address | pool pool-name ]
ip ip-address: Clears binding information about the specified expired IP address.
pool pool-name: Clears binding information about the expired IP addresses in the specified address pool. The pool name is a case-insensitive string of 1 to 63 characters.
If you do not specify any parameters, this command clears binding information about all expired IP addresses.
# Clear binding information about all expired IP addresses.
<Sysname> reset dhcp server expired
Use reset dhcp server ip-in-use to clear binding information about assigned IP addresses.
reset dhcp server ip-in-use [ ip ip-address | pool pool-name ]
ip ip-address: Clears binding information about the specified assigned IP address.
pool pool-name: Clears binding information about the specified address pool. The pool name is a case-insensitive string of 1 to 63 characters.
If you do not specify any parameters, this command clears binding information about all assigned IP addresses.
If you use this command to clear information about an assigned static binding, the static binding becomes an unassigned static binding.
# Clear binding information about the IP address 10.110.1.1.
<Sysname> reset dhcp server ip-in-use ip 10.110.1.1
Use reset dhcp server statistics to clear DHCP server statistics.
# Clear DHCP server statistics.
<Sysname> reset dhcp server statistics
static-bind
Use static-bind to statically bind a client ID or MAC address to an IP address.
Use undo static-bind to remove a static binding.
undo static-bind ip-address ip-address
No static binding is specified in a DHCP address pool.
ip-address ip-address: Specifies the IP address of the static binding. The natural mask is used if no mask length or mask is specified.
mask mask: Specifies the mask, in dotted decimal format.
client-identifier client-identifier: Specifies the client ID of the static binding, a string of 4 to 254 characters. The string can contain only hexadecimal numbers and hyphen (-), in the format of H-H-H…. The last H can be a two-digit or four-digit hexadecimal number while the other Hs must be all four-digit hexadecimal numbers. For example, aabb-cccc-dd is correct, and aabb-c-dddd and aabb-cc-dddd are not correct.
hardware-address hardware-address: Specifies the client hardware address of the static binding, a string of 4 to 39 characters. The string can contain only hexadecimal numbers and hyphen (-), in the format of H-H-H…. The last H can be a two-digit or four-digit hexadecimal number while the other Hs must be all four-digit hexadecimal numbers. For example, aabb-cccc-dd is correct, and aabb-c-dddd and aabb-cc-dddd are not correct.
ethernet: Specifies the client hardware address type as Ethernet. The default type is Ethernet.
token-ring: Specifies the client hardware address type as token ring.
The IP address of a static binding must not be an interface address of the DHCP server. Otherwise, an IP address conflict occurs, and the bound client cannot obtain the IP address.
You can specify multiple static bindings in an address pool. The total number of static bindings in all address pools cannot exceed 8192.
You cannot modify bindings. To change the binding for a DHCP client, you must delete the existing binding first and create a new binding.
# Bind the IP address 10.1.1.1/24 to the client ID 00aa-aabb in DHCP address pool 0.
[Sysname-dhcp-pool-0] static-bind ip-address 10.1.1.1 mask 255.255.255.0 client-identifier 00aa-aabb
Use tftp-server domain-name to specify a TFTP server name in a DHCP address pool.
Use undo tftp-server domain-name to remove the TFTP server name from a DHCP address pool.
No TFTP server name is specified.
domain-name: Specifies the TFTP server name, a case-sensitive string of 1 to 63 characters.
# Specify the TFTP server name aaa in DHCP address pool 0.
[Sysname-dhcp-pool-0] tftp-server domain-name aaa
Use tftp-server ip-address to specify a TFTP server address in a DHCP address pool.
Use undo tftp-server ip-address to remove the TFTP server address from a DHCP address pool.
No TFTP server address is specified.
ip-address: Specifies the IP address of a TFTP server.
# Specify the TFTP server address 10.1.1.1 in DHCP address pool 0.
[Sysname-dhcp-pool-0] tftp-server ip-address 10.1.1.1
voice-config
Use voice-config to configure the content for Option 184 in a DHCP address pool.
Use undo voice-config to remove the Option 184 content from a DHCP address pool.
voice-config { as-ip ip-address | fail-over ip-address dialer-string | ncp-ip ip-address | voice-vlan vlan-id { disable | enable } }
undo voice-config [ as-ip | fail-over | ncp-ip | voice-vlan ]
No Option 184 content is configured in a DHCP address pool.
as-ip ip-address: Specifies the IP address of the backup network calling processor.
fail-over ip-address dialer-string: Specifies the failover IP address and dialer string. The dialer-string is a string of 1 to 39 characters, which can include numbers 0 through 9 and asterisk (*).
ncp-ip ip-address: Specifies the IP address of the primary network calling processor.
voice-vlan vlan-id: Specifies the voice VLAN ID in the range of 2 to 4094.
·     disable: Disables the specified VLAN. DHCP clients will not take this VLAN as their voice VLAN.
·     enable: Enables the specified VLAN. DHCP clients will take this VLAN as their voice VLAN.
# Configure Option 184 in DHCP address pool 0. The primary and backup network calling processors are at 10.1.1.1 and 10.2.2.2, respectively. The voice VLAN 3 is enabled. The failover IP address is 10.3.3.3. The dialer string is 99*.
[Sysname-dhcp-pool-0] voice-config ncp-ip 10.1.1.1
[Sysname-dhcp-pool-0] voice-config as-ip 10.2.2.2
[Sysname-dhcp-pool-0] voice-config voice-vlan 3 enable
[Sysname-dhcp-pool-0] voice-config fail-over 10.3.3.3 99*
Use dhcp relay check mac-address to enable MAC address check on the relay agent.
Use undo dhcp relay check mac-address to disable MAC address check on the relay agent.
The MAC address check feature is disabled.
This feature enables the DHCP relay agent to compare the chaddr field of a received DHCP request with the source MAC address in the frame header. If they are the same, the DHCP relay agent forwards the request to the DHCP server. If they are not the same, the DHCP relay agent discards the request.
The MAC address check feature takes effect only when the dhcp select relay command has already been configured on the interface.
Enable the MAC address check feature only on the DHCP relay agent directly connected to the DHCP clients. A DHCP relay agent changes the source MAC address of DHCP packets before sending them. If you enable this feature on an intermediate relay agent, it might discard valid DHCP packet, and the sending clients will not obtain IP addresses.
# Enable MAC address check on the relay agent.
[Sysname-Vlan-interface10] dhcp relay check mac-address
dhcp select relay
Use dhcp relay check mac-address aging time to configure the aging time for MAC address check entries on the DHCP relay agent.
Use undo dhcp relay check mac-address aging time to restore the default.
undo dhcp relay check mac-address aging-time
The aging time is 30 seconds.
time: Specifies the aging time for MAC address check entries in seconds, in the range of 30 to 600.
This command takes effect only after you execute the dhcp relay check mac-address command.
# Set the aging time for MAC address check entries on the DHCP relay agent to 60 seconds.
[Sysname] dhcp relay check mac-address aging-time 60
Use dhcp relay client-information record to enable recording client information in relay entries. A relay entry contains information about a client such as the client's IP and MAC addresses.
Use undo dhcp relay client-information record to disable the feature.
The DHCP relay agent does not record client information in relay entries.
Disabling recording of client information deletes all recorded relay entries.
Client information is recorded only when the DHCP relay agent is configured on the gateway of DHCP clients.
# Enable recording of relay entries on the relay agent.
[Sysname] dhcp relay client-information record
·     dhcp relay client-information refresh
·     dhcp relay client-information refresh enable
Use dhcp relay client-information refresh to configure the interval at which the DHCP relay agent periodically refreshes relay entries.
Use undo dhcp relay client-information refresh to restore the default.
dhcp relay client-information refresh [ auto | interval interval ]
The refresh interval is automatically calculated based on the number of relay entries.
auto: Automatically calculates the refresh interval. The more the entries, the shorter the refresh interval. The shortest interval will not be less than 50 ms.
interval interval: Specifies the refresh interval in the range of 1 to 120 seconds.
# Set the refresh interval to 100 seconds.
[Sysname] dhcp relay client-information refresh interval 100
·     dhcp relay client-information record
Use dhcp relay client-information refresh enable to enable the DHCP relay agent to periodically refresh dynamic relay entries.
Use undo dhcp relay client-information refresh enable to disable the DHCP relay agent to periodically refresh dynamic relay entries.
The DHCP relay agent periodically refreshes relay entries.
A DHCP client unicasts a DHCP-RELEASE message to the DHCP server to release its IP address. The DHCP relay agent conveys the message to the DHCP server and does not remove the IP-to-MAC entry of the client.
With this feature, the DHCP relay agent uses a client's IP address and the relay interface's MAC address to periodically send a DHCP-REQUEST message to the DHCP server.
·     If the server returns a DHCP-ACK message or does not return any message within an interval, the DHCP relay agent performs the following operations:
¡     Removes the relay entry.
¡     Sends a DHCP-RELEASE message to the DHCP server to release the IP address.
·     If the server returns a DHCP-NAK message, the relay agent keeps the entry.
With this feature disabled, the DHCP relay agent does not remove relay entries automatically. After a DHCP client releases its IP address, you must use the reset dhcp relay client-information on the relay agent to remove the corresponding relay entry.
# Disable periodic refresh of relay entries.
[Sysname] undo dhcp relay client-information refresh enable
·     reset dhcp relay client-information
Use dhcp relay information circuit-id to configure the padding mode and padding format for the Circuit ID sub-option of Option 82.
Use undo dhcp relay information circuit-id to restore the default.
dhcp relay information circuit-id { string circuit-id | { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] } [ format { ascii | hex } ] }
The padding mode is normal and the padding format is hex.
string circuit-id: Specifies the string mode that uses a case-sensitive string of 3 to 63 characters as the content of the Circuit ID sub-option.
normal: Specifies the normal mode, in which the padding content consists of the VLAN ID and port number.
verbose: Specifies the verbose mode. The padding content includes the node identifier, interface information, and VLAN ID.
node-identifier { mac | sysname | user-defined node-identifier }: Specifies the access node identifier.
·     mac: Uses the MAC address of the access node as the node identifier. It is the default node identifier.
·     sysname: Uses the device name as the node identifier. You can set the device name by using the sysname command in system view. The padding format for the device name is always ASCII regardless of the specified padding format.
If sysname is used as the node identifier, do not include any spaces when you set the device name. Otherwise, the DHCP relay agent fails to add or replace Option 82.
·     user-defined node-identifier: Uses a case-sensitive string of 1 to 50 characters as the node identifier. The padding format for the specified character string is always ASCII regardless of the specified padding format.
format: Specifies the padding format for the Circuit ID sub-option.
ascii: Specifies the padding format as ASCII.
hex: Specifies the padding format as hex.
The Circuit ID sub-option cannot carry information about interface splitting. For more information about interface splitting, see Interface Configuration Guide.
The padding format for the user-defined string, the normal mode, or the verbose mode varies by command configuration. Table 7 shows how the padding format is determined for different modes.
Table 7 Padding format for different modes
Keyword (mode)
If no padding format is specified
If the padding format is ascii
If the padding format is hex
string circuit-id
You cannot specify a padding format, and the padding format is always ASCII.
N/A
N/A
normal
Hex.
ASCII.
Hex.
verbose
Hex for the VLAN ID.
ASCII for the node identifier, Ethernet type, chassis number, slot number, sub-slot number, and interface number.
ASCII.
ASCII for the node identifier and Ethernet type.
Hex for the chassis number, slot number, sub-slot number, interface number, and VLAN ID.
# Specify the content mode as verbose, node identifier as the device name, and the padding format as ASCII for the Circuit ID sub-option.
[Sysname-Vlan-interface10] dhcp relay information enable
[Sysname-Vlan-interface10] dhcp relay information strategy replace
[Sysname-Vlan-interface10] dhcp relay information circuit-id verbose node-identifier sysname format ascii
·     dhcp relay information enable
·     dhcp relay information strategy
·     display dhcp relay information
Use dhcp relay information enable to enable the DHCP relay agent to support Option 82.
Use undo dhcp relay information enable to disable Option 82 support.
The DHCP relay agent does not support Option 82.
This command enables the DHCP relay agent to add Option 82 to DHCP requests that do not contain Option 82 before forwarding the requests to the DHCP server. The content of Option 82 is determined by the dhcp relay information circuit-id and dhcp relay information remote-id commands. If the DHCP requests contain Option 82, the relay agent handles the requests according to the strategy configured with the dhcp relay information strategy command.
If this feature is disabled, the relay agent forwards requests that contain or do not contain Option 82 to the DHCP server.
# Enable Option 82 support on the relay agent.
·     dhcp relay information circuit-id
·     dhcp relay information remote-id
Use dhcp relay information remote-id to configure the padding mode and padding format for the Remote ID sub-option of Option 82.
Use undo dhcp relay information remote-id to restore the default.
normal: Specifies the normal mode in which the padding content is the MAC address of the receiving interface.
format: Specifies the padding format for the Remote ID sub-option. The default padding format is hex.
hex: Specifies the padding format as Hex.
string remote-id: Specifies the string mode that uses a case-sensitive string of 1 to 63 characters as the content of the Remote ID sub-option.
sysname: Specifies the sysname mode that uses the device name as the content of the Remote ID sub-option. You can set the device name by using the sysname command.
The padding format for the specified character string (string) or the device name (sysname) is always ASCII. The padding format for the normal mode is determined by the command.
# Specify the padding content for the Remote ID sub-option of Option 82 as device001.
[Sysname-Vlan-interface10] dhcp relay information remote-id string device001
Use dhcp relay information strategy to configure the strategy for the DHCP relay agent to handle messages containing Option 82.
Use undo dhcp relay information strategy to restore the default handling strategy.
The handling strategy for messages that contain Option 82 is replace.
drop: Drops DHCP messages that contain Option 82 messages.
keep: Keeps the original Option 82 intact.
replace: Replaces the original Option 82 with the configured Option 82.
This command takes effect only on DHCP requests that contain Option 82.
For DHCP requests that do not contain Option 82, the DHCP relay agent always adds Option 82 to the requests before forwarding the requests to the DHCP server.
# Specify the handling strategy for Option 82 as keep.
[Sysname-Vlan-interface10] dhcp relay information strategy keep
dhcp relay release ip
Use dhcp relay release ip to release a specific client IP address.
dhcp relay release ip client-ip [ vpn-instance vpn-instance-name ]
client-ip: Specifies the IP address to be released.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance of the IP address. The vpn-instance-name is a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command releases the IP address in the public network.
After you execute this command, the relay agent sends a DHCP-RELEASE packet to the DHCP server and removes the relay entry of the IP address. Upon receiving the packet, the server removes binding information about the specified IP address to release the IP address.
# Release the IP address 1.1.1.1.
[Sysname] dhcp relay release ip 1.1.1.1
dhcp relay server-address
Use dhcp relay server-address to specify DHCP servers on the DHCP relay agent.
Use undo dhcp relay server-address to remove DHCP servers.
dhcp relay server-address ip-address
undo dhcp relay server-address [ ip-address ]
No DHCP server is specified on the relay agent.
Layer 3 interface view
ip-address: Specifies the IP address of a DHCP server. The DHCP relay agent forwards DHCP packets received from DHCP clients to this DHCP server.
The specified IP address of the DHCP server must not reside on the same subnet as the IP address of the DHCP relay agent interface. Otherwise, the DHCP clients might fail to obtain IP addresses.
You can specify a maximum of eight DHCP servers on an interface. The DHCP relay agent forwards the packets from the clients to all the specified DHCP servers.
If you do not specify an IP address, the undo dhcp relay server-address command removes all DHCP servers on the interface.
# Specify the DHCP server 1.1.1.1 on the relay agent interface VLAN-interface 10.
[Sysname-Vlan-interface10] dhcp relay server-address 1.1.1.1
·     dhcp select relay
·     display dhcp relay interface
display dhcp relay check mac-address
Use display dhcp relay check mac-address to display MAC address check entries on the relay agent.
# Display MAC address check entries on the DHCP relay agent.
<Sysname> display dhcp relay check mac-address
Source-MAC        Interface                 Aging-time
23f3-1122-adf1    GE1/0/1                   10
23f3-1122-2230    GE1/0/2                   30
Table 8 Command output
Source MAC
Source MAC address of the attacker.
Interface where the attack comes from.
Aging-time
Aging time of the MAC address check entry, in seconds.
display dhcp relay client-information
Use display dhcp relay client-information to display relay entries on the relay agent.
interface interface-type interface-number: Displays relay entries on the specified interface.
ip ip-address: Displays the relay entry for the specified IP address.
vpn-instance vpn-instance-name: Displays the relay entry for the specified IP address in the specified MPLS L3VPN instance. The vpn-instance-name is a case-sensitive string of 1 to 31 characters.
The DHCP relay agent records relay entries only when the dhcp relay client-information record command has been issued.
If you do not specify any parameters, the display dhcp relay client-information command displays all relay entries on the relay agent.
# Display all relay entries on the relay agent.
<Sysname> display dhcp relay client-information
Total number of client-information items: 2
Total number of dynamic items: 1
Total number of temporary items: 1
IP address       MAC address      Type        Interface            VPN name
10.1.1.1         00e0-0000-0001   Dynamic     GE1/0/1              VPN1
10.1.1.5         00e0-0000-0000   Temporary   Vlan2                VPN2
Table 9 Command output
Total number of relay entries.
Total number of dynamic relay entries.
Total number of temporary relay entries.
IP address
IP address of the DHCP client.
MAC address
MAC address of the DHCP client.
Relay entry type:
·     Dynamic—The relay agent creates a dynamic relay entry upon receiving an ACK response from the DHCP server.
·     Temporary—The relay agent creates a temporary relay entry upon receiving a REQUEST packet from a DHCP client.
Layer 3 interface connected to the DHCP client. N/A is displayed for relay entries without interface information.
VPN name
Name of the VPN instance to which the DHCP client belongs. If the DHCP client does not belong to any VPN, this field displays N/A.
Use display dhcp relay information to display Option 82 configuration information for the DHCP relay agent.
interface interface-type interface-number: Displays Option 82 configuration information for the specified interface. If you do not specify an interface, this command displays Option 82 configuration information about all interfaces.
# Display Option 82 configuration information for all interfaces.
<Sysname> display dhcp relay information
Interface: Vlan-interface100
   Status: Enable
   Strategy: Replace
   Circuit ID Pattern: Verbose
   Remote ID Pattern: Sysname
   Circuit ID format-type: Undefined
   Remote ID format-type: ASCII
   Node identifier: aabbcc
Interface: Vlan-interface200
   Status: Enable
   Strategy: Replace
   Circuit ID Pattern: User Defined
   Remote ID Pattern: User Defined
   Circuit ID format-type: ASCII
   User defined:
   Circuit ID: vlan100
   Remote ID: device001
Table 10 Command output
Interface name.
Status
Option 82 states:
·     EnableDHCP relay agent support for Option 82 is enabled.
·     DisableDHCP relay agent support for Option 82 is disabled.
Strategy
Handling strategy for request messages containing Option 82, Drop, Keep, or Replace.
Circuit ID Pattern
Padding content mode of the Circuit ID sub-option, Verbose, Normal, or User Defined.
Remote ID Pattern
Padding content mode of the Remote ID sub-option, Sysname, Normal, or User Defined.
Padding format of the Circuit ID sub-option, ASCII, Hex, or Undefined.
Padding format of the Remote ID sub-option, ASCII, Hex, or Undefined.
Node identifier
Access node identifier.
User defined
Content of the user-defined sub-options.
Circuit ID
User-defined content of the Circuit ID sub-option.
Remote ID
User-defined content of the Remote ID sub-option.
display dhcp relay server-address
Use display dhcp relay server-address to display DHCP server addresses configured on an interface.
interface interface-type interface-number: Displays DHCP server addresses on the specified interface. If you do not specify an interface, this command displays DHCP server addresses on all interfaces.
# Display DHCP server addresses on all interfaces.
<Sysname> display dhcp relay server-address
Interface name                 Server IP address
GE1/0/1                        2.2.2.2
Table 11 Command output
Interface name
Interface name.
Server IP address
DHCP server IP address.
display dhcp relay statistics
Use display dhcp relay statistics to display DHCP packet statistics on the DHCP relay agent.
interface interface-type interface-number: Displays DHCP packet statistics on the specified interface. If you do not specify an interface, this command displays all DHCP packet statistics on the DHCP relay agent.
# Display all DHCP packet statistics on the DHCP relay agent.
<Sysname> display dhcp relay statistics
DHCP packets dropped:                  0
DHCP packets received from clients:    0
   DHCPDISCOVER:                       0
   DHCPREQUEST:                        0
   DHCPINFORM:                         0
   DHCPRELEASE:                        0
   DHCPDECLINE:                        0
   BOOTPREQUEST:                       0
DHCP packets received from servers:    0
   DHCPOFFER:                          0
   DHCPACK:                            0
   DHCPNAK:                            0
   BOOTPREPLY:                         0
DHCP packets relayed to servers:       0
   DHCPDISCOVER:                       0
   DHCPREQUEST:                        0
   DHCPINFORM:                         0
   DHCPRELEASE:                        0
   DHCPDECLINE:                        0
   BOOTPREQUEST:                       0
DHCP packets relayed to clients:       0
   DHCPOFFER:                          0
   DHCPACK:                            0
   DHCPNAK:                            0
   BOOTPREPLY:                         0
DHCP packets sent to servers:          0
   DHCPDISCOVER:                       0
   DHCPREQUEST:                        0
   DHCPINFORM:                         0
   DHCPRELEASE:                        0
   DHCPDECLINE:                        0
   BOOTPREQUEST:                       0
DHCP packets sent to clients:          0
   DHCPOFFER:                          0
   DHCPACK:                            0
   DHCPNAK:                            0
   BOOTPREPLY:                         0
reset dhcp relay statistics
gateway-list
Use gateway-list to specify a list of gateways for DHCP clients in the relay address pool.
Use undo gateway-list to remove the specified gateway addresses from a DHCP relay address pool.
No gateway address is specified in a DHCP relay address pool.
DHCP relay address pool view
ip-address&<1-8>: Specifies a space-separated list of up to eight addresses. Only the first gateway address takes effect and it must reside on the same subnet assigned to the DHCP clients.
DHCP clients of the same access type can be classified into different types by their locations. In this case, the relay interface typically has no IP address configured. You can use the gateway-list command to specify the gateway for clients matching the same relay address pool and bind the gateway address to the device's MAC address.
Upon receiving a DHCP DISCOVER or REQUEST from a client that matches a relay address pool, the relay agent processes the packet as follows:
·     Fills the giaddr field of the packet with the specified gateway address.
·     Forwards the packet to all DHCP servers in the matching relay address pool.
The DHCP servers select an address pool according to the gateway address.
# Specify the gateway address 10.1.1.1 in DHCP relay address pool 0.
[Sysname] dhcp server ip-pool 0
Use reset dhcp relay client-information to clear relay entries on the DHCP relay agent.
interface interface-type interface-number: Clears relay entries on the specified interface.
ip ip-address: Clears the relay entry for the specified IP address.
vpn-instance vpn-instance-name: Clears the relay entry for the specified IP address in the specified MPLS L3VPN instance. The vpn-instance-name is a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears the relay entry in the public network.
If you do not specify any parameters, this command clears all relay entries on the DHCP relay agent.
# Clear all relay entries on the DHCP relay agent.
<Sysname> reset dhcp relay client-information
Use reset dhcp relay statistics to clear relay agent statistics.
interface interface-type interface-number: Clears DHCP relay agent statistics on the specified interface. If you do not specify an interface, this command clears all DHCP relay agent statistics.
# Clear all DHCP relay agent statistics.
<Sysname> reset dhcp relay statistics
DHCP client commands
dhcp client dad enable
Use dhcp client dad enable to enable duplicate address detection.
Use undo dhcp client dad enable to disable duplicate address detection.
The duplicate address detection feature is enabled on an interface.
DHCP client detects IP address conflict through ARP packets. An attacker can act as the IP address owner to send an ARP reply. This makes the client unable to use the IP address assigned by the server. As a best practice, disable duplicate address detection when ARP attacks exist on the network.
# Disable the duplicate address.
[Sysname] undo dhcp client dad enable
dhcp client dscp
Use dhcp client dscp to set the DSCP value for DHCP packets sent by the DHCP client.
Use undo dhcp client dscp to restore the default.
dhcp client dscp dscp-value
The DSCP value in DHCP packets is 56.
dscp-value: Sets the DSCP value for DHCP packets, in the range of 0 to 63.
The DSCP value of a packet specifies the priority level of the packet and affects the transmission priority of the packet. A bigger DSCP value represents a higher priority.
# Set the DSCP value for DHCP packets sent by the DHCP client to 30.
[Sysname] dhcp client dscp 30
dhcp client identifier
Use dhcp client identifier to configure a DHCP client ID for an interface.
Use undo dhcp client identifier to restore the default.
dhcp client identifier { ascii string | hex string | mac interface-type interface-number }
An interface generates the DHCP client ID based on its MAC address. If the interface has no MAC address, it uses the MAC address of the first Ethernet interface to generate its client ID.
Interface view
ascii string: Specifies a case-sensitive ASCII string of 1 to 63 characters as the client ID.
hex string: Specifies a hex string of 4 to 64 characters as the client ID.
mac interface-type interface-number: Uses the MAC address of the specified interface as a DHCP client ID. The interface-type interface-number argument specifies an interface by its type and number.
A DHCP client ID is added to the DHCP option 61. A DHCP server can specify IP addresses for clients based on the DHCP client ID. You can specify a DHCP client ID by performing one of the following operations:
·     Naming an ASCII string or hex string as the client ID.
·     Using the MAC address of an interface to generate a client ID.
Whichever method you use, make sure the IDs for different DHCP clients are unique.
# Specify the hex string of FFFFFFFF as the client ID for VLAN-interface 10.
[Sysname-Vlan-interface10] dhcp client identifier hex FFFFFFFF
display dhcp client
display dhcp client
Use display dhcp client to display DHCP client information.
verbose: Displays verbose DHCP client information.
If you do not specify an interface, this command displays DHCP client information about all interfaces.
# Display DHCP client information about all interfaces.
<Sysname> display dhcp client
Vlan-interface10 DHCP client information:
 Current state: BOUND
 Allocated IP: 40.1.1.20 255.255.255.0
 Allocated lease: 259200 seconds, T1: 129600 seconds, T2: 226800 seconds
 DHCP server: 40.1.1.2
# Display verbose DHCP client information.
<Sysname> display dhcp client verbose
 Transaction ID: 0x1c09322d
 Default router: 40.1.1.2
 Classless static routes:
   Destination: 1.1.0.1, Mask: 255.0.0.0, NextHop: 192.168.40.16
   Destination: 10.198.122.63, Mask: 255.255.255.255, NextHop: 192.168.40.16
 DNS servers: 44.1.1.11 44.1.1.12
 Domain name: ddd.com
 Boot servers: 200.200.200.200  1.1.1.1
 ACS parameter:
   URL: http://192.168.1.1:7547/acs
   Username: bims
   Password: ******
 Client ID value: 000c.29d3.8659-GE1/0/1
                            6433-2e38-3635-392d-
                            4574-6830-2f30-2f32
 T1 will timeout in 1 day 11 hours 58 minutes 52 seconds.
Table 12 Command output
Information about the interface that acts as the DHCP client.
Current state
Current state of the DHCP client:
·     HALT—The client stops applying for an IP address.
·     INIT—The initialization state.
·     SELECTING—The client has sent out a DHCP-DISCOVER message in search for a DHCP server and is waiting for the response from DHCP servers.
·     REQUESTING—The client has sent out a DHCP-REQUEST message requesting for an IP address and is waiting for the response from DHCP servers.
·     BOUND—The client has received the DHCP-ACK message from a DHCP server and obtained an IP address successfully.
·     RENEWING—The T1 timer expires.
·     REBOUNDING—The T2 timer expires.
Allocated IP
IP address allocated by the DHCP server.
Allocated lease
Allocated lease time.
T1
1/2 lease time (in seconds) of the DHCP client IP address.
T2
7/8 lease time (in seconds) of the DHCP client IP address.
Lease from….to….
Start and end time of the lease.
DHCP server
DHCP server IP address that assigned the IP address.
Transaction ID
Transaction ID, a random number chosen by the client to identify an IP address allocation.
Default router
Gateway address assigned to the client.
Classless static routes assigned to the client.
Static routes
Classful static routes assigned to the client.
DNS servers
DNS server address assigned to the client.
Domain name
Domain name suffix assigned to the client.
Boot servers
PXE server addresses (up to 16 addresses) specified for the DHCP client, which are obtained through Option 43.
ACS parameter
Parameters about the ACS.
URL
URL of the ACS.
Username
Username for logging in to the ACS.
Password
Password for logging in to the ACS. If a password is configured, this field displays ******. If no password is configured, this field is not displayed.
Client ID type
DHCP client ID type:
·     If an ASCII string is used as the client ID value, the type value is 00.
·     If the MAC address of a specific interface is used as the client ID value, the type value is 01.
·     If a hex string is used as the client ID value, the type value is the first two characters in the string.
Client ID value
Value of the DHCP client ID.
DHCP client ID with the type field, a hexadecimal string.
How long the T1 (1/2 lease time) timer will timeout.
·     dhcp client identifier
·     ip address dhcp-alloc
Use ip address dhcp-alloc to configure an interface to use DHCP for IP address acquisition.
Use undo ip address dhcp-alloc to cancel an interface from using DHCP.
An interface does not use DHCP for IP address acquisition.
Interface view
When you execute the undo ip address dhcp-alloc command, the interface sends a DHCP-RELEASE message to release the IP address obtained through DHCP. If the interface is down, the message cannot be sent out.
# Configure VLAN-interface 10 to use DHCP for IP address acquisition.
[Sysname-Vlan-interface10] ip address dhcp-alloc
DHCP snooping commands
DHCP snooping works between the DHCP client and the DHCP server or between the DHCP client and the relay agent. DHCP snooping does not work between the DHCP server and the DHCP relay agent.
dhcp snooping binding database filename
Use dhcp snooping binding database filename to configure the DHCP snooping device to back up DHCP snooping entries to a file.
Use undo dhcp snooping binding database filename to disable the auto backup and remove the backup file.
dhcp snooping binding database filename { filename | url url [ username username [ password { cipher | simple } key ] ] }
The DHCP snooping device does not back up DHCP snooping entries.
filename: Specifies the name of a local file. For information about the filename argument, see Fundamentals Configuration Guide.
url url: Specifies the URL of a remote file. Do not include a username or password in the URL. Case sensitivity and the supported path format type vary by server.
username username: Specifies the username for logging in to the remote device.
cipher: Sets a ciphertext password.
simple: Sets a plaintext password.
key: Specifies the key string. This argument is case sensitive. If simple is specified, it must be a string of 1 to 32 characters. If cipher is specified, it must be a ciphertext string of 1 to 73 characters.
For security purposes, all passwords, including passwords configured in plaintext, are saved in ciphertext.
With this command executed, the DHCP snooping device backs up DHCP snooping entries immediately and runs auto backup. The command automatically creates the file if you specify a non-existent file. The DHCP snooping device, by default, waits 300 seconds after a DHCP snooping entry change to update the backup file. To change the waiting period, use the dhcp snooping binding database update interval command. If no DHCP snooping entry changes, the backup file is not updated.
When the file is on a remote device, follow these restrictions and guidelines to specify the URL, username, and password:
·     If the file is on an FTP server, enter URL in the following format: ftp://server address:port/file path, where the port number is optional.
·     If the file is on a TFTP server, enter URL in the following format: tftp://server address:port/file path, where the port number is optional.
·     The username and password must be the same as those configured on the FTP or TFTP server. If the server authenticates only the username, the password can be omitted. For example, enter URL ftp://1.1.1.1/database.dhcp username admin to specify the URL and username options at the CLI.
·     If the IP address of the server is an IPv6 address, enclose the address in a pair of brackets, for example, ftp://[1::1]/database.dhcp.
·     You can also specify the DNS domain name for the server address field, for example, ftp://company/database.dhcp.
# Configure the DHCP snooping device to back up DHCP snooping entries to the file database.dhcp.
[Sysname] dhcp snooping binding database filename database.dhcp
# Configure the DHCP snooping device to back up DHCP snooping entries to the file database.dhcp in the working directory of the FTP server at 10.1.1.1.
[Sysname] dhcp snooping binding database filename url ftp://10.1.1.1/database.dhcp username 1 password simple 1
# Configure the DHCP snooping device to back up DHCP snooping entries to the file database.dhcp in the working directory of the TFTP server at 10.1.1.1.
[Sysname] dhcp snooping binding database filename tftp://10.1.1.1/database.dhcp
Use dhcp snooping binding database update interval to set the waiting time after a DHCP snooping entry change for the DHCP snooping device to update the backup file.
Use undo dhcp snooping binding database update interval to restore the default.
dhcp snooping binding database update interval seconds
The DHCP snooping device waits 300 seconds after a DHCP snooping entry change to update the backup file. If no DHCP snooping entry changes, the backup file is not updated.
seconds: Sets the waiting time in seconds, in the range of 60 to 864000.
When a DHCP snooping entry is learned, updated, or removed, the waiting period starts. The DHCP snooping device updates the backup file when the waiting period is reached. All changed entries during the period will be saved to the backup file.
The waiting time does not take effect if you do not configure the DHCP snooping entry auto backup by using the dhcp snooping binding database filename command.
# Set the waiting time to 600 seconds for the DHCP snooping device to update the backup file.
[Sysname] dhcp snooping binding database update interval 600
dhcp snooping binding database update now
Use dhcp snooping binding database update now to manually save DHCP snooping entries to the backup file.
This command does not take effect if you do not configure the DHCP snooping auto backup by using the dhcp snooping binding database filename command.
# Manually save DHCP snooping entries to the backup file.
[Sysname] dhcp snooping binding database update now
dhcp snooping binding record
Use dhcp snooping binding record to enable recording of client information in DHCP snooping entries.
Use undo dhcp snooping binding record to disable recording of client information in DHCP snooping entries.
DHCP snooping does not record client information.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
This command enables DHCP snooping on the port directly connecting to the clients to record client information in DHCP snooping entries.
# Enable recording of client information in DHCP snooping entries.
[Sysname-GigabitEthernet1/0/1] dhcp snooping binding record
dhcp snooping check mac-address
Use dhcp snooping check mac-address to enable MAC address check for DHCP snooping.
Use undo dhcp snooping check mac-address to disable MAC address check for DHCP snooping.
This feature is disabled.
With MAC address check enabled, DHCP snooping compares the chaddr field of a received DHCP request with the source MAC address field in the frame header. If they are the same, DHCP snooping considers this request valid and forwards it to the DHCP server. If they are not the same, DHCP snooping discards the DHCP request.
# Enable MAC address check for DHCP snooping.
[Sysname-GigabitEthernet1/0/1] dhcp snooping check mac-address
dhcp snooping check request-message
Use dhcp snooping check request-message to enable DHCP-REQUEST check for DHCP snooping.
Use undo dhcp snooping check request-message to disable DHCP-REQUEST check for DHCP snooping.
DHCP-REQUEST packets include lease renewal packets, DHCP-DECLINE packets, and DHCP-RELEASE packets. This feature prevents unauthorized clients that forge DHCP-REQUEST packets from attacking the DHCP server.
With this feature enabled, DHCP snooping looks for a matching DHCP snooping entry for each received DHCP-REQUEST message.
·     If a match is found, DHCP snooping compares the entry with the message. If they have consistent information, DHCP snooping considers the packet valid and forwards it to the DHCP server. If they have different information, DHCP snooping considers the message invalid and discards it.
·     If no match is found, DHCP snooping forwards the message to the DHCP server.
# Enable DHCP-REQUEST check for DHCP snooping.
[Sysname-GigabitEthernet1/0/1] dhcp snooping check request-message
dhcp snooping deny
Use dhcp snooping deny to configure a port as DHCP packet blocking port.
Use undo dhcp snooping deny to restore the default.
dhcp snooping deny
undo ipv6 dhcp snooping deny
A port does not block DHCP packets.
DHCP clients connected to DHCP packet blocking ports cannot obtain IP addresses and other configuration parameters from a DHCP server.
Do not configure a port as both a trusted port and a DHCP packet blocking port.
# Configure Layer 2 Ethernet interface GigabitEthernet 3/0/1 as a DHCP packet blocking port.
[Sysname] interface gigabitethernet 3/0/1
[Sysname-GigabitEthernet3/0/1] dhcp snooping deny
dhcp snooping enable
Use dhcp snooping enable to enable DHCP snooping.
Use undo dhcp snooping enable to disable DHCP snooping.
DHCP snooping is disabled.
Use the DHCP snooping feature together with trusted port configuration. Before trusted ports are configured, all ports on the DHCP snooping device are untrusted and the device discards all responses sent from DHCP servers.
When DHCP snooping is disabled, the device forwards all responses from DHCP servers.
# Enable DHCP snooping.
[Sysname] dhcp snooping enable
dhcp snooping information circuit-id
Use dhcp snooping information circuit-id to configure the padding mode and padding format for the Circuit ID sub-option.
Use undo dhcp snooping information circuit-id to restore the default.
dhcp snooping information circuit-id { [ vlan vlan-id ] string circuit-id | { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] } [ format { ascii | hex } ] }
undo dhcp snooping information circuit-id [ vlan vlan-id ]
vlan vlan-id: Specifies a VLAN ID for the Circuit ID sub-option.
string circuit-id: Specifies the string mode, in which the padding content for the Circuit ID sub-option is a case-sensitive string of 3 to 63 characters.
normal: Specifies the normal mode. The padding content includes the VLAN ID and interface number.
node-identifier { mac | sysname | user-defined node-identifier }: Specifies the access node identifier. The padding content includes the node identifier, Ethernet type (fixed to eth), chassis number, slot number, sub-slot number, interface number, and VLAN ID. The node identifier varies by keyword mac, sysname, and user-defined.
If sysname is used as the node identifier, do not include any spaces when you set the device name. Otherwise, the DHCP snooping device fails to add or replace the Option 82.
If you use this command multiple times, the most recent configuration takes effect.
The padding format for the user-defined string, the normal mode, or the verbose mode varies by command configuration. Table 13 shows how the padding format is determined for different modes.
Table 13 Padding format for different modes
Keyword (mode)
string circuit-id
N/A
N/A
normal
Hex.
ASCII.
Hex.
verbose
ASCII.
If the handling strategy for DHCP requests containing Option 82 is replace, you must specify the padding mode and padding format for the Circuit ID sub-option. If the handling strategy is keep or drop, you do not need to specify the padding mode and padding format for the Circuit ID sub-option.
# Configure verbose as the padding mode, device name as the node identifier, and ASCII as the padding format for the Circuit ID sub-option.
[Sysname-GigabitEthernet1/0/1] dhcp snooping information enable
[Sysname-GigabitEthernet1/0/1] dhcp snooping information strategy replace
[Sysname-GigabitEthernet1/0/1] dhcp snooping information circuit-id verbose node-identifier sysname format ascii
·     dhcp snooping information enable
·     dhcp snooping information strategy
·     display dhcp snooping information
Use dhcp snooping information enable to enable DHCP snooping to support Option 82.
Use undo dhcp snooping information enable to disable this feature.
DHCP snooping does not support Option 82.
This command enables DHCP snooping to add Option 82 into DHCP requests that do not contain Option 82 before forwarding the requests to the DHCP server. The content of Option 82 is determined by the dhcp snooping information circuit-id and dhcp snooping information remote-id commands. If the received DHCP request packets contain Option 82, DHCP snooping handles the packets according to the strategy configured with the dhcp snooping information strategy command.
If this feature is disabled, DHCP snooping forwards requests that contain or do not contain Option 82 to the DHCP server.
# Enable DHCP snooping to support Option 82.
[Sysname] interface gigabitethernet1/0/1
·     dhcp snooping information circuit-id
·     dhcp snooping information remote-id
Use dhcp snooping information remote-id to configure the padding mode and padding format for the Remote ID sub-option.
Use undo dhcp snooping information remote-id to restore the default.
dhcp snooping information remote-id { normal [ format { ascii | hex } ] | [ vlan vlan-id ] { string remote-id | sysname } }
undo dhcp snooping information remote-id [ vlan vlan-id ]
vlan vlan-id: Specifies the VLAN ID as the Remote ID sub-option.
sysname: Specifies the sysname mode that uses the device name as the Remote ID sub-option. You can configure the device name by using the sysname command in system view.
normal: Specifies the normal mode. The padding content is the MAC address of the receiving interface.
DHCP snooping uses ASCII to pad the specified string or device name for the Remote ID sub-option. The padding format for the normal padding mode is determined by the command configuration.
# Pad the Remote ID sub-option with the character string device001.
[Sysname-GigabitEthernet1/0/1] dhcp snooping information remote-id string device001
Use dhcp snooping information strategy to configure the handling strategy for Option 82 in request messages.
Use undo dhcp snooping information strategy to restore the default.
dhcp snooping information strategy { drop | keep | replace }
The handling strategy for Option 82 in request messages is replace.
drop: Drops DHCP messages that contain Option 82.
This command takes effect only on DHCP requests that contain Option 82. For DHCP requests that do not contain Option 82, the DHCP snooping device always adds Option 82 into the requests before forwarding them to the DHCP server.
# Specify the handling strategy for Option 82 in request messages as keep.
[Sysname-GigabitEthernet1/0/1] dhcp snooping information strategy keep
dhcp snooping log enable
Use dhcp snooping log enable to enable DHCP snooping logging.
Use undo dhcp snooping log enable to disable DHCP snooping logging.
DHCP snooping logging is disabled.
This command enables the DHCP snooping device to generate DHCP snooping logs and send them to the information center. For information about the log destination and output rule configuration in the information center, see Network Management and Monitoring Configuration Guide.
As a best practice, disable this feature if the log generation affects the device performance.
# Enable DHCP snooping logging.
[Sysname] dhcp snooping log enable
dhcp snooping max-learning-num
Use dhcp snooping max-learning-num to set the maximum number of DHCP snooping entries that an interface can learn.
Use undo dhcp snooping max-learning-num to restore the default.
dhcp snooping max-learning-num number
The maximum number of DHCP snooping entries for an interface to learn is unlimited.
number: Specifies the maximum number of DHCP snooping entries for an interface to learn, in the range of 1 to 4294967295.
# Set the maximum number of DHCP snooping entries for the Layer 2 Ethernet interface GigabitEthernet 1/0/1 to learn to 1000.
[Sysname-GigabitEthernet1/0/1] dhcp snooping max-learning-num 1000
dhcp snooping rate-limit
Use dhcp snooping rate-limit to configure the maximum rate at which an interface can receive DHCP packets.
Use undo dhcp snooping rate-limit to remove the configured rate limit.
dhcp snooping rate-limit rate
Incoming DHCP packets on an interface are not rate limited.
rate: Specifies the maximum rate for an interface to receive DHCP packets, in Kbps in the range of 64 to 512.
This command takes effect only when DHCP snooping is enabled.
With the rate limit feature, the interface discards DHCP packets that exceed the maximum rate.
The rate configured on a Layer 2 aggregate interface applies to all members of the aggregate interface. If a member interface leaves the aggregation group, it uses the rate configured on its Ethernet interface view.
# Set the maximum rate at which the Layer 2 Ethernet interface GigabitEthernet 1/0/1 can receive DHCP packet to 64 Kbps.
[Sysname-GigabitEthernet1/0/1] dhcp snooping rate-limit 64
dhcp snooping trust
Use dhcp snooping trust to configure a port as a trusted port.
Use undo dhcp snooping trust to restore the default state of a port.
dhcp snooping trust
After you enable DHCP snooping, all ports are untrusted.
Specify the ports facing the DHCP server as trusted ports and specify the other ports as untrusted ports so DHCP clients can obtain valid IP addresses.
# Specify the Layer 2 Ethernet interface GigabitEthernet 1/0/1 as a trusted port.
[Sysname-GigabitEthernet1/0/1] dhcp snooping trust
display dhcp snooping trust
display dhcp snooping binding
Use display dhcp snooping binding to display DHCP snooping entries.
display dhcp snooping binding [ ip ip-address [ vlan vlan-id ] ]
ip ip-address: Displays the DHCP snooping entry for the specified IP address.
vlan vlan-id: Specifies the VLAN ID where the IP address resides.
If you do not specify any parameters, this command displays all DHCP snooping entries.
# Display all DHCP snooping entries.
<Sysname> display dhcp snooping binding
 2 DHCP snooping entries found
 IP address      MAC address    Lease        VLAN  SVLAN Interface
 1.1.1.7         0000-0101-0107 16907533     2     3     GE1/0/1
 1.1.1.11        0000-0101-010b 16907537     2     3     GE1/0/3
Table 14 Command output
Number of DHCP snooping entries.
IP address
IP address assigned to the DHCP client.
MAC address
Lease
Remaining lease duration in seconds.
VLAN
When both DHCP snooping and QinQ are enabled or the DHCP packet contains two VLAN tags, this field identifies the outer VLAN tag. Otherwise, it identifies the VLAN where the port connecting the DHCP client resides.
SVLAN
When both DHCP snooping and QinQ are enabled or the DHCP packet contains two VLAN tags, this field identifies the inner VLAN tag. Otherwise, it displays N/A.
Port connected to the DHCP client.
·     dhcp snooping enable
·     reset dhcp snooping binding
display dhcp snooping binding database
Use display dhcp snooping binding database to display information about DHCP snooping entry auto backup.
# Display information about DHCP snooping entry auto backup.
<Sysname> display dhcp snooping binding database
Username                :
Password                :
Latest write time       :   Feb 27 18:48:04 2012
Table 15 Command output
File name
Name of the DHCP snooping entry backup file.
Username
Username for logging in to the remote device.
Password
Password for logging in to the remote device. This field displays ****** if a password is configured.
Update interval
Waiting time in seconds after a DHCP snooping entry change for the DHCP snooping device to update the backup file.
Latest write time
Time of the latest update.
Status
Status of the update:
·     WritingThe backup file is being updated.
·     Last write succeededThe backup file was successfully updated.
·     Last write failedThe backup file failed to be updated.
Use display dhcp snooping information to display Option 82 configuration on the DHCP snooping device.
display dhcp snooping information { all | interface interface-type interface-number }
all: Displays Option 82 configuration on all Layer 2 Ethernet interfaces.
# Display Option 82 configuration on all interfaces.
<Sysname> display dhcp snooping information all
Interface: Bridge-Aggregation1
   Status: Disable
   Strategy: Drop
   Circuit ID:
     Padding format: User Defined
       User defined: abcd
     Format: ASCII
   Remote ID:
     Padding format: Normal
     Format: ASCII
   VLAN 10:
     Circuit ID: abcd
     Remote ID: company
Table 16 Command output
Interface name.
Status
Option 82 status, Enable or Disable.
Strategy
Handling strategy for DHCP requests that contain Option 82, Drop, Keep, or Replace.
Circuit ID
Content of the Circuit ID sub-option.
Padding format
Padding format of Option 82:
·     For Circuit ID sub-option, the padding format can be Normal, User Defined, Verbose (sysname), Verbose (MAC), or Verbose (user defined).
·     For Remote ID sub-option, the padding format can be Normal, Sysname, or User Defined.
Node identifier
User defined
Content of the user-defined sub-option.
Format
Code type of Option 82 sub-option:
·     For Circuit ID sub-option, the code type can be ASCII, Default, or Hex.
·     For Remote ID sub-option, the code type can be ASCII or Hex.
Remote ID
Content of the Remote ID sub-option.
VLAN
Pads Circuit ID sub-option and Remote ID sub-option in the DHCP packets received in the specified VLAN.
display dhcp snooping packet statistics
Use display dhcp snooping packet statistics to display DHCP packet statistics for DHCP snooping.
In standalone mode:
display dhcp snooping packet statistics [ slot slot-number ]
In IRF mode:
display dhcp snooping packet statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by the slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. (In IRF mode.)
If you do not specify the slot slot-number option, this command displays DHCP packet statistics for the card where the command is executed. (In standalone mode.)
If you do not specify the chassis chassis-number slot slot-number option, this command displays DHCP packet statistics for the card or PEX where the command is executed. (In IRF mode.)
# Display DHCP packet statistics for DHCP snooping.
<Sysname> display dhcp snooping packet statistics
 DHCP packets received                  : 100
 DHCP packets sent                      : 200
 Invalid DHCP packets dropped           : 0
reset dhcp snooping packet statistics
Use display dhcp snooping trust to display information about trusted ports.
# Display information about trusted ports.
<Sysname> display dhcp snooping trust
 Interface                                       Trusted
 GigabitEthernet1/0/1                            Trusted
dhcp snooping trust
Use reset dhcp snooping binding to clear DHCP snooping entries.
reset dhcp snooping binding { all | ip ip-address [ vlan vlan-id ] }
all: Clears all DHCP snooping entries.
ip ip-address: Clears the DHCP snooping entry for the specified IP address.
vlan vlan-id: Clears DHCP snooping entries for the specified VLAN.
This command applies to all slots on the device.
# Clear all DHCP snooping entries.
<Sysname> reset dhcp snooping binding all
Use reset dhcp snooping packet statistics to clear DHCP packet statistics for DHCP snooping.
In standalone mode:
reset dhcp snooping packet statistics [ slot slot-number ]
In IRF mode:
reset dhcp snooping packet statistics [ chassis chassis-number slot slot-number ]
If you do not specify the slot slot-number option, this command clears DHCP packet statistics for the card where the command is executed. (In standalone mode.)
If you do not specify the chassis chassis-number slot slot-number option, this command clears DHCP packet statistics for the card or PEX where the command is executed. (In IRF mode.)
# Clear DHCP packet statistics for DHCP snooping.
<Sysname> reset dhcp snooping packet statistics
BOOTP client commands
display bootp client
Use display bootp client to display information about a BOOTP client.
If you do not specify an interface, this command displays BOOTP client information about all interfaces.
# Display BOOTP client information about VLAN-interface 10.
<Sysname> display bootp client interface vlan-interface 10
Vlan-interface10 BOOTP client information:
Allocated IP: 169.254.0.2 255.255.0.0
Transaction ID: 0x3d8a7431
MAC Address: 00e0-fc0a-c3ef
Table 17 Command output
GigabitEthernet1/0/1 BOOTP client information or Vlan-interface10 BOOTP client information
Information about the interface that acts as a BOOTP client.
Allocated IP
BOOTP client's IP address allocated by the BOOTP server.
Transaction ID
Value of the XID field in a BOOTP message. The BOOTP client chooses a random number for the XID field when sending a BOOTP request to the BOOTP server. It is used to match a response message from the BOOTP server. If the values of the XID field are different in the BOOTP response and request, the BOOTP client drops the BOOTP response.
Mac Address
MAC address of a BOOTP client.
ip address bootp-alloc
Use ip address bootp-alloc to configure an interface to use BOOTP for IP address acquisition.
Use undo ip address bootp-alloc to cancel an interface from using BOOTP.
An interface does not use BOOTP for IP address acquisition.
# Configure VLAN-interface 10 to use BOOTP for IP address acquisition.
[Sysname-Vlan-interface10] ip address bootp-alloc
