05-Layer 3 - IP Services Command Reference
HomeSupportSwitchesH3C S7500E-X Switch SeriesReference GuidesCommand ReferencesH3C S7500E-X Switch Series Command References-Release7178-6W10005-Layer 3 - IP Services Command Reference
01-ARP commands
01-ARP commands 108.31 KB
ARP commands
arp check enable
Use arp check enable to enable dynamic ARP entry check.
Use undo arp check enable to disable dynamic ARP entry check.
arp check enable
Dynamic ARP entry check is enabled.
Dynamic ARP entry check disables a device from supporting dynamic ARP entries with multicast MAC addresses. The device cannot learn dynamic ARP entries containing multicast MAC addresses. You cannot manually add static ARP entries that contain multicast MAC addresses.
When dynamic ARP entry check is disabled, ARP entries containing multicast MAC addresses are supported. The device can learn dynamic ARP entries containing multicast MAC addresses obtained from the ARP packets sourced from a unicast MAC address. You can also manually add static ARP entries containing multicast MAC addresses.
# Enable dynamic ARP entry check.
[Sysname] arp check enable
arp check log enable
Use arp check log enable to enable the ARP logging feature.
Use undo arp check log enable to disable the ARP logging feature.
ARP logging is disabled.
This feature enables a device to log ARP events when ARP cannot resolve IP addresses correctly. The device can log the following ARP events:
·     On a proxy ARP-disabled interface, the target IP address of a received ARP packet is not the IP address of the receiving interface.
·     The sender IP address of a received ARP reply conflicts with the IP address of the receiving interface.
The device sends ARP log messages to the information center. You can use the info-center source command to specify the log output rules for the information center. For more information about information center, see Network Management and Monitoring Configuration Guide.
The device can generate a large amount of ARP logs. To conserve system resources, enable ARP logging only when you are troubleshooting or debugging ARP events.
# Enable ARP logging.
[Sysname] arp check log enable
arp max-learning-num
Use arp max-learning-num to set the maximum number of dynamic ARP entries that an interface can learn.
Use undo arp max-learning-num to restore the default.
arp max-learning-num number
The maximum number of dynamic ARP entries that an interface can learn depends on the maximum free space of the ARP table.
Layer 2 Ethernet interface/Layer 2 aggregate interface view
VLAN interface view
number: Specifies the maximum number of dynamic ARP entries for an interface. The value range is 0 to 184320.
An interface can dynamically learn ARP entries. To prevent an interface from holding too many ARP entries, you can set the maximum number of dynamic ARP entries that the interface can learn. When the maximum number is reached, the interface stops learning ARP entries.
When the number argument is set to 0, the interface is disabled from learning dynamic ARP entries.
# Specify VLAN-interface 40 to learn a maximum of 500 dynamic ARP entries.
[Sysname] interface vlan-interface 40
[Sysname-Vlan-interface40] arp max-learning-num 500
# Specify GigabitEthernet 1/0/1 to learn a maximum of 1000 dynamic ARP entries.
[Sysname-GigabitEthernet1/0/1] arp max-learning-num 1000
# Specify Layer 2 aggregate interface Bridge-Aggregation 1 to learn a maximum of 1000 dynamic ARP entries.
[Sysname-Bridge-Aggregation1] arp max-learning-num 1000
# Specify Layer 3 aggregate interface Route-Aggregation 1 to learn a maximum of 1000 dynamic ARP entries.
[Sysname-Route-Aggregation1] arp max-learning-num 1000
arp max-learning-number
Use arp max-learning-number to set the maximum number of dynamic ARP entries that a device can learn.
Use undo arp max-learning-number to restore the default.
In standalone mode:
arp max-learning-number number slot slot-number
undo arp max-learning-number slot slot-number
In IRF mode:
arp max-learning-number number chassis chassis-number slot slot-number
undo arp max-learning-number chassis chassis-number slot slot-number
The maximum number of dynamic ARP entries that a device can learn depends on the maximum free space of the ARP table.
number: Specifies the maximum number of dynamic ARP entries for a device. The value range is 0 to 184320.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. (In IRF mode.)
A device can dynamically learn ARP entries. To prevent a device from holding too many ARP entries, you can set the maximum number of dynamic ARP entries that the device can learn. When the maximum number is reached, the device stops learning ARP entries.
When the number argument is set to 0, the device is disabled from learning dynamic ARP entries.
# Set the card in slot 1 to learn a maximum of 64 dynamic ARP entries.
[Sysname] arp max-learning-number 64 slot 1
arp mode uni
Use arp mode uni to configure a port as a customer-side port.
Use undo arp mode to restore the default.
arp mode uni
undo arp mode
A port operates as a network-side port.
VLAN interface view
By default, the device associates an ARP entry with routing information when the device learns an ARP entry. The ARP entry provides the next hop information for routing. To save hardware resources, you can use this command to specify a port that connects to a user terminal as a customer-side port. The device will not associate the routing information with the learned ARP entries.
# Specify VLAN-interface 2 as a customer-side port.
[Sysname-Vlan-interface2] arp mode uni
arp multiport
Use arp multiport to configure a multiport ARP entry.
Use undo arp to remove an ARP entry.
arp multiport ip-address mac-address vlan-id [ vpn-instance vpn-instance-name ]
undo arp ip-address [ vpn-instance-name ]
No multiport ARP entries are configured.
ip-address: Specifies an IP address for the multiport ARP entry.
mac-address: Specifies a MAC address for the multiport ARP entry, in the format of H-H-H.
vlan-id: Specifies a VLAN for the multiport ARP entry, in the range of 1 to 4094.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN for the multiport ARP entry. The VPN instance name is a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist. If you do not specify this option, the multiport ARP entry belongs to the public network.
The specified VLAN must already exist. If the VLAN or the corresponding VLAN interface is removed, the multiport ARP entry is also removed.
The specified IP address must reside on the same subnet as the VLAN interface of the specified VLAN. Otherwise, the multiport ARP entry does not take effect.
To use the multiport ARP entry, you must configure a multicast or multiport unicast MAC address entry to specify multiple output interfaces. The MAC address entry must have the same MAC address and VLAN ID as the multiport ARP entry.
# Configure a multiport ARP entry that contains IP address 202.38.10.2 and MAC address 00e0-fc01-0000 in VLAN 10.
[Sysname] arp multiport 202.38.10.2 00e0-fc01-0000 10
·     display arp multiport
·     reset arp multiport
arp static
Use arp static to configure a static ARP entry.
arp static ip-address mac-address [ vlan-id interface-type interface-number ] [ vpn-instance vpn-instance-name ]
No static ARP entries are configured.
ip-address: Specifies an IP address for the static ARP entry.
mac-address: Specifies a MAC address for the static ARP entry, in the format of H-H-H.
vlan-id: Specifies the ID of a VLAN to which the static ARP entry belongs. The value range is 1 to 4094. The VLAN and VLAN interface must already exist.
interface-type interface-number: Specifies an interface by its type and number. Make sure the interface belongs to the specified VLAN.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN for the static ARP entry. The VPN instance name is a case-sensitive string of 1 to 31 characters. The VPN instance must already exist. To specify a static ARP entry on the public network, do not specify this option.
A static ARP entry is manually configured and maintained. It does not age out and cannot be overwritten by any dynamic ARP entry.
Static ARP entries can be classified into long and short static ARP entries. A short static ARP entry contains an IP-to-MAC mapping. A long static ARP entry contains an IP-to-MAC mapping, a VLAN, and an output interface.
A static ARP entry is effective when the device operates correctly.
When the VLAN or VLAN interface is deleted, long static ARP entries in the VLAN are deleted, and resolved short static ARP entries in the VLAN become unresolved.
A resolved short static ARP entry becomes unresolved upon certain events, for example, when the output interface goes down.
A long static ARP entry is ineffective when the corresponding VLAN interface or output interface is down. An ineffective long static ARP entry cannot be used to forward packets.
If you specify both the vlan-id and ip-address arguments, the IP address of the corresponding VLAN interface must be on the same network as the specified IP address.
If you do not specify a VPN, the undo arp command removes ARP entries only for the public network.
# Configure a static ARP entry that contains IP address 202.38.10.2, MAC address 00e0-fc01-0000, and output interface GigabitEthernet 1/0/1 in VLAN 10.
[Sysname] arp static 202.38.10.2 00e0-fc01-0000 10 gigabitethernet 1/0/1
·     display arp
·     reset arp
arp timer aging
Use arp timer aging to set the aging timer for dynamic ARP entries.
Use undo arp timer aging to restore the default.
arp timer aging aging-time
The aging timer for dynamic ARP entries is 20 minutes.
aging-time: Sets the aging timer for dynamic ARP entries, in the range of 1 to 1440 minutes.
Each dynamic ARP entry in the ARP table has a limited lifetime, called an aging timer. The aging timer of a dynamic ARP entry is reset each time the dynamic ARP entry is updated. Dynamic ARP entries that are not updated before their aging timers expire are deleted from the ARP table.
Set the aging timer for dynamic ARP entries as needed. For example, when you configure proxy ARP, set a short aging time so that invalid dynamic ARP entries can be deleted in time.
# Set the aging timer for dynamic ARP entries to 10 minutes.
[Sysname] arp timer aging 10
display arp timer aging
display arp
Use display arp to display ARP entries.
In standalone mode:
display arp [ [ all | dynamic | multiport |static ] [ slot slot-number ] | vlan vlan-id | interface interface-type interface-number ] [ count | verbose ]
In IRF mode:
display arp [ [ all | dynamic | multiport |static ] [ chassis chassis-number slot slot-number ] | vlan vlan-id | interface interface-type interface-number ] [ count | verbose ]
all: Displays all ARP entries.
dynamic: Displays dynamic ARP entries.
multiport: Displays multiport ARP entries.
static: Displays static ARP entries.
vlan vlan-id: Specifies a VLAN by its VLAN ID. The VLAN ID is in the range of 1 to 4094.
count: Displays the number of ARP entries.
verbose: Displays detailed information about ARP entries.
This command displays information about ARP entries, including the IP address, MAC address, VLAN ID, output interface, entry type, and aging timer.
If you do not specify any parameters, the command displays all ARP entries.
# Display all ARP entries.
<Sysname> display arp all
  Type: S-Static   D-Dynamic   O-Openflow   M-Multiport  I-Invalid
IP Address       MAC Address     VLAN     Interface              Aging Type
20.1.1.1         00e0-fc00-0001  N/A      N/A                    N/A   S
193.1.1.70       00e0-fe50-6503  100      GE1/0/1                N/A   IS
192.168.0.115    000d-88f7-9f7d  1        GE1/0/2                18    D
192.168.0.39     0012-a990-2241  1        GE1/0/3                20    D
22.1.1.1         000c-299d-c041  10       N/A                    N/A   M
# Display detailed information about all ARP entries.
<Sysname> display arp all verbose
Vpn Instance
test
[No Vrf]
[No Vrf]
[No Vrf]
[No Vrf]
# Display the number of all ARP entries.
<Sysname> display arp all count
 Total number of entries : 5
IP Address
IP address in an ARP entry.
MAC Address
MAC address in an ARP entry.
VLAN
ID of the VLAN to which the ARP entry belongs. This field displays N/A in either of the following situations:
·     The ARP entry is an unresolved short static ARP entry.
·     The output interface of the ARP entry does not belong to the VLAN.
Output interface in an ARP entry. This field displays N/A in either of the following situations:
·     The ARP entry is a multiport ARP entry and has no output interface information.
To obtain the output interface information of the multiport ARP entry, look up the MAC address table according to the MAC address in the ARP entry.
Aging
Aging time for a dynamic ARP entry in minutes. N/A means unknown aging time or no aging time.
ARP entry type:
·     D—Dynamic.
·     S—Static.
·     O—OpenFlow.
·     M—Multiport.
·     I—Invalid.
Vpn Instance
Name of VPN instance. [No Vrf] is displayed if no VPN instance is configured for the ARP entry.
Number of ARP entries.
·     arp static
·     reset arp
display arp ip-address
Use display arp ip-address to display the ARP entry for an IP address.
In standalone mode:
display arp ip-address [ slot slot-number ] [ verbose ]
In IRF mode:
display arp ip-address [ chassis chassis-number slot slot-number ] [ verbose ]
ip-address: Displays the ARP entry for the specified IP address.
verbose: Displays the detailed information about the specified ARP entry.
The ARP entry information includes the IP address, MAC address, VLAN ID, output interface, entry type, and aging timer.
# Display the ARP entry for the IP address 20.1.1.1.
<Sysname> display arp 20.1.1.1
IP address       MAC address     VLAN     Interface              Aging Type
·     arp static
·     reset arp
Use display arp timer aging to display the aging timer of dynamic ARP entries.
# Display the aging timer of dynamic ARP entries.
<Sysname> display arp timer aging
Current ARP aging time is 10 minute(s)
arp timer aging
display arp vpn-instance
Use display arp vpn-instance to display the ARP entries for a VPN instance.
display arp vpn-instance vpn-instance-name [ count ]
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
This command displays information about ARP entries for a VPN instance, including the IP address, MAC address, VLAN ID, output interface, entry type, and aging timer.
# Display ARP entries for the VPN instance named test.
<Sysname> display arp vpn-instance test
IP address       MAC address     VLAN ID  Interface              Aging Type
·     arp static
·     reset arp
reset arp
Use reset arp to clear ARP entries from the ARP table.
In standalone mode:
reset arp { all | dynamic | interface interface-type interface-number | multiport | slot slot-number | static }
In IRF mode:
reset arp { all | chassis chassis-number slot slot-number | dynamic | interface interface-type interface-number | multiport | static }
all: Clears all ARP entries.
dynamic: Clears all dynamic ARP entries.
multiport: Clears all multiport ARP entries.
static: Clears all static ARP entries.
This command can separately clear static ARP entries, dynamic ARP entries, multiport ARP entries, ARP entries of specified cards, or ARP entries on specified interfaces.
When the interface interface-type interface-number option is specified, this command clears only dynamic ARP entries for the specified interface.
When the slot slot-number option is specified, this command clears only dynamic ARP entries for the specified card.
# Clear all static ARP entries.
<Sysname> reset arp static
·     arp static
·     display arp
Gratuitous ARP commands
arp ip-conflict log prompt
Use arp ip-conflict log prompt to enable IP conflict notification without conflict confirmation.
Use undo arp ip-conflict log prompt to restore the default.
IP conflict notification is disabled.
By default, the device performs the following operations if it is using the sender IP address of a received ARP packet:
·     Sends a gratuitous ARP request.
·     Displays an error message after the device receives an ARP reply about the conflict.
# Enable IP conflict notification on the device.
[Sysname] arp ip-conflict log prompt
arp send-gratuitous-arp
Use arp send-gratuitous-arp to enable periodic sending of gratuitous ARP packets and set the sending interval on an interface.
Use undo arp send-gratuitous-arp to disable the interface from periodically sending gratuitous ARP packets.
arp send-gratuitous-arp [ interval milliseconds ]
Periodic sending of gratuitous ARP packets is disabled.
VLAN interface view
interval milliseconds: Sets the interval at which gratuitous ARP packets are sent, in the range of 200 to 200000 milliseconds. The default value is 2000 milliseconds.
This feature takes effect only when the enabled interface is up and an IP address has been assigned to the interface.
This feature can send gratuitous ARP requests only for a VRRP virtual IP address, or the sending interface's primary IP address or manually configured secondary IP address. The primary IP address can be configured manually or automatically, whereas the secondary IP address must be configured manually.
If you change the interval for sending gratuitous ARP packets, the configuration takes effect at the next sending interval.
The frequency of sending gratuitous ARP packets might be much lower than expected when any of the following conditions exist:
·     This feature is enabled on multiple interfaces.
·     Each interface is configured with multiple secondary IP addresses.
·     A small sending interval is configured in the preceding cases.
# Enable VLAN-interface 2 to send gratuitous ARP packets every 300 milliseconds.
[Sysname-Vlan-interface2] arp send-gratuitous-arp interval 300
gratuitous-arp-learning enable
Use gratuitous-arp-learning enable to enable learning of gratuitous ARP packets.
Use undo gratuitous-arp-learning enable to disable learning of gratuitous ARP packets.
Learning of gratuitous ARP packets is enabled.
The learning of gratuitous ARP packets feature allows a device to maintain its ARP table by creating or updating ARP entries based on received gratuitous ARP packets.
When this feature is disabled, the device uses received gratuitous ARP packets to update existing ARP entries only. ARP entries are not created based on the received gratuitous ARP packets, which saves ARP table space.
# Enable learning of gratuitous ARP packets.
[Sysname] gratuitous-arp-learning enable
gratuitous-arp-sending enable
Use gratuitous-arp-sending enable to enable sending gratuitous ARP packets upon receiving ARP requests whose sender IP address is on a different subnet.
Use undo gratuitous-arp-sending enable to restore the default.
A device does not send gratuitous ARP packets when it receives ARP requests whose sender IP address is on a different subnet.
# Disable a device from sending gratuitous ARP packets upon receiving ARP requests whose sender IP address is on a different subnet.
[Sysname] undo gratuitous-arp-sending enable
Proxy ARP commands
display local-proxy-arp
Use display local-proxy-arp to display the local proxy ARP status.
display local-proxy-arp [ interface interface-type interface-number ]
You can use this command to check whether local proxy ARP is enabled or disabled.
If an interface is specified, this command displays the local proxy ARP status for the specified interface.
If no interface is specified, this command displays the local proxy ARP status for all interfaces.
# Display the local proxy ARP status for VLAN-interface 2.
<Sysname> display local-proxy-arp interface vlan-interface 2
Interface Vlan-interface2
 Local Proxy ARP status: enabled
local-proxy-arp enable
display proxy-arp
Use display proxy-arp to display the proxy ARP status.
display proxy-arp [ interface interface-type interface-number ]
You can use this command to check whether proxy ARP is enabled or disabled.
If an interface is specified, this command displays proxy ARP status for the specified interface.
If no interface is specified, this command displays proxy ARP status for all interfaces.
# Display the proxy ARP status on GigabitEthernet 1/0/1.
<Sysname> display proxy-arp interface gigabitethernet 1/0/1
 Proxy ARP status: disabled
proxy-arp enable
Use local-proxy-arp enable to enable local proxy ARP.
Use undo local-proxy-arp enable to disable local proxy ARP.
local-proxy-arp enable [ ip-range startIP to endIP ]
Local proxy ARP is disabled.
VLAN interface view
ip-range startIP to endIP: Specifies the IP address range for which local proxy ARP is enabled. The start IP address must be lower than or equal to the end IP address.
Proxy ARP enables a device on a network to answer ARP requests for an IP address not on that network. With proxy ARP, hosts in different broadcast domains can communicate with each other as they do on the same network.
Proxy ARP includes common proxy ARP and local proxy ARP.
Common proxy ARP allows communication between hosts that connect to different Layer 3 interfaces and reside in different broadcast domains.
Local proxy ARP allows communication between hosts that connect to the same Layer 3 interface and reside in different broadcast domains.
Only one IP address range can be specified by using the ip-range keyword on an interface.
# Enable local proxy ARP on VLAN-interface 2.
[Sysname-Vlan-interface2] local-proxy-arp enable
# Enable local proxy ARP on VLAN-interface 2 for an IP address range.
[Sysname-Vlan-interface2] local-proxy-arp enable ip-range 1.1.1.1 to 1.1.1.20
proxy-arp enable
Use proxy-arp enable to enable proxy ARP.
Use undo proxy-arp enable to disable proxy ARP.
proxy-arp enable
Proxy ARP is disabled.
VLAN interface view
# Enable proxy ARP on VLAN-interface 2.
[Sysname-Vlan-interface2] proxy-arp enable
display proxy-arp
ARP snooping commands
arp snooping enable
Use arp snooping enable to enable ARP snooping.
Use undo arp snooping enable to disable ARP snooping.
arp snooping enable
ARP snooping is disabled.
VLAN view
# Enable ARP snooping for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] arp snooping enable
display arp snooping
Use display arp snooping to display ARP snooping entries.
In standalone mode:
display arp snooping [ vlan vlan-id ] [ slot slot-number ] [ count ]
display arp snooping ip ip-address [ slot slot-number ]
In IRF mode:
display arp snooping [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ count ]
display arp snooping ip ip-address [ chassis chassis-number slot slot-number ]
vlan vlan-id: Displays ARP snooping entries for a VLAN. The vlan-id argument is in the range of 1 to 4094.
count: Displays the number of the current ARP snooping entries.
ip ip-address: Displays the ARP snooping entry for the specified IP address.
If you do not specify any keywords or arguments, the command displays all ARP snooping entries.
# Display ARP snooping entries for VLAN 2.
<Sysname> display arp snooping vlan 2
IP Address   MAC Address    VLAN ID Interface  Aging       Status
3.3.3.3      0003-0003-0003 2       GE1/0/1    20          Valid
3.3.3.4      0004-0004-0004 2       GE1/0/2    5           Invalid
# Display the number of the current ARP snooping entries.
<Sysname> display arp snooping count
Total entries: 2
IP Address
IP address in an ARP snooping entry.
MAC Address
MAC address in an ARP snooping entry.
VLAN ID
ID of the VLAN to which the ARP snooping entry belongs.
Input interface in an ARP snooping entry.
Aging
Aging time for an ARP snooping entry in minutes.
If the card learns an ARP snooping entry from another card, the card cannot learn the aging time of the entry, and this field displays N/A.
Status
Status of an ARP snooping entry: Valid, Invalid, Collision.
Total entries
Number of ARP snooping entries.
reset arp snooping
reset arp snooping
Use reset arp snooping to remove ARP snooping entries.
reset arp snooping [ ip ip-address | vlan vlan-id ]
ip ip-address: Removes the ARP entry for the specified IP address.
vlan vlan-id: Removes ARP entries for the specified VLAN. The vlan-id argument is in the range of 1 to 4094.
If you do not specify any keywords or arguments, the command removes all ARP snooping entries.
# Remove ARP snooping entries for VLAN 2.
<Sysname> reset arp snooping vlan 2
ARP fast-reply commands
arp fast-reply enable
Use arp fast-reply enable to enable ARP fast-reply for a VLAN.
Use undo arp fast-reply enable to disable ARP fast-reply for a VLAN.
ARP fast-reply is disabled on a VLAN.
VLAN view
# Enable ARP fast-reply for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] arp fast-reply enable
ARP proxy forwarding commands
arp proxy-forwarding
Use arp proxy-forwarding to enable the ARP proxy forwarding feature.
Use undo arp proxy-forwarding to disable ARP proxy forwarding.
ARP proxy forwarding is disabled.
VLAN interface view
# Enable ARP proxy forwarding on VLAN-interface 10.
[Sysname-Vlan-interface10] arp proxy-forwarding
