13-OAA Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10313-OAA Command Reference
Table of Contents
Related Documents
02-ACSEI Commands
02-ACSEI Commands 74.8 KB
ACSEI configuration commands
acsei client reboot
acsei client reboot client-id
View
ACSEI server view
Default level
2: System level
client-id: ID of the ACSEI client to be restarted.
Use the acsei client reboot command to restart the specified ACSEI client.
# Restart ACSEI client 1.
[Sysname] acsei server
[Sysname-acsei-server] acsei client reboot 1
acsei server
acsei server
View
Default level
2: System level
None
Use the acsei server command to enter ACSEI server view.
You can use the acsei server command to enter ACSEI server view only when you enable the ACSEI server function with the acsei server enable command.
# Enter ACSEI server view.
acsei server enable
acsei server enable
undo acsei server enable
View
Default level
2: System level
None
Use the acsei server enable command to enable ACSEI server.
Use the undo acsei server enable command to disable ACSEI server.
By default, ACSEI server is disabled.
# Enable ACSEI server.
[Sysname] acsei server enable
acsei timer clock-sync
acsei timer clock-sync minutes
undo acsei timer clock-sync
View
ACSEI server view
Default level
2: System level
minutes: Value of the synchronization timer that is used for clock synchronization from ACSEI server to ACSEI client. It ranges from 0 to 1440 (in minutes), where value 0 disables the clock synchronization from ACSEI server to ACSEI client.
Use the acsei timer clock-sync command to set the synchronization timer that is used for clock synchronization from ACSEI server to ACSEI client.
Use the undo acsei timer clock-sync command to restore the default.
By default, the clock sychronization timer is set to five minutes.
# Set the clock synchronization timer from ACSEI server to ACSEI client to 20 minutes.
[Sysname-acsei-server] acsei timer clock-sync 20
acsei timer monitor
acsei timer monitor seconds
undo acsei timer monitor
View
ACSEI server view
Default level
2: System level
seconds: Value of the monitoring timer that is used for ACSEI server to monitor ACSEI clients. It ranges from 0 to 10 (in seconds), where 0 disables ACSEI server from monitoring ACSEI client.
Use the acsei timer monitor command to set the monitoring timer for ACSEI server to monitor ACSEI client.
Use the undo acsei timer monitor command to restore the default.
By default, the monitoring timer is set to 5 seconds.
# Set the monitor timer for ACSEI server to monitor ACSEI client to 6 seconds.
[Sysname-acsei-server] acsei timer monitor 6
display acsei client info
display acsei client info [ client-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
client-id: ID of an ACSEI client.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display acsei client info command to display the ACSEI client information. The client information is retrieved from the advertisement packet sent by the client, so that when there is no ACSEI client information, the command displays the information keywords only.
If executed without the client-id argument, the command displays information about all the ACSEI clients in order of registration time.
# Display information about ACSEI client 1.
<Sysname> display acsei client info 1
 client ID: 1
 client Description: Intrusion Prevention System
 Hardware: 2.0
 System Software: i-Ware software, Version 1.10
 Application Software: Ess 2111
 CPU: RMI XLR732
 PCB Version: Ver.A
 CPLD Version: 2.0
 Bootrom Version: 1.28
 CF card: 247MB
 Memory: 1993MB
 Harddisk: 0MB
# Display information about all ACSEI clients.
 Total client Number: 1
 client ID: 1
 Hardware: 2.0
 CPU: RMI XLR732
 PCB Version: Ver.A
 CPLD Version: 2.0
 CF card: 247MB
 Memory: 1993MB
 Harddisk: 0MB
Table 1 Output description
client ID
client Description
ACSEI client description
Hardware
Hardware version of the ACSEI client
System Software
System software name and version of the ACSEI client
Application name and version of the ACSEI client
CPU
CPU information of the ACSEI client
PCB Version
PCB version of the ACSEI client
CPLD Version
CPLD version of the ACSEI client
Bootrom Version
Boot ROM version of the ACSEI client
CF card
CF card information of the ACSEI client
Memory
Memory information of the ACSEI client
Harddisk
Harddisk information of the ACSEI client
display acsei client summary
display acsei client summary [ client-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
client-id: ID of an ACSEI client whose summary is to be displayed.
Use the display acsei client summary command to display ACSEI client summary information. Summary information of multiple ACSEI clients is displayed in order of registration time.
If executed without the client-id argument, the command displays summary information about all the ACSEI clients.
# Display the summary of all ACSEI clients.
<Sysname> display acsei client summary
 client ID: 1
 Status: Open
 MAC Address: 3ce5-a604-d100
 Interface: Ten-GigabitEthernet4/0/1
 Last registered:  08/20/2010 13:36:54
Table 2 Output description
client ID
Status
ACSEI client status
MAC Address
MAC address of the ACSEI client
Interface carrying the ACSEI client
Last registered
The last registration time of the ACSEI client
