11-High Availability Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10311-High Availability Command Reference
06-Track Commands
06-Track Commands 84.45 KB
Track configuration commands
display track
display track { track-entry-number | all } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
track-entry-number: Displays information about the specified track entry, in the range of 1 to 1024.
all: Displays information about all the track entries.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display track command to display track entry information.
# Display information about all track entries.
<Sysname> display track all
Track ID: 1
  Status: Positive (notify 13 seconds later)
  Duration: 0 days 0 hours 0 minutes 7 seconds
  Notification delay: Positive 20, Negative 30 (in seconds)
  Reference object:
    NQA entry: admin test
    Reaction: 10
Track ID: 2
  Status: Invalid
  Reference object:
    BFD session:
    Packet type: Echo
    Interface   : GigabitEthernet 3/1/1
    Remote IP   : 192.168.40.1
    Local IP    : 192.168.40.2
Track ID: 3
  Status: Negative
  Reference object:
    Track interface  :
    Interface status : Inserted
    Interface        : GigabitEthernet 3/1/9
    Protocol         : IPv4
Table 1 Output description
Track ID
ID of a track entry.
Status
Status of a track entry:
·       Positive—The tracked object functions properly.
·       Invalid—The tracked object is invalid.
·       Negative—The tracked object is abnormal.
The track module notifies the application modules of the track entry state change 13 seconds later. The information is not displayed after the track module notifies the application modules.
Duration
Time period during which the track entry stays in the state.
·       The track module notifies the application modules that the status of the track entry changes to Positive after a delay time of 20 seconds.
·       The track module notifies the application modules that the status of the track entry changes to Negative after a delay time of 30 seconds.
Reference object
The tracked object associated with the track entry.
NQA entry
The NQA test group associated with the track entry.
Reaction
The reaction entry associated with the track entry.
BFD session
Information about the BFD session associated with the track entry.
Packet type
Type of the BFD session packets, which can only be Echo.
Outgoing interface of BFD echo packets.
Remote IP
Remote IP address of the BFD echo packets.
Local IP
Local IP address of the BFD echo packets.
Track interface
Information of the interface associated with the track entry.
Interface status
Interface status:
·       Inserted
·       Removed
Interface to be monitored.
Protocol
Physical status or Layer 3 protocol status of the monitored interface:
·       None—Physical status of the monitored interface.
·       IPv4—IPv4 protocol status of the monitored Layer 3 interface.
·       IPv6—IPv6 protocol status of the monitored Layer 3 interface.
track bfd echo
track track-entry-number bfd echo interface interface-type interface-number remote ip remote-ip local ip local-ip [ delay { negative negative-time | positive positive-time } * ]
undo track track-entry-number
View
Default level
2: System level
track-entry-number: Track entry ID, in the range of 1 to 1024.
interface interface-type interface-number: Specifies the outgoing interface for BFD echo packets. interface-type interface-number represents the interface type and interface number.
remote ip remote-ip: Specifies the destination IP address of the BFD echo packets.
local ip local-ip: Specifies the source IP address of the BFD echo packets.
delay: Specifies that the track module notifies the application modules of the track entry status change after a specific delay time. If this keyword is not provided, the track module notifies the application modules immediately when the track entry status changes.
negative negative-time: Specifies the delay time for the track module to notify the application modules that the status of the track entry changes to Negative. negative-time represents the delay time in seconds, in the range of 1 to 300.
positive positive-time: Specifies the delay time for the track module to notify the application modules that the status of the track entry changes to Positive. positive-time represents the delay time in seconds, in the range of 1 to 300.
Use the track bfd echo command to create a track entry, associate it with the BFD session, specify to use echo packets in BFD probes, and specify the delay time for the track module to notify the application modules when the status of the track entry changes.
Use the undo track command to remove the track entry.
By default, no track entry exists.
After a track entry is created, you cannot change its settings except the delay time. To change the delay time for this track entry, use the track bfd echo delay command. To modify other settings of this track entry, first delete the entire track entry, and then recreate a new track entry.
When configuring collaboration between track and BFD, do not configure the virtual IP address of a VRRP group as the local or remote address of a BFD session.
Related commands: display track.
# Create track entry 1, which uses BFD to monitor the link between local IP address 192.168.40.2 and remote IP address 192.168.40.1 by sending BFD echo packets.
[Sysname] track 1 bfd echo interface GigabitEthernet 3/1/1 remote ip 192.168.40.1 local ip 192.168.40.2
track interface
track track-entry-number interface interface-type interface-number [ delay { negative negative-time | positive positive-time } * ]
View
Default level
2: System level
interface-type interface-number: Type and number of the interface to be monitored.
negative negative-time: Specifies the delay time for the track module to notify the application modules that the status of the track entry changes to Negative. negative-time represents the delay time in seconds, in the range o 1 to 300.
Use the track interface command to create a track entry, associate it with the physical status of a specific interface, and specify the delay time for the track module to notify the application modules when the status of the track entry changes.
After a track entry is created, you cannot change its settings except the delay time. To change the delay time, use the track interface delay command. To modify other settings of this track entry, first delete the entire track entry, and then create a new track entry.
When a track entry to be associated with the physical status of a specific interface is created, the status of the track entry is Positive if the physical status of the interface is up. The status of the track entry is Negative if the physical status of the interface is down. To display the physical status of an interface, use the display ip interface brief command.
Related commands: display track; display ip interface brief (Layer 3—IP Services Command Reference).
# Create track entry 1 and associate it with the physical status of interface GigabitEthernet 3/1/1.
[Sysname] track 1 interface GigabitEthernet 3/1/1
track interface protocol
track track-entry-number interface interface-type interface-number protocol { ipv4 | ipv6 } [ delay { negative negative-time | positive positive-time } * ]
View
Default level
2: System level
ipv4: IPv4 protocol status of the interface to be monitored. When the IPv4 protocol status of an interface is up, the status of the track object is Positive. When the IPv4 protocol status of an interface is down, the status of the track object is Negative. To display the IPv4 protocol status of an interface, use the display ip interface brief command.
ipv6: IPv6 protocol status of the interface to be monitored. When the IPv6 protocol status of an interface is up, the status of the track object is Positive. When the IPv6 protocol status of an interface is down, the status of the track object is Negative. To display the IPv6 protocol status of an interface, use the display ipv6 interface command.
Use the track interface protocol command to create a track entry, associate it with the protocol status of a specific interface, and specify the delay time for the track module to notify the application modules when the status of the track entry changes.
After a track entry is created, you cannot change its settings except the delay time. To change the delay time, use the track interface protocol delay command. To modify other settings of this track entry, first delete the entire track entry, and then recreate a new track entry.
Related commands: display track; display ip interface brief (Layer 3—IP Services Command Reference); display ipv6 interface (Layer 3—IP Services Command Reference).
# Create track entry 1 and associate it with the IPv4 protocol status of interface GigabitEthernet 3/1/1.
[Sysname] track 1 interface GigabitEthernet 3/1/1 protocol ipv4
track nqa
track track-entry-number nqa entry admin-name operation-tag reaction item-number [ delay { negative negative-time | positive positive-time } * ]
View
Default level
2: System level
entry admin-name operation-tag: Specifies the NQA test group to be associated with the track entry. admin-name is the name of the NQA test group administrator who creates the NQA operation, and is a case-insensitive string of 1 to 32 characters. operation-tag is the NQA operation tag, and is a case-insensitive string of 1 to 32 characters.
reaction item-number: Specifies the reaction entry to be associated with the track entry. item-number is the reaction entry ID, in the range of 1 to 10.
Use the track nqa command to create a track entry, associate it with the specified reaction entry of the NQA test group, and specify the delay time for the track module to notify the application modules when the status of the track entry changes.
By default, no track entry to be associated with the track entry is created.
After a track entry is created, you cannot change its settings except the delay time. To change the delay time, use the track nqa delay command. To modify other settings of this track entry, first delete the entire track entry, and then recreate a new track entry.
Related commands: display track; nqa and reaction (Network Management and Monitoring Command Reference).
# Create track entry 1 and associate it with reaction entry 3 of the NQA test group (admin-test).
[Sysname] track 1 nqa entry admin test reaction 3
