11-High Availability Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10311-High Availability Command Reference
02-Ethernet OAM Commands
02-Ethernet OAM Commands 126.59 KB
In this documentation, SPC cards refer to the cards prefixed with SPC, for example, SPC-GT48L. SPE cards refer to the cards prefixed with SPE, for example, SPE-1020-E-II.
display oam
display oam { local | remote } [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
local: Displays the Ethernet OAM connection information of the local end.
remote: Displays the Ethernet OAM connection information of the remote end.
interface interface-type interface-number: Specifies a port by its type and number.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display oam command to display the information about an Ethernet OAM connection, including connection status, information contained in Ethernet OAM packet header, and Ethernet OAM packet statistics.
If you do not specify the interface keyword, this command displays the information about all the Ethernet OAM connections.
Related commands: reset oam.
# Display the information about the Ethernet OAM connection established on the local port GigabitEthernet 5/1/1.
<Sysname> display oam local interface GigabitEthernet5/1/1
Port        : GigabitEthernet5/1/1
Link Status : Up
EnableStatus              : Enable
Local_oam_mode            : Active      Local_pdu              : ANY
Local_mux_action          : FWD         Local_par_action       : FWD
OAMLocalFlagsField :
Link Fault                : 0           Dying Gasp             : 0
Critical Event            : 0           Local Evaluating       : COMPLETE
Remote Evaluating         : COMPLETE
Packets statistic :
Packets                        Send                   Receive
OAMPDU                         645                    648
OAMInformation                 645                    648
OAMEventNotification           0                      --
OAMUniqueEventNotification     --                     0
OAMDuplicateEventNotification  --                     0
Table 1 Output description
Port
Port index.
Link Status
Link status (up or down).
EnableStatus
Ethernet OAM state (enabled or disabled).
Local_oam_mode
Local Ethernet OAM mode:
·       Active—The port operates in the active Ethernet OAM mode.
·       Passive—The port operates in the passive Ethernet OAM mode.
Local_pdu
The way in which the local end processes Ethernet OAMPDUs:
·       RX_INFO—The port only receives Information OAMPDUs and does not send any Ethernet OAMPDUs.
·       LF_INFO—The port only sends the Information OAMPDUs without Information TLV triplets and with their link error flag bits being set.
·       INFO—The port sends and receives only Information OAMPDUs.
·       ANY—The port sends and receives Ethernet OAMPDUs of any type.
Local_mux_action
Working mode of the local transmitter:
·       FWD—The port can send any packets.
·       DISCARD—The port only sends Ethernet OAMPDUs.
Local_par_action
Working mode of the local receiver:
·       FWD—The port can receive any packets.
·       DISCARD—The port only receives Ethernet OAMPDUs.
·       LB—The local receiver is in loopback state. All the packets other than Ethernet OAMPDUs received on the local receiver are returned to their sources along the ways they come.
OAMLocalFlagsField
Local flags inserted in the local flag fields of the Ethernet OAMPDUs sent.
Link Fault
Indicates whether an Ethernet OAM link error is present: 0 for no and 1 for yes.
Dying Gasp
Indicates whether a fatal error is present: 0 for no and 1 for yes.
Critical Event
Indicates whether a critical error is present: 0 for no and 1 for yes.
Local Evaluating
Indicates whether the local-to-remote configuration negotiation is complete:
·       COMPLETE—Completed.
·       REVERSED—Uncompleted.
Remote Evaluating
Indicates whether the remote-to-local configuration negotiation is complete:
Packets statistic
Statistics about Ethernet OAMPDUs sent and received.
OAMPDU
Total number of the Ethernet OAMPDUs sent and received.
OAMInformation
Number of the Information OAMPDUs sent and received.
Number of the Event notification OAMPDUs sent and received.
Number of the unduplicated Event notification OAMPDUs sent or received uniquely.
Number of the duplicate Event notification OAMPDUs sent or received.
# Display the Ethernet OAM information of the peer port GigabitEthernet 5/1/1.
<Sysname> display oam remote interface GigabitEthernet5/1/1
Link Status : Up
Information of the latest received OAM packet:
OAMRemoteMACAddress       : 00e0-fd73-6502
OAMRemotePDUConfiguration : 1500
OAMRemoteState :
Remote_mux_action         : FWD         Remote_par_action      : FWD
OAMRemoteConfiguration :
OAM Mode                  : Active      Unidirectional Support : YES
Loopback Support          : YES         Link Events            : YES
Variable Retrieval        : NO
OAMRemoteFlagsField :
Table 2 Output description
Port
Port index.
Link Status
Link status.
Information about the latest received Ethernet OAMPDU.
OAMRemoteMACAddress
MAC address of the Ethernet OAM peer.
Maximum Ethernet OAMPDU size allowed.
OAMRemoteState
State of the Ethernet OAM peer.
Remote_mux_action
Peer sending mode. For more information, see Table 1.
Remote_par_action
Peer receiving mode. For more information, see Table 1.
Configuration of the peer Ethernet OAM entity.
OAM Mode
Ethernet OAM mode.
Indicates whether unidirectional transmission is supported (YES or NO).
Loopback Support
Indicates whether Ethernet OAM remote loopback is supported (YES or NO).
Link Events
Indicates whether Ethernet OAM link error events are supported (YES or NO).
Variable Retrieval
Indicates whether MIB variable retrieval is supported (YES or NO).
OAMRemoteFlagsField
Values of the peer Ethernet OAM flag fields in OAM packets.
Link Fault
Indicates whether a link fault is present: 0 for no and 1 for yes.
Dying Gasp
Indicate whether a fatal fault is present: 0 for no and 1 for yes.
Critical Event
Indicate whether a critical fault is present: 0 for no and 1 for yes.
Local Evaluating
Remote Evaluating
display oam configuration
display oam configuration [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
Use the display oam configuration command to display global Ethernet OAM configuration, including the periods and thresholds for Ethernet OAM link error event detection.
Related commands: oam errored-frame period, oam errored-frame threshold, oam errored-frame-period period, oam errored-frame-period threshold, oam errored-frame-seconds period, and oam errored-frame-seconds threshold.
# Display global Ethernet OAM configuration.
<Sysname> display oam configuration
Configuration of the link event window/threshold :
Errored-symbol Event period(in seconds)           :     1
Errored-symbol Event threshold                    :     1
Errored-frame Event period(in seconds)            :     1
Errored-frame Event threshold                     :     1
Errored-frame-period Event period(in ms)          :     1000
Errored-frame-period Event threshold              :     1
Errored-frame-seconds Event period(in seconds)    :     60
Errored-frame-seconds Event threshold             :     1
Table 3 Output description
Detection intervals and triggering thresholds configured for link events.
Errored-symbol Event period (in seconds)
Errored symbol event detection interval, which defaults to one second.
Errored symbol event triggering threshold, which defaults to 1.
Errored-frame Event period (in seconds)
Errored frame event detection interval, which defaults to one second.
Errored frame event triggering threshold, which defaults to 1.
Errored-frame-period Event period (in ms)
Errored frame period event detection interval, which defaults to 1000 milliseconds.
Errored frame period event triggering threshold, which defaults to 1.
Errored-frame-seconds Event period (in seconds)
Errored frame seconds event detection interval, which defaults to 60 seconds.
Errored frame seconds event triggering threshold, which defaults to 1.
display oam critical-event
display oam critical-event [ interface interface-type interface-number] [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
Use the display oam critical-event command to display the statistics on critical Ethernet OAM link events occurred on a port.
If you do not specify the interface keyword, this command displays the statistics on the critical Ethernet OAM link events occurred on all the ports of the switch.
# Display the statistics on critical Ethernet OAM link events occurred on all the ports.
<Sysname> display oam critical-event
Link Status : Up
Event statistic :
Link Fault    :0    Dying Gasp    : 0    Critical Event    : 0
Table 4 Output description
Port
Port index
Link Status
Link status
Event statistic
Statistics on critical Ethernet OAM link events
Link Fault
Dying Gasp
Critical Event
display oam link-event
display oam link-event { local | remote } [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
local: Displays the statistics on the local Ethernet OAM link error events.
remote: Displays the statistics on the peer Ethernet OAM link error events.
Use the display oam link-event command to display the statistics on Ethernet OAM link error events occurred on a local port or a peer port. Ethernet OAM link error events include errored symbol events, errored frame events, errored frame period events, and errored frame seconds events.
If you do not specify the interface keyword, this command displays the statistics on the Ethernet OAM link error events occurred on all the local/peer ports.
Related commands: display oam configuration and reset oam.
# Display the statistics on Ethernet OAM link error events occurred on all the local ports.
<Sysname> display oam link-event local
Link Status : Up
OAMLocalErrFrameEvent : (ms = milliseconds)
Event Time Stamp          : 3539        Errored Frame Window  : 10(100ms)
Errored Frame Threshold   : 5           Errored Frame         : 1488111
Error Running Total       : 260908758   Event Running Total   : 307
OAMLocalErrFramePeriodEvent :
Event Time Stamp          : 3539        Errored Frame Window  : 976500
Errored Frame Threshold   : 1           Errored Frame         : 1042054
Error Running Total       : 260909151   Event Running Total   : 471
OAMLocalErrFrameSecsSummaryEvent : (ms = milliseconds)
Event Time Stamp : 3389
Errored Frame Second Summary Window     : 600(100ms)
Errored Frame Second Summary Threshold  : 1
Errored Frame Second Summary            : 60
Error Running Total       : 292         Event Running Total   : 5
Table 5 Output description
Port
Port index.
Link Status
Link status.
Information about local errored frame events:
·       Event Time Stamp—Time when an errored frame event occurred (in 100 milliseconds).
·       Errored Frame Window—Error frame detection interval (in 100 milliseconds).
·       Errored Frame Threshold—Error threshold that triggers an errored frame event.
·       Errored Frame—Number of detected error frames over the specific detection interval.
·       Error Running Total—Total number of error frames.
·       Event Running Total—Total number of errored frame events that have occurred.
Information about local errored frame period events:
·       Errored Frame Window—Maximum number of 64-byte frames that can be transmitted through an Ethernet port over the configured error frame period detection interval. For more information, see the “oam errored-frame-period period” command.
·       Errored Frame Threshold—Error threshold that triggers an error frame period event.
·       Errored Frame—Number of detected error frames over a detection interval.
·       Error Running Total—Total number of error frames that have detected.
·       Event Running Total—Total number of error frame period events.
Information about local errored frame seconds events:
·       Event Time Stamp—Time when an error frame seconds event occurred (in terms of 100 milliseconds).
·       Errored Frame Second Summary Window—Error frame second detection interval (in 100 milliseconds).
·       Errored Frame Second Summary Threshold—Error threshold that triggers an error frame seconds event.
·       Errored Frame Second Summary—Number of detected error frame seconds over a detection interval.
·       Error Running Total—Total number of error frame seconds.
·       Event Running Total—Total number of error frame seconds events that have occurred.
# Display Ethernet OAM link event statistics of the remote ends of all the ports.
<Sysname> display oam link-event remote
Link Status :Up
OAMRemoteErrFrameEvent : (ms = milliseconds)
Event Time Stamp          : 5789        Errored Frame Window   : 10(100ms)
Errored Frame Threshold   : 1           Errored Frame         : 3
Error Running Total       : 35          Event Running Total   : 17
Table 6 Output description
Port
Port index.
Link Status
Link status.
Information about remote errored frame events:
oam enable
oam enable
undo oam enable
View
Ethernet port view
Default level
2: System level
None
Use the oam enable command to enable Ethernet OAM on the Ethernet port.
Use the undo oam enable command to disable Ethernet OAM on the Ethernet port.
By default, Ethernet OAM is disabled on all Ethernet ports.
# Enable OAM on port GigabitEthernet 5/1/1.
[Sysname] interface GigabitEthernet 5/1/1
[Sysname-GigabitEthernet5/1/1] oam enable
oam errored-frame period period-value
undo oam errored-frame period
View
Default level
2: System level
period-value: Errored frame event detection interval, ranging from 1 to 60 (in seconds).
Use the oam errored-frame period command to set the errored frame event detection interval.
Use the undo oam errored-frame period command to restore the default.
By default, the errored frame event detection interval is one second.
Related commands: oam errored-frame threshold, display oam link-event, and display oam configuration.
# Set the errored frame event detection interval to 10 seconds.
[Sysname] oam errored-frame period 10
oam errored-frame threshold threshold-value
undo oam errored-frame threshold
View
Default level
2: System level
threshold-value: Errored frame event triggering threshold, ranging from 0 to 4294967295.
Use the oam errored-frame threshold command to set the errored frame event triggering threshold.
Use the undo oam errored-frame threshold command to restore the default.
By default, the errored frame event triggering threshold is 1.
Related commands: oam errored-frame period, display oam link-event, and display oam configuration.
# Set the errored frame event triggering threshold to 100.
[Sysname] oam errored-frame threshold 100
oam errored-frame-period period period-value
undo oam errored-frame-period period
View
Default level
2: System level
period-value: Errored frame period event detection interval, ranging from 100 to 60000 (in milliseconds).
Use the oam errored-frame-period period command to set the errored frame period event detection interval.
Use the undo oam errored-frame-period period command to restore the default.
By default, the errored frame period event detection interval is 1000 milliseconds.
As for errored frame period event detection, the system first uses the following expression to convert the errored frame period event detection interval to the maximum number of 64-byte frames that can be transmitted through an Ethernet port in the period:
bandwidth * period / (64 * 8 * 1000),
where bandwidth is the port bandwidth (in bps) and “period” is the configured period (in milliseconds).
Related commands: oam errored-frame-period threshold, display oam link-event, and display oam configuration.
# Set the errored frame period event detection interval to 10 seconds (10000 milliseconds).
[Sysname] oam errored-frame-period period 10000
oam errored-frame-period threshold threshold-value
undo oam errored-frame-period threshold
View
Default level
2: System level
threshold-value: Errored frame period event triggering threshold, ranging from 0 to 4294967295.
Use the oam errored-frame-period threshold command to set the errored frame period event triggering threshold.
Use the undo oam errored-frame-period threshold command to restore the default.
By default, the errored frame period event triggering threshold is 1.
Related commands: oam errored-frame-period period, display oam link-event, and display oam configuration.
# Set the errored frame period event triggering threshold to 100.
[Sysname] oam errored-frame-period threshold 100
oam errored-frame-seconds period period-value
undo oam errored-frame-seconds period
View
Default level
2: System level
period-value: Errored frame seconds event detection interval, ranging from 10 to 900 (in seconds).
Use the oam errored-frame-seconds period command to set the errored frame seconds event detection interval.
Use the undo oam errored-frame-seconds period command to restore the default.
By default, the errored frame seconds event detection interval is 60 seconds.
Related commands: oam errored-frame-seconds threshold, display oam link-event, and display oam configuration.
# Set the errored frame seconds event detection interval to 100 seconds.
[Sysname] oam errored-frame-seconds period 100
oam errored-frame-seconds threshold threshold-value
undo oam errored-frame-seconds threshold
View
Default level
2: System level
threshold-value: Errored frame seconds event triggering threshold, ranging from 0 to 900.
Use the oam errored-frame-seconds threshold command to set the errored frame seconds event triggering threshold.
Use the undo oam errored-frame-seconds threshold command to restore the default.
By default, the errored frame seconds event triggering threshold is 1.
Related commands: oam errored-frame-seconds period, display oam link-event, and display oam configuration.
# Set the errored frame seconds event triggering threshold to 100.
[Sysname] oam errored-frame-seconds threshold 100
oam loopback
oam loopback
undo oam loopback
View
Ethernet port view
Default level
2: System level
None
Use the oam loopback command to enable Ethernet OAM remote loopback on an Ethernet port.
Use the undo oam loopback command to disable Ethernet OAM remote loopback.
By default, Ethernet OAM remote loopback is disabled.
Ethernet OAM remote loopback is available only after the Ethernet OAM connection is established and can be performed only by the Ethernet OAM entities operating in active Ethernet OAM mode.
Only the SPC cards support Ethernet OAM remote loopback.
Related commands: oam enable and oam mode.
# Configure the active Ethernet OAM mode, enable Ethernet OAM, and enable Ethernet OAM remote loopback on GigabitEthernet 5/1/1.
[Sysname-GigabitEthernet5/1/1] oam mode active
[Sysname-GigabitEthernet5/1/1] oam loopback
oam loopback reject-request
undo oam loopback reject-request
View
Ethernet port view
Default level
2: System level
None
Use the oam loopback reject-request command to configure a port to reject the Ethernet OAM remote loopback request from a remote port.
Use the undo loopback reject-request command to restore the default.
By default, a port does not reject the Ethernet OAM remote loopback request from a remote port.
This command is available only on the SPC cards.
# Configure GigabitEthernet 5/1/1 to reject the Ethernet OAM remote loopback request from a remote port.
[Sysname] interface GigabitEthernet5/1/1
[Sysname-GigabitEthernet5/1/1] oam loopback reject-request
oam mode
oam mode { active | passive }
undo oam mode
View
Ethernet port view
Default level
2: System level
active: Specifies the active Ethernet OAM mode.
passive: Specifies the passive Ethernet OAM mode.
Use the oam mode command to set the Ethernet OAM mode for an Ethernet port.
Use the undo oam mode command to restore the default.
By default, an Ethernet OAM-enabled Ethernet port operates in the active Ethernet OAM mode.
To change the Ethernet OAM mode of an Ethernet OAM-enabled Ethernet port, you need to disable Ethernet OAM on the port first.
Related commands: oam enable.
# Disable Ethernet OAM on GigabitEthernet 5/1/1, and then configure GigabitEthernet 5/1/1 to operate in passive Ethernet OAM mode.
[Sysname-GigabitEthernet5/1/1] undo oam enable
[Sysname-GigabitEthernet5/1/1] oam mode passive
reset oam
reset oam [ interface interface-type interface-number ]
View
Default level
2: System level
Use the reset oam command to clear the statistics on Ethernet OAM packets and Ethernet OAM link error events of an Ethernet port.
If you do not specify the interface keyword, this command clears the statistics on Ethernet OAM packets and Ethernet OAM link error events of all the ports.
Related commands: display oam and display oam link-event.
# Clear the statistics on Ethernet OAM packets and Ethernet OAM link error events of all the ports.
<Sysname> reset oam
