03-Layer 2 - LAN Switching Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10303-Layer 2 - LAN Switching Command Reference
09-VLAN Termination Commands
09-VLAN Termination Commands 78.14 KB
·       In this documentation, SPC cards refer to the cards prefixed with SPC, for example, SPC-GT48L, and SPE cards refer to the cards prefixed with SPE, for example, SPE-1020-E-II.
·       Only SPE cards support VLAN termination.
dot1q ethernet-type
dot1q ethernet-type hex-value
undo dot1q ethernet-type
View
Layer 3 Ethernet interface view, Layer 3 aggregate interface view
Default level
2: System level
hex-value: Hexadecimal tag protocol identifier (TPID) value, excluding the common protocol type values listed in Table 1.
Table 1 Common protocol type values
Protocol
Value
ARP
0x0806
PUP
0x0200
RARP
0x8035
IP
0x0800
IPv6
0x86DD
PPPoE
0x8863/0x8864
MPLS
0x8847/0x8848
IPX/SPX
0x8137
IS-IS
0x8000
LACP
0x8809
802.1X
0x888E
Cluster
0x88A7
Reserved on the router
0xFFFD/0xFFFE/0xFFFF
Use the dot1q ethernet-type command to set the TPID value in the outer VLAN tag of packets received and sent by the interface. If the interface receives and sends QinQ packets, the TPID value in the inner VLAN tag of packets is always 0x8100, and is not configurable.
Use the undo dot1q ethernet-type command to restore the default.
By default, the TPID value for VLAN-tagged packets received and sent by the router is 0x8100.
After you configure the TPID value, only packets whose TPID is 0x8100 or the value you configured will be processed as VLAN-tagged packets. When a packet is sent out the interface, the TPID value you configured will be applied in the VLAN tag of the packet.
The dot1q ethernet-type command can be configured only on main Layer 3 Ethernet interfaces and Layer 3 aggregate interfaces, not on subinterfaces or aggregation member ports. A main Layer 3 Ethernet interface configured with this command cannot be added to an aggregation group.
Configurations made in Layer 3 Ethernet interface view apply to all its subinterfaces. Configurations made in Layer 3 aggregate interface view apply to all Layer 3 aggregate subinterfaces of the interface.
To change a non-default TPID value to another non-default TPID value, you must first restore the default TPID value, 0x8100.
Configuration of this command on an interface of a card applies to all interfaces on the card.
# Set the TPID value of the VLAN-tagged packets that can be received and sent by Layer 3 aggregate interface Route-Aggregation 2 to 0x9100.
[Sysname] interface Route-Aggregation 2
[Sysname-Route-Aggregation2] dot1q ethernet-type 9100
second-dot1q
second-dot1q { any | vlan-id-list }
undo second-dot1q { any | vlan-id-list }
View
Layer 3 Ethernet subinterface view, Layer 3 aggregate subinterface view, VLAN interface view
Default level
2: System level
any: Configure the subinterface or VLAN interface to terminate any QinQ packet whose outer VLAN ID is the subinterface number and whose inner VLAN ID ranges from 1 to 4094.
vlan-id-list: A list of inner VLAN IDs in the format of vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>, where the vlan-id argument ranges from 1 to 4094 and &<1-10> indicates that you can specify up to 10 inner VLAN ID ranges.
Use the second-dot1q command to enable QinQ termination, and specify the inner VLAN IDs of the QinQ packets that can be terminated by the subinterface or VLAN interface. The outer VLAN ID of QinQ packets that can be terminated by the subinterface is the subinterface number, and is not configurable.
Use the undo second-dot1q command to restore the default.
By default, a subinterface or VLAN interface terminates only Dot1q packets.
After you configure the second-dot1q command, the subinterface or VLAN interface can only terminate QinQ packets.
After you use the undo second-dot1q command to disable the subinterface or VLAN interface from terminating QinQ packets, the subinterface will restart, and the ARP table entry corresponding to the subinterface will be removed.
# Configure GigabitEthernet 2/1/7.20 to terminate QinQ packets with inner VLAN IDs ranging from 10 to 20; configure GigabitEthernet 2/1/7.25 to terminate QinQ packets with inner VLAN ID 100; configure GigabitEthernet 2/1/7.100 to terminate QinQ packets with any inner VLAN ID.
[Sysname] interface GigabitEthernet2/1/7.20
[Sysname-GigabitEthernet2/1/7.20] second-dot1q 10 to 20
[Sysname-GigabitEthernet2/1/7.20] quit
[Sysname] interface GigabitEthernet2/1/7.25
[Sysname-GigabitEthernet2/1/7.25] second-dot1q 100
[Sysname-GigabitEthernet2/1/7.25] quit
[Sysname] interface GigabitEthernet2/1/7.100
[Sysname-GigabitEthernet2/1/7.100] second-dot1q any
The following table describes the results of the configuration:
Outer VLAN ID of QinQ packets that the subinterface can terminate
Inner VLAN IDs of QinQ packets that the subinterface can terminate
20
10–20
25
100
100
1–4094
# Configure VLAN-interface 10 to terminate QinQ packets with inner VLAN IDs ranging from 10 to 20; configure VLAN-interface 12 to terminate QinQ packets with inner VLAN ID 100; configure VLAN-interface 100 to terminate QinQ packets with any inner VLAN ID.
[Sysname] interface Vlan-interface 10
[Sysname-Vlan-interface10] second-dot1q 10 to 20
[Sysname-Vlan-interface10] quit
[Sysname] interface Vlan-interface 12
[Sysname-Vlan-interface12] second-dot1q 100
[Sysname-Vlan-interface12] quit
[Sysname] interface Vlan-interface 100
[Sysname-Vlan-interface100] second-dot1q any
The following table shows the results of the configuration:
VLAN-interface 10
10
10–20
VLAN-interface 12
12
100
VLAN-interface 100
100
1–4094
vlan-termination broadcast enable
undo vlan-termination broadcast enable
View
Default level
2: System level
None
Use the vlan-termination broadcast enable command to enable the current subinterface or VLAN interface to send broadcast and multicast packets.
Use the undo vlan-termination broadcast enable command to restore the default.
By default, an ambiguous QinQ termination-enabled subinterface or VLAN interface drops broadcast and multicast packets. Ambiguous QinQ termination terminates QinQ packets with a specific range of inner VLAN IDs.
# Enable Layer 3 Ethernet subinterface GigabitEthernet 3/1/1.512 to send broadcast and multicast packets.
[Sysname] interface GigabitEthernet 3/1/1.512
[Sysname-GigabitEthernet3/1/1.512] second-dot1q 10 to 20
[Sysname-GigabitEthernet3/1/1.512] vlan-termination broadcast enable
After the above configuration, when GigabitEthernet 3/1/1.512 receives broadcast or multicast packets with VLAN IDs ranging from 10 to 20, it broadcasts or multicasts the packets within the corresponding VLANs.
