03-Layer 2 - LAN Switching Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10303-Layer 2 - LAN Switching Command Reference
06-QinQ Commands
06-QinQ Commands 80.9 KB
QinQ configuration commands
In this documentation, base cards refer to the CR-SPE-3020-E cards, and EF interface cards refer to the CR-SPC-XP8LEF, CR-SPC-XP4LEF, CR-SPC-GP48LEF, and CR-SPC-GT48LEF cards.
In this documentation, SPC cards refer to the cards prefixed with SPC, for example, SPC-GT48L, and SPE cards refer to the cards prefixed with SPE, for example, SPE-1020-E-II.
qinq enable
qinq enable
undo qinq enable
View
Layer 2 Ethernet interface view, Layer 2 aggregate interface view, port group view
Default level
2: System level
None
Use the qinq enable command to enable basic QinQ on a port or a group of ports.
Use the undo qinq enable command to disable basic QinQ.
By default, basic QinQ is disabled on ports.
A basic QinQ-enabled port tags received frames with its port VLAN (PVID) tag.
Configured in Layer 2 Ethernet interface view, the command takes effect on the interface only.
Configured in Layer 2 aggregate interface view, the command takes effect on the aggregate interface and the member ports in its aggregation group.
Configured in port group view, the command takes effect on all ports in the port group.
# Enable basic QinQ on GigabitEthernet 4/1/1.
[Sysname] interface GigabitEthernet 4/1/1
[Sysname-GigabitEthernet4/1/1] qinq enable
# Enable basic QinQ on all the ports in port group 1.
[Sysname] port-group manual 1
[Sysname]-port-group-manual-1] group-member GigabitEthernet 4/1/1 to GigabitEthernet 4/1/6
[Sysname-port-group-manual-1] qinq enable
qinq ethernet-type
qinq ethernet-type hex-value
undo qinq ethernet-type
View
Default level
2: System level
hex-value: Hexadecimal tag protocol identifier (TPID) value, excluding the common protocol type values listed in Table 1.
Table 1 Common protocol type values
Protocol type
Value
ARP
0x0806
PUP
0x0200
RARP
0x8035
IP
0x0800
IPv6
0x86DD
PPPoE
0x8863/0x8864
MPLS
0x8847/0x8848
IPX/SPX
0x8137
IS-IS
0x8000
LACP
0x8809
802.1x
0x888E
Cluster
0x88A7
Reserved
0xFFFD/0xFFFE/0xFFFF
Use the qinq ethernet-type command to configure the TPID in the outer VLAN tag on a port.
Use the undo qinq ethernet-type command to restore the default.
The default TPID for the outer VLAN tag on a port is 0x8100.
Configured in aggregate interface view, the command takes effect on the Layer 2 aggregate interface and the member ports in its aggregation group.
To change a non-default TPID value to another non-default TPID value, you must first restore the default TPID value (0x8100) on an SPE card a base card, but you can directly change the TPID value on an SPC card an EF interface card.
# Set the TPID value in the outer VLAN tags to 0x9100 on GigabitEthernet 4/1/1.
[Sysname-GigabitEthernet4/1/1] qinq ethernet-type 9100
# Set the TPID value in the outer VLAN tags to 0x9100 on all ports in port group 1.
[Sysname-port-group-manual-1] group-member GigabitEthernet 4/1/1 to GigabitEthernet 4/1/6
[Sysname-port-group-manual-1] qinq ethernet-type 9100
