02-Interface Command Reference
HomeSupportRoutersH3C SR8800 Router SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10302-Interface Command Reference
05-E-CPOS Interface Commands
05-E-CPOS Interface Commands 143.61 KB
clock
clock { master | slave }
undo clock
View
E-CPOS interface view
Default level
2: System level
master: Sets the E-CPOS interface to use the internal clock.
slave: Sets the E-CPOS interface to use the clock from the line.
Use the clock command to set the clock mode of the E-CPOS interface.
Use the undo clock command to restore the default.
By default, the clock mode of an E-CPOS interface is slave.
When an E-CPOS interface is connected to a SONET/SDH router, you need to set the clock mode of the interface to slave because the clock of a SONET/SDH network is more precise. When two E-CPOS interfaces are directly connected through an optical fiber, you can set either of them of work in slave clock mode and make sure that the two ends operate in different clock modes.
# Set the clock mode of interface E-CPOS 7/1/6 to master.
[Sysname] controller E-Cpos 7/1/6
[Sysname-E-Cpos7/1/6] clock master
controller e-cpos
controller e-cpos e-cpos-number
View
Default level
2: System level
e-cpos-number: E-CPOS interface number.
Use the controller e-cpos command to enter E-CPOS interface view.
To configure an E-CPOS interface, you must enter its interface view first.
# Enter the view of interface E-CPOS 7/1/6.
default
default
View
Default level
2: System level
None
Use the default command to restore the default settings for an E-CPOS interface.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. You can use the display this command in interface view to check for these commands, and perform their undo forms or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you perform it on a live network.
# Restore the default settings for E-CPOS interface E-CPOS 7/1/6.
[Sysname-E-Cpos7/1/6] default
This command will restore the default settings. Continue? [Y/N]:y
description
View
Default level
2: System level
text: Interface description, a case-sensitive character string of 1 to 80 characters. The description can contain letters, digits, special characters such as tilde (~), exclamation mark (!), at sign (@), number sign (#), dollar sign ($), percent (%), caret (^), ampersand (&), asterisk(*), brackets ({ }, ( ),[ ], < >), hyphen (-), underscore (_), plus (+), equal sign (=), vertical bar (|), backslash (\), colon (:), semicolon (;), quotation marks (", '), comma (,), period (.), and slash (/), spaces, and Unicode characters and symbols.
Use the description command to set the description for the E-CPOS interface.
Use the undo description command to restore the default.
By default, the description of an E-CPOS interface is interface name Interface, for example, E-Cpos7/1/6 Interface.
# Set the description for E-CPOS interface E-CPOS 7/1/6 to ecpos-interface.
[Sysname-E-Cpos7/1/6] description ecpos-interface
display controller e-cpos
display controller e-cpos [ e-cpos-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display controller e-cpos command to display information about the specified E-CPOS interface or all E-CPOS interfaces if no E-CPOS interface is specified. The output of the command includes channel status information and alarms and errors of the regenerator section, multiplex section, and high-order path.
# Display information about all channels of interface E-CPOS 7/1/6.
<Sysname> display controller E-Cpos 7/1/6
E-Cpos7/1/6 current state: UP
Description : E-Cpos7/1/6 Interface
Port connector type: OC3/STM_1_SR_SFP
Physical layer is packet over SDH
Port speed type: STM-1
Multiplex mode: AU-4
Loopback is not set
Clock source: Slave
Clock grade: DNU(Do not use for synchronization)
BER thresholds:
    SD: 10e-6    SF: 10e-3
Regenerator section layer:
    J0(TX): ""
            00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    J0(RX): ""
    Alarm: NONE
    Error: 0 BIP(B1)
Multiplex section layer:
    Alarm: NONE
    Error: 0 BIP(B2), 0 REI(M1)
Table 1 Output description
Current physical state of the E-CPOS interface
Description of the interface
Physical layer
Framing format of the interface
Loopback
Whether loopback is enabled
Clock source
Clock mode
BER thresholds
The signal degrade (SD) threshold and signal fail (SF) threshold of the E-CPOS interface
Regenerator section
Alarm and error statistics for the regenerator section
J0(TX)
J0 overhead bytes sent
J0(RX)
J0 overhead bytes received
Alarm
Alarm information
Error
Types and numbers of errors that occurred:
·       BIP—Number of bit-interleaved parity (BIP) errors
·       SEF—Severely error framing errors
Multiplex section
Alarm and error statistics for the multiplex section
e3 unframed
e3 e3-number unframed
undo e3 e3-number unframed
View
E-CPOS interface view, OC-3 view
Default level
2: System level
e3-number: E3 channel number, in the range of 1 to 3.
Use the e3 unframed command to configure the specified E3 channel on the E-CPOS interface or 155 Mbps channel to work in unframed mode.
Use the undo e3 unframed command to remove the specified E3 channel working in unframed mode on the E-CPOS interface.
By default, no E3 channel is created.
·       The E3 channels of an E-CPOS interface can work in unframed mode (also known as the clear channel mode) or framed mode (also known as the channelized mode). Currently, the router supports only the unframed mode.
·       An E3 channel working in unframed mode is a 34 Mbps serial interface without timeslot bundling.
# Configure E3 channel 3 of 155 Mbps interface E-CPOS 7/1/6 to work in unframed mode.
[Sysname-E-Cpos7/1/6] e3 3 unframed
flag j0
flag j0 { sdh j0-string | sonet j0-value }
undo flag j0 { sdh | sonet }
View
Default level
2: System level
sdh j0-string: Specifies the regenerator section trace byte for SDH. The j0-string argument is a string of 1 to 15 characters.
sonet j0-value: Specifies the regenerator section trace byte for SONET. The j0-value argument is a hexadecimal number ranging from 0 to FF and defaults to 0x01.
Use the flag j0 command to set the J0 overhead byte for SONET/SDH frames.
Use the undo flag j0 command to restore the default J0 overhead byte.
·       J0 is a section overhead byte used for detecting the continuity of the connection between two interfaces at the section layer. It is mainly used for interoperability of network devices in different countries/regions or devices of different vendors.
·       The J0 value range differs for SDH and SONET framing formats. For more information about the framing format, see the frame-format command.
# Set j0 to aa on interface E-CPOS 7/1/6 in SDH mode.
[Sysname-E-Cpos7/1/6] flag j0 sdh aa
frame-format
frame-format { sdh | sonet }
undo frame-format
View
Default level
2: System level
sdh: Sets the framing format to synchronous digital hierarchy (SDH).
sonet: Sets the framing format to synchronous optical network (SONET).
Use the frame-format command to configure the framing format of the current E-CPOS interface.
Use the undo frame-format command to restore the default.
The default framing format of an E-CPOS interface is SDH.
# Set the framing format of interface E-CPOS 7/1/6 to SONET.
[Sysname-E-Cpos7/1/6] frame-format sonet
loopback
loopback { local | remote }
undo loopback
View
Default level
2: System level
local: Enables internal loopback on the E-CPOS interface.
remote: Enables external loopback on the E-CPOS interface.
Use the loopback command to set the loopback mode of the current E-CPOS interface.
Use the undo loopback command to disable loopback on the current E-CPOS interface.
By default, loopback is disabled.
·       Loopback is intended for troubleshooting purposes. Normally, do not enable loopback.
·       Internal loopback, also known as local loopback, is used for testing the status of the local physical interface. External loopback is used for testing the status of the cable connected to the local interface.
# Enable external loopback on interface E-CPOS 7/1/6.
[Sysname-E-Cpos7/1/6] loopback remote
multiplex mode
multiplex mode { au-3 | au-4 }
undo multiplex mode
View
Default level
2: System level
au-3: Sets the AU multiplexing mode of AUG to AU-3.
au-4: Sets the AU multiplexing mode of AUG to AU-4.
Use the multiplex mode command to set the AU multiplexing mode for AUG.
Use the undo multiplex mode command to restore the default.
The default AU multiplexing mode for AUG is AU-4 in SDH mode and AU-3 in SONET mode.
On an E-CPOS interface in SDH mode, both the au-3 and au-4 keywords are available; on an E-CPOS interface in SONET mode, only the au-3 keyword is available.
For SDH, the ANSI and the ETSI provide their respective payload mapping/multiplexing solutions.
·           The ANSI uses the AU-3 multiplexing scheme. The lower-order payloads are aggregated into a VC-3 higher-order path. A VC-3 plus an AU pointer forms an AU-3. Three such AU-3s are synchronously multiplexed into an AUG.
·           The ETSI uses the AU-4 multiplexing scheme. The lower-order payloads are aggregated into a VC-4 higher-order path. A VC-4 plus an AU pointer forms an AU-4. This AU-4 is “multiplexed” into an AUG, that is to say, the AUG is, in fact, equivalent to an AU-4.
Only subcards PIC-CLS4G4L and PIC-CHS1G4L support this command.
Related commands: frame-format.
# Sets the AU multiplexing mode of AUG to AU-3 on interface E-CPOS 7/1/6 in SDH mode.
[Sysname-E-Cpos7/1/6] frame-format sdh
[Sysname-E-Cpos7/1/6] multiplex mode au-3
oc-12
oc-12 oc-12-number
undo oc-12 oc-12-number
View
2.5 Gbps E-CPOS interface view, OC-48 view
Default level
2: System level
oc-12-number: Number of a 622 Mbps channel. The value range for this argument is 1 to 4.
Use the oc-12 command to create a 622 Mbps channel with the specified number in the view of a 2.5 Gbps E-CPOS interface and enter the view of the 622 Mbps channel. If the specified 622 Mbps channel already exists, you enter the view of the 622 Mbps channel directly.
Use the undo oc-12 command to remove the specified 622 Mbps channel and its subchannels.
# Create the 622 Mbps channel OC-12 2 on 2.5 Gbps E-CPOS interface E-CPOS 7/1/6.
[Sysname] controller E-Cpos7/1/6
[Sysname-E-Cpos7/1/6] oc-12 2
[Sysname-E-Cpos7/1/6-oc-12-2]
oc-3
oc-3 oc-3-number
undo oc-3 oc-3-number
View
622 Mbps E-CPOS interface view, OC-12 view
Default level
2: System level
oc-3-number: Number of a 155 Mbps channel. The value range for this argument is 1 to 4.
Use the oc-3 command to create a 155 Mbps channel with the specified number in the view of a 622 Mbps E-CPOS interface or channel and enter the view of the 155 Mbps channel. If the specified 155 Mbps channel already exists, you enter the view of the 155 Mbps channel directly.
Use the undo oc-3 command to remove the specified 155 Mbps channel and its subchannels.
# Create the 155 Mbps channel OC-3 1 on the 622 Mbps channel OC-12 2 on 2.5 Gbps E-CPOS interface E-CPOS 7/1/6.
[Sysname-E-Cpos7/1/6-oc-12-2] oc-3 1
# Create 155 Mbps channel OC-3 2 on 622 Mbps E-CPOS interface E-CPOS 7/1/6.
[Sysname-E-Cpos7/1/6] oc-3 2
[Sysname-E-Cpos7/1/6-oc-3-2]
shutdown
shutdown
View
Default level
2: System level
None
Use the shutdown command to shut down the current E-CPOS interface.
Use the undo shutdown command to bring up the current E-CPOS interface.
By default, an E-CPOS physical interface is up.
The shutdown command on an E-CPOS physical interface shuts down all its E3/T3 channels or POS channels, and these channels stop transmitting and receiving data as a result. To bring them up, use the undo shutdown command on the E-CPOS interface.
# Shut down the E-CPOS interface E-CPOS 7/1/6.
[Sysname-E-Cpos7/1/6] shutdown
t3 unframed
t3 t3-number unframed
undo t3 t3-number unframed
View
Default level
2: System level
t3-number: T3 channel number, in the range of 1 to 3.
Use the t3 unframed command to configure the specified T3 channel on the E-CPOS interface to work in unframed mode.
Use the undo t3 unframed command to remove the specified T3 channel working in unframed mode on the E-CPOS interface.
By default, no T3 channel is created.
·       The T3 channels of an E-CPOS interface on the router can work only in unframed mode.
·       A T3 channel working in unframed mode is a 45 Mbps serial interface without timeslot bundling.
# Configure T3 channel 3 of interface E-CPOS 7/1/6 to work in unframed mode.
[Sysname-E-Cpos7/1/6] t3 3 unframed
threshold
threshold { sd | sf } value
undo threshold { sd | sf }
View
Default level
2: System level
value: SD or SF threshold, an integer in the range of 3 to 9. It is interpreted as a negative exponent of 10e. For example, the threshold can be 10e-3.
sd: Sets the signal degrade (SD) threshold.
sf: Sets the signal fail (SF) threshold.
Use the threshold command to set the SD or SF alarm threshold for the current E-CPOS interface.
Use the undo threshold command to restore the default.
By default, the SD alarm threshold is 10e-6, and the SF alarm threshold is 10e-3.
SD and SF alarms are used to indicate current line performance. They are generated when the receiving end detects a certain amount of B2 errors. The bit error rate threshold of SF is higher than that of SD. When a small amount of errors occur, SD alarms are generated; when the error rate increases to a certain level, SF alarms are generated, indicating the line performance has been degrading seriously.
When setting the thresholds, set the SD threshold lower than the SF threshold.
# Set the SD threshold to 10e-4 on interface E-CPOS 7/1/6.
[Sysname] interface e-cpos 7/1/6
[Sysname-E-Cpos7/1/6] threshold sd 4
using { oc-48 | oc-48c }
undo using
View
Default level
2: System level
oc-48: Sets the 2.5 Gbps E-CPOS interface to work in channelized mode.
oc-48c: Sets the 2.5 Gbps E-CPOS interface to work in concatenated mode.
Use the using oc-48 command to configure the 2.5 Gbps E-CPOS interface to work in channelized mode, where you can configure 622 Mbps channels.
Use the using oc-48c command to configure the 2.5 Gbps E-CPOS interface to work in concatenated mode, where you can create a 2.5 Gbps POS channel.
Use the undo using command to restore the default operation mode of the E-CPOS interface.
By default, a 2.5 Gbps E-CPOS interface works in channelized mode.
# Configure the 2.5 Gbps interface E-CPOS 7/1/6 to work in concatenated mode.
[Sysname-E-Cpos7/1/6] using oc-48c
using { oc-12 | oc-12c }
undo using
View
Default level
2: System level
oc-12: Sets the 622 Mbps E-CPOS interface or 622 Mbps channel to work in channelized mode.
oc-12c: Sets the 622 Mbps E-CPOS interface or 622 Mbps channel to work in concatenated mode.
Use the using oc-12 command to configure the 622 Mbps E-CPOS interface or 622 Mbps channel to work in channelized mode, where you can configure 155 Mbps channels.
Use the using oc-12c command to configure the 622 Mbps E-CPOS interface or 622 Mbps channel to work in concatenated mode, where you can create one 622 Mbps POS channel.
Use the undo using command to restore the default operation mode of the E-CPOS interface or channel.
By default, a 622 Mbps E-CPOS interface or channel works in channelized mode.
# Configure the 622 Mbps interface E-CPOS 7/1/6 to work in concatenated mode.
[Sysname-E-Cpos7/1/6] using oc-12c
# Configure the 622 Mbps channel OC-12 1 on E-CPOS interface 7/1/6 to work in concatenated mode.
[Sysname-E-Cpos7/1/6] oc-12 1
[Sysname-E-Cpos7/1/6-oc-12-1] using oc-12c
using { oc-3 | oc-3c }
undo using
View
155 Mbps E-CPOS interface view, OC-3 view
Default level
2: System level
oc-3: Sets the 155 Mbps E-CPOS interface or 155 Mbps channel to work in channelized mode.
oc-3c: Sets the 155 Mbps E-CPOS interface or 155 Mbps channel to work in concatenated mode.
Use the using oc-3 command to configure the 155 Mbps E-CPOS interface or channel to work in channelized mode, where you can configure E3 or T3 channels.
Use the using oc-3c command to configure the 155 Mbps E-CPOS interface or channel to work in concatenated mode, where you can create one 155 Mbps POS channel.
By default, a 155 Mbps E-CPOS interface or channel works in channelized mode.
# Configure the 155 Mbps interface E-CPOS 7/1/6 to work in concatenated mode.
[Sysname-E-Cpos7/1/6] using oc-3c
# Configure the 155 Mbps channel OC-3 1 on 622 Mbps E-CPOS interface E-CPOS 7/1/6 to work in concatenated mode.
[Sysname-E-Cpos7/1/6] oc-3 1
[Sysname-E-Cpos7/1/6-oc-3-1] using oc-3c
