01-Fundamentals Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10301-Fundamentals Command Reference
02-Login Management Commands
02-Login Management Commands 186.48 KB
CLI login configuration commands
display telnet client configuration
display telnet client configuration [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display telnet client configuration command to display the Telnet configuration when the router operates as a Telnet client.
The command displays the source IPv4 address or source interface information of the Telnet client.
Related commands: telnet client source.
# Display the Telnet configuration when the router operates as a Telnet client.
<Sysname> display telnet client configuration
 The source IP address is 1.1.1.1.
The output shows that when the router operates as the Telnet client, the source IPv4 address for sending Telnet packets is 1.1.1.1.
telnet
telnet remote-host [ service-port ] [ vpn-instance vpn-instance-name ] [ source { interface interface-type interface-number | ip ip-address } ]
View
Default level
0: Visit level
remote-host: IPv4 address or host name of a remote system, a case-insensitive string of 1 to 20 characters.
service-port: TCP port number for the remote system to provide Telnet services. It ranges from 0 to 65535 and defaults to 23.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN that the remote system belongs to, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. If the remote system is on the public network, do not specify this option.
interface interface-type interface-number: Specifies the source interface. The source IPv4 address of the Telnet packets sent is the IPv4 address of the specified interface. interface-type interface-number represents the interface type and number.
ip ip-address: Specifies the source IPv4 address of Telnet packets.
Use the telnet command to telnet a remote host to remotely manage the host. You can press Ctrl+K or use the quit command to stop the current Telnet login.
The source IPv4 address or source interface specified by this command is applicable to the current Telnet connection only.
If you use both the telnet command and the telnet client source command to specify the source IPv4 address or source interface, the source IPv4 address or interface specified by the telnet command takes effect.
# Telnet the remote host with the IP address 1.1.1.2, specifying the source IP address of Telnet packets as 1.1.1.1.
<Sysname> telnet 1.1.1.2 source ip 1.1.1.1
telnet ipv6
telnet ipv6 remote-host [ -i interface-type interface-number ] [ port-number ] [ vpn-instance vpn-instance-name ]
View
Default level
0: Visit level
remote-host: IP address or host name of a remote system, a case-insensitive string of 1 to 46 characters.
-i interface-type interface-number: Specifies the outbound interface for sending Telnet packets, where interface-type interface-number represents the interface type and number. You need to provide the -i interface-type interface-number argument if the destination address is a link-local address.
port-number: TCP port number for the remote system to provide Telnet services. It ranges from 0 to 65535 and defaults to 23.
Use the telnet ipv6 command to telnet a remote host to remotely manage the host in an IPv6 network. To stop the current Telnet login, press Ctrl+K or use the quit command.
# Telnet the remote host with the IPv6 address 2000::1.
<Sysname> telnet ipv6 2000::1
telnet server enable
undo telnet server enable
View
Default level
3: Manage level
None
Use the telnet server enable command to enable Telnet services.
Use the undo telnet server enable command to disable Telnet services.
Telnet services are disabled by default.
# Enable Telnet services.
User interface configuration commands
acl (user interface view)
·           To use a basic or advanced ACL:
acl [ ipv6 ] acl-number { inbound | outbound }
undo acl [ ipv6 ] acl-number { inbound | outbound }
·           To use an Ethernet frame header ACL:
acl acl-number inbound
undo acl acl-number inbound
View
VTY user interface view
Default level
2: System level
ipv6: When this keyword is present, the command supports IPv6; otherwise, it supports IPv4.
acl-number: Number of access control list (ACL), which takes the following value ranges:
·           Basic ACL: 2000 to 2999
·           Advanced ACL: 3000 to 3999
·           Ethernet frame header ACL: 4000 to 4999
inbound: Restricts Telnet or SSH connections established in the inbound direction through the VTY user interface. If the received packets for establishing a Telnet or SSH connection are permitted by an ACL rule, the connection is allowed to be established. When the device functions as a Telnet server or SSH server, this keyword is used to control access of Telnet clients or SSH clients.
outbound: Restricts Telnet connections established in the outbound direction through the VTY user interface. If the packets sent for establishing a Telnet connection are permitted by an ACL rule, the connection is allowed to be established. When the device functions as a Telnet client, this keyword is used to define Telnet servers accessible to the client.
Use the acl command to reference ACLs to control access to the VTY user interface.
Use the undo acl command to cancel the ACL application. For more information about ACL, see ACL and QoS Configuration Guide.
By default, access to the VTY user interface is not restricted.
If no ACL is referenced in VTY user interface view, the VTY user interface has no access control over establishing a Telnet or SSH connection.
If an ACL is referenced in VTY user interface view, the connection is permitted to be established only when packets for establishing a Telnet or SSH connection match a permit statement in the ACL.
The system regards the basic/advanced ACL with the inbound keyword, the basic/advanced ACL with the outbound keyword, and Ethernet frame header ACL as three different types of ACLs, which can coexist in one VTY user interface. The match order is basic/advanced ACL and Ethernet frame header ACL. At most one ACL of each type can be referenced in the same VTY user interface, and the last configured one takes effect.
# Allow only the user with the IP address of 192.168.1.26 to access the device through Telnet or SSH.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 192.168.1.26 0
[Sysname-acl-basic-2001] quit
[Sysname] user-interface vty 0
[Sysname-ui-vty0] acl 2001 inbound
After your configuration, user A (with IP address 192.168.1.26) can telnet to the device while user B (with IP address 192.168.1.60) cannot telnet to the device. Upon a connection failure, a message appears, saying "%connection closed by remote host!"
# Allow the device to only telnet to the Telnet server with IP address 192.168.1.41.
[Sysname] acl number 3001
[Sysname-acl-adv-3001] rule permit tcp destination 192.168.1.41 0
[Sysname-acl-adv-3001] quit
[Sysname] user-interface vty 0 15
[Sysname-ui-vty0-15] acl 3001 outbound
[Sysname-ui-vty0-15] return
<Sysname>
After your configuration, if you telnet to 192.168.1.46, your operation fails.
<Sysname> telnet 192.168.1.46
%Can't access the host from this terminal!
But you can telnet to 192.168.1.41.
<Sysname> telnet 192.168.1.41
Trying 192.168.1.41 ...
Press CTRL+K to abort
Connected to 192.168.1.41 ...
activation-key
activation-key character
undo activation-key
View
User interface view
Default level
3: Manage level
character: Shortcut key for starting a terminal session, which specifies a single character or its corresponding ASCII code value that ranges from 0 to 127. If you enter a string of 1 to 3 characters. only the first character functions as the shortcut key. For example, if you enter an ASCII code value of 97, the system uses its corresponding character a as the shortcut key. If you enter string b@c, the system uses the first character b as the shortcut key.
Use the activation-key command to define a shortcut key for starting a terminal session.
Use the undo activation-key command to restore the default.
By default, pressing the Enter key starts a terminal session. However, if a new shortcut key is defined by the activation-key command, the Enter key no longer functions. To display the shortcut key you have defined, use the display current-configuration | include activation-key command.
The activation-key command is not supported by the VTY user interface.
# Configure character s as the shortcut key for starting a terminal session on the console port.
[Sysname] user-interface console 0
[Sysname-ui-console0] activation-key s
# Verify the configuration.
1.      Exit the terminal session on the console port.
[Sysname-ui-console0] return
<Sysname> quit
2.      Log in to the router through the console port again.
The following message appears.
* Copyright (c) 2004-2009 Hangzhou H3C Tech. Co., Ltd. All rights reserved.  *
User interface con0 is available.
Please press ENTER.
3.      Press Enter.
At this moment, pressing Enter does not start a session.
4.      Enter s.
A terminal session is started.
<Sysname>
%Mar  2 18:40:27:981 2005 Sysname SHELL/5/LOGIN: Console login from con0
auto-execute command
auto-execute command command
undo auto-execute command
View
User interface view
Default level
3: Manage level
command: Specifies a command to be automatically executed.
Use the auto-execute command command to specify a command to be automatically executed when a user logs in to the current user interface.
Use the undo auto-execute command command to remove the configuration.
By default, command auto-execution is disabled.
The auto-execute command command is not supported by the console port, or the AUX port when the router has only one AUX port and no console port.
The system automatically executes a command when a user logs in to the user interface where the auto-execute command command is configured. The system tears down the user connection after the command completes. If the auto-execution command triggers another task, the system does not tear down the user connection until the task completes.
Typically, you use can use the auto-execute command telnet command in user interface view to enable a user to automatically telnet to the specified host when the user logs in to the device. After the user terminates the connection with the host, the user’s connection with the device is automatically terminated.
CAUTION
CAUTION:
The auto-execute command command may disable you from configuring the system through the user interface to which the command is applied. Therefore, before configuring the command and saving the configuration (by using the save command), make sure that you can access the router by other VTY, console, or AUX interfaces to remove the configuration in case a problem occurs.
# Configure the router to automatically telnet to 192.168.1.41 after a user logs in to interface VTY 0.
[Sysname-ui-vty0] auto-execute command telnet 192.168.1.41
% This action will lead to configuration failure through ui-vty0. Are you sure? [Y/N]:y
[Sysname-ui-vty0]
To verify the configuration:
Telnet to 192.168.1.40. The device automatically telnets to 192.168.1.41. The following output is displayed:
C:\> telnet 192.168.1.40
* Copyright (c) 2004-2010 Hangzhou H3C Tech. Co., Ltd. All rights reserved.  *
<Sysname>
<Sysname.41>
This operation is the same as directly logging in to the device at 192.168.1.41. If the Telnet connection to 192.168.1.41 is broken down, the Telnet connection to 192.168.1.40 breaks down at the same time.
authentication-mode
authentication-mode { none | password | scheme }
undo authentication-mode
View
User interface view
Default level
3: Manage level
none: Performs no authentication.
password: Performs local password authentication.
scheme: Performs AAA authentication. For more information about AAA, see Security Configuration Guide.
Use the authentication-mode command to set the authentication mode when users log in to the  user interface.
Use the undo authentication-mode command to restore the default.
By default, the authentication mode is password for VTY and AUX user interfaces, and is none for the console user interface.
Related commands: set authentication password.
# Specify that no authentication is needed when users log in to the router through VTY 0. (This mode is insecure.)
[Sysname-ui-vty0] authentication-mode none
# Set to use password authentication when users log in to the router through VTY 0, and set the authentication password to 321.
[Sysname-ui-vty0] authentication-mode password
[Sysname-ui-vty0] set authentication password cipher 321
# Set to authenticate users by username and password when the users log in to the router through VTY 0. Set the username to 123 and the password to 321.
[Sysname-ui-vty0] authentication-mode scheme
[Sysname-ui-vty0] quit
[Sysname] local-user 123
[Sysname-luser-123] password cipher 321
[Sysname-luser-123] service-type telnet
[Sysname-luser-123] authorization-attribute level 3
command accounting
command accounting
undo command accounting
View
User interface view
Default level
3: Manage level
None
Use the command accounting command to enable command accounting.
Use the undo command accounting command to restore the default.
By default, command accounting is disabled. The accounting server does not record the commands that users have executed.
When command accounting is enabled and command authorization is not, every executed command is recorded on the HWTACACS server.
When both command accounting and command authorization are enabled, only the authorized and executed commands are recorded on the HWTACACS server.
# Enable command accounting on VTY 0. Then the HWTACACS server records the commands executed by users that have logged in through VTY 0.
[Sysname-ui-vty0] command accounting
undo command authorization
View
User interface view
Default level
3: Manage level
None
Use the command authorization command to enable command authorization.
Use the undo command authorization command to restore the default.
By default, command authorization is disabled. Logged-in users can execute commands without authorization.
With command authorization enabled, users logging in from the current user interface can perform only commands authorized by the server.
# Enable command accounting for VTY 0 so that users logging in from VTY 0 can perform only the commands authorized by the HWTACACS server.
[Sysname-ui-vty0] command authorization
databits
databits { 5 | 6 | 7 | 8 }
undo databits
View
User interface view
Default level
2: System level
5: Sets 5 data bits for each character.
6: Sets 6 data bits for each character.
7: Sets 7 data bits for each character.
8: Sets 8 data bits for each character.
Use the databits command to set data bits for each character.
Use the undo databits command to restore the default.
By default, 8 data bits are set for each character.
·       The command is only applicable to asynchronous serial interfaces (including AUX and console ports).
·       The router does not support data bits 5 and 6.
·       If the data bits on the user interface is set to 7, only English letters are supported.
·       The data bits settings must be identical for the user interfaces of the connecting ports on the redirection router and the terminal device for communication.
# Specify 5 data bits for each character.
[Sysname] user-interface aux 0
[Sysname-ui-aux0] databits 5
display user-interface
display user-interface [ num1 | { aux | console | vty } num2 ] [ summary ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
num1: Absolute number of a user interface.
aux: AUX user interface.
console: Console user interface.
vty: VTY user interface.
num2: Relative number of a user interface, in the following rules:
·           For AUX user interfaces, the value is 0 or 1.
·           For console user interfaces, the value is 0 or 1.
·           For VTY user interfaces, the value ranges from 0 to 15.
summary: Displays summary about user interfaces.
Use the display user-interface command to display information about the specified or all user interfaces.
If the summary keyword is not included, the command displays the type of the user interface, the absolute or relative number, the transmission rate, the user privilege level, the authentication mode, and the access interface.
If the summary keyword is included, the command displays all user interface numbers and types.
# Display information about user interface 0.
<Sysname> display user-interface 0
  Idx  Type     Tx/Rx      Modem Privi Auth  Int
+ 0    CON 0    9600       -     3     N     -
  +    : Current user-interface is active.
  F    : Current user-interface is active and work in async mode.
  Idx  : Absolute index of user-interface.
  Type : Type and relative index of user-interface.
  Privi: The privilege of user-interface.
  Auth : The authentication mode of user-interface.
  Int  : The physical location of UIs.
  A    : Authentication use AAA.
  L    : Authentication use local database.
  N    : Current UI need not authentication.
  P    : Authentication use current UI's password.
Table 1 Output description
The current user interface is active.
F
The current user interface is active and works in asynchronous mode.
Idx
The absolute number of the user interface.
Type and relative number of the user interface.
Tx/Rx
Transmission rate of the user interface
Modem
Whether the modem is allowed to dial in (in), dial out (out), or both (inout).
By default, a hyphen (-) is displayed to indicate that this function is disabled.
Privi
Indicates the command level of a user under that user interface.
Auth
Authentication mode for users logging in from the interface, which can be A, P, L, and N.
Int
The physical port that corresponds to the user interface. For user interfaces of console ports, AUX ports, and VTY interfaces, a hyphen (-) is displayed.
A
AAA authentication.
L
Local authentication (not supported at present).
N
No authentication.
P
Password authentication.
# Display summary about all user interfaces.
<Sysname> display user-interface summary
  User interface type : [CON]
            0:X
  User interface type : [AUX]
            2:XX
  User interface type : [VTY]
           9:UXXX X
    2 character mode users.    (U)
    7 UI never used.        (X)
    2 total UI in use
Table 2 Output description
User interface type
Type of user interface (CON/ AUX/VTY).
0: X
0 represents the absolute number of the user interface. X means this user interface is not used;  U means this user interface is in use. For example, 9:UXXX X shows that the absolute number of the first user interface is 9, and the user interface is in use. User interfaces 10, 11, 12, and 13 are not in use.
Number of users, that is, the total number of character U.
UI never used.             (X)
Number of user interfaces not used, that is, the total number of character X.
total UI in use
Total number of user interfaces in use.
display users
display users [ all ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays information about all user interfaces that the router supports.
Use the display users command to display information about the user interfaces that are being used.
Use the display users all command to display information about all user interfaces supported by the router.
# Display information about the user interfaces that are being used.
<Sysname> display users
The user application information of the user interface(s):
  Idx UI      Delay    Type Userlevel
+ 9   VTY 0   00:00:00 TEL  3
  10  VTY 1   00:02:34 TEL  3
Following are more details.
VTY 0   :
VTY 1   :
+   : Current operation user.
F   : Current operation user work in async mode.
The output shows that two users have logged in to the router. The one with IP address 192.168.1.54 uses VTY 0, and the other with IP address 192.168.1.58 uses VTY 1.
Table 3 Output description
Idx
Absolute number of the user interface.
UI
Relative number of the user interface. The first column, for example, VTY, represents user interface type, and the second column, for example, 0, represents the relative number of the user interface.
Delay
Time elapsed since the user's last input, in the format of hh:mm:ss.
User type, such as Telnet and SSH.
Userlevel
User level: 0 for visit, 1 for monitor, 2 for system, and 3 for manage.
Current user.
Location
IP address of the user.
F
The current user works in asynchronous mode.
escape-key
escape-key { default | character }
undo escape-key
View
User interface view
Default level
3: Manage level
character: Specifies the escape key for aborting a task, a single character (or its corresponding ASCII code value in the range of 0 to 127) or a string of 1 to 3 characters. Only the first character of a string functions as the escape key. For example, if you enter an ASCII code value 113, the system uses its corresponding character q as the escape key. If you enter the string q@c, the system uses the first character q as the escape key.
default: Restores the default escape key sequence of Ctrl+C.
Use the escape-key command to define a escape key for aborting a task.
Use the undo escape-key command to disable the escape key for aborting tasks.
By default, a task is terminated by using Ctrl+C.
After defining a new escape key by using the escape-key command, the new escape key functions to terminate a task. To display the escape key you have defined, use the display current-configuration command.
If you set the character argument in a user interface of a router, when you use the user interface to log in to the router and then telnet to another device, the character argument can be used as a control character to terminate a task only, rather than entered as a common character. For example, if you specify character as e in VTY 0 user interface of Device A, when you log in to Device A by using VTY 0 on a PC (Hyper Terminal), you can enter e as a common character on the PC, and you can also use e to terminate the task running on Device A. If you telnet to Device B from Device A, however, you can only use e to terminate the task running on Device B, rather than enter e as a common character. It is good practice to use an escape key sequence.
# Define key a as the escape key for aborting a task.
[Sysname-ui-console0] escape-key a
# Use the ping command to check the reachability of the router with the IP address of 192.168.1.49 and use the -c argument to specify the number of ICMP echo packets to be sent as 20.
<Sysname> ping -c 20 192.168.1.49
  PING 192.168.1.49: 56  data bytes, press a to break
    Reply from 192.168.1.49: bytes=56 Sequence=1 ttl=255 time=3 ms
    Reply from 192.168.1.49: bytes=56 Sequence=2 ttl=255 time=3 ms
# Enter a. The task terminates immediately and the system returns to system view.
  --- 192.168.1.49 ping statistics ---
    2 packet(s) transmitted
    2 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 3/3/3 ms
<Sysname>
flow-control
undo flow-control
View
User interface view
Default level
2: System level
hardware: Performs hardware flow control.
none: Performs no flow control.
software: Performs software flow control.
Use the flow-control command to configure flow control mode.
Use the undo flow-control command to restore the default.
By default, no flow control is performed.
A flow control mode takes effect on both inbound and outbound directions. In inbound flow control, the local device listens to the remote device for flow control information while in the outbound flow control, the local device sends flow control information to the remote device.
The flow control mode setting on one end must be the same as that in the outbound/inbound direction on the other end.
·       The router does support hardware and software flow control.
·       The flow control settings must be consistent for the user interfaces of the connecting ports on the redirection device and the terminal device for communication.
# Configure software flow control in the inbound and outbound directions for port console 0.
[Sysname-ui-console0] undo flow-control software
free user-interface
free user-interface { num1 | { aux | console | vty } num2 }
View
Default level
3: Manage level
Use the free user-interface command to release the connection established on the specified user interface.
This command cannot release the connection that you are using.
# Release the connection established on user interface VTY 1.
+ 82  VTY 0   00:00:00 TEL  3
  83  VTY 1   00:00:03 TEL  3
VTY 0   :
VTY 1   :
// You can display information about the users that are using the router.
<Sysname> free user-interface vty 1
Are you sure to free user-interface vty1? [Y/N]:y
// To make configurations without interruption from the user using VTY 1, you can release the connection established on VTY 1.
history-command max-size
history-command max-size size-value
undo history-command max-size
View
User interface view
Default level
2: System level
size-value: Specifies the number of history commands that the buffer can store. The value ranges from 0 to 256.
Use the history-command max-size command to set the size of history command buffer of the current user interface.
Use the undo history-command max-size command to restore the default.
By default, the buffer saves 10 history commands.
The history command buffer saves validated history commands individually per user interface and buffers for different user interfaces do not affect each other. To display the commands that are stored in the history buffer, use the display history-command command. To view the recently executed commands, press the upper arrow or lower arrow key.
After you terminate the current session, the system automatically removes the commands saved in the related history buffer.
# Set the buffer to store 20 history commands at most.
[Sysname-ui-console0] history-command max-size 20
idle-timeout
undo idle-timeout
View
User interface view
Default level
2: System level
minutes: Specifies timeout time in minutes, which ranges from 0 to 35791, and defaults to 10 minutes.
seconds: Specifies timeout time in seconds, which ranges from 0 to 59, and defaults to 0 seconds.
Use the idle-timeout command to set the idle-timeout timer. When it expires, user sessions are terminated.
Use the undo idle-timeout command to restore the default.
The default idle-timeout is 10 minutes.
·       The system automatically terminates the user’s connection if there is no information interaction between the router and the user in timeout time.
·       Setting idle-timeout to zero disables the timer. In this case, connections are maintained unless you terminate them.
# Set the idle-timeout timer to 1 minute and 30 seconds.
[Sysname-ui-console0] idle-timeout 1 30
lock
lock
View
Default level
3: Manage level
None
Use the lock command to lock the user interface by password protection. This method prevents unauthorized users from using the user interface.
When entering the lock command, you are asked to enter a password (up to 16 characters) and then confirm it by entering the password again. To successfully set the password, enter the same passwords. After locking the user interface, next time you enter this user interface, you must press Enter and enter the correct password.
By default, this function is disabled.
# Lock the current user interface.
<Sysname> lock
Please input password<1 to 16> to lock current user terminal interface:
Password:
Again:
                   locked !
Password:
<Sysname>
parity
undo parity
View
User interface view
Default level
2: System level
even: Performs an even parity check.
mark: Performs a mark parity check.
none: Performs no parity check.
odd: Performs an odd parity check.
space: Performs a space parity check.
Use the parity command to set a parity check method.
Use the undo parity command to restore the default.
By default, no parity check is performed.
·       The parity check settings must be identical for the user interfaces of the connecting ports on the redirection device and the target terminal device for communication.
# Configure the AUX port to perform odd parity check.
[Sysname-ui-aux0] parity odd
protocol inbound
undo protocol inbound
View
VTY interface view
Default level
3: Manage level
all: Supports the two protocols, Telnet and SSH.
ssh: Supports SSH only.
telnet: Supports Telnet only.
Use the protocol inbound command to enable the current user interface to support Telnet, SSH, or both of them. The configuration takes effect next time you log in.
Use the undo protocol inbound command to restore the default.
By default, all the three protocols are supported.
CAUTION
CAUTION:
·       Before configuring a user interface to support SSH, set the authentication mode to scheme for users logging in through the user interface; otherwise, the protocol inbound ssh command fails. For more information, see authentication-mode.
·       By default, the authentication mode of the Telnet protocol is password.
# Enable the VTYs 0 through 4 to support SSH only.
[Sysname] user-interface vty 0 4
[Sysname-ui-vty0-4] authentication-mode scheme
[Sysname-ui-vty0-4] protocol inbound ssh
screen-length
screen-length screen-length
undo screen-length
View
User interface view
Default level
2: System level
screen-length: Maximum number of lines on a screen, which ranges from 0 to 512. The value of 0 disables pausing between screens of output.
Use the screen-length command to set the maximum number of lines on a screen.
Use the undo screen-length command to restore the default.
By default, a screen displays 24 lines at most.
When screen output pauses, press the blank space key to display the next screen. Not all display terminals support this setting. For example, assume that you set screen-length to 40, but the terminal screen can display 24 lines at most. When you press the blank space key, the router sends 40 lines to the terminal display, but the screen displays only lines 18 through 40. To view the first 17 lines, you must press Page Up or Page Down.
To disable pausing between screens of output for the current session, set the maximum number of lines to 0 or execute the screen-length disable command.
Related commands: screen-length disable.
# Set the screen length of the user interface of console port 0 to 30 lines.
[Sysname-ui-console0] screen-length 30
send
send { all | num1 | { aux | console | vty } num2 }
View
Default level
1: Monitor level
all: Sends messages to all user interfaces.
Use the send command to send messages to the specified user interfaces.
To end message input, press Ctrl+Z. To cancel message input and exit to user view, press Ctrl+C.
# Send message hello abc to the console user interface.
<Sysname> send console 0
Enter message, end with CTRL+Z or Enter; abort with CTRL+C:
hello abc^Z
Send message? [Y/N]:y
<Sysname>
***Message from con0 to con0
hello abc
<Sysname>
# A user logging in through VTY 0 wants to restart the router. To inform the other users to take corresponding actions (for example, save the current configuration), the system sends the message “Note please, I will reboot the system!”.
·           Configuration on VTY 0
  10  VTY 1   00:00:03 TEL  3
VTY 0   :
VTY 1   :
// The output shows that a user is using VTY 0.
<Sysname> send vty 1
Note please, I will reboot the system in 3 minutes!^Z
<Sysname>
// A message is sent to VTY 1, telling that the system will reboot in 3 minutes.
·           If a user is trying to log in through VTY 1, a message appears. (VTY 1 receives the message from VTY 0 when the interface ethernet command is entered.)
[Sysname] interface Giga
***Message from vty0 to vty1
set authentication password { cipher | simple } password
undo set authentication password
View
User interface view
Default level
3: Manage level
cipher: Cipher text password.
simple: Plain text password.
password: A case-sensitive string. If the password format is simple, the password argument must be in plain text, and the configuration file saves the password in plain text. If the format is cipher, password can be either in cipher text or in plain text, and the configuration file always saves the password in cipher text. A plain text password can be a string of no more than 16 characters, 1234567 for example. A cipher text password or the encrypted version of the plain text password comprises 24 characters, such as _(TT8F]Y\5SQ=^Q`MAF4<1!!.
Use the set authentication password command to set a local authentication password.
Use the undo set authentication password command to remove the local authentication password.
By default, no local authentication password is set.
No matter whether the password format is plain text or cipher text, you must enter the password in plain text for authentication.
A plain text password may get cracked easily. A good practice is to use a cipher text password.
Related commands: authentication-mode.
# Set the local authentication password for user interface console 0 to hello.
[Sysname-ui-console0] authentication-mode password
[Sysname-ui-console0] set authentication password cipher hello
Next time you enter the system, the password is required.
shell
shell
undo shell
View
User interface view
Default level
3: Manage level
None
Use the shell command to enable terminal services on the current user interface.
Use the undo shell command to disable terminal services on the current user interface.
The console user interface does not support the undo shell command.
The AUX user interface does not support the undo shell command when the router has only one AUX port and no console port.
You cannot disable the terminal services on the user interface through which you are logged in.
By default, terminal services are enabled on all user interfaces.
# Disable terminal services on VTYs 0 through 4, which means you cannot log in to the router through VTYs 0 through 4.
[Sysname-ui-vty0-4] undo shell
% Disable ui-vty0-4 , are you sure? [Y/N]:y
[Sysname-ui-vty0-4]
The following message appears when a terminal tries to telnet to the router:
The connection was closed by the remote host!
speed (user interface view)
speed speed-value
undo speed
View
User interface view
Default level
2: System level
speed-value: Transmission rate in bps.
The transmission rates available with asynchronous serial interfaces include 300 bps, 600 bps, 1200 bps, 2400 bps, 4800 bps, 9600 bps, 19200 bps, 38400 bps, 57600 bps, and 115200 bps.
Use the speed command to set the transmission rate on the user interface.
Use the undo speed command to restore the default transmission rate.
By default, the transmission rate is 9600 bps.
·       The transmission rate settings must be identical for the user interfaces of the connecting ports on the redirection device and the target terminal device for communication.
# Set the transmission rate on the user interface AUX 0 to 19200 bps.
[Sysname-ui-aux0] speed 19200
stopbits
stopbits { 1 | 1.5 | 2 }
undo stopbits
View
User interface view
Default level
2: System level
1: One stop bit.
1.5: One and a half stop bits.
2: Two stop bits.
Use the stopbits command to set the number of stop bits transmitted per byte.
Use the undo stopbits command to restore the default.
By default, the stop bit is one.
·       The router does not support stop bits 1.5.
·       The stop bits settings must be the identical for the user interfaces of the connecting ports on the redirection device and the target device for communication.
# Set the stop bits on the user interface AUX 0 to 2.
[Sysname-ui-aux0] stopbits 2
terminal type
undo terminal type
View
User interface view
Default level
2: System level
ansi: Specifies the terminal display type as ANSI.
vt100: Specifies the terminal display type as VT100.
Use the terminal type command to configure the type of terminal display under the current user interface.
Use the undo terminal type command to restore the default.
By default, the terminal display type is ANSI.
The router supports two types of terminal display: ANSI and VT100. It is recommended to set the display type of both the router and the client to VT100. If types of terminal displays are different for the router and the client (for example, hyper terminal or Telnet terminal) or both are set to ANSI, when the total number of characters of the currently edited command line exceeds 80, anomalies such as cursor corruption or abnormal display of the terminal display may occur on the client. .
# Set the terminal display type to VT100.
[Sysname-ui-vty0] terminal type vt100
user privilege level level
undo user privilege level
View
User interface view
Default level
3: Manage level
level: Specifies a command level, which ranges from 0 to 3.
Command level is divided into four levels of visit, monitor, system, and manage, represented by the number 0, 1, 2 and 3 respectively. The administrator can change the command level of a user when necessary.
Use the user privilege level command to configure the command level for login users on the current user interface.
Use the undo user privilege level command to restore the default.
By default, the default command level is 3 for the console user interface and 0 for the other user interfaces.
# Set the command level for the user logging in from VTY 0 to 0.
[Sysname-ui-vty0] user privilege level 0
After you telnet to the device through VTY 0, the terminal only displays commands of level 0 in the help information:
<Sysname> ?
User view commands:
  cluster  Run cluster command
  display  Display current system information
  ping     Ping function
  quit     Exit from current command view
  rsh      Establish one RSH connection
  ssh2     Establish a secure shell client connection
  super    Set the current user priority level
  telnet   Establish one TELNET connection
  tracert  Trace route function
user-interface
user-interface { first-num1 [ last-num1 ] | { aux | console | vty } first-num2 [ last-num2 ] }
View
Default level
2: System level
first-num1: Absolute number of the first user interface.
last-num1: Absolute number of the last user interface. The value typically starts from 0, and cannot be smaller than the first-num1.
first-num2: Relative number of the first user interface, in the following rules:
·           For VTY user interfaces, the value ranges from 0 to 4.
last-num2: Relative number of the last user interface. For VTY user interfaces, the value ranges from ( first-num2+1 ) to 15.
Use the user-interface command to enter a single or multiple user interface views.
In a single user interface view, the configuration takes effect in the user view only.
In multiple user interface views, the configuration takes effect in these user views.
# Enter console user interface view.
# Enter the user interface view of VTY 0 to 4.
[Sysname-ui-vty0-4]
