H3C WX Series Access Controllers Web-Based Configuration Manual-6PW103
HomeSupportWLANConfigurationUser ManualH3C WX Series Access Controllers Web-Based Configuration Manual-6PW103
02-Web Overview
02-Web Overview 349.71 KB
l          The H3C WX series access controller products include H3C access controllers, access controller modules, and H3C WX series unified switches' access controller engines.
l          The WX5000 series include the WX5002 and the WX5004 access controllers and the LS8M1WCMA0 access controller module; the WX6000 series include the WX6103 access controller and the LSQM1WCMB0 and the LSBM1WCM2A0 access controller modules; the WX3000 series include the WX3024, WX3010 and WX3008 unified switches.
l          The access controller service interface boards include the LS8M1WCMA0 applied on the H3C S7502/7503/7506/7506R Ethernet switches, the LSQM1WCMB0 applied on the H3C S7502E/S7503E/S7506E/S7506E-V/S7510E Ethernet switches, and the LSBM1WCM2A0 applied on the H3C S9512/S9508/S9508V/S9505 Ethernet switches.
l          The sample Web page information in this manual was created on the WX5002. The Web page information on your device may vary.
l          The models listed in this manual are not applicable to all regions. Please consult the local agents for the models applicable to your region.
The following table shows the support of the H3C WX series access controller products for features:
Feature
WX5000 series
WX6000 series
WX3000 series
WX5002
LS8M1WCMA0
WX5004
WX6103
LSQM1WCMB0
LSBM1WCM2A0
WX3024
WX3010
WX3008
Port mirroring
Supported
Supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
IPv6 routing
Supported
Supported
Supported
Supported
Supported
Not supported
Not supported
Not supported
Not supported
Mesh service
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
IPv6 ACL
Supported
Supported
Supported
Supported
Supported
Not supported
Not supported
Not supported
Not supported
Port rate limiting
Supported
Supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Web Overview
Overview
Each H3C WX series access controller product has a Web server built in. It enables you to log in to the device through a Web browser and then manage and maintain the device intuitively by interacting with the built-in Web server.
To log in to the access controller product through the built-in Web-based network management system, you need to perform the related configuration on both the switching engine and the PC operating as the network management terminal.
Figure 1-1 shows a Web-based network management operating environment:
Figure 1-1 Web-based network management operating environment
Table 1-1 Requirements for logging in to the access controller product through the Web-based network management system
Item
Requirement
Access controller product (Device)
The VLAN interface or management interface of the access controller product is assigned an IP address, and the route between the access controller product and the Web network management terminal is reachable.
The user name and password for logging in to the Web-based network management system are configured.
IE is available.
The IP address of the VLAN interface of the access controller product, the user name, and the password are available.
An access controller product has a factory default configuration when it is shipped. With this configuration, you can input http://192.168.0.100 in the address bar of the browser on a Web network management terminal (PC), supposing that a route between the Web network management terminal and the access controller product is available, and the browser will display the login page. Input the default username and password admin, and the verification code, select the language, and then you can log in to the Web interface.
l          For the WX5002 and the WX5004, you can log in to the device through the Web-based network management system.
l          For the access controller modules LS8M1WCMA0, LSQM1WCMB0, and LSBM1WCM2A0, you can log in to the modules through the Web-based network management system.
l          For the WX6103, you can log in to the main control board through the Web-based network management system. For the login to the switch interface board, see the related section of the Login Configuration in the H3C WX6103 Access Controller Switch Interface Board  Operation Manual.
l          For the WX3024, WX3010 and WX3008, you can log in to the access controller engine through the Web-based network management system. For details, see the related section of the Login Configuration in the H3C WX3000 Series Unified Switches Switching Engine  Operation Manual.
Logging In to the Web Interface
The device is provided with the default Web login information. You can use the default information to log in to the Web interface. The default Web login information is:
l          Username: admin
l          Password: admin
l          IP address of the device: 192.168.0.100.
You can follow the steps below to log in to the device through the Web interface.
1)        Connect the device and PC
Connect the Ethernet interface of the device to the PC using a crossover Ethernet cable.
2)        Configure an IP address for the PC and ensure that the PC and device can communicate with each other properly.
Modify the IP address of the PC to one that within the network segment 192.168.0.X/24 (except for 192.168.0.100), for example, 192.168.0.2.
3)        Open the browser, and input the login information.
On the PC, open the browser, type the IP address http://192.168.0.100 in the address bar, press Enter and you can enter the login page of the Web interface, as shown in Figure 1-2. Input the username and password admin, and the verification code, select the language (English and Chinese are supported at present), and click Login.
Figure 1-2 Login page of the Web interface
l          The PC where you configure the device is not necessarily the Web-based network management terminal. A Web-based network management terminal is a PC (or another terminal) used to log in to the Web interface and is required to be reachable to the device.
l          After logging in to the Web interface, you can create a new user and configure the IP address of the interface connecting the user and the device.
l          If you click the verification code displayed on the Web login page, you can get a new verification code.
Logging Out of the Web Interface
Click Logout in the upper-right corner of the Web interface to quit Web-based network management.
Note that:
l          The system will not save the current configuration before you log out of the Web interface. Therefore, it is recommended to save the current configuration before logout.
l          A maximum of five concurrent users are allowed by the system.
l          Do not directly close the IE browser; otherwise you cannot log out of the system and other offline users may fail to log in when the concurrent users reach the maximum.
Introduction to the Web Interface
The Web interface is composed of three parts: navigation tree, tile area, and body area, as shown in Figure 1-3.
Figure 1-3 Web-based configuration interface
(1) Navigation area
(2) Body area
(3) Title area
l          Navigation area: Organizes the Web-based NM function menus in the form of a navigation tree, where you can select function menus as needed. The result is displayed in the body area.
l          Body area: The area where you can configure and display a function.
l          Tile area: Displays the path of the current configuration interface in the navigation area; provides the Help button to display the Web related help information, and the Logout button to log out of the Web interface.
The Web network management functions not supported by the device will not be displayed in the navigation area.
Web User Level
Web user levels, ranging from low to high, are visitor, monitor, configure, and management. A user with a higher level has all the operating rights of a user with a lower level.
l          Visitor: Users of this level can only use the network diagnostic tool trace route. They can neither access the device data nor configure the device.
l          Monitor: Users of this level can use the network diagnostic tool ping, and access the device data but cannot configure the device.
l          Configure: Users of this level can access data from the device and configure the device, but they cannot upgrade the host software, add/delete/modify users, or back up/restore the application file.
l          Management: Users of this level can perform any operations for the device.
Introduction to the Web-Based NM Functions
Table 1-2 describes the Web-based network management functions in detail.
l          Support for the configuration items depends on the device model.
l          User level in Table 1-2 indicates that users of this level or users of a higher level can perform the corresponding operations.
Table 1-2 Description of Web-based NM functions
Function menu
User level
Quick Start
Performs quick configuration of the device.
Configure
Summary
Device
Displays and refreshes system resource state, device information, device interface information, and recent system operation logs.
Monitor
Wlan Service
Displays the information of the queried WLAN service, including the detailed information, statistics, and connection records.
Monitor
AP
Displays the information of the queried AP, including wireless service, connection records, radio, and detailed information.
Monitor
Reboots AP.
Configure
Client
Displays the detailed information, statistics, and roaming information of the client.
Monitor
Resets statistics of the client, disconnect the connection, and adds the client into the blacklist.
Configure
Device
License
Display license information.
Monitor
Add licenses.
Configure
Basic
Set sysname
Displays and sets the system name.
Configure
Set idle timeout
Displays and sets the idle timeout period for a logged-in user.
Configure
System Time
Displays and sets the system date and time.
Configure
Syslog
Loglist
Displays and refreshes syslogs.
Monitor
Clears syslogs.
Configure
Loghost
Displays and sets the loghost.
Configure
Logset
Displays and sets the buffer capacity and refresh interval for displaying syslogs.
Configure
Configuration management
Backup
Backs up the configuration file for the next startup to the host of the current user.
Management
Restore
Uploads the configuration file on the host of the current user to the devices for the next startup.
Management
Save
Saves the current configuration to the configuration file for the next startup.
Configure
Initialize
Restores the system to factory defaults.
Configure
Software Upgrade
Uploads the application file from the local host to upgrade the device software.
Management
File management
Manages files on the device, including displays file list, downloads a file, uploads a file, and removes a file.
Management
Reboot
Reboots the device.
Configure
Interface Management
Displays and views interface information and statistics.
Monitor
Creates, modifies, deletes, and enables/disables an interface, and clears interface statistics.
Configure
Port Mirroring
Summary
Displays the configuration information of a port mirroring group.
Monitor
Create
Creates a port mirroring group.
Configure
Remove
Removes a port mirroring group.
Configure
Modify Port
Configures ports for a mirroring group.
Configure
User Management
Summary
Displays brief information of FTP and Telnet users.
Monitor
Super Password
Sets the password for a lower-level user to switch from the current access level to the management level.
Management
Create
Creates an FTP or a Telnet user.
Management
Modify
Modifies FTP or Telnet user information.
Management
Remove
Removes an FTP or a Telnet user.
Management
Switch To Management
Switches the current user level to the management level.
Visitor
Loopback Test
Performs the loopback test on Ethernet interfaces.
Configure
Network
MAC
MAC
Displays MAC address information.
Monitor
Creates or removes MAC addresses.
Configure
Config
Displays and sets MAC address aging time.
Configure
VLAN
VLAN
Displays all VLANs on the device and information about their member ports.
Monitor
Creates, modifies, and deletes VLANs.
Configure
Port
Displays VLANs to which a port on the device belongs.
Monitor
Modifies the VLANs to which a port belongs.
Configure
ARP
Displays or refreshes information about the ARP entries.
Monitor
IGMP Snooping
Configures IGMP snooping.
Configure
IPv4 Routing
Summary
Displays the IPv4 active route table.
Monitor
Create
Creates an IPv4 static route.
Configure
Remove
Deletes the selected IPv4 static routes.
Configure
IPv6 Routing
Summary
Displays the IPv6 active route table.
Monitor
Create
Creates an IPv6 static route.
Configure
Remove
Delete the selected IPv6 static routes.
Configure
DHCP
Global Configuration
Displays or sets the global DHCP service status.
Configure
DHCP
Displays the DHCP service type of an interface.
Monitor
Configures the DHCP service type and related parameters of an interface.
Configure
DHCP Server Group
Displays information about the DHCP server groups.
Monitor
Creates or deletes a DHCP server group.
Configure
Address Pool
Displays information about DHCP static or dynamic address pools.
Monitor
Creates, modifies, or deletes a DHCP static or dynamic address pool.
Configure
DNS
Static Domain Name Resolution
Displays, creates, modifies, or deletes a static host name-to-IP address mapping.
Configure
Dynamic Domain Name Resolution
Displays or sets related parameters for dynamic domain name resolution. Displays, creates, or deletes an IP address and the domain name suffix.
Configure
Service Management
Displays the states of the services: enabled or not.
Configure
Specifies whether to enable various services, and sets related parameters.
Management
Diagnostic Tools
IPv4 Ping
Performs ping operations on an IPv4 address or host name and displays the result.
Monitor
IPv6 Ping
Performs ping operations on an IPv6 address or host name and displays the result.
Monitor
Trace Route
Performs trace route operations and displays the result.
Visitor
AP
AP Setup
Displays AP-related information, including AP name, AP IP address, serial ID and status.
Monitor
Adds an AP and modifies the AP configuration.
Configure
Auto AP
Displays auto AP information after auto AP is enabled, including AP name, model, serial ID and IP address.
Monitor
Enables auto AP.
Configure
AP Group
Displays AP group information.
Monitor
Creates and sets an AP group.
Configure
WLAN Service
Access Service
Displays access service information, including security type, details, service status, and binding status.
Monitor
Creates and sets an access service, maps an access service to an AP radio, and adds a MAC authentication list.
Configure
Mesh Service
Mesh Service
Displays a mesh service and its status.
Monitor
Creates and sets a mesh service, including security settings.
Configure
Mesh Policy
Displays mesh policies.
Monitor
Creates and sets a mesh policy.
Configure
Mesh Global Setting
Displays mesh global setting, including basic setting and mesh portal service.
Monitor
Configures mesh global setting, including basic setting and mesh portal service.
Configure
Roam
Roam Group
Displays a roaming group and its members.
Monitor
Sets a roaming group and adds a group member.
Configure
Client Information
Displays client information, including MAC address, BSSID, VLAN ID and roaming direction.
Monitor
Radio
Radio Setup
Displays radio status, including radio mode and radio status.
Monitor
Sets radio status, including 802.11n settings.
Configure
Rate
Displays radio settings.
Monitor
Sets 802.11n rates, including MCS index.
Configure
Scan
Displays channel scanning, including scan mode, scan type, and scan interval.
Monitor
Sets channel scanning, including scan mode and scan type.
Configure
Calibration
Calibration Operations
Displays and refreshes AP status, including channel status, neighbor information, and history information.
Monitor
Manual calibration
Configure
Parameter Setting
Displays basic setup, channel setup and power setup.
Monitor
Sets channel calibration parameters.
Configure
Authentication
802.1x
Device Summary
Displays the global 802.1x related information.
Configure
Port Summary
Displays the 802.1x information of a port.
Configure
Global Setup
Configures 802.1x globally.
Configure
Port Setup
Configures 802.1x on a port.
Configure
Portal
Portal Server
Displays the portal server configuration information.
Monitor
Adds and deletes a portal server.
Configure
Application
Displays the portal service application information on interfaces.
Monitor
Adds and deletes a portal service application.
Configure
Free Rule
Displays the portal-free rule configuration information.
Monitor
Adds and deletes a portal-free rule.
Configure
Local Portal
Protocol
Displays the local portal server configuration information.
Monitor
Configures the local portal server.
Configure
Binding
Displays information about SSID-to-authentication page file bindings.
Monitor
Adds and deletes a binding between an SSID and an authentication page file.
Configure
AAA
Domain Setup
Displays ISP domain configuration information.
Monitor
Allows you to add and remove ISP domains.
Management
Authentication
Displays the authentication method configuration information of an ISP domain.
Monitor
Allows you to specify authentication methods for an ISP domain.
Management
Authorization
Displays the authorization method configuration information of an ISP domain.
Monitor
Allows you to specify authorization methods for an ISP domain.
Management
Accounting
Displays the accounting method configuration information of an ISP domain.
Monitor
Allows you to specify accounting methods for an ISP domain.
Management
RADIUS
RADIUS Server
Displays and allows configuration of RADIUS server information.
Management
RADIUS Setup
Displays and allows configuration of RADIUS parameters.
Management
Local EAP Server
Displays the configuration information of the local EAP service.
Monitor
Allows you to configure the local EAP service.
Configure
Users
Local User
Displays local users’ configuration information.
Monitor
Allows you to add, modify, and remove local users.
Management
User Group
Displays user groups’ configuration information.
Monitor
Allows you to add, modify, and remove user groups.
Management
Guest
Displays guest users’ configuration information.
Monitor
Allows you to add, modify, and remove guest users.
Management
User Profile
Displays user profile configuration information.
Monitor
Allows you to add, modify, remove, enable, and disable user profiles.
Configure
PKI
Entity
Displays information about PKI entities.
Monitor
Adds, modifies, and deletes a PKI entity.
Configure
Domain
Displays information about PKI domains.
Monitor
Adds, modifies, and deletes a PKI domain.
Configure
Certificate
Displays the certificate information of PKI domains and views the contents of a certificate.
Monitor
Generates a key pair, destroys a key pair, retrieves a certificate, requests a certificate, and deletes a certificate.
Configure
CRL
Displays the contents of the CRL.
Monitor
Retrieves the CRL of a domain.
Configure
Security
Rogue Detection
AP Monitor
Displays AP operating mode.
Monitor
Sets AP operating mode.
Configure
Rule List
Displays list types for the rogue device detection and the detection rules.
Monitor
Configures list types for rogue device detection and the rules.
Configure
Monitor Record
Displays monitor record of rogue device detection.
Monitor
Clears monitor record of rogue device detection, and adds rogue devices to blacklist.
Configure
History Record
Displays rogue device detection history.
Monitor
Clears history of rogue device detection and adds rogue devices to blacklist.
Configure
IDS
IDS Setup
Displays IDS configuration.
Monitor
Configures IDS detection, including flood attack detection, spoofing attack detection, and weak IV detection.
Configure
History Record
Displays IDS attack detection history.
Monitor
Clears history record of IDS attack detection and adds the detected devices that initiate attacks to blacklist.
Configure
Statistics
Displays statistics of IDS attack detection.
Monitor
Clears the statistics.
Configure
Filter
Blacklist
Displays dynamic and static blacklists.
Monitor
Clears dynamic blacklist and static blacklist; enables dynamic blacklist; adds entries to the static blacklist.
Configure
Whitelist
Displays white list.
Monitor
Clears Whitelist, and adds entries to the white list.
Configure
Authorized IP
Summary
Displays the configurations of the authorized IP, the associated IPv4 ACL rule list, and the associated IPv6 ACL rule list.
Management
Setup
Sets the authorized IP.
Configure
User Isolate
Displays, adds, modifies and removes user isolation configuration.
Management
QoS
Time Range
Display
Displays time range configuration information.
Monitor
Create
Creates a time range.
Configure
Delete
Deletes a time range.
Configure
ACL IPv4
Display
Displays IPv4 ACL configuration information.
Monitor
Create
Creates an IPv4 ACL.
Configure
Basic Setup
Configures a rule for a basic IPv4 ACL.
Configure
Advanced Setup
Configures a rule for an advanced IPv4 ACL.
Configure
Link Setup
Creates a rule for an Ethernet frame header ACL.
Configure
Delete
Deletes an IPv4 ACL or its rules.
Configure
ACL IPv6
Display
Display IPv6 ACL configuration information.
Monitor
Create
Creates an IPv6 ACL.
Configure
Basic Setup
Configures a rule for a basic IPv6 ACL.
Configure
Advanced Setup
Configures a rule for an advanced IPv6 ACL.
Configure
Delete
Deletes an IPv6 ACL or its rules.
Configure
Wireless QoS
Wireless QoS
Displays wireless QoS information, including SVP mapping, CAC admission policy, radio EDCA, and client EDCA.
Monitor
Sets wireless QoS, including SVP mapping, CAC admission policy, radio EDCA and client EDCA.
Configure
Radio Statistics
Displays radio statistics, including WMM status and detailed radio information.
Monitor
Displays radio statistics, including WMM status and detailed radio information, and clears the radio statistics.
Configure
Client Statistics
Displays client statistics, including WMM status and detailed client information.
Monitor
Displays client statistics, including WMM status and detailed client information, and clears the client statistics.
Configure
Rate Limiting
Displays configured client rate limiting information.
Monitor
Sets and modifies client rate limiting mode, direction, and client rate.
Configure
Line Rate
Display
Displays line rate configuration information.
Monitor
Setup
Sets the line rate.
Configure
Trust Mode
Displays priority trust mode configuration information.
Management
Sets the priority trust mode.
Management
Classifier
Display
Displays classifier configuration information.
Monitor
Create
Creates a class.
Configure
Setup
Sets the classification rules for a class.
Configure
Delete
Deletes a class or its classification rules.
Configure
Behavior
Display
Displays traffic behavior configuration information.
Monitor
Create
Creates a traffic behavior.
Configure
Setup
Sets actions for a traffic behavior.
Configure
Delete
Configure
QoS Policy
Display
Displays QoS policy configuration information.
Monitor
Create
Creates a QoS policy.
Configure
Setup
Sets the classifier-behavior associations for a QoS policy.
Configure
Delete
Deletes a QoS policy or its classifier-behavior associations.
Configure
Apply to Port
Display
Displays the QoS policy applied to a port.
Monitor
Setup
Applies a QoS policy to a port.
Configure
Delete
Removes the QoS policy from the port.
Configure
Service Policy
Queries wireless QoS service policies.
Monitor
SNMP
Setup
Summary
Displays SNMP configurations and statistics.
Monitor
Configuration
Specifies whether to enable or disable SNMP and sets related parameters.
Management
Users
Summary
Displays configurations of SNMP users, detailed information of their groups and views.
Monitor
Create
Creates an SNMP user.
Management
Modify
Modifies an SNMP user.
Management
Remove
Removes an SNMP user.
Management
Groups
Summary
Displays the configurations of the SNMP groups.
Monitor
Create
Creates an SNMP group.
Management
Modify
Modifies an SNMP group.
Management
Remove
Removes an SNMP group.
Management
Summary
Displays the configurations of the SNMP views.
Management
Create
Creates an SNMP view.
Management
Remove
Removes an SNMP view.
Management
Traps
Summary
Displays the configurations of SNMP traps target hosts.
Monitor
Setup
Specifies whether to enable or disable the SNMP traps.
Management
Add Target Hosts
Adds SNMP traps target hosts.
Management
Remove Target Hosts
Removes SNMP traps target hosts.
Management
Advanced Settings
District code
Displays the district code.
Monitor
Modifies the district code.
Configure
AC Backup
Setup
Displays the address of the backup AC.
Monitor
Sets the address of the backup AC.
Configure
Status
Displays the status of the AC.
Monitor
Load Balancing
Displays the load balancing mode and the current connection status.
Monitor
Sets the load balancing mode and refreshes the current connection status.
Configure
AP Setup
AP Version
Displays the AP version, including the AP model and software version.
Monitor
Upgrades the software.
Configure
Switch to fat AP
Displays the model and IP address of the AP.
Monitor
Switches to fat AP.
Configure
Introduction to the Controls on the Web Pages
Apply button
Click to submit the input information.
Cancel button
Click to cancel the input information. The page changes to the display page of the function or to the Device Info page.
Search button
Select an item to be queried, input the keyword, and click the Query button to display the items that meet the requirements.
The advance search function is also provided. You can click the plus sign before Search Item, as shown in Figure 1-4. You can select Match case and whole word, that is, the item to be searched must completely match the keyword, or you can select Search in previous results. If you do not select exact search, fuzzy search is performed.
Figure 1-4 Advanced search
Refresh button
Click to refresh the display information of the current page.
Clear button
Click to clear all the items in a list or all statistics.
Remove button
Click to remove the selected items.
Select All button
Click to select all the items in a list, or all the ports on the device panel.
Select None button
Click to deselect all the items in a list, or all the ports on the device panel.
Restore button
Click to restore all the items in the current configuration page to the system default.
 icon
Click to enter the modification page of an item to modify the configurations of the item.
 icon
Click to delete the item corresponding to this icon.
Help button
Click to open the online help page, which provides the help information of the operations performed on the current Web page.
Sort display
On the page, you can click the blue items of each column (for example, as shown in the following figure, if you click Name, an upper or lower arrow will be displayed at the right side of the Name column) to sort and display the records based on the item you selected.
Figure 1-5 Sort display
Configuration Guidelines
l          The Web-based configuration interface does not support the Back, Next, Refresh buttons provided by the browser. Using these buttons may result in abnormal display of Web pages.
l          When the device is performing the spanning tree calculation, you cannot log in to or use the Web interface.
l          As the Windows firewall limits the number of TCP connections, when you use IE to log in to the Web interface, sometimes you may be unable to open the Web interface. To avoid this problem, it is recommended to turn off the Windows firewall before login.
l          If the software version of the device changes, when you log in to the device through the Web interface, you are recommended to delete the temporary Internet files on IE; otherwise, the Web page content may not be displayed correctly.
l          The Web interface supports only Microsoft Internet Explorer 6.0 SP2 or higher.
