Title | Size | Downloads |
09-System Maintaining and Debugging Configuration.pdf | 151.87 KB |
09-System Maintaining and Debugging Configuration | 151.87 KB |
1 System Maintaining and Debugging
When maintaining and debugging the system, go to these sections for information you are interested in:
l System Maintaining and Debugging
l Ping
l Tracert
l Ping and Tracert Configuration Example
You can use the ping command and the tracert command to verify the current network connectivity, and use the debug command to enable debugging and thus to diagnose system faults based on the debugging information.
Ping
Introduction
You can use the ping command to verify whether a device with a specified address is reachable, and to examine network connectivity.
The ping function is implemented through the Internet Control Message Protocol (ICMP):
1) The source device sends an ICMP echo request to the destination device.
2) The source device determines whether the destination is reachable based on whether it receives an ICMP echo reply, determines the link quality based on the numbers of ICMP echo requests sent and replies received, determines the distance between the source and destination based on the round trip time of ping packets.
The ping function of H3C devices provides the –r option, with which you can know the detailed information of routes from source to destination. The principle of ping –r is as shown in Figure 1-1.
3) The source (Device A) sends an ICMP echo request with the RR option being empty.
4) The intermediate device (Device B) adds the IP address of its outbound interface to the RR option of the ICMP echo request, and forwards the packet.
5) Upon receiving the request, the destination device copies the RR option in the request and adds the IP address of its outbound interface to RR option. Then the destination device sends an ICMP echo reply.
6) The intermediate device adds the IP address of its outbound interface to the RR option in the ICMP echo reply, and then forwards the reply.
7) Upon receiving the reply, the source device adds the IP address of its outbound interface to RR option and device sends the reply to the CPU for processing. The CPU will display the output route information.
Figure 1-1 ping –r principle diagram
Configuring Ping
Follow the step below to configure the ping function:
To do… |
Use the command… |
Remarks |
Check whether a specified address in an IP network is reachable |
ping [ ip ] [ -a source-ip | -c count | -f | -h ttl | -i interface-type interface-number | -m interval | -n | -p pad | -q | -r | -s packet-size | -t timeout | -tos tos | -v | -vpn-instance vpn-instance-name ] * host |
Required Use either approach The ping command is applicable in an IPv4 network; the ping ipv6 command is applicable in an IPv6 network. Available in any view |
ping ipv6 [ -a source-ipv6 | -c count | -m interval | -s packet-size | -t timeout ] * host [ -i interface-type interface-number ] |
l For a low-speed network, you are recommended to set a larger value for the timeout timer (indicated by the -t parameter in the command) when configuring the ping command.
l Only the directly connected segment address can be pinged if the outgoing interface is specified with the -i argument
l For an S3610/S5510 switch to support the VPN instance feature and the vpn-instance keyword in related commands, you must configure it to operate in MCE mode. For details about the operating mode of a switch, refer to Dual Stack Configuration in the IP Services Volume
Tracert
Introduction
By using the tracert command, you can trace the Layer 3 devices involved in delivering an IP packet from source to destination to check whether a network is available. This is useful for identification of failed node(s) in the event of network failure.
Figure 1-2 Tracert diagram
The tracert function is implemented through ICMP, as shown in Figure 1-2:
1) The source (Device A) sends a packet with a TTL value of 1 to the destination (Device D). The UDP port of the packet is a port number that will not be used by any application of the destination.
2) The first hop (Device B) (the Layer 3 device that first receives the packet) responds by sending a TTL-expired ICMP error message to the source, with its IP address 1.1.1.2 encapsulated. In this way, the source device can get the address (1.1.1.2) of the first Layer 3 device.
3) The source device sends a packet with a TTL value of 2 to the destination device.
4) The second hop (Device C) responds with a TTL-expired ICMP error message, which gives the source device the address (1.1.2.2) of the second Layer 3 device.
5) The above process continues until the ultimate destination device is reached. No application of the destination uses this UDP port. Therefore, the destination replies a port unreachable ICMP error message with the destination IP address 1.1.3.2.
6) When the source device receives the port unreachable ICMPv6 error message, it knows that the packet has reached the destination, and it can get the addresses of all the Layer 3 devices involved to get to the destination device (1.1.1.2, 1.1.2.2, 1.1.3.2).
Configuring Tracert
Follow these steps to configure tracert:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enable sending of ICMP timeout packets |
ip ttl-expires enable |
Required Disabled by default. |
Enable sending of ICMP destination unreachable packets |
ip unreachables enable |
Display the routes from source to destination |
tracert [ -a source-ip | -f first-ttl | -m max-ttl | -p port | -q packet-number | -vpn-instance vpn-instance-name | -w timeout ] * host |
Required Use either approach The tracert command is applicable in an IPv4 network; the tracert ipv6 command is applicable in an IPv6 network. Available in any view |
tracert ipv6 [ -f first-ttl | -m max-ttl | -p port | -q packet-number | -w timeout ] * host |
System Debugging
Introduction to System Debugging
The device provides various debugging functions. For the majority of protocols and features supported, the system provides corresponding debugging information to help users diagnose errors.
The following two switches control the display of debugging information:
l Protocol debugging switch, which controls protocol-specific debugging information.
l Screen output switch, which controls whether to display the debugging information on a certain screen.
As Figure 1-3 illustrates, suppose the device can provide debugging for the three modules 1, 2, and 3. Only when both the protocol debugging switch and the screen output switch are turned on can debugging information be output on a terminal.
Figure 1-3 The relationship between the protocol and screen debugging switch
Configuring System Debugging
Output of the debugging information may reduce system efficiency. The debugging commands are usually used by administrators in diagnosing network failure. After completing the debugging, disable the corresponding debugging function, or use the undo debugging all command to disable all the debugging functions.
Output of debugging information is related to the configurations of the information center and the debugging commands of each protocol and functional module. Displaying the debugging information on a terminal (including console or VTY) is a common way to output debugging information. You can also output debugging information to other destinations. For the detailed configurations, refer to Information Center Commands in the System Volume. By default, you can output debugging information to a terminal by following these steps:
To do… |
Use the command… |
Remarks |
Enable the terminal monitoring of system information |
terminal monitor |
Optional The terminal monitoring on the console is enabled by default and that on the monitoring terminal is disabled by default. Available in user view |
Enable the terminal display of debugging information |
terminal debugging |
Required Disabled by default Available in user view |
Enable debugging for a specified module |
debugging { all [ timeout time ] | module-name [ option ] } |
Display the enabled debugging functions |
display debugging [ interface interface-type interface-number ] [ module-name ] |
Optional Available in any view |
You must configure the debugging, terminal debugging and terminal monitor commands first to display the detailed debugging information on the terminal. For the detailed description on the terminal debugging and terminal monitor commands, refer to Information Center Commands in the System Volume.
Network requirements
As shown in Figure 1-4, Device A failed to telnet Device C. Now it is required to determine whether an available route exists between Device A and Device C. If no such a route exists, you need to locate the failed nodes in the network.
Figure 1-4 Ping and tracert network diagram
Configuration procedure
# Use the ping command to display whether an available route exists between Device A and Device C.
<DeviceA> ping 1.1.2.2
PING 1.1.2.2: 56 data bytes, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
--- 1.1.2.2 ping statistics ---
5 packet(s) transmitted
0 packet(s) received
100.00% packet loss
# No such a route exists. Use the tracert command to determine failed nodes.
[DeviceA] ip ttl-expires enable
[DeviceA] ip unreachables enable
[DeviceA] tracert 1.1.2.2
traceroute to 1.1.2.2(1.1.2.2) 30 hops max,40 bytes packet, press CTRL_C to bre
ak
1 1.1.1.2 14 ms 10 ms 20 ms
2 * * *
3 * * *
4 * * *
5
<DeviceA>
The above output shows that no available route exists between Device A and Device C; an available router exists between Device A and Device B; an error occurred on the connection between Device B and Device C. In this case, you can use the debugging ip icmp command to enable ICMP debugging on Device A and Device C to check whether the devices send or receive the specified ICMP packets, or you can use the display ip routing-table command to display whether a route exists between the two devices.
