01-Access Volume
HomeSupportSwitchesH3C S3610[S5510] Switch SeriesConfigure & DeployConfiguration GuidesH3C S3610[S5510] Series Ethernet Switches Operation Manual-Release 5309-6W10001-Access Volume
01-Access Volume
Title Size Downloads
03-Port Isolation Configuration.pdf 67.01 KB
Table of Contents
Related Documents
03-Port Isolation Configuration 67.01 KB
When configuring port isolation, go to these sections for information you are interested in:
l          Introduction to Port Isolation
l          Configuring the Isolation Group
l          Displaying and Maintaining Isolation Groups
l          Port Isolation Configuration Example
Usually, Layer 2 traffic isolation is achieved by assigning ports to different VLANs. To save VLAN resources, port isolation is introduced to isolate ports within a VLAN, allowing for great flexibility and security.
Currently:
l          S3610&S5510 series Ethernet switches support only one isolation group that is created automatically by the system as isolation group 1. You can neither remove the isolation group nor create other isolation groups on such devices.
l          There is no restriction on the number of ports assigned to an isolation group.
l          The member port of an aggregation group cannot be configured as the uplink port of an isolation group and vice versa. If you assign a port to an aggregation group and to an isolation group as the uplink port at the same time, the aggregation group configuration will take effect and the isolation group configuration will be removed for backward configuration file compatibility. For detailed information about link aggregation, refer to Link Aggregation Configuration in the Access Volume.
l          The member port of a service loopback group cannot be configured as the uplink or isolated port of an isolation group and vice versa.
Usually, Layer 2 traffic cannot be forwarded between ports in different VLANs. However, the Layer-2 traffic from an isolated port can pass through the uplink port in the same isolation group unidirectionally even if they belong to different VLANs.
Within the same VLAN, the supported Layer 2 data transmission between different types of ports is shown in Figure 1-1.
Figure 1-1 Layer 2 traffic forwarding for an isolation group (with an uplink port)
The arrows in the above figure indicate the move direction of Layer 2 traffic.
Assigning a Port to the Isolation Group
Follow these steps to add a port to the isolation group:
To do…
Use the command…
Remarks
Enter system view
Enter interface view or, port group view
Enter Layer 2 Ethernet port view
Required
Use one of the commands.
l      In Layer 2 Ethernet port view, the subsequent configurations apply to the current port.
l      In Layer-2 aggregate interface view, the subsequent configurations apply to the Layer-2 aggregate interface and all its member ports.
l      In port group view, the subsequent configurations apply to all ports in the port group.
Enter Layer-2 aggregate interface view
Enter port group view
port-group manual port-group-name
Assign the port or ports to the isolation group as an isolated port or ports
port-isolate enable
Required
No ports are added to the isolation group by default.
Specifying the Uplink Port for the Isolation Group
Follow these steps to specify the uplink port for the isolation group:
To do…
Use the command…
Remarks
Enter system view
Enter Ethernet or Layer-2 aggregate interface view
Required
Use either command.
l      In Layer-2 aggregate interface view, only the Layer-2 aggregate interface is configured as the uplink port of the isolation group. You can configure the member ports of the aggregation group corresponding to the Layer-2 aggregate interface as isolated ports of the isolation group. Thus configured, these ports are set to the unselected state in the aggregation group, that is, these ports cannot forward user traffic.
Configure the current port as the uplink port of the isolation group
port-isolate uplink-port
Required
An isolation group has no uplink port by default.
l          An isolation group can have only one uplink port. The uplink port you configured for an isolation group can overwrite the previous one, if any.
To do…
Use the command…
Remarks
Display the isolation group information on a single-isolation-group device
display port-isolate group
Available in any view
Network requirements
l          Users Host A, Host B, and Host C are connected to Ethernet 1/0/1, Ethernet 1/0/2, and Ethernet 1/0/3 of Device.
l          Device is connected to the Internet through Ethernet 1/0/4.
l          Ethernet 1/0/2, Ethernet 1/0/3, and Ethernet 1/0/4 belong to VLAN 2 and Ethernet 1/0/1 carries VLAN 2.
It is required that Host A, Host B, and Host C can access the Internet while being isolated from one another.
Figure 1-2 Networking diagram for port isolation configuration
Configuration procedure
# Add ports Ethernet 1/0/1, Ethernet 1/0/2 and Ethernet 1/0/3 to the isolation group.
[Device] interface ethernet 1/0/1
[Device-Ethernet1/0/1] port-isolate enable
[Device-Ethernet1/0/1] quit
[Device] interface ethernet 1/0/2
[Device-Ethernet1/0/2] port-isolate enable
[Device-Ethernet1/0/2] quit
[Device] interface ethernet 1/0/3
[Device-Ethernet1/0/3] port-isolate enable
# Configure port Ethernet 1/0/4 as the uplink port of the isolation group.
[Device-Ethernet1/0/3] quit
[Device] interface ethernet 1/0/4
[Device-Ethernet1/0/4] port-isolate uplink-port
[Device-Ethernet1/0/4] return
# Display the information about the isolation group.
<Device> display port-isolate group
 Port-isolate group information:
 Uplink port support: YES
 Group ID: 1
 Uplink port: Ethernet1/0/4
 Group members:
    Ethernet1/0/1     Ethernet1/0/2     Ethernet1/0/3
