08-ACL and QoS Configuration Guide
HomeSupportSwitchesS6890 SeriesConfigure & DeployConfiguration GuidesH3C S6890 Switch Series Configuration Guides(R27xx)-6W10508-ACL and QoS Configuration Guide
05-MPLS QoS configuration
05-MPLS QoS configuration 51.23 KB
Configuring MPLS QoS
About MPLS QoS
MPLS uses 3 bits, called EXP bits, to carry class-of-service information to provide support for DiffServ. MPLS QoS identifies different traffic flows with different EXP bits and implements differentiated services.
MPLS QoS supports CAR and priority marking. MPLS QoS classifies traffic on the PE and apply differentiated QoS strategies for different traffic classes. For example, MPLS QoS can organize packets with EXP value 1 into a class and packets with EXP value 2 into another class. Then it performs traffic policing and priority marking for each class of packets.
The EXP field in an MPLS label is processed according to the following rules:
·     The device re-sets the EXP field of only the topmost label.
·     During label encapsulation, the ToS field of the IP packet is directly changed into the EXP field of the MPLS label.
·     The EXP field remains unchanged when label swapping is performed.
·     During a label push operation, the EXP field of the newly pushed outer label inherits the EXP field of the inner label.
·     After a label pop operation for a packet, the following rules apply:
¡     If the packet is still an MPLS packet, the EXP field of the popped label is not copied to the inner label.
¡     If the packet is an IP packet, the EXP field of the popped label is not copied to the ToS field of the IP packet.
Configuring MPLS priority marking
In an MPLS network, you can adjust the priority of an MPLS traffic flow by marking its EXP value. For more information about priority marking, see "Configuring priority marking."
2.     Define a traffic class.
a.     Create a traffic class and enter traffic class view.
b.     Configure match criteria for the traffic class.
-     if-match mpls-exp exp-value&<1-8>
-     if-match second-mpls-exp exp-value&<1-8>
-     if-match mpls-label { label-value&<1-8> | label-value1 to label-value2 }
-     if-match second-mpls-label { label-value&<1-8> | label-value1 to label-value2 }
By default, no match criteria are configured.
The match criteria apply only to MPLS packets.
c.     Return to system view.
3.     Define a traffic behavior.
a.     Create a traffic behavior and enter traffic behavior view.
b.     Configure an EXP marking action in the traffic behavior.
remark mpls-exp exp-value
By default, no EXP marking action is configured.
4.     Define a QoS policy.
a.     Create a QoS policy and enter QoS policy view.
qos policy policy-name
b.     Associate the traffic class with the traffic behavior in the QoS policy.
classifier classifier-name behavior behavior-name
By default, no traffic behavior is associated with a traffic class.
5.     Apply the QoS policy.
For more information, see "Configuring a QoS policy."
