| Title | Size | Downloads |
| APP_R3.1.572_G_EN.zip | 10.28 MB |
Version
APP-R3.1.572-G
MD5 Value
DF0DED28E20F6B2F2F726E95FE8B998E
Update Time
2026-07-07
Applicable Versions
Compatible with ACG1000 R6614 and later host versions
Notes:
1) The signature library is in .ubc format and can be directly uploaded for use;
2) Product updates may take some time. During the update process, users should not perform operations involving other functions of the product. Since background services will be modified during the update, this precaution helps avoid data inconsistencies caused by the upgrade.
