- H3C SecPath AFC2000-EX0-G Series Abnormal Traffic Cleaning System Configuration Examples-5W100
- 01-Series Deployment Single-Machine Single-Channel and Multi-Channel Configuration Example.
- 02-BGP Layer 3 Bypass Return Path Configuration Example
- 03-BGP Auto-Diversion Deployment with Bypass and Abnormal Traffic Detection System Example
- 04-TCP Port Protection Configuration Example
- 05-AFC Comprehensive Protection Configuration Example
- 06-Typical Configuration Examples of Traction Management Example
- 07-OSPF Layer 2 Reintroduction Configuration Example
- 08-Cascaded Cluster and Dual-Node Active-Standby Configuration Example
- 09-Bypass BGP Layer 2 Return Traffic Configuration Example
- 10-OSPF-Based Three-Layer Return Injection Configuration Example
- 11-BGP-Based Three-Layer Injection Configuration Example for Bypass Single-Device Multi-Channel Deployment Example
- 12-BGP-Based Three-Layer Injection Configuration Example for Bypass Multi-Device Cluster Deployment Example
- 13-Bypass GRE Layer 3 Return Injection Configuration Example
- 14-Typical Configuration for HTTPS CC Protection Example
| 00-Preface | 110.89 KB |
Preface
This configuration guide mainly introduces configuration examples methods of the H3C SecPath AFC2000 series application control gateway.
· Audience
Audience
· Network planners.
· Network operators, administrators, and maintainers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
The angle brackets "< >" indicate the name of a button, such as "Click the button". |
Square brackets "[ ]" indicate window names, menu names, and data tables, such as "Pop up the [New User] window". |
Symbols
This documentation uses the following symbols to highlight information that requires different levels of attention:
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Screenshots and examples provided in this documentation are for illustration only. They might differ depending on the hardware model, software version, and configuration. In actual use, please refer to the content displayed on the device.
The interface numbers in this documentation are for illustration only. They might differ from the port numbers available on your device.
Documentation feedback
We appreciate your comments.
