04-Layer 2—LAN Switching Configuration Guide
HomeSupportSwitchesS7500X-G SeriesConfigure & DeployConfiguration GuidesH3C S7500X-G Switch Series Configuration Guides-R7756Pxx-6W10104-Layer 2—LAN Switching Configuration Guide
13-Service loopback group configuration
13-Service loopback group configuration 51.45 KB
Configuring service loopback groups
About service loopback groups
A service loopback group loops packets sent out by the device back to the device. This feature must work with other features. In the current software version, a service loopback group can be applied only to the EVPN VXLAN gateway service.
Restrictions: Hardware compatibility with service loopback group
Only SD interface modules, SF interface modules, and ports on the SC MPUs prefixed with LSCM2 support the service loopback group feature.
A device supports service loopback groups only when it operates in expert mode. For more information about device operating modes, see device management configuration in Fundamentals Configuration Guide.
Restrictions and guidelines: Service loopback group configuration
When you apply service loopback groups to features, follow these restrictions and guidelines:
·     You can apply a service loopback group to other features once the group is created. The service loopback group will process services for the features.
·     Do not delete a service loopback group that is being used by a feature.
Configuring a service loopback group
2.     Create a service loopback group and specify its service type.
service-loopback group group-id type vsi-gateway
You can configure only one service loopback group for a service type.
Display and maintenance commands for service loopback groups
Display information about service loopback groups.
display service-loopback group [ group-id ]
