22-WLAN Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath F1000[F5000] Firewalls Series Configuration Guides(V7)(R9900)-6W10022-WLAN Configuration Guide
15-WLAN IP snooping configuration
15-WLAN IP snooping configuration 150.25 KB
Configuring WLAN IP snooping
The following compatibility matrix shows the support of hardware platforms for WLAN IP snooping:
Series
Models
WLAN IP snooping compatibility
F5000系列
F5000-AI-160-GF5000-AI-130-GF5000-AI-120-GF5000-AI-110-GF5000-AI-55-GF5000-AI-25-GF5000-AI-15-GF5000-CN160-GF5000-E-GF5000-E-G2F5000-S-G2F5000-M-G2F5000-A-G2F5000-CN160F5000-CN-G55F5080F5030
No
F5000-AI160
Yes
F1000系列
F1000-AK9130F1000-AI-35F1000-AI-25F1000-AI-10F1000-AI-03-EF1000-AI-90-GF1000-AI-80-GF1000-AI-75-GF1000-AI-65-GF1000-AI-55-GF1000-AI-35-GF1000-AI-25-GF1000-AI-05-GF1000-AI-03-GF1000-AI-05-GSF1000-AK1380-GF1000-AK1300-GF1000-AK1220-GF1000-AK1180-GF1000-AK1080-GF1000-AK1050-G
No
F1000-AI-90F1000-AI-60F1000-AI-55F1000-AI-15
Yes
About WLAN IP snooping
WLAN IP snooping enables an AP to learn clients' IP addresses through snooping ARP, DHCP, ND, and HTTP/HTTPS packets and generate snooping entries that record client IP address, MAC address, and learning method. The entries will be used by AAA for 802.1X and MAC authentication client accounting or by WLAN SAVI to determine whether to forward client packets. For more information about WLAN SAVI, see WLAN Configuration Guide.
In an AP+AC network, APs report snooping entries to the AC.
Client IPv4 address learning
An AP learns client IPv4 addresses by using the following methods:
·     Snooping ARP packets sent by clients.
For more information about ARP, see Layer 3IP Services Configuration Guide.
·     Snooping DHCPv4 packets exchanged between client and server.
For more information about DHCP, see Layer 3IP Services Configuration Guide.
·     Snooping HTTP/HTTPS requests redirected to the portal server.
For more information about portal authentication, see Security Configuration Guide.
The priorities for learning IP addresses through snooping DHCPv4 packets, ARP packets, and HTTP/HTTPS requests are in descending order.
Client IPv6 address learning
An AP learns client IPv6 addresses by using the following methods:
·     Snooping DHCPv6 packets exchanged between client and server.
For more information about DHCPv6, see Layer 3IP Services Configuration Guide.
·     Snooping ND packets, including Router Advertisement (RA) packets, Neighbor Solicitation (NS) packets, and Neighbor Advertisement (NA) packets sent by clients.
For more information about ND, see Layer 3—IP Services Configuration Guide.
The priorities for learning IPv6 addresses through snooping DHCPv6 packets, ND packets, and HTTP/HTTPS requests are in descending order.
Disabling snooping ARP packets
By default, an AP learns client IPv4 addresses by snooping ARP and DHCPv4 packets. Perform this task to disable client IPv4 address learning from ARP packets.
2.     Create a service template and enter its view.
wlan service-template service-template-name
3.     Disable snooping ARP packets.
undo client ipv4-snooping arp-learning enable
By default, snooping ARP packets is enabled.
Configuring snooping DHCPv4 packets
By default, an AP learns client IPv4 addresses by snooping ARP and DHCPv4 packets. You can perform this task to disable client IPv4 address learning from DHCPv4 packets and set the timeout for IPv4 address learning through DHCP.
With the timeout set, the system logs off clients that fail to obtain an IPv4 address through DHCP within the specified period.
The timeout takes effect only on clients coming online afterwards from the AC.
3.     Disable snooping DHCPv4 packets.
undo client ipv4-snooping dhcp-learning enable
By default, snooping DHCPv4 packets is enabled.
4.     (Optional.) Set the timeout for IPv4 address learning through DHCP.
client ipv4-snooping dhcp-learning timeout value
By default, the timeout is 0 and the system does not log off clients that fail to obtain an IPv4 address through DHCP.
Enabling snooping DHCPv6 packets
By default, an AP does not learn client IPv6 addresses. Perform this task to enable client IPv6 address learning from DHCPv6 packets.
3.     Enable snooping DHCPv6 packets.
client ipv6-snooping dhcpv6-learning enable
By default, snooping DHCPv6 packets is enabled.
Enabling snooping ND packets
By default, an AP does not learn client IPv6 addresses. Perform this task to enable client IPv6 address learning from ND packets.
3.     Enable snooping ND packets.
client ipv6-snooping nd-learning enable
By default, snooping ND packets is enabled.
Disabling SNMP from getting client IPv6 addresses learned from ND packets
By default, SNMP obtains client IPv6 addresses learned from both DHCPv6 and ND packets. Perform this task to enable SNMP to obtain only client IPv6 addresses learned from DHCPv6 packets.
3.     Disable SNMP from getting client IPv6 addresses learned from ND packets.
undo client ipv6-snooping snmp-nd-report enable
Enabling snooping HTTP and HTTPS requests redirected to the portal server
Before a client passes portal authentication, all of its HTTP and HTTPS requests are redirected to the portal server. Perform this task to enable snooping of redirected HTTP and HTTPS requests for the AC to learn client IPv4 addresses.
This feature can only be used to learn IP addresses of portal-authenticated clients.
3.     Enable snooping HTTP and HTTPS requests redirected to the portal server.
client ip-snooping http-learning enable
By default, snooping HTTP and HTTPS requests is disabled.
Enabling ACL-based learning of endpoint IP addresses
After connecting to a wireless network, a wireless endpoint will carry vendor information and an IP address obtained from that wireless network. If the endpoint accesses another vendor's network or another network later, the device on the new network might learn an incorrect IP address from the endpoint. To resolve this issue, enable ACL-based learning of endpoint IP addresses. This feature enables the device to learn IP addresses of new endpoints based on rules of the specified ACL.
When a wireless endpoint connects to a wireless network, the device performs the following task:
1.     Matches IP address of that wireless endpoint against the specified ACL.
2.     Determines whether to learn the endpoint IP address based on the match result as follows:
¡     If the endpoint IP address matches a permit rule in the ACL, the device will learn the endpoint IP address.
¡     If the endpoint IP address matches a deny rule or cannot match any rule in the ACL, the device will not learn the endpoint IP address.
CAUTION
CAUTION:
After you configure a deny rule in the ACL to reject learning specific endpoint IP addresses, you must configure a permit rule following the deny rule. The permit rule must allow learning all endpoint IP addresses. Otherwise, the device cannot learn any endpoint IP addresses.
This feature takes effect only if snooping ARP or ND packets is enabled.
If you execute this command multiple times, only the most recent configuration takes effect.
3.     Enable ACL-based learning of endpoint IP addresses.
client ip-snooping acl acl-number
By default, ACL-based learning of endpoint IP addresses. is disabled.
Enabling IP address conflict detection
This feature enables the system to detect IP address conflicts between a client attempting to come online and online clients. The system logs off the online clients that use the same IP address as the new client and creates IP address conflict entries for the clients. The system deletes the IP address conflict entry for a client when the client cache expires or the client's IP address changes.
In an AC hierarchy network, you can disable IP address conflict detection on the central AC if portal authentication has been disabled or accounting has been disabled for 802.1X or MAC authentication clients. This allows clients from different local ACs to come online with the same IP address, simplifying DHCP configuration.
2.     Enable IP address conflict detection.
wlan client ip-conflict-detection enable
By default, IP address conflict detection is enabled.
Enabling IP address recovery for reassociated clients
After a roaming, clients might fail to obtain new IP addresses through DHCP, DHCPv6, or ND for a long time, because the previously obtained addresses have not expired. If WLAN SAVI is enabled, data packets from such clients will be discarded. To resolve the issue, you can enable IP address recovery for reassociated clients.
With this feature enabled, the AC reports the IP and MAC addresses of a client to the WLAN roaming center when the client leaves an AP. If the client fails to obtain a new address within the address recovery period after the roaming, it retrieves the old address from the WLAN roaming center for temporary network access.
After obtaining a new address, the client will update its address and use the new address to access the network.
This feature takes effect only on clients association of which is performed at the AC.
2.     Enter service template view.
3.     Enable IP address recovery for reassociated clients.
client ip-snooping ip-recover enable [ delay time ]
By default, IP address recovery is disabled for reassociated clients.
Display and maintenance commands for WLAN IP snooping
Execute the display command in any view.
Display statistics about clients with conflict IP addresses.
display wlan statistics client-ip-conflict
WLAN IP snooping configuration examples
Example: Configuring WLAN IP snooping
As shown in Figure 1, configure the AP to learn the client's IPv6 address from DHCPv6 packets.
Figure 1 Network diagram
# Configure wireless services. (Details not shown.)
For more information, see "Managing APs" and "Configuring WLAN access."
# Enable snooping DHCPv6 packets.
<AC> system-view
[AC] wlan service-template service
[AC-wlan-st-service] client ipv6-snooping dhcpv6-learning enable
[AC-wlan-st-service] quit
# Verify that the AC has learned the IPv6 address of the client.
[AC] display wlan client ipv6
MAC address    AP name              IPv6 address                            VLAN
84db-ac14-dd08 ap1                  1::2:0:0:3                              1
