15-Network Management and Monitoring Command Reference
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesCommand ReferencesH3C SR8800-X Routers Command Reference-R8530Pxx-6W10215-Network Management and Monitoring Command Reference
04-iFIT commands
04-iFIT commands 367.12 KB
iFIT commands for application-level measurement
bind interface
Use bind interface to bind an interface to an instance.
Use undo bind interface to unbind an interface from an instance.
bind interface interface-type interface-number
undo bind interface [ interface-type interface-number ]
An instance is not bound to any interface.
iFIT instance view
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this argument, the default setting will be restored. In the current software version, you can bind a Layer 3 physical interface, Layer 3 aggregate interface, a slot-based L2VE interface, and a slot-based L3VE and its subinterface to an instance.
Before enabling iFIT measurement on the ingress node of an instance, execute this command to bind an interface to the instance. After you bind an interface to an instance, iFIT parses the packets passing through the interface to identify the target packets and add an iFIT header to each target packets. Meanwhile, iFIT will count the number of target packets, and send the packet count and timestamp to the analyzer at intervals through gRPC.
You can repeat this command to bind multiple interfaces to an instance. You can configure only one set of flow match criteria for an instance. Each bound interface matches target flows based on the same set of criteria and assigns different flow IDs to the target flows. iFIT measures the delay and packet loss of the target flows on a per-interface basis.
# Bind interface Ten-GigabitEthernet3/1/1 to instance abc.
[Sysname] ifit enable
[Sysname-ifit] instance abc
[Sysname-ifit-instance-abc] bind interface ten-gigabitethernet 3/1/1
# Bind interface Route-Aggregation 1 to instance abc.
[Sysname-ifit-instance-abc] bind interface route-aggregation 1
delay-measure disable
Use delay-measure disable to disable packet delay measurement.
Use undo delay-measure disable to enable packet delay measurement.
Packet delay measurement is enabled.
iFIT instance view
By default, packet delay measurement is enabled. You can execute this command to disable packet delay measurement as required.
# Disable packet delay measurement.
[Sysname-ifit-instance-abc] delay-measure disable
delete dynamic-flow
Use delete dynamic-flow to delete iFIT dynamic flows.
delete dynamic-flow { all | device-id device-id flow-id flow-id }
iFIT view
all: Specifies all dynamic flows.
device-id device-id: Specifies an iFIT device by its ID in the range of 1 to 1048575. A flow ID and a device ID uniquely identify an iFIT flow.
flow-id flow-id: Specifies an iFIT flow by its ID in the range of 1 to 1048575.
A flow ID is generated on the ingress node and passed to the transit nodes and egress node. A flow ID and a device ID/device IP uniquely identify a flow and you can execute the display ifit flow static command to view the flow ID.
# Delete the dynamic flow with device ID 2 and flow ID 4098.
[Sysname-ifit] delete dynamic-flow device-id 2 flow-id 4098
device-id
Use device-id to specify a device ID.
Use undo device-id to restore the default.
device-id device-id
undo device-id
No device ID is specified.
iFIT view
device-id: Specifies a device ID in the range of 1 to 1048575.
A device ID uniquely identifies a device on an iFIT network. To make iFIT function correctly, specify a device ID and make sure the specified device ID is unique.
# Specify 100 as the device ID.
[Sysname-ifit] device-id 100
display ifit flow dynamic
flow
Use display ifit flow dynamic to display dynamic flow information.
display ifit flow dynamic [ device-id device-id flow-id flow-id]
flow-id flow-id: Displays information about a dynamic flow by its ID. The value range for the flow-id argument is 1 to 1048575.
A static flow is a service flow that matches a set of criteria configured on the ingress node. The ingress node generates a static flow after you enable iFIT measurement and execute the flow command to configure iFIT flow match criteria. The static flow is uniquely identified by a device ID and a flow ID. The  device ID is configured by the device-id command and the flow ID is a number that is randomly generated on the ingress node in the range of 1 to 1048575. The device ID and flow ID are encapsulated in an iFIT header and passed to the transit nodes and egress node.
To view the device ID and flow ID of a static flow, execute the display ifit flow static command on the ingress node.
A dynamic flow is a service flow that the device dynamically learns. For the ingress node, if the device receives a packet that matches static flow settings, a dynamic flow with the same flow ID as the static flow is generated. For a transit node and the egress node, they parse the received packets and generate dynamic flows by dynamically learning from the iFIT headers of the packets.
# Display dynamic flow information.
<Sysname> display ifit flow dynamic
Device ID                : 1
Flow ID                  : 4099
Flow type                : Dynamic
Flow direction           : Unidirection
Period                   : 10 sec
Actual aging-time        : 300 sec
Aging threshold          : 90%
Interface information
Name                          Direction
Ten-GigabitEthernet3/1/1          TransitInput
Ten-GigabitEthernet3/1/2          TransitOutput
Device ID
iFIT device ID.
Flow ID
Flow ID of a dynamic flow.
Flow type
Flow type:
·     Static.
·     Dynamic.
Flow direction
Flow direction. If the field value is Unidirection, the flow is a unidirectional flow.
Period
Measurement period in seconds.
Actual aging-time
Actual time when the dynamic flow is aged out.
Aging threshold
Aging threshold of dynamic flows in percentage, that is, the percentage of the number of dynamic flows to the total number of dynamic flows supported on the device.
Information about the interfaces that receive the dynamic flow.
Name
Interface name.
Direction
Flow direction for the interface:
·     Ingress—The target flow enters the transit network from this interface.
·     TransitInput—The target flow enters the node from this interface.
·     TransitOutput—The target flow leaves the node from this interface.
·     Egress—The target flow leaves the transit network from this interface.
flow
Use display ifit flow static to display static flow information for the most recent 10 measurement periods.
display ifit flow static [ device-id device-id flow-id flow-id]
flow-id flow-id: Displays information about a static flow by its ID. The value range for the flow-id argument is 1 to 1048575.
# Display the configuration of the static flow with flow ID 4097. (The static flow is measured based on 5-tuple granularity in public network IPv4 over SRv6.)
<Sysname> display ifit flow static device-id 1 flow-id 4097
Instance name                  : 1
Device ID                      : 1
Flow ID                        : 4097
Transmit network type          : Tunnel
Flow information:
  Flow type                    : Static
  Source IP/mask length        : 1.1.1.1/24
  Destination IP/mask length   : 2.2.2.2/32
  Protocol                     : TCP
  Source port                  : Any
  Destination port             : Any
  DSCP                         : 23
  VPN instance name            : --
Measurement information:
  Period                       : 10 sec
  Measurement mode             : e2e
  Loss measurement             : Enabled
  Delay measurement            : Enabled
  Measurement configuration    : Enabled
  Measurement status           : Active
Bound interface:
# Display the configuration of the static flow with flow ID 4098. (The static flow is measured based on the 5-tuple granularity for IPv4 service traffic on an MPLS/SR-MPLS private network.)
<Sysname> display ifit flow static device-id 1 flow-id 4098
Instance name                  : 2
Device ID                      : 1
Flow ID                        : 4098
Flow information:
  Flow type                    : Static
  Destination IP/mask length   : 1.1.2.1/32
  Protocol                     : TCP
  Source port                  : Any
  DSCP                         : 23
  VPN instance name            : vpn2
  Period                       : 30 sec
Bound interface:
# Display the configuration of the static flow with flow ID 4100. (The static flow is measured based on the PeerLocator granularity on an L3VPN over SRv6 network.)
<Sysname> display ifit flow static device-id 1 flow-id 4100
Instance name                  : 4
Device ID                      : 1
Flow ID                        : 4100
Flow information:
  Flow type                    : Static
  Source IPv6                  : Any
  Destination IPv6             : Any
  DSCP                         : --
  VPN instance name            : 1
  Peer locator                 : 1::1/32
  Period                       : 30 sec
Bound interface:
# Display the configuration of the static flow with flow ID 4097. (The static flow is measured based on the Layer 2 parameter granularity on an EVPN VPLS over SRv6/G-SRv6 network.)
Instance name                    : 1
Device ID                        : 1
Flow ID                          : 4097
Flow information:
  Flow type                      : Static
  Source MAC                     : 0001-0001-0001
  EtherType                      : 0x0800
  VlanID                         : 200
  Vlan-Priority                  : 5
  VSI name                       : 1
  Peer locator                   : --
  Period                         : 30 sec
Bound interface:
Instance Name
Name of the iFIT instance.
Device ID
ID of the device that generates the iFIT target flow.
Flow ID
Flow ID of the target flow.
This field is available only for static flows.
Type of the transit network for iFIT measurement:
·     Tunnel.
·     Native-IP.
Flow information
Information about the target flow.
Flow type
Flow type:
·     Static.
·     Dynamic.
Flow direction
Source IP/maskLength
Source IP address and mask length.
Destination IP/maskLength
Destination IP address and mask length.
Source IPv6/prefix length
Source IPv6 address and prefix length.
Destination IPv6/prefix length
Destination IPv6 address and prefix length.
Protocol
Protocol:
·     Protocol ID, an integer in the ranges of 0 to 5, 7 to 16, 18 to 131, and 133 to 255, indicating protocols except UDP, TCP, and SCTP.
·     UDP.
·     TCP.
·     SCTP.
Source port
Source port number.
Destination port
Destination port number.
DSCP
DSCP value of the target flow.
VPN-instance name
Name of the VPN instance bound to the target flow.
Source MAC
Source MAC address of the target flow.
EtherType
Ethernet type of packets of the target flow, including:
·     0x0800—IPv4 packet.
·     0x86dd—IPv6 packet.
VlanID
VLAN ID of the target flow.
Vlan-Priority
VLAN priority of the target flow.
VSI name
Name of the VSI bound to the iFIT flow.
Xconnect-group
Name of the cross-connect group bound to the iFIT flow.
Connection
Cross-connect bound to the iFIT flow.
Information about iFIT measurement.
Period
Measurement period.
Measurement mode
Measurement mode:
·     trace—Hop-by-hop measurement.
·     e2e—End-to-end measurement.
Peer locator
Remote locator of the iFIT flow.
Loss measurement
Delay measurement state:
·     Enabled.
·     Disabled.
Delay measurement
Loss measurement state:
·     Enabled.
·     Disabled.
Configured measurement state:
·     Enabled.
·     Disabled.
Measurement status
Actual measurement state:
·     Active—iFIT measurement is in progress.
·     Inactive—iFIT measurement has not started.
Bound interface
Interface bound with the target flow.
flow
display ifit global-information
Use display ifit global-information to display global iFIT flow information.
# On an MPLS network, display global iFIT flow information.
<Sysname> display ifit global-information
Current instance count                            : 2
Enabled instance count                            : 1
Current static flow count                         : 1
Current dynamic flow count                        : 1
Current technical-standard                        : cmcc
Current trace-measure per-hop                     : be
Current SRv6 TE policy created flow count         : 0
Current SRv6 TE policy created inactive flow count: 0
Global next hop configuration : 1.1.1.1
                                2.2.2.2
# On an SRv6 network, display global iFIT flow information.
Current SRv6 TE policy created flow count         : 1
Global next hop configuration : --
Inherit encap configuration                       : 1:2:: 96
Number of configured iFIT instances.
Number of instances enabled with iFIT.
Number of static target flows.
Number of dynamic target flows.
Technical standards used by iFIT:
·     cmcc—CMCC technical standards.
·     telecom—China Telecom technical standards.
·     unicom—China Unicom technical standards.
‌Enabling status of iFIT measurement when the device acts as a transit node in an SRv6 tunnel:
·     be—iFIT measurement is enabled in SRv6 BE tunnels
·     te—iFIT measurement is enabled SRv6 TE policy tunnels.
·     all—iFIT measurement is enabled both SRv6 BE and SRv6 TE policy tunnels.
·     --—The device does not support iFIT measurement in SRv6 tunnels.
Number of iFIT target flows for the SRv6 TE policy
Number of inactive iFIT target flows for the SRv6 TE policy.
Globally configured next hops.
On an MPLS/SR-MPLS network, you must specify a next-hop globally to determine a peer PE for iFIT encapsulation. The device performs iFIT encapsulation only for service flows sent to the peer PE.
On an SRv6, G-BIER, or G-SRv6 network, this setting is not required and does not take effect even if you configure it.
Configuration of the iFIT header inheriting feature.
This field is displayed when you execute the inherit peer-locator command.
display ifit instance
Use display ifit instance to display iFIT instance information.
display ifit instance [ instance-name ]
instance-name: Specifies an iFIT instance by its name, a case-sensitive string of 1 to 31 characters.
# Display information about iFIT instance 1 (for an iFIT target flow to measure IPv4 service traffic based on the 5-tuple granularity).
<Sysname> display ifit instance 1
Instance name                  : 1
Device ID                      : 1
Flow information:
  Flow type                    : Static
  Protocol                     : TCP
  Source port                  : Any
  DSCP                         : 23
  Period                       : 10 sec
  Measurement configuration    : Disabled
  Measurement status           : Inactive
Flow items:
  Flow ID                     Interface
# Display information about iFIT instance 2 (for an iFIT target flow to measure IPv4 service traffic based on the PeerLocator granularity).
<Sysname> display ifit instance 2
Instance name                  : 2
Device ID                      : 1
Flow information:
  Flow type                    : Static
  Source IP                    : Any
  Destination IP               : Any
  DSCP                         : --
  Period                       : 30 sec
Flow items:
  Flow ID                     Interface
  2                           Ten-GigabitEthernet3/1/1
# Display information about iFIT instance 3 (for an iFIT target flow to measure IPv6 service traffic based on 5-tuple granularity).
<Sysname> display ifit instance 3
Instance name                  : 3
Device ID                      : 1
Flow information:
  Flow type                    : Static
  Source IPv6/prefix length      : 1::1/68
  Destination IPv6/prefix length : 2::2/128
  Protocol                     : UDP
  Source port                  : 8080
  Destination port             : 2308
  DSCP                         : --
  VPN instance name            : vpn3
  Period                       : 30 sec
Flow items:
  Flow ID                     Interface
  11                          Ten-GigabitEthernet3/1/1
  12                          Ten-GigabitEthernet3/1/2
# Display information about iFIT instance 4 (for an iFIT target flow to measure IPv6 service traffic based on the PeerLocator granularity).
<Sysname> display ifit instance 4
Instance name                  : 4
Device ID                      : 1
Flow information:
  Flow type                    : Static
  Source IPv6                  : Any
  DSCP                         : --
  Period                       : 30 sec
Flow items:
  Flow ID                     Interface
# Display information about iFIT instance 1 (for an iFIT target flow to measure service traffic based on the Layer 2 parameter granularity on an EVPN VPLS over MPLS/SR-MPLS network).
Instance name                  : 1
Device ID                      : 1
Flow information:
  Flow type                    : Static
  EtherType                      : 0x0800
  VlanID                         : 200
  Vlan-Priority                  : 5
  VSI name                       : 1
  Peer locator                   : --
  Period                         : 30 sec
Flow items:
  Flow ID                       Interface
Instance Name
iFIT instance name.
Device ID
iFIT device ID.
·     Tunnel.
·     Native-IP.
Flow information
iFIT target flow information.
Flow type
iFIT flow type:
·     Static.
·     Dynamic.
Flow direction
iFIT flow direction.
Source IP address and mask length of the target flow.
Destination IP address and mask length of the target flow.
Source IPv6 address and prefix length of the target flow.
Destination IPv6 address and prefix length of the target flow.
Protocol
Target flow protocol:
·     UDP.
·     TCP.
·     SCTP.
Source port
Source port number of the target flow.
Destination port
Destination port number of the target flow.
DSCP
VPN-instance name
Name of the VPN instance bound to the iFIT flow.
Source MAC
EtherType
VlanID
Vlan-Priority
VSI name
Xconnect-group
Connection
Measurement information.
Period
Measurement period.
Measurement mode
Measurement mode:
·     e2e—End to end measurement.
·     trace—Hop by hop measurement.
Peer locator
Destination locator of the iFIT flow.
Loss measurement
Whether packet loss measurement is enabled:
·     Enabled.
·     Disabled.
Delay measurement
Whether delay measurement is enabled:
·     Enabled.
·     Disabled.
Whether measurement is enabled:
·     Enabled.
·     Disabled.
Measurement status
Flow items
iFIT target flow. Flow information is displayed only when the measure enable command is executed.
Flow ID
iFIT target flow ID. -- indicates that the flow has not been assigned with an ID.
Interface bound to the iFIT target flow.
display ifit statistic
Use display ifit statistic to display statistics about an iFIT dynamic flow for the most recent 10 measurement periods.
display ifit statistic device-id device-id flow-id flow-id [ verbose ]
device-ip device-ip: Specifies an iFIT device by its IP address, which can be any IPv4
flow-id flow-id: Specifies an iFIT dynamic flow by its flow ID. The value range for the flow-id argument is 1 to 1048575.
verbose: Displays detailed statistics about an iFIT dynamic flow. If you do not specify this keyword, this command displays brief statistics about an iFIT flow.
A static flow is a set of flow match criteria that are configured. A dynamic flow is actually a service flow, and the device collects statistics only for dynamic flows. It takes time for the device to learn and generate dynamic flows. Therefore, for the dynamic flows that are newly generated, the accuracy of statistics from the first two measurement periods is not reliable and trustable. As a best practice, do not use the statistics on new dynamic flows in the first two measurement periods.
A flow ID is generated on the ingress node and passed to the transit nodes and egress node. A flow ID and device ID uniquely identify a flow and you can execute the display ifit flow static command to view the flow ID.
# Display brief measurement information about the flow with device ID 1 and flow ID 123.
<Sysname> display ifit statistic device-id 1 flow-id 123
Period ID      Direction         PktCount    Timestamp (sec, nsec)   Interface
159627365      TransitIn         1500         1596273655,349433112   XGE3/1/1
# Display detailed measurement information about the flow with device ID 1 and flow ID 123 when the flow is bound to a Layer 3 physical interface.
<Sysname> display ifit statistic device-id 1 flow-id 123 verbose
Period ID            : 159627365
Period started at    : 2020-08-01 17:20:55
Direction            : TransitInput
Interface            : Ten-GigabitEthernet3/1/1
PktCount             : 844619
ByteCount            : 108111232
Timestamp (sec, nsec): 2020-08-01 17:20:55.349433112 (1619278726, 349433112)
TTL                  : 0
Trust flag           : Trusted
# Display detailed measurement information about the flow with device ID 1 and flow ID 123 when the flow is bound to an aggregate interface.
Interface            : Ten-GigabitEthernet3/1/1(Route-Aggregation1)
PktCount             : 844619
TTL                  : 0
Table 5 Command output
PeriodID
Measurement period number.
Period started at
Start time of the measurement period.
Direction
Flow direction of the interface:
·     TransitIn—The target flow enters the node from this interface. You can view this value only in the simplified iFIT flow statistics.
·     TransitInput—The target flow enters the node from this interface. You can view this value only in the detailed iFIT flow statistics.
·     TransitOut—The target flow leaves the node from this interface. You can view this value only in the simplified iFIT flow statistics.
·     TransitOutput—The target flow leaves the node from this interface. You can view this value only in the detailed iFIT flow statistics.
Physical interface name. If this interface is a member interface of an aggregate interface, this field displays in the format of physical interface name (name of the aggregate interface to which the physical interface belongs).
PktCount
Number of packets measured in the period.
ByteCount
Number of bytes detected in the period.
Timestamp value for the delay measurement. In the detailed information, this field is displayed in the YY-MM-DD HH:MM:SS.nanosecond format.
TTL
TTL value of the packet.
Trust flag
Whether statistics reported in this period can be trusted:
·     Trusted.
·     Untrusted—The statistics are not trustable. For the dynamic flows that are newly generated, the accuracy of statistics from the first two measurement periods is not reliable and trustable. As a best practice, do not use the statistics on new dynamic flows in the first two measurement periods.
dynamic-flow aging-time
Use dynamic-flow aging-time to specify the aging parameters for dynamic flows.
Use undo dynamic-flow aging-time to restore the default.
dynamic-flow aging-time multi-value [ threshold-percent threshold-percent ]
The aging time for dynamic flows is 10 times the measurement period and it cannot be less than 5 minutes.
iFIT view
multi-value: Specifies a multiplier value. The aging time for dynamic flows is equal to the measurement period multiplied by the multiplier value. The value range is 2 to 100.
threshold-percent threshold-percent: Specifies an aging threshold in percentage, in the range of 0 to 100. The default value for the threshold-percent argument is 30.
The device sets an aging timer for a dynamic flow upon the generation of the dynamic flow. The aging timer is reset each time the device receives a packet of the dynamic flow. If no packets of the dynamic flow are received before the aging timer expires, the device considers the dynamic flow to be inactive.
Meanwhile, the device also counts the number of the existing dynamic flows at intervals. If the number of the existing dynamic flows exceeds the aging threshold (maximum number of dynamic flows supported × aging threshold in percentage), the device ages out inactive dynamic flows. That is, the device will remove inactive dynamic flows to prevent system resources from being occupied by inactive flows.
The aging time for dynamic flows must be equal to or greater than 5 minutes. If the configured aging time is less than 5 minutes, the actual aging time will be 5 minutes.
# Configure the aging time for dynamic flows to be 20 times the measurement period.
[Sysname-ifit] dynamic-flow aging-time 20
encapsulation
Use encapsulation to specify a next hop for iFIT encapsulation.
Use undo encapsulation to delete iFIT encapsulation configuration for a next hop.
encapsulation { nexthop ip-address | nexthop-ipv6 ipv6-address }
undo encapsulation [ nexthop ip-address | nexthop-ipv6 ipv6-address ]
No next hop is specified for iFIT encapsulation.
iFIT view
nexthop ip-address: Specifies the IPv4 address of the peer PE in the MPLS or SR-MPLS network.
nexthop-ipv6 ip-address: This option has been replaced by other configuration methods. For compatibility with history versions, you can specify this option, but it does not take effect.
On an MPLS or SR-MPLS network, you must execute this command to specify a peer PE as the next hop for iFIT encapsulation after you execute the flow command. The device performs iFIT encapsulation only for service flows sent to the specified peer PE. For matched packets, the device will add iFIT headers to the packets, count the number of matched packets, attach timestamps to the packets, and report the iFIT data to the analyzer.
On an SRv6, G-BIER, or G-SRv6 network, iFIT encapsulation takes effect on all next hops, and the configuration by this command does not take effect.
# Encapsulate the packets send to 1.1.0.1.
[Sysname-ifit] encapsulation nexthop 1.1.0.1
flow
flow
Use flow to specify a static flow to be monitored by an iFIT instance.
Use undo flow to remove the static flow settings.
·     On a Native-IP network, iFIT measurement based on 5-tuple granularity:
¡     IPv4:
flow unidirection source-ip { src-ip-address [ src-mask-length ] | any } destination-ip { dest-ip-address [ dest-mask-length ] | any } [ protocol { { sctp | tcp | udp } [ source-port src-port-number ] [ destination-port dest-port-number ] | protocol-number } ] [ dscp dscp-value ] vpn-instance vpn-instance-name
undo flow
¡     IPv6:
flow unidirection source-ipv6 { src-ipv6-address [ src-prefix-length ] | any } destination-ipv6 { dest-ipv6-address [ dest-prefix-length ] | any } [ protocol { { sctp | tcp | udp } [ source-port src-port-number ] [ destination-port dest-port-number ] | protocol-number } ] [ dscp dscp-value ] vpn-instance vpn-instance-name
undo flow
·     On an MPLS/SR-MPLS public network, iFIT measurement based on 5-tuple granularity:
¡     IPv4:
undo flow
¡     IPv6:
IPv6 service flows are not supported in the current software version.
·     On an MPLS/SR-MPLS private network, iFIT measurement based on 5-tuple granularity:
¡     IPv4:
undo flow
¡     IPv6:
undo flow
·     On an EVPN VPLS over MPLS/SR-MPLS network:
¡     iFIT measurement based on Layer 2 parameter granularity:
flow unidirection { destination-mac dest-mac-address | eth-type eth-type-id | priority-8021p priority-value | source-mac src-mac-address | vlan vlan-id } * vsi vsi-name
undo flow
¡     iFIT measurement based on 5-tuple granularity:
-     IPv4:
flow unidirection source-ip { src-ip-address [ src-mask-length ] | any } destination-ip { dest-ip-address [ dest-mask-length ] | any } [ protocol { { sctp | tcp | udp } [ source-port src-port-number ] [ destination-port dest-port-number ] | protocol-number } ] [ dscp dscp-value ] vsi vsi-name
undo flow
-     IPv6:
flow unidirection source-ipv6 { src-ipv6-address [ src-prefix-length ] | any } destination-ipv6 { dest-ipv6-address [ dest-prefix-length ] | any } [ protocol { { sctp | tcp | udp } [ source-port src-port-number ] [ destination-port dest-port-number ] | protocol-number } ] [ dscp dscp-value ] vsi vsi-name
undo flow
·     On an EVPN VPWS over MPLS/SR-MPLS network:
flow unidirection { destination-mac dest-mac-address | eth-type eth-type-id | priority-8021p priority-value | source-mac src-mac-address | vlan vlan-id } * xconnect-group group-name connection connection-name
undo flow
-     IPv4:
flow unidirection source-ip { src-ip-address [ src-mask-length ] | any } destination-ip { dest-ip-address [ dest-mask-length ] | any } [ protocol { { sctp | tcp | udp } [ source-port src-port-number ] [ destination-port dest-port-number ] | protocol-number } ] [ dscp dscp-value ] xconnect-group group-name connection connection-name
undo flow
-     IPv6:
flow unidirection source-ipv6 { src-ipv6-address [ src-prefix-length ] | any } destination-ipv6 { dest-ipv6-address [ dest-prefix-length ] | any } [ protocol { { sctp | tcp | udp } [ source-port src-port-number ] [ destination-port dest-port-number ] | protocol-number } ] [ dscp dscp-value ] xconnect-group group-name connection connection-name
undo flow
·     On an IPv4 over SRv6/G-SRv6 network:
-     IPv4:
undo flow
-     IPv6:
undo flow
¡     iFIT measurement based on PeerLocator granularity:
-     IPv4:
flow unidirection [ source-ip any destination-ip any ] peer-locator ipv6-address prefix-length
undo flow
-     IPv6:
flow unidirection [ source-ipv6 any destination-ipv6 any ] peer-locator ipv6-address prefix-length
undo flow
·     On an L3VPN/EVPN L3VPN over SRv6/G-SRv6 network:
-     IPv4:
undo flow
-     IPv6:
undo flow
-     IPv4:
flow unidirection [ source-ip any destination-ip any ] [ vpn-instance vpn-instance-name ] peer-locator ipv6-address prefix-length
undo flow
-     IPv6:
flow unidirection [ source-ipv6 any destination-ipv6 any ] [ vpn-instance vpn-instance-name ] peer-locator ipv6-address prefix-length
undo flow
·     On an EVPN VPLS over SRv6/G-SRv6 network:
undo flow
-     IPv4:
undo flow
-     IPv6:
undo flow
flow unidirection vsi vsi-name peer-locator ipv6-address prefix-length
undo flow
·     On an EVPN VPWS over SRv6/G-SRv6 network:
undo flow
-     IPv4:
undo flow
-     IPv6:
undo flow
flow unidirection xconnect-group group-name connection connection-name peer-locator ipv6-address prefix-length
undo flow
·     On a G-BIER network:
¡     IPv4:
undo flow
¡     IPv6:
flow unidirection source-ipv6 { src-ipv6-address [ src-prefix-length ] | any } destination-ipv6 { dest-ipv6-address [ dest-prefix-length ] | any } [ protocol { { sctp | tcp | udp } [ source-port src-port-number ] [ destination-port dest-port-number ] | protocol-number } ] [ dscp dscp-value ] [ vpn-instance vpn-instance-name ]
undo flow
No static flow is configured for an iFIT instance.
iFIT instance view
unidirection: Specifies the unidirectional flows.
source-ip src-ip-address: Specifies a source IPv4 address of the flow, in dotted decimal format.
src-mask-length: Specifies a mask length for the source IPv4 address. The value range is 1 to 32. If you do not specify this argument, the exact match of the source IPv4 address is used.
destination-ip dest-ip-address: Specifies a destination IPv4 address of the flow, in dotted decimal format.
dest-mask-length: Specifies a mask length for the destination IPv4 address. The value range is 1 to 32. If you do not specify this argument, the exact match of the source IPv4 address is used.
source-ipv6 src-ipv6-address: Specifies a source IPv6 address of the flow.
src-prefix-length: Specifies a prefix length for the source IPv6 address. The value range is 1 to 128. If you do not specify this argument, the exact match of the source IPv6 address is used.
destination-ipv6 dest-ipv6-address: Specifies a destination IPv6 address of the flow.
dest-prefix-length: Specifies a prefix length for the destination IPv6 address. The value range is 1 to 128. If you do not specify this argument, the exact match of the destination IPv6 address is used.
protocol: Specifies a protocol type of the flow. If you do not specify this keyword, the flow can use any protocol.
·     { sctp | tcp | udp }: Specifies the SCTP, TCP, or UDP protocol.
·     destination-port dest-port-number: Specifies a destination port number. The value range is 0 to 65535. If you do not specify this option, the flow can use any port number as the destination port number.
·     source-port src-port-number: Specifies a source port number. The value range is 0 to 65535. If you do not specify this option, the flow can use any port number as the source port number.
·     protocol-number: Specifies the number of the protocol type. The value range is 0 to 255, excluding 132 (SCTP protocol number), 6 (TCP protocol number), and 17 (UDP protocol number).
dscp dscp-value: Specifies a DSCP value of the flow, in the range of 0 to 63.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To specify a flow on the public network, do not specify this option.
destination-mac dest-mac-address: Specifies the destination MAC address of the flow, in the format of H-H-H. The MAC address cannot be all zeros, all Fs, or multicast MAC addresses.
eth-type eth-type-id: Specifies the EthType field value of packets for the flow, a case-insensitive four-digit hexadecimal number in the range of 0x1 to 0xffff.
priority-8021p priority-value: Specifies the VLAN priority of the flow, in the range of 0 to 7.
source-mac src-mac-address: Specifies the source MAC address of the flow, in the format of H-H-H. The MAC address cannot be all zeros, all Fs, or multicast MAC addresses.
vlan vlan-id: Specifies the VLAN priority of the flow, in the range of 1 to 4094.
vsi vsi-name: Specifies the VSI to which the static flow belongs. The VSI name is a case-sensitive string of 1 to 31 characters. For more information about VSIs, see EVPN VPLS over SRv6 configuration in Segment Routing Configuration Guide.
xconnect-group group-name: Specifies the cross-connect group to which the static flow belongs. The group name is a case-sensitive string of 1 to 31 characters that cannot contain hyphens (-). For more information about cross-connect groups, see EVPN VPWS over SRv6 configuration in Segment Routing Configuration Guide.
connection connection-name: Specifies the cross-connect to which the static flow belongs. The cross-connect name is a case-sensitive string of 1 to 20 characters that cannot contain hyphens (-). For more information about cross-connects, see EVPN VPWS over SRv6 configuration in Segment Routing Configuration Guide.
source-ip any: Specifies any source IPv4 address.
destination-ip any: Specifies any destination IPv4 address.
source-ipv6 any: Specifies any source IPv6 address.
destination-ipv6 any: Specifies any destination IPv6 address.
nexthop ip-address: This option has been replaced by other configuration methods. For compatibility with history versions, you can specify this option after you specify source-ip any, destination-ip any, and a VPN instance, but it does not take effect.
nexthop-ipv6 ip-address: This option has been replaced by other configuration methods. For compatibility with history versions, you can specify this option after you specify source-ipv6 any, destination-ipv6 any, and a VPN instance, but it does not take effect.
peer-locator ipv6-address prefix-length: Specifies the locator to which the flow belongs. The ipv6-address argument represents the IPv6 address prefix. The prefix-length argument represents the prefix length, in the range of 32 to 120. The IPv6 address prefix cannot be an IPv4-compatible IPv6 address.
Static flows are key elements for iFIT measurement. Before starting an iFIT measurement, you must execute this command to specify a flow to be measured on the ingress node. You do not need to specify a flow on the transit nodes and egress node because the device can automatically learn the target flow through the iFIT header of the packets.
The device can perform iFIT measurement based on the following granularities in different scenarios:
·     Layer 2 parameter granularity—Used for measuring communication quality of a service flow within an L2VPN tunnel. You can match the service flow by using Layer 2 parameters such as source MAC Ethernet packet type, VLAN priority, and VLAN ID. This measurement granularity is supported on an EVPN VPLS over MPLS/SR-MPLS, EVPN VPWS over MPLS/SR-MPLS, EVPN VPLS over SRv6/G-SRv6, or EVPN VPWS over SRv6/G-SRv6 network.
·     5-tuple granularity—Used for measuring communication quality of the specified service flow. You can use 5-tuple to match service flows or perform iFIT measurement on any service traffic on a network. This granularity is available for all networks supported by iFIT.
·     PeerLocator granularity—Used for measuring end-to-end communication quality on the entire network. On an IPv6 network, the peer-locator keyword can specify a tunnel. The device performs iFIT measurement on any service flows through the tunnel. This granularity is available only for SRv6 and G-SRv6 networks.
An iFIT instance can be configured with only one static flow. If you execute this command multiple times for the same iFIT instance, the most recent configuration takes effect.
For the flows to be monitored by different instances, the flow attributes must not be identical.
The source and destination IP addresses must be legal unicast IP addresses on a non-G-BIER network. On a G-BIER network, the destination IP address can be a legal unicast or multicast address.
To ensure iFIT measurement accuracy on a VPLS network, you can deploy only unicast forwarding services in the network. If multicast or broadcast services are present on the network, traffic from these services might lead to inaccurate iFIT measurement results.
On an MPLS or SR-MPLS network, you must execute the encapsulation command to specify a peer PE for iFIT encapsulation after you execute the flow command. The device performs iFIT encapsulation only for service flows sent to the specified peer PE. For matched packets, the device will add iFIT headers to the packets, count the number of matched packets, attach timestamps to the packets, and report the iFIT data to the analyzer.
On an SRv6, G-BIER, or G-SRv6 network, iFIT encapsulation takes effect on all next hops, and the configuration by the encapsulation command does not take effect.
# On an MPLS or SR-MPLS private network, configure instance abc to monitor IPv4 service flows based on 5-tuple granularity of unidirectional flow, source IP 1.1.1.1/24, destination IP 2.2.2.2/24, and VPN instance vpn1.
[Sysname-ifit-instance-abc] flow unidirection source-ip 1.1.1.1 24 destination-ip 2.2.2.2 24 vpn-instance vpn1
# On an MPLS or SR-MPLS private network, configure instance abc to monitor IPv4 service flows based on 5-tuple granularity of unidirectional flow, any source IP, destination IP 2.2.2.2/24, and VPN instance vpn1.
[Sysname-ifit-instance-abc] flow unidirection source-ip any destination-ip 2.2.2.2 24
# On an EVPN VPLS over SRv6/G-SRv6 network, configure instance 1 to perform iFIT measurement on a service flow with MAC address 1-1-1 and EthType field value 0x0800.
[Sysname-ifit] instance 1
[Sysname-ifit-instance-1] flow  unidirection source-mac 1-1-1 eth-type 0800 vsi 1
# On an EVPN VPLS over SRv6/G-SRv6 network, configure instance 1 to perform iFIT measurement on a service flow with VLAN ID 1 and VLAN priority 7.
[Sysname-ifit-instance-1] flow  unidirection vlan 1 priority-8021p 7 vsi 1
# On an EVPN VPLS over SRv6 or G-SRv6 network, configure instance abc to monitor IPv4 service flows based on 5-tuple granularity of unidirectional flow, any source IP, any destination IP, and VSI 1.
[Sysname-ifit-instance-abc] flow unidirection source-ip any destination-ip any vsi 1
# On an EVPN VPLS over SRv6 or G-SRv6 network, configure instance abc to monitor IPv4 service flows based on 5-tuple granularity of unidirectional flow, source IP 1.1.1.1/24, destination IP 2.2.2.2/24, and VSI 1.
# On an EVPN VPWS over SRv6 or G-SRv6 network, configure instance abc to monitor IPv4 service flows based on 5-tuple granularity of unidirectional flow, source IP 1.1.1.1/24, destination IP 2.2.2.2/24, cross-connect group 1, and cross-connect 2.
[Sysname-ifit-instance-abc] flow unidirection source-ip 1.1.1.1 24 destination-ip 2.2.2.2 24 xconnect-group 1 connection 2
# On an EVPN VPLS over SRv6 or G-SRv6 network, configure instance abc to monitor service flows based on PeerLocator granularity of unidirectional flow, VSI 1, and PeerLocator 2001::1.
[Sysname-ifit-instance-abc] flow unidirection vsi 1 peer-locator 2001::1 64
# On an EVPN VPWS over SRv6 or G-SRv6 network, configure instance abc to monitor service flows based on PeerLocator granularity of unidirectional flow, cross-connect group 1, cross-connect 2, and PeerLocator 2001::1.
[Sysname-ifit-instance-abc] flow unidirection xconnect-group 1 connection 2 peer-locator 2001::1 64
# On an L3VPN/EVPN L3VPN over SRv6 or G-SRv6 network, configure instance abc to monitor service flows based on PeerLocator granularity of unidirectional flow and PeerLocator 2001::1.
[Sysname-ifit-instance-abc] flow unidirection source-ip any destination-ip any peer-locator 2001::1 64
# On an L3VPN/EVPN L3VPN over SRv6 or G-SRv6 network, configure instance abc to monitor IPv6 service flows based on PeerLocator granularity of unidirectional flow and PeerLocator 2001::1.
[Sysname-ifit-instance-abc] flow unidirection source-ipv6 any destination-ipv6 any peer-locator 2001::1 64
encapsulation
ifit enable
Use ifit enable to enable the iFIT functionality globally and enter its view, or enter the existing iFIT view.
Use undo ifit enable to disable the iFIT functionality globally.
ifit enable
undo ifit enable
The iFIT functionality is disabled.
To measure the packet loss and packet delay of the network in real time, you can enable iFIT measurement.
To start iFIT measurement, perform the following tasks:
·     On the ingress node, enable the iFIT functionality, configure iFIT device ID, create an instance, and configure a flow to be monitored by the instance. The configured flow is a static flow. The ingress node automatically uses the device ID to generates a flow ID, and encapsulates the flow ID and local iFIT device ID in the iFIT header of packets transmitted to the transit nodes and egress node. The flow ID uniquely identifies a flow.
·     On the transit nodes and egress node, enable the iFIT functionality. If the received packet carries an iFIT header, a transit node or the egress node will perform iFIT measurement according to the flow ID, measurement period number, timestamp in the iFIT header.
# Enable iFIT and enter its view.
[Sysname-ifit]
Use inherit peer-locator to enable iFIT header inheriting.
Use undo inherit peer-locator to disable iFIT header inheriting.
inherit peer-locator prefix prefix-length
iFIT header inheriting is disabled.
iFIT view
prefix prefix-length: Specifies the next-hop locator. The device can inherit the IFIT header into packets destined for the specified next-hop locator. The prefix argument represents the IPv6 address prefix. The prefix-length argument represents the prefix length, in the range of 32 to 120. The IPv6 address prefix cannot be an IPv4-compatible IPv6 address.
Application scenarios
As shown in Figure 1, in an SRv6 HoVPN scenario, there's an SRv6 network between the UPE and the MPE and another between the MPE and the SPE. This feature measures the performance across the entire UPE-to-SPE link.
Figure 1 SRv6 HoVPN networking scenario
Operating mechanism
To monitor the entire link performance between the UPE and the SPE, execute this command on the MPE and specify the next-hop locator. When the MPE receives a packet from the UPE, and the next-hop locator is the specified SPE, MPE inherits the iFIT header in the received packet into the SRv6 packet sent to the SPE. This retains the iFIT header information during traffic transmission on a PE hierarchical network for measuring link performance of the entire PE hierarchical network.
If you do not execute this command, when the traffic passes through the MPE, the original iFIT header is removed and a new iFIT header is added based on the egress interface that belongs to another SRv6 network.
# Enable iFIT header inheriting for the packets destined for the next-hop locator of 6:5::  96.
[Sysname-ifit] inherit peer-locator 6:5:: 96
instance
Use instance to create an iFIT instance and enter its view, or enter the view of an existing iFIT instance.
Use undo instance to delete an iFIT instance.
instance instance-name
undo instance instance-name
No iFIT instance exists.
iFIT view
instance-name: Specifies an iFIT instance by its name. The instance name is a case-sensitive string of 1 to 31 characters.
You must configure an iFIT instance on the ingress node. You can configure only one set of flow match criteria for an instance. An instance can be bound to multiple interfaces. Each bound interface matches target flows based on the same set of criteria and assigns different flow IDs to the target flows. iFIT measures the delay and packet loss of the target flows on a per-interface basis.
To perform iFIT measurement on the transit nodes and egress node, enable iFIT. After you enable iFIT on a transit node or the egress node, the point automatically identifies the flows according to the iFIT header, and perform iFIT measurement on the target flows. The flows identified automatically are dynamic flows.
# Create iFIT instance abc and enter its view.
[Sysname-ifit-abc]
measure enable
Use measure enable to enable iFIT measurement for an iFIT instance.
Use undo measure enable to disable iFIT measurement for an iFIT instance.
measure enable
undo measure enable
iFIT measurement for an iFIT instance is disabled.
iFIT instance view
You can execute this command to start iFIT measurement for an iFIT instance to monitor the packet delay and packet loss of the flow.
Before starting iFIT measurement, configure a device ID, create an iFIT instance, and configure a flow.
To modify the configuration for the device-id command or an iFIT enabled instance, disable iFIT measurement for the instance firstly.
# Enable iFIT measurement  for iFIT instance abc.
[Sysname-ifit-instance-abc] measure enable
measure mode
Use measure mode to specify an iFIT measurement mode.
Use undo measure mode to restore the default.
measure mode { e2e | trace }
undo measure mode
End-to-end measurement is used.
iFIT instance view
e2e: Specifies end-to-end measurement. In this mode, only the ingress node and egress node report the measurement data.
trace: Specifies hop-by-hop measurement. In this mode, all points that are enabled with iFIT and receive the flow packets will report the measurement data.
iFIT measurement helps you to measure the network performance, troubleshoot the network faults, and measure the service quality.
To measure the packet loss and packet delay of the whole network, you can use end-to-end measurement. To accurately locate the packet loss and packet delay of each network node, you can use the hop-by-hop measurement.
# Specify hop-by-hop measurement as the measurement mode.
[Sysname-ifit-instance-abc] measure mode trace
period
Use period to specify the measurement period for an iFIT instance.
Use undo period to restore the default.
period period
undo period
The measurement period for an iFIT instance is 30 seconds.
iFIT instance view
period: Specifies the measurement period in seconds. Valid values include 1, 10, 30, 60, and 300.
iFIT collects performance statistics based on the measurement period.
·     The sender records the sending time of the first iFIT packet in each sending interval, and counts the number of the iFIT packets sent from an interface in each sending interval. Sending interval = iFIT measurement period.
·     The receiver records the receiving time of the first iFIT packet in each receiving interval, and counts the number of the iFIT packets received by an interface in each receiving interval. To reduce the impact of network delay and disorder on statistics, the receiving interval equals to (1+1/3) measurement period.
If network delay between the ingress and egress nodes is greater than 1/3 measurement period, the accuracy of iFIT packet loss statistics might be affected. This is because iFIT considers packets received beyond the receiving interval as packet loss. For example, if the measurement period is 1 second and the network delay greater than 1/3 seconds (333 milliseconds), the accuracy of iFIT packet loss statistics might be affected. In this case, set the measurement period to a greater value.
# Specify 60 seconds as the measurement period for an iFIT instance.
[Sysname-ifit-instance-abc] period 60
reset ifit statistic
Use reset ifit statistic to clear iFIT statistics of dynamic flows for the most recent 10 measurement periods.
reset ifit statistic [ device-id device-id flow-id flow-id | instance instance-name ]
device-id device-id: Specifies an iFIT device by its ID in the range of 1 to 1048575. In a Tunnel transit network (such as an MPLS or SRv6 private network), a flow ID and a device ID uniquely identify an iFIT flow.
flow-id flow-id: Clears statistics about an iFIT flow by its flow ID. The value range for the flow-id argument is 1 to 1048575.
instance instance-name: Clears statistics about an iFIT flow by its instance name. The instance name is a case-sensitive string of 1 to 31 characters. Only the ingress node supports instances. The transit nodes and egress node do not support instances.
# Clear iFIT statistics generated in the most recent 10 measurement periods for the flow with device ID 1 and flow ID 40962.
<Sysname> reset ifit statistic device-id 1 flow-id 40962
technical-standard
Use technical-standard to specify the standards used by iFIT.
Use undo technical-standard to restore the default.
technical-standard { cmcc | telecom | unicom }
iFIT uses CMCC technical standards.
iFIT view
cmcc: Specifies the CMCC standards.
telecom: Specifies the China Telecom standards.
unicom: Specifies the China Unicom standards.
The implementation of iFIT adheres to the technical standards of China Telecom, China Mobile, and China Unicom, which have some slight differences, for example, in encapsulation requirements for iFIT headers in IPv6 packets. Choose one set of standards as needed.
Devices included in iFIT measurement on the same SRv6 link must be configured with the same technical standards. If you fail to do so, iFIT packet parsing might fail, leading to inaccurate iFIT measurement results.
# Configure iFIT to use CMCC standards.
[Sysname-ifit] technical-standard cmcc
Use trace-measure per-hop to enable iFIT measurement on transit nodes in SRv6 tunnels.
Use undo trace-measure per-hop to disable iFIT measurement on transit nodes in SRv6 tunnels.
trace-measure per-hop [ be | te ]
iFIT measurement on transit nodes in SRv6 tunnels are disabled.
iFIT view
be: Enables iFIT measurement on transit nodes in SRv6 BE tunnels. If you do not specify the be or te keyword, this command applies to both SRv6 BE tunnels and SRv6 TE policy tunnels.
te: Enables iFIT measurement on transit nodes in SRv6 TE policy tunnels. If you do not specify the be or te keyword, this command applies to both SRv6 BE tunnels and SRv6 TE policy tunnels.
When a device uses CMCC technical standards and acts as a transit node in an SRv6 link, you can execute this command on the device to enable iFIT measurement.
Operating mechanism
An SR node is a node that supports the SRv6 feature. The following SR nodes are available:
·     Source node—Responsible for inserting an SRH into the IPv6 header of IPv6 packets, or encapsulating an outer IPv6 header into IPv6 packets and inserting an SRH into the outer IPv6 header.
·     Transit node—Forwards IPv6 packets along the SRv6 path. A transit node does not participate in SRv6 processing. It can be an SRv6-aware or SRv6-unaware node.
·     Endpoint node—Performs an SRv6 function for received SRv6 packets. The IPv6 destination address of the received SRv6 packets must be an SRv6 SID configured on the endpoint node. The endpoint node processes the packets based on the SRv6 SID and updates the SRH.
By configuring iFIT hop-by-hop measurement at the source node and enabling iFIT measurements at the endpoint node, To implement iFIT measurement in hop-by-hop mode on the SRv6 network, enable iFIT measurement in hop-by-hop mode on the source node and enable iFIT measurement on the endpoint node. By default, iFIT measurement is not performed on transit nodes. iFIT measurement on transit nodes is enabled by using this command, the transit nodes will parse iFIT headers for iFIT measurement.
·     If you execute this command multiple times, the most recent configuration takes effect.
·     On an SRv6 TE policy network where iFIT uses China Telecom standards in hop-by-hop measurement mode, this command does not take effect on transit nodes and iFIT measurement is not performed on these nodes. This is because China Telecom standards require transit nodes on an SRv6 TE policy network not to perform iFIT measurement.
·     On an SRv6 TE policy network, the subsequent transit nodes might not have the SRH due to special settings such as PSP. In this case, for the subsequent transit nodes to forcedly parse iFIT headers for iFIT measurement, execute trace-measure per-hop be on these transit nodes instead of trace-measure per-hop te.
# Enable iFIT measurement on transit nodes in SRv6 BE tunnels.
[Sysname-ifit] trace-measure per-hop be
technical-standard
transmit-network type
Use transmit-network type to specify the transit network type for iFIT measurement.
Use undo transmit-network type to restore the default.
transmit-network type { tunnel | native-ip }
The transit network type for iFIT measurement is Tunnel.
iFIT instance view
tunnel: Specifies the Tunnel network type. This transit network type supports only iFIT measurement on an MPLS, SR-MPLS, SRv6, G-SRv6, or G-BIER network.
native-ip: Specifies the Native-IP network type. This transit network type supports only iFIT measurement on public network.
To measure the transmission quality of an iFIT flow on a transit network, the administrator must perform the following operations:
·     Specify the device where the iFIT flow enters the transit network as the ingress node.
·     Specify the device where the iFIT flow leaves the transit network as the egress node.
The ingress node adds an iFIT header to the target flow. The encapsulation format of an iFIT header varies by transit network type.
Execute this command depends on the transit network type of the target flow as follows:
·     If the transit network is an MPLS, SR-MPLS, SRv6, G-SRv6, or G-BIER network, specify the iFIT network type for iFIT measurement as Tunnel.
·     If the transit network is the public network, specify the iFIT network type for iFIT measurement as Native-IP.
# Specify Native-IP as the type of the transit network for iFIT measurement.
[Sysname-ifit-instance-abc] transmit-network type native-ip
iFIT commands for tunnel-level measurement
Use display ifit global-information to display global information of iFIT target flows.
# Display global information of iFIT target flows on an MPLS network.
                                2.2.2.2
# Display global information of iFIT target flows on an SRv6 network.
Table 6 Command output
Number of iFIT instances.
Number of iFIT static target flows.
Number of iFIT dynamic target flows.
‌Technical standards used by iFIT:
Number of the iFIT target flows for the SRv6 TE policy
Global next hop.
·     On an MPLS/SR-MPLS network, you must configure the global next hop to specify the peer PE that supports iFIT. The device will perform iFIT only for the traffic flows sent to that peer PE.
·     On an SRv6, G-BIER, or G-SRv6 network, this setting is not required and does not take effect even if you configure it.
display ifit srv6-segment-list
Use display ifit srv6-segment-list to display information about the iFIT target flow for the SRv6 TE policy.
display ifit srv6-segment-list [ segment-list-id ]
segment-list-id: Specifies a segment list by its ID in the range of 1 to 4294967295. This value is automatically assigned to an SRv6 path by the SRv6 TE policy. If you do not specify a segment list, this command displays iFIT target flows for all SRv6 TE policies.
# Display information about the iFIT target flows for SRv6 TE policies.
<Sysname> display ifit srv6-segment-list
Device ID                             : 1
Flow ID                               : 2866
  Period                              : 30(s)
Segment list information:
  Global segment list ID              : 2
  Segment list ID                     : 0
  Color                               : 4
  EndPoint                            : 2001:DB8:3::3
Device ID                             : 1
Flow ID                               : 2867
  Period                              : 30(s)
  Segment list ID                     : 0
  Color                               : 4
Device ID                             : 1
Flow ID                               : 2868
  Period                              : 30(s)
  Segment list ID                     : 0
  Color                               : 4
Table 7 Command output
Device ID
iFIT device ID.
Flow ID
iFIT flow ID.
Flow direction
iFIT flow direction. The value is Unidirection.
Information about the measurement parameters.
Loss measurement
Whether packet loss is measured.
·     Enabled.
·     Disabled.
Delay Measurement
Whether delay is measured.
·     Enabled.
·     Disabled.
Measurement Mode
Measurement Mode:
·     e2e: End-to-end measurement.
·     Trace: Hop-by-hop measurement.
Period
Measurement interval, in seconds.
SRv6 segment list information
Segment List ID referenced by the candidate path of the global SRv6 TE policy.
Segment list ID
ID of the segment list for the SRv6 TE policy candidate path.
Color
Color value of the SRv6 TE policy.
EndPoint
Destination address of the SRv6 TE policy.
work-mode analyzer
display ifit statistic-type
Use display ifit statistic-type to display the iFIT measurement result from iFIT Analyzer.
display ifit statistic-type { one-way-delay | one-way-loss } { srv6-segment-list segment-list-id | device-id device-id  flow-id flow-id }
one-way-delay: Displays the iFIT one-way delay measurement result.
one-way-loss: Displays the iFIT one-way packet loss measurement result.
srv6-segment-list segment-list-id: Specifies an SRv6 path by its segment list ID in the range of 1 to 4294967295. The value is automatically assigned to the SRv6 path by the SRv6 TE policy.
device-id device-id flow-id flow-id: Specifies the target flow. The device-id argument represents the iFIT device ID in the range of 1 to 1048575. The flow-id argument represents the target slow in the range of 1 to 1048575.
The command displays the iFIT measurement result for the SRv6 TE policy from iFIT Analyzer in the SRv6 TE policy and iFIT collaboration scenario.
This command is not available for static iFIT flows configured by using the flow command and dynamically learned iFIT flows.
# Display the one-way packet loss information for the iFIT target flow with device ID 1 and flow ID 123.
<Sysname> display ifit statistic-type one-way-loss device-id 1 flow-id 123
One-way-loss statistics:
Period ID      Loss          Loss Ratio              Trust flag (Error code)
1              0             0                       Untrusted (1)
2              0             0                       Untrusted (1)
3              0             0                       Trusted (0)
4              0             0                       Trusted (0)
5              0             0                       Trusted (0)
6              0             0                       Trusted (0)
7              0             0                       Trusted (0)
8              0             0                       Trusted (0)
9              0             0                       Trusted (0)
10             0             0                       Trusted (0)
# Display the one-way delay information for the iFIT target flow with device ID 1 and flow ID 123.
<Sysname> display ifit statistic-type one-way-delay device-id 1 flow-id 123
One-way-delay statistics:
Period ID      Delay(ns)                  Jitter(ns)              Trust flag (Error code)
1              0                          0                      Untrusted (1)
2              0                          0                      Untrusted (1)
3              0                          0                      Trusted (0)
4              0                          0                      Trusted (0)
5              0                          0                      Trusted (0)
6              0                          0                      Trusted (0)
7              0                          0                      Trusted (0)
8              0                          0                      Trusted (0)
9              0                          0                      Trusted (0)
10             0                          0                      Trusted (0)
Table 8 Command output
One-way packet loss statistics.
One-way delay statistics.
Period ID
Measurement cycle ID.
Loss
Dropped packet count
Loss Ratio
Packet loss rate, with accuracy to one part per million.
Delay(ns)
End-to-end delay from the ingress node to the egress node on the SRv6 path, in nanoseconds.
Jitter(ns)
End-to-end jitter from the ingress node to the egress node on the SRv6 path, in nanoseconds.
Whether the data reported in this cycle can be trusted.
·     Trusted: The data can be trusted.
·     Untrusted: The data cannot be trusted. The accuracy of the measurement data for the new target flow generated in the first and second cycles cannot be guaranteed and is considered untrustworthy. As a best practice, configure the controller to not use the data generated in the first and second measurement cycles for the new target flow.
The values of the error code are 0 and 1.
·     0: Indicates that the data can be trusted.
·     1: Indicates that the data cannot be trusted.
work-mode analyzer
service-type srv6-segment-list
Use service-type srv6-segment-list to configure iFIT Collector to collect and report only the iFIT measurement results for SRv6 paths, and to enable iFIT instances from iFIT Analyzer.
undo service-type to restore the default.
undo service-type
iFIT Collector does not collect or report the iFIT measurement results for SRv6 paths, and the service iFIT instances cannot be enabled from iFIT Analyzer.
iFIT Collector view or iFIT Analyzer view
In the SRv6 TE policy and iFIT collaboration scenario, perform the following operations:
·     Execute this command on the egress node for iFIT Collector to only collect and report the iFIT measurement results for SRv6 paths.
·     Execute this command on the ingress node to enable the service iFIT instances issued from the SRv6 TE policy module.
Operating mechanism
In the SRv6 TE policy and iFIT collaboration scenario, iFIT is used to measure the end-to-end latency from the ingress node to the egress node on the SRv6 TE policy path. The measurement result will be used to guide SRv6 TE policy routing on the ingress node. An iFIT flow is created on the ingress node, and the egress node performs iFIT measurement only on packets carrying the iFIT header. The egress node can perform iFIT measurements for multiple service flows simultaneously. If you configure this command on the egress node, the egress node will only collect and report the iFIT measurement result for the SRv6 paths. If you configure this command on the ingress node, it will enable the service iFIT instances issued from the SRv6 TE policy module.
# Specify the SRv6 TE policy service for iFIT measurement.
[Sysname] ifit
[Sysname-ifit] work-mode collector
[Sysname-ifit-collector] service-type srv6-segment-list
work-mode collector
work-mode analyzer
Use work-mode analyzer to configure the device to act as iFIT Analyzer and enter iFIT Analyzer view.
Use undo work-mode analyzer to cancel iFIT Analyzer settings.
work-mode analyzer
The device does not act as iFIT Analyzer or iFIT Collector.
iFIT view
In the scenario where the SRv6 TE policy and iFIT do not operate collaboratively, the device sends the iFIT measurement data to a separately deployed analyzer through Telemetry. This analyzer gathers the statistics transmitted from the ingress, transmit, and egress nodes and performs the aggregation and analysis.
In the scenario where the SRv6 TE policy and iFIT operate collaboratively, iFIT is used to measure the end-to-end delay from the ingress node to the egress node on the SRv6 paths. The measurement results are used to guide route selection on the ingress node. If the device acts as the ingress node of SRv6 paths, you must configure this command on the device.
Operating mechanism
In the scenario where the SRv6 TE policy and iFIT operate collaboratively, the SRv6 TE policy issues measurement parameters to iFIT, which then creates a service measurement instance. After the service measurement instance is activated, iFIT performs measurements on the matched service packets to monitor transmission performance (one-way packet loss and one-way delay) on the SRv6 paths. If the iFIT measurement result do not meet the requirements of the SRv6 TE policy, iFIT will immediately notify the SRv6 TE policy to initiate a link switchover.
In the SRv6 TE policy and iFIT collaboration scenario, Analyzer (ingress node) will perform the following tasks:
1.     Enables iFIT to periodically send the measurement results to Analyzer on the same node.
2.     Calculate the packet loss rate based on the number of service packets received on both the ingress and egress nodes.
3.     Calculate the one-way delay and one-way jitter based on the timestamp when the ingress node sent the service packet and the timestamp when the egress node received the same service packet.
4.     Report the iFIT calculation results to the local SRv6 TE policy module for intelligent route selection by the SRv6 TE policy.
# Configure the device to act as iFIT Analyzer and enter iFIT Analyzer view.
[Sysname] ifit enable
[Sysname-ifit] work-mode analyzer
[Sysname-ifit-analyzer]
work-mode collector
Use work-mode collector to configure the device to act as iFIT Collector and enter iFIT Collector view.
Use undo work-mode collector to cancel the iFIT Collector settings.
work-mode collector
iFIT view
In the scenario where iFIT collaborates with the SRv6 TE policy for intelligent route selection, you can configure this command on the egress node of the SRv6 TE policy path.
Operating mechanism
After you configure the egress node of an SRv6 TE policy to act as iFIT Collector, the egress node establishes a UDP session using the source address of the received SRv6 packets with the ingress node. Over this UDP session, the egress node sends the packet count statistics and timestamps to the ingress node at the iFIT monitoring cycle of the SRv6 TE policy.
# Configure the device to act as iFIT Collector and enter iFIT Collector view.
