- 13-Security Command Reference
- 01-DAE proxy commands
- 02-Password control commands
- 03-Keychain commands
- 04-Public key management commands
- 05-PKI commands
- 06-IPsec commands
- 07-SSH commands
- 08-SSL commands
- 09-Session management commands
- 10-Object group commands
- 11-Attack detection and prevention commands
- 12-IP-based attack prevention commands
- 13-IP source guard commands
- 14-ARP attack protection commands
- 15-ND attack defense commands
- 16-uRPF commands
- 17-SAVA commands
- 18-Crypto engine commands
- 19-SMA commands
- 20-Trust level commands
- 21-Encryption card user management commands
- 22-SAVNET commands
- 23-MACsec commands
17-SAVA commands | 81.29 KB |
Content
display ipv6 sava packet-drop statistics
ipv6 sava log enable spoofing-packet
SAVA commands
display ipv6 sava
Use display ipv6 sava to display SAVA entries.
display ipv6 sava [ interface interface-type interface-number | slot slot-number ]
In IRF mode:
display ipv6 sava [ interface interface-type interface-number | chassis chassis-number slot slot-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays SAVA entries for all interfaces.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays SAVA entries on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays SAVA entries on the global active MPU. (In IRF mode.)
# Display SAVA entries.
<Sysname> display ipv6 sava
IPv6 SAVA entry count: 2
Destination: 2011:: Prefix length: 64
Interface: XGE3/1/1 Flags: L
VPN instance: --
Destination: 2012:: Prefix length: 64
Interface: XGE3/1/2 Flags: L
VPN instance: --
IPv6 SAVA entry count |
Number of SAVA entries. |
Destination |
Destination IPv6 address. |
Prefix length |
Prefix length of the IPv6 address. |
Interface name. |
Flag |
Flag of the SAVA entry: · L—Local entry. · R—Remote entry. · G—Access group entry. |
VPN instance |
Name of the VPN instance associated with the interface in the SAVA entry. If the interface is not associated with a VPN instance, this field displays two hyphens (--). |
Use display ipv6 sava packet-drop statistics to display SAVA packet drop statistics.
display ipv6 sava packet-drop statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays SAVA packet drop statistics for all interfaces.
# Display SAVA packet drop statistics.
<Sysname> display ipv6 sava packet-drop statistics
Ten-GigabitEthernet3/1/1:
Packets:0 Bytes: 0
Ten-GigabitEthernet3/1/2:
Packets:10 Bytes: 1500
Packets |
Number of packets dropped by SAVA. |
Bytes |
Number of bytes dropped by SAVA. |
reset ipv6 sava packet-drop statistics
ipv6 sava access-group
Use ipv6 sava access-group to add an interface to an access group.
Use undo ipv6 sava access-group to remove an interface from an access group.
ipv6 sava access-group group-name
An interface does not belong to any access group.
group-name: Specifies an access group by its name, a case-sensitive string of 1 to 255 characters.
All interfaces in a SAVA access group must belong to the public network or the same VPN instance.
A SAVA access group can contain a maximum of eight interfaces.
# Add Ten-GigabitEthernet3/1/1 10 to SAVA access group aaa.
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] ipv6 sava access-group aaa
ipv6 sava enable
Use ipv6 sava enable to enable SAVA.
Use undo ipv6 sava enable to disable SAVA.
If the device has a large number of routing entries, it might take a long time for the device to complete SAVA entry creation. Before SAVA entry creation completes, valid IPv6 packets might be dropped.
# Enable Ten-GigabitEthernet3/1/1 on VLAN-interface 10.
[Sysname-Ten-GigabitEthernet3/1/1] ipv6 sava enable
Use ipv6 sava log enable spoofing-packet to enable SAVA logging.
Use undo ipv6 sava log enable spoofing-packet to disable SAVA logging.
ipv6 sava log enable spoofing-packet [ interval interval | number number ]*
interval interval: Specifies the interval at which the device outputs SAVA logs, in seconds. The value can be 0 or in the range of 5 to 3600, and the default is 60. If you set the interval to 0 seconds, the device outputs a SAVA log immediately after detecting an IPv6 source address spoofed packet.
number number: Specifies the maximum number of SAVA logs that can be outputted each time, in the range of 1 to 128. The default is 128.
To identify and troubleshoot issues, enable SAVA logging.
This feature enables the device to output SAVA logs when SAVA detects spoofed packets.
Due to hardware performance, the device still generates SAVA logs for a short time after you disable SAVA logging.
A card can output a maximum of 128 SAVA logs each time. (In standalone mode.) (In IRF mode.)
[Sysname] ipv6 sava log enable spoofing-packet
ipv6 sava import remote-route-tag
Use ipv6 sava import remote-route-tag to enable an interface to create SAVA entries based on synchronized remote routes.
Use undo ipv6 sava import remote-route-tag to restore the default.
ipv6 sava import remote-route-tag tag
An interface does not create SAVA entries based on synchronized remote routes.
tag: Specifies a tag of synchronized remote routes, in the range of 1 to 4294967295.
# Configure the device to create SAVA entries based on synchronized remote entries with tag 10 on Ten-GigabitEthernet3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] ipv6 sava import remote-route-tag 100
ipv6 sava packet-drop enable
Use ipv6 sava enable to enable dropping of SAVA-detected spoofed packets.
Use undo ipv6 sava enable to disable dropping of SAVA-detected spoofed packets.
undo ipv6 sava packet-drop enable
Dropping of SAVA-detected spoofed packets is enabled.
By default, when a SAVA-enabled interface receives an IPv6 packet and no matching SAVA entry containing the packet's source IPv6 address exists on the device, the packet is dropped. The device creates SAVA entries based on corresponding routing entries. If the device has a large number of routing entries, it might take a long time for the device to complete SAVA entry creation. Before SAVA entry creation completes, valid IPv6 packets might be dropped. To resolve this issue, use the undo ipv6 sava packet-drop enable command to disable dropping of SAVA-detected spoofed packets. In this way, before enabling dropping of SAVA-detected spoofed packets, you can analyze and adjust network configurations according to the output spoofed packet logs.
# Disable dropping of SAVA-detected spoofed packets.
[Sysname] undo ipv6 sava packet-drop enable
Use reset ipv6 sava packet-drop statistics to clear SAVA packet drop statistics.
reset ipv6 sava packet-drop statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears SAVA packet drop statistics for all interfaces.
# Clear SAVA packet drop statistics.
<Sysname> reset ipv6 sava packet-drop statistics
