09-Security Command Reference
HomeSupportSwitchesS9850-G SeriesTechnical DocumentsReference GuidesCommand ReferencesH3C S6850-G&S6805-G&S9850-G Switch Series Command References-R8307Pxx-6W10009-Security Command Reference
24-Microsegmentation commands
24-Microsegmentation commands 89.00 KB
display microsegment
Use display microsegment to display the configuration and status of microsegments.
display microsegment [ microsegment-id | name microsegment-name ]
microsegment-id: Specifies a microsegment by its ID in the range of 1 to 65535.
name microsegment-name: Specifies a microsegment by its name, a case-insensitive string of 1 to 32 characters.
If you do not specify any parameters, this command displays summary information and status information about all microsegments.
# Display the configuration of microsegment 1.
<Sysname> display microsegment 1
Microsegment ID    : 1
Microsegment name  : micseg1
  IPv4 member:
    192.168.56.0/24
  IPv6 member:
    10:10::/64
# Display summary information and status information about all microsegments.
Microsegment status   : Enabled
Subnet matching method: Longest
Total microsegments   : 2
Microsegment list     :
  Microsegment ID  Members  Microsegment name
  12345            3        abc
  32789            5        xyz
Subnet matching method.
display microsegment aggregation
Use display microsegment aggregation to display aggregate microsegment configuration.
display microsegment aggregation [ aggregation-id | name aggregation-name ]
aggregation-id: Specifies an aggregate microsegment by its ID in the range of 1 to 65535.
name aggregation-name: Specifies an aggregate microsegment by its name, a case-insensitive string of 1 to 32 characters.
If you do not specify any parameters, this command displays the configuration of all aggregate microsegments. If you specify an aggregate microsegment, this command displays the configuration of the specified microsegment.
# Display the configuration of aggregate microsegment 16.
<Sysname> display microsegment aggregation 16
Aggregation ID     Range        Aggregation name
16                 16-19        agg16
# Display the configuration of aggregate microsegments.
16                 16-19        agg16
32                 32-35
Aggregation ID
Aggregate microsegment ID.
Range
Member microsegment ID range.
Aggregation name
Aggregate microsegment name.
extcommunity-type microsegment-id
Use extcommunity-type microsegment-id to set the microsegment extended community attribute.
Use undo extcommunity-type microsegment-id to restore the default.
extcommunity-type microsegment-id microsegment-type-value
The microsegment extended community value is 83ff (hexadecimal).
BGP instance view
microsegment-type-value: Specifies the microsegment extended community value in the range of 0 to ffff (hexadecimal).
BGP carries microsegment IDs in an extended community attribute and advertises microsegment settings to a peer through the extended community attribute.
To avoid attribute conflicts, you can execute this command to modify the microsegment extended community attribute value.
# In BGP instance view, set the microsegment extended community value to 0x5688.
[Sysname] bgp 200
[Sysname-bgp-default] extcommunity-type microsegment-id 5688
member
Use member to add a member to a microsegment.
Use undo member to remove a member from a microsegment.
member { ipv4 ipv4-address { mask | mask-length } | ipv6 ipv6-address prefix-length } [ vpn-instance vpn-instance-name ]
undo member { ipv4 ipv4-address { mask | mask-length } | ipv6 ipv6-address prefix-length } [ vpn-instance vpn-instance-name ]
A microsegment does not contain members.
Microsegment view
ipv4 ipv4-address { mask | mask-length }: Specifies a range of IPv4 addresses. The mask argument specifies a subnet mask. The mask-length argument specifies a subnet mask length in the range of 0 to 32. The endpoints that use the IPv4 addresses are added to the microsegment.
ipv6 ipv6-address prefix-length: Specifies a range of IPv6 addresses. The prefix-length argument specifies a prefix length in the range of 0 to 128. The endpoints that use the IPv6 addresses are added to the microsegment.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command adds IP addresses in the public network to the microsegment.
A member can belong to multiple microsegments.
You can execute this command multiple times to add multiple IP addresses or IP address ranges to a microsegment.
# Add IPv4 address 192.168.56.3 to microsegment 1 as a member.
[Sysname] microsegment 1
[Sysname-microsegment-1]  member ipv4 192.168.56.3 32
microsegment
microsegment
Use microsegment to create a microsegment and enter its view, or enter the view of an existing microsegment.
Use undo microsegment to delete a microsegment.
microsegment microsegment-id [ name microsegment-name ]
undo microsegment microsegment-id
No microsegments exist.
microsegment-id: Specifies a microsegment ID in the range of 1 to 65535.
name microsegment-name: Specifies a microsegment name, a case-insensitive string of 1 to 32 characters. The microsegment name must be globally unique. If you do not specify a microsegment name, this command creates the microsegment without a name.
To modify the name of an existing microsegment, you must delete the microsegment and then re-create it with a new name.
If the amount of the free memory space reaches an alarm threshold, the system does not support creating a segment or entering the view of an existing segment. However, existing microsegments can be used.
# Create microsegment 1 with name micseg1 and enter its view.
[Sysname] microsegment 1 name micseg1
member
Use microsegment aggregation to create an aggregate microsegment and enter its view, or enter the view of an existing microsegment.
Use undo microsegment aggregation to delete an aggregate microsegment.
microsegment aggregation aggregation-id mask-length mask-length [ name aggregation-name ]
undo microsegment aggregation aggregation-id
No aggregate microsegments exist.
aggregation-id: Specifies an aggregate microsegment ID in the range of 1 to 65535. The ID must be an even number.
mask-length mask-length: Specifies a mask length for the aggregate microsegment ID in the range of 1 to the number of contiguous 0s of the decimal number converted from the aggregate microsegment ID. The maximum mask length is 9.
name aggregation-name: Specifies a microsegment name, a case-insensitive string of 1 to 32 characters. The microsegment name must be globally unique. If you do not specify a microsegment name, this command creates the aggregate microsegment without a name.
An aggregate microsegment is a group of microsegments with contiguous IDs. The ID of the aggregate microsegment is the start microsegment ID. You can uses a mask to specify the microsegments for an aggregate microsegment. The GBP used by an aggregate microsegment has higher priority than that used by a member microsegment. Suppose microsegments 12 and 14 can communicate with each other and microsegments 13 and 14 can also communicate with each other. Combine microsegments 12 and 13 into aggregate microsegment 12 and use a GBP to prevent aggregate microsegment 12 from communicating with microsegment 14. The result is that microsegments 12 and 13 cannot communicate with microsegment 14.
The number of member microsegments of an aggregate microsegment is determined by the mask-length argument. For example, if the mask-length argument is 3, the number of member microsegments is 2^3=8. If you want to aggregate microsegments 6 and 7, the aggregation-id argument must be 6 and the mask-length argument must be 1 (6 corresponds to decimal 110, and the number of contiguous 0s is 1).
To modify the name of an existing aggregate microsegment, you must delete the microsegment and then re-create it with a new name.
# Create aggregate microsegment 16 with name agg16 with mask length 3.
[Sysname] microsegment aggregation 16 mask-length 3 name agg16
microsegment enable
Use microsegment enable to enable microsegmentation.
Use undo microsegment enable to disable microsegmentation.
microsegment enable
Microsegmentation is disabled.
After you enable microsegmentation, member IP addresses and microsegment IDs are sent to the FIB. When you disable microsegmentation, the information is deleted from the FIB. The device forwards or drops an incoming packet according to the microsegment IDs of its source and destination IP addresses and the ACL and GBP configurations.
In an EVPN network, the synchronized microsegment settings directly take effect on the remote end and are not subject to this command.
# Enable microsegmentation.
[Sysname] microsegment enable
member
microsegment
microsegment subnet-match
Use microsegment subnet-match to configure network address match method for microsegments.
Use undo microsegment subnet-match to restore the default.
microsegment subnet-match longest
Exact match is used for network addresses.
longest: Specifies longest match.
The device determines the segment membership of packets by matching the source and destination IP addresses of packets. The following match methods are available:
·     Exact match—The mask lengths of the source and destination IP addresses must be equal to those of members in microsegments. For example, a packet sourced from 10.10.10.1/24 matches member 10.10.10.0/24 instead of 10.10.10.0/23.
·     Longest match—The mask lengths of the source and destination IP addresses can be greater than or equal to those of members in microsegments. For example, a packet sourced from 10.10.10.1/24 matches member 10.10.10.0/16.
The device uses different match methods for different member types of microsegments:
·     Host addresses (IPv4 addresses with a 32-bit mask and IPv6 addresses with a 128-bit prefix) use the longest match method, which cannot be modified.
·     The default route (0.0.0.0/0 or 0::0/0) uses the exact match method, which cannot be modified.
·     Network addresses (IPv4 addresses with a 1-bit to 31-bit mask and IPv6 addresses with a 1-bit to 127-bit prefix) use the exact match method by default. You can configure the longest match method for this member type.
The longest match method helps you simplify configuration when you need to add a large number of network addresses to a microsegment. For example, to match network addresses 10.10.10.0/24, 10.10.20.0/24, and 10.10.30.0/24 to microsegment 1, you need to execute only the member ipv4 10.10.10.0/16 command if you use longest match.
# Configure the network address match method as longest match.
[Sysname] microsegment subnet-match longest
member
snmp-agent trap enable microsegment
Use snmp-agent trap enable microsegment to enable SNMP notifications for microsegmentation.
Use undo snmp-agent trap enable microsegment to disable SNMP notifications for microsegmentation.
snmp-agent trap enable microsegment [ join | leave ] *
undo snmp-agent trap enable microsegment [ join | leave ] *
SNMP notifications are enabled for microsegmentation.
join: Generates notifications when the device receives an microsegmentation membership report message.
leave: Generates notifications when the device receives an microsegmentation leave group message.
To report critical microsegmentation events to an SNMP NMS, enable SNMP notifications for microsegmentation.
For microsegmentation SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about configuring SNMP, see Network Management and Monitoring Configuration Guide.
# Disable SNMP notifications for microsegmentation.
[Sysname] undo snmp-agent trap enable microsegment
