12-Telemetry Configuration Guide
HomeSupportSwitchesS9850-G SeriesTechnical DocumentsConfigure & DeployConfiguration GuidesH3C S6850-G&S6805-G&S9850-G Switch Series Configuration Guides-R8307Pxx-6W10012-Telemetry Configuration Guide
02-Telemetry stream configuration
02-Telemetry stream configuration 85.12 KB
Configuring telemetry stream
About telemetry stream
Telemetry stream is a network monitoring technology used to collect data from devices. It continuously streams data to a collector.
Telemetry stream supports collecting the input interface, timestamp, and output interface of traffic.
How telemetry stream works
The working mechanism of telemetry stream is as follows:
1.     Telemetry stream samples a matching packet on the input interface and copies it to the telemetry stream processor in the device. The telemetry stream processor adds the input interface information to the packet.
2.     The telemetry stream processor encapsulates the packet and routes it to the collector.
The collector can calculate the path and delay information according to the collected data from multiple nodes.
Telemetry stream timestamping
With this function enabled, the device carries the timestamp in its packets sent to the collector. The collector can calculate the delay introduced when a node forwards packets. Additionally, the collector can use the timestamp information collected from multiple nodes to calculate the delay introduced when packets are forwarded along the path.
Telemetry stream tasks at a glance
To configure telemetry stream, perform the following tasks:
1.     Configuring basic telemetry stream functions
2.     (Optional.) Configuring telemetry stream timestamping
Configure routing to make sure the devices can reach each other.
The device copies an original packet on the input interface and sends the copy to the telemetry stream processor in the device. The telemetry stream processor adds the input and output interface information to the packet, encapsulates it, and routes it to the collector.
Too many original packets will overwhelm the Telemetry processor and even cause it to drop packets. To address this problem, you can use an ACL or sampler on the input interface to reduce the packets sent to the collector. Only packets matching a permit ACL rule or sampled packets are sent to the collector.
If the data portion of original packets is large, you can enables the truncation function to save the link bandwidth consumed between the device and the collector and reduce the parsing load of the collector. The truncation function truncates the packets before sending them to the collector. The truncated packets retain complete input interface, output interface, and timestamp information.
1.     Specify a device ID.
a.     Enter system view.
b.     Specify a device ID.
telemetry stream device-id address
By default, no device ID is specified.
2.     Configure addressing parameters to encapsulate in the packets sent to the collector.
telemetry stream collector source source-address destination destination-address source-port source-port destination-port destination-port [ vpn-instance vpn-instance-name ] [ truncation ]
By default, no addressing parameters are configured.
3.     Configure a telemetry stream action on the input interface.
a.     Enter interface view.
b.     Configure a telemetry stream action on the interface.
telemetry stream action action-id [ acl [ ipv6 | mac | user-defined ] { acl-number | name acl-name } | sampler sampler-name ] *
By default, no telemetry stream action is configured.
c.     Return to system view.
For information about ACLs, see ACL and QoS Configuration Guide.
For information about samplers, see Network Management and Monitoring Configuration Guide.
4.     Enable telemetry stream.
telemetry stream enable
By default, telemetry stream is enabled.
This feature allows the device to add the timestamp information when a packet enters and leaves it.
2.     Enable telemetry stream timestamping.
telemetry stream timestamp enable
By default, telemetry stream timestamping is disabled.
Display and maintenance commands for telemetry stream
Display ACL configuration and match statistics.
display acl [ ipv6 | mac | user-defined ] { acl-number | all | name acl-name }
For more information about this command, see ACL and QoS Command Reference.
Display the configuration of samplers.
display sampler [ sampler-name ] [ slot slot-number ]
For more information about this command, see Network Management and Monitoring Command Reference.
Display telemetry stream configuration.
display telemetry stream
Telemetry stream configuration examples
Example: Configuring telemetry stream
As shown in Figure 1, configure telemetry stream on Device B for the collector to calculate the delay when packets are forwarded by Device B.
Figure 1 Network diagram
Assign IP addresses to interfaces and configure routing protocols. (Details not shown.)
# Specify 10.0.0.1 as the device ID.
[DeviceB] telemetry stream device-id 10.0.0.1
# Configure addressing parameters to encapsulate in telemetry stream packets sent to the collector.
[DeviceB] telemetry stream collector source 20.0.0.2 destination 30.0.0.1 source-port 12 destination-port 14
# Enable telemetry stream timestamping.
[DeviceB] telemetry stream timestamp enable
# Create sampler samp in random sampling mode, and set the sampling rate to 8. One packet from 256 (2 to the 8th power) packets is selected.
[DeviceB] sampler samp mode random packet-interval n-power 8
# Create IPv4 basic ACL 2000, and configure a rule to match packets with source IP address 192.168.1.2.
[DeviceB] acl basic 2000
[DeviceB-acl-ipv4-basic-2000] rule permit source 192.168.1.2 0
[DeviceB-acl-ipv4-basic-2000] quit
# Configure telemetry stream action 1 to use ACL 2000 and sampler samp on Ten-GigabitEthernet 1/0/3.
[DeviceB] interface ten-gigabitethernet 1/0/3
[DeviceB-Ten-GigabitEthernet1/0/3] telemetry stream action 1 acl 2000 sampler samp
[DeviceB-Ten-GigabitEthernet1/0/3] quit
# Enable telemetry stream.
[DeviceB] telemetry stream enable
# Display the telemetry stream configuration on Device B.
[DeviceB] display telemetry stream
Telemetry stream status          : Enabled
Telemetry stream timestamp status: Enabled
Telemetry stream device-id       : 10.0.0.1
Telemetry stream action:
  Ten-GigabitEthernet1/0/3:
    Telemetry stream action 1:
      ACL    : 2000
      Sampler: samp
Telemetry stream collector:
  Source IP       : 20.0.0.2
  Destination IP  : 30.0.0.1
  Source port     : 12
  Destination port: 14
  Truncation      : Enable
