- 10-High Availability Configuration Guide
- 01-Ethernet OAM configuration
- 02-DLDP configuration
- 03-RRPP configuration
- 04-ERPS configuration
- 05-Smart Link configuration
- 06-Monitor Link configuration
- 07-Error code detection configuration
- 08-VRRP configuration
- 09-BFD configuration
- 10-Track configuration
- 11-Process placement configuration
- 12-Interface collaboration configuration
10-Track configuration | 615.60 KB |
Restrictions and guidelines: Track configuration
Collaboration application example
Associating the Track module with a detection module
Associating Track with interface management
Associating Track with route management
Associating Track with M-LAG MAD state
Associating Track with a tracked list
Associating Track with a Boolean list
Associating Track with a percentage threshold list
Associating Track with a weight threshold list
Associating the Track module with an application module
Prerequisites for associating the Track module with an application module
Associating Track with static routing
Associating Track with traffic redirection
Display and maintenance commands for Track
Example: Configuring VRRP-Track-NQA collaboration
Example: Configuring an echo-mode BFD session for a VRRP backup to monitor the master
Example: Configuring a control-mode BFD session for a VRRP backup to monitor the master
Example: Configuring an echo-mode BFD session for the VRRP master to monitor the uplink
Example: Configuring a control-mode BFD session for the VRRP master to monitor the uplink
Example: Configuring static routing-Track-NQA collaboration
Example: Configuring static routing-Track-BFD (echo mode) collaboration
Example: Configuring static routing-Track-BFD (control mode) collaboration
Example: Configuring VRRP-Track-interface management collaboration
Example: Configuring VRRP-Track-route management collaboration
Example: Configuring static routing-Track-LLDP collaboration
Configuring Track
About Track
Collaboration mechanism
The Track module collaborates with detection modules and application modules.
As shown in Figure 1, collaboration is enabled when you associate the Track module with a detection module and an application module, and it operates as follows:
1. The detection module probes specific objects such as interface status, link status, network reachability, and network performance, and informs the Track module of detection results.
2. The Track module sends the detection results to the application module.
3. When notified of changes for the tracked object, the application modules can react to avoid communication interruption and network performance degradation.
Figure 1 Collaboration through the Track module
Collaboration between the Track module and a detection module
The detection module sends the detection result of the tracked object to the Track module. The Track module changes the status of the track entry as follows:
· If the tracked object operates correctly, the state of the track entry is Positive. For example, the track entry state is Positive in one of the following conditions:
¡ The target interface is up.
¡ The target network is reachable.
· If the tracked object does not operate correctly, the state of the track entry is Negative. For example, the track entry state is Negative in one of the following conditions:
¡ The target interface is down.
¡ The target network is unreachable.
· If the detection result is invalid, the state of the track entry is NotReady. For example, the track entry state is NotReady if its associated NQA operation does not exist.
Collaboration between the Track module and an application module
Supported detection modules
The following detection modules can be associated with the Track module:
· NQA.
· BFD.
· Interface management.
· Route management.
· LLDP.
· M-LAG
You can also associate a track entry with a list of objects called a tracked list. The state of a tracked list is determined by the states of all objects in the list. The following types of tracked lists are supported:
· Boolean AND list—The state of a Boolean AND list is determined by the states of the tracked objects using the Boolean AND operation.
· Boolean OR list—The state of a Boolean OR list is determined by the states of the tracked objects using the Boolean OR operation.
· Percentage threshold list—The state of a percentage threshold list is determined by comparing the percentage of positive objects in the list with the percentage thresholds configured for the list.
· Weight threshold list—The state of a weight threshold list is determined by comparing the weight of positive objects in the list with the weight thresholds configured for the list.
Supported application modules
The following application modules can be associated with the Track module:
· VRRP.
· Static routing.
· PBR.
· Traffic redirection.
· Smart Link.
· Embedded Automation Architecture (EAA).
When configuring a track entry for an application module, you can set a notification delay to avoid immediate notification of status changes.
When the delay is not configured and the route convergence is slower than the link state change notification, communication failures occur. For example, when the master in a VRRP group detects an uplink interface failure through Track, Track immediately notifies the master to decrease its priority. A backup with a higher priority then preempts as the new master. When the failed uplink interface recovers, the Track module immediately notifies the original master to restore its priority. If the uplink route has not recovered, forwarding failure will occur.
The following is an example of collaboration between NQA, Track, and static routing.
Configure a static route with next hop 192.168.0.88 on the device. If the next hop is reachable, the static route is valid. If the next hop becomes unreachable, the static route is invalid. For this purpose, configure NQA-Track-static routing collaboration as follows:
1. Create an NQA operation to monitor the accessibility of IP address 192.168.0.88.
2. Create a track entry and associate it with the NQA operation.
¡ When next hop 192.168.0.88 is reachable, NQA sends the result to the Track module. The Track module sets the track entry to Positive state.
¡ When the next hop becomes unreachable, NQA sends the result to the Track module. The Track module sets the track entry to Negative state.
3. Associate the track entry with the static route.
¡ When the track entry is in Positive state, the static routing module considers the static route to be valid.
¡ When the track entry is in Negative state, the static routing module considers the static route to be invalid.
Track tasks at a glance
To implement the collaboration function, establish associations between the Track module and detection modules, and between the Track module and application modules.
To configure the Track module, perform the following tasks:
1. Associating the Track module with a detection module
¡ Associating Track with interface management
¡ Associating Track with route management
¡ Associating Track with M-LAG MAD state
2. Associating Track with a tracked list
¡ Associating Track with a Boolean list
¡ Associating Track with a percentage threshold list
¡ Associating Track with a weight threshold list
3. Associating the Track module with an application module
¡ Associating Track with static routing
¡ Associating Track with traffic redirection
Associating Track with NQA
NQA supports multiple operation types to analyze network performance and service quality. For example, an NQA operation can periodically detect whether a destination is reachable, or whether a TCP connection can be established.
An NQA operation operates as follows when it is associated with a track entry:
· If the consecutive probe failures reach the specified threshold, the NQA module notifies the Track module that the tracked object has malfunctioned. The Track module then sets the track entry to Negative state.
· If the specified threshold is not reached, the NQA module notifies the Track module that the tracked object is operating correctly. The Track module then sets the track entry to Positive state.
For more information about NQA, see Network Management and Monitoring Configuration Guide.
If you associate a track entry with a nonexistent NQA operation or reaction entry, the state of the track entry is NotReady.
1. Enter system view.
2. Create a track entry, associate it with an NQA reaction entry, and enter its view.
track track-entry-number nqa entry admin-name operation-tag reaction item-number
3. Set the delay for notifying the application module of track entry state changes.
delay { negative negative-time | positive positive-time } *
By default, the Track module notifies the application module immediately when the track entry state changes.
Associating Track with BFD
You can associate a track entry with an echo-mode BFD session, a control-mode BFD session, or a static BFD session. For more information about BFD, see "Configuring BFD."
The associated Track and BFD operate as follows:
· If the BFD detects that the link fails, it informs the Track module of the link failure. The Track module sets the track entry to Negative state.
· If the BFD detects that the link is operating correctly, the Track module sets the track entry to Positive state.
After associating a track entry with an echo-packet-mode BFD session, by default, the device checks the echo response receiving interface. If it is different from the echo packet output interface, the device takes the echo response packet as an invalid packet, and discards it. The BFD session then goes down. When multiple paths are available for the BFD session, as a best practice, enable checking for the echo response receiving interface. This can avoid BFD session failure when the echo response receiving interface is different from the echo packet output interface.
When you associate a track entry with BFD, do not configure the virtual IP address of a VRRP group as the local or remote address of the BFD session.
For correct establishment of a control-mode BFD session, follow these guidelines when you execute the track bfd ctrl command:
· Execute the track bfd ctrl command on both the local and peer ends.
· Specify the BFD session parameters (outgoing interface, source IP address, and destination IP address of BFD control packets) correctly for the command.
Before you associate Track with an echo-mode BFD session, configure the source IP address of BFD echo packets. For more information, see "Configuring BFD."
2. Create a track entry, associate it with a BFD session, and enter its view. Choose the options to configure as needed:
¡ Create a track entry, and associate it with an echo-mode BFD session.
track track-entry-number bfd echo interface interface-type interface-number remote { ip remote-ipv4-address | ipv6 remote-ipv6-address } local { ip local-ipv4-address | ipv6 local-ipv6-address } [ ignore-rx-interface ]
¡ Create a track entry, and associate it with a control-mode BFD session.
track track-entry-number bfd ctrl [ interface interface-type interface-number | vpn-instance vpn-instance-name ] remote { ip remote-ipv4-address | ipv6 remote-ipv6-address } local { ip local-ipv4-address | ipv6 local-ipv6-address }
¡ Create a track entry, and associate it with a static BFD session.
track track-entry-number bfd static bfd-session-name
The interface management module monitors the link status or network-layer protocol status of interfaces. The associated Track and interface management operate as follows:
· When the link or network-layer protocol status of the interface changes to up, the interface management module informs the Track module of the change. The Track module sets the track entry to Positive state.
· When the link or network-layer protocol status of the interface changes to down, the interface management module informs the Track module of the change. The Track module sets the track entry to Negative state.
2. Create a track entry, associate it with interface management, and enter its view.
¡ Create a track entry to monitor the link status of an interface.
track track-entry-number interface interface-type interface-number
¡ Create a track entry to monitor the physical status of an interface.
track track-entry-number interface interface-type interface-number physical
¡ Create a track entry to monitor the network layer protocol status of an interface.
track track-entry-number interface interface-type interface-number protocol { ipv4 | ipv6 }
The route management module monitors route entry changes in the routing table. The associated Track and route management operate as follows:
· Monitor the specified route entry:
¡ If the route entry exists in the routing table, the route management module informs the Track module. The Track module then sets the track entry to Positive state.
¡ When the route entry is removed from the routing table, the route management module informs the Track module of the change. The Track module then sets the track entry to Negative state.
· Monitor the number of ECMP routes associated with the specified route entry:
¡ When the number of ECMP routes is within the specified range, the route management module informs the Track module. The Track module then sets the track entry to Positive state.
¡ When the number of ECMP routes is out of the specified range, the route management module informs the Track module. The Track module then sets the track entry to Negative state.
2. Create a track entry, associate it with a route entry, and enter its view.
track track-entry-number ip route [ vpn-instance vpn-instance-name ] ipv4-address { mask-length | mask } { ecmp-number { greater-equal min-ecmp-number | less-equal max-ecmp-number } * | reachability }
Associating Track with LLDP
The LLDP module detects neighbor availability and informs the detection result to the Track module. The associated Track and LLDP operate as follows:
· When the neighbor is available, the Track module sets the track entry to Positive state.
· When the neighbor is unavailable, the Track module sets the track entry to Negative state.
For more information about LLDP, see Layer 2—LAN Switching Configuration Guide.
2. Create a track entry, associate it with an LLDP interface, and enter its view.
track track-entry-number lldp neighbor interface interface-type interface-number
M-LAG provides the MAD mechanism to set associated device interfaces to M-LAG MAD DOWN state when the peer link between M-LAG member devices goes down. This can avoid traffic forwarding failure on the interfaces and avoid impacts on services. When the peer link comes up and the delay timer expires, M-LAG brings up the interfaces placed in M-LAG MAD DOWN state.
The associated Track and M-LAG MAD state operate as follows:
· If specific interfaces on the device are set to M-LAG MAD DOWN state, the Track module sets the track entry to Negative state.
· If the interfaces in M-LAG MAD DOWN state come up, the Track module sets the track entry to Positive state.
· If no M-LAG MAD state change events are triggered or received, the Track module sets the track entry to NotReady state.
For more information about M-LAG MAD, see M-LAG configuration in Layer 2—LAN Switching Configuration Guide.
2. Create a track entry, associate it with M-LAG MAD state, and enter its view.
track track-entry-number mlag-mad-status
A Boolean list is a list of tracked objects based on a Boolean logic. It can be further divided into the following types:
· Boolean AND list—A Boolean AND list is set to the Positive state only when all objects are in Positive state. If one or more objects are in Negative state, the tracked list is set to the Negative state.
· Boolean OR list—A Boolean OR list is set to the Positive state if any object is in Positive state. If all objects are in Negative state, the tracked list is set to the Negative state.
2. Create a Boolean tracked list and enter its view.
track track-entry-number list boolean { and | or }
3. (Optional.) Set the delay for notifying the application module of tracked list state changes.
By default, the Track module notifies the application module immediately when the tracked list state changes.
4. Add the track entry as an object to the tracked list.
object track-entry-number [ not ]
By default, a tracked list does not contain any objects.
Repeat this step to add all interested objects to the tracked list.
· If the percentage of positive objects is equal to or above the positive state threshold, the list is set to the Positive state.
· If the percentage of positive objects is equal to or below the negative state threshold, the list is set to the Negative state.
· The state of a percentage threshold list remains unchanged if the percentage of positive objects is below the positive state threshold and above the negative state threshold.
2. Create a percentage threshold list and enter its view.
track track-entry-number list threshold percentage
5. Configure the threshold values used to determine the state of the percentage threshold list.
threshold percentage { negative negative-threshold | positive positive-threshold } *
By default, the negative state threshold is 0% and the positive state threshold is 1%.
· If the total weight of positive objects is equal to or above the positive state threshold, the list is set to the Positive state.
· If the total weight of positive objects is equal to or below the negative state threshold, the list is set to the Negative state.
· The state of a weight threshold list remains unchanged if the total weight of positive objects is below the positive state threshold and above the negative state threshold.
2. Create a weight threshold list and enter its view.
track track-entry-number list threshold weight
object track-entry-number [ weight weight ]
5. Configure the threshold values used to determine the state of the weight threshold list.
threshold weight { negative negative-threshold | positive positive-threshold } *
By default, the negative state threshold is 0 and the positive state threshold is 1.
Before you associate the Track module with an application module, make sure the associated track entry has been created.
Create a track entry first before you associate it with an application module.
An application module might obtain incorrect track entry status information if the associated track entry does not exist.
For more information about the Track and application module collaboration commands, see the command reference of the associated application module.
Associating Track with VRRP
When VRRP is operating in standard mode or load balancing mode, associate the Track module with the VRRP group to implement the following actions:
· Change the priority of a router according to the status of the uplink. If a fault occurs on the uplink of the router, the VRRP group is not aware of the uplink failure. If the router is the master, hosts in the LAN cannot access the external network. To resolve this problem, configure a detection module-Track-VRRP collaboration. The detection module monitors the status of the uplink of the router and notifies the Track module of the detection result.
When the uplink fails, the detection module notifies the Track module to change the status of the monitored track entry to Negative. The priority of the master decreases by a user-specified value. A router with a higher priority in the VRRP group becomes the master.
· Monitor the master on a backup. If a fault occurs on the master, the backup operating in switchover mode will switch to the master immediately to maintain normal communication.
When VRRP is operating in load balancing mode, associate the Track module with the VRRP VF to implement the following functions:
· Change the priority of the AVF according to its uplink state. When the uplink of the AVF fails, the track entry changes to Negative state. The weight of the AVF decreases by a user-specified value. The VF with a higher priority becomes the new AVF to forward packets.
· Monitor the AVF status from the LVF. When the AVF fails, the LVF that is operating in switchover mode becomes the new AVF to ensure continuous forwarding.
For more information about configuring VRRP, see "Configuring VRRP."
Restrictions and guidelines for Track association with VRRP
· VRRP tracking does not take effect on an IP address owner. The configuration takes effect when the router does not act as the IP address owner.
An IP address owner is the router with its interface IP address used as the virtual IP address of the VRRP group.
· When the status of the track entry changes from Negative to Positive or NotReady, the associated router or VF restores its priority automatically.
Associating Track with a VRRP group
2. Enter interface view.
3. Associate a track entry with a VRRP group.
vrrp [ ipv6 ] vrid virtual-router-id track track-entry-number { forwarder-switchover member-ip ip-address | priority reduced [ priority-reduced ] switchover | weight reduced [ weight-reduced ] }
By default, no track entry is associated with a VRRP group.
This command is supported when VRRP is operating in both standard mode and load balancing mode.
Associating Track with a VRRP VF
3. Associate Track with a VRRP VF.
By default, no track entry is associated with a VRRP VF.
This command is configurable when VRRP is operating in standard mode or load balancing mode. However, the configuration takes effect only when VRRP is operating in load balancing mode.
A static route is a manually configured route to route packets. For more information about static route configuration, see Layer 3—IP Routing Configuration Guide.
Static routes cannot adapt to network topology changes. Link failures or network topological changes can make the routes unreachable and cause communication interruption.
To resolve this problem, configure another route to back up the static route. When the static route is reachable, packets are forwarded through the static route. When the static route is unreachable, packets are forwarded through the backup route.
To check the accessibility of a static route in real time, associate the Track module with the static route.
If you specify the next hop but not the output interface when configuring a static route, you can configure the static routing-Track-detection module collaboration. This collaboration enables you to verify the accessibility of the static route based on the track entry state.
· If the track entry is in Positive state, the following conditions exist:
¡ The next hop of the static route is reachable.
¡ The configured static route is valid.
· If the track entry is in Negative state, the following conditions exist:
¡ The next hop of the static route is not reachable.
¡ The configured static route is invalid.
· If the track entry is in NotReady state, the following conditions exist:
¡ The accessibility of the next hop of the static route is unknown.
¡ The static route is valid.
In static routing-Track-NQA collaboration, you must configure the same VPN instance name for the NQA operation and the next hop of the static route. Otherwise, the accessibility detection cannot operate correctly.
If a static route needs route recursion, the associated track entry must monitor the next hop of the recursive route. The next hop of the static route cannot be monitored. Otherwise, a valid route might be considered invalid.
Associating Track with an IPv4 static route
2. Associate an IPv4 static route with a track entry to check the accessibility of the next hop.
Public network:
ip route-static { dest-address { mask-length | mask } | group group-name } { interface-type interface-number [ next-hop-address ] track track-entry-number | next-hop-address [ recursive-lookup host-route ] track track-entry-number | vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup host-route ] track track-entry-number } [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name { dest-address { mask-length | mask } | group group-name } { interface-type interface-number [ next-hop-address ] track track-entry-number | next-hop-address [ recursive-lookup host-route ] [ public ] track track-entry-number | vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup host-route ] track track-entry-number } [ preference preference ] [ tag tag-value ] [ description text ]
By default, an IPv4 static route is not associated with any track entries.
Associating Track with an IPv6 static route
2. Associate an IPv6 static route with a track entry to check the accessibility of the next hop.
Public network:
ipv6 route-static ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] track track-entry-number | [ vpn-instance d-vpn-instance-name ] next-hop-address [ recursive-lookup host-route ] track track-entry-number } [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] track track-entry-number | next-hop-address [ public ] track track-entry-number | vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup host-route ] track track-entry-number } [ preference preference ] [ tag tag-value ] [ description text ]
By default, an IPv6 static route is not associated with any track entries.
Associating Track with PBR
PBR uses user-defined policies to route packets. You can specify parameters in a PBR policy to guide the forwarding of the packets that match specific criteria. For more information about PBR, see Layer 3—IP Routing Configuration Guide.
PBR cannot detect the availability of any action taken on packets. When an action is not available, packets processed by the action might be discarded. For example, if the output interface specified for PBR fails, PBR cannot detect the failure, and continues to forward matching packets out of the interface.
To enable PBR to detect topology changes and improve the flexibility of the PBR application, configure Track-PBR-detection module collaboration.
After you associate a track entry with an apply clause, the detection module associated with the track entry sends Track the detection result of the availability of the tracked object.
· The Positive state of the track entry indicates that the object is available, and the apply clause is valid.
· The Negative state of the track entry indicates that the object is not available, and the apply clause is invalid.
· The NotReady state of the track entry indicates that the apply clause is valid.
The following objects can be associated with a track entry:
· Output interface.
· Next hop.
· Default next hop.
Prerequisites for Track association with PBR
Before you associate Track with PBR, create a policy node, and set the match criteria.
2. Create a policy node and enter its view.
3. Set match criteria. Choose the options to configure as needed:
¡ Set an ACL match criterion.
By default, no ACL match criterion is set.
The ACL match criterion cannot match Layer 2 information.
When using the ACL to match packets, PBR ignores the time range settings in the ACL. If the specified ACL does not exist, no packets will be matched.
When using the ACL to match packets, interface PBR ignores the action (permit or deny) setting in the ACL.
When using the ACL to match packets, local PBR uses only the permit action in the ACL.
¡ Set a VXLAN match criterion.
if-match vxlan-id vxlan-id
By default, no VXLAN match criterion is set.
¡ Set a service chain match criterion.
if-match service-chain path-id service-path-id [ path-index service-path-index ]
By default, no service chain match criterion is set.
4. Set actions and associate the policy node with a track entry. Choose the options to configure as needed:
¡ Set the output interface.
apply output-interface null 0 [ track track-entry-number ]
By default, no output interface is set.
¡ Set the next hop.
apply next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ]}&<1-4>
By default, no next hop is set.
Associating Track with IPv6 PBR
2. Create an IPv6 policy node and enter its view.
When using the ACL to match packets, IPv6 PBR ignores the action (permit or deny) and time range settings in the ACL.
¡ Set the next hop.
apply next-hop [ vpn-instance vpn-instance-name ] { ipv6-address [ direct ] [ track track-entry-number ] } &<1-4>
¡ Set the default next hop.
apply default-next-hop [ vpn-instance vpn-instance-name | inbound-vpn ] { ipv6-address [ direct ] [ track track-entry-number ] }&<1-4>
By default, no default next hop is set.
Traffic redirection redirects the packets matching specific criteria to a certain location, such as to an interface, a CPU, or a next hop. When the location (for example, next hop) is not reachable, packets redirected to it are lost. To check the accessibility of the next hop in real time, associate Track with traffic redirection. For more information about traffic redirection, see QoS configuration in ACL and QoS Configuration Guide.
¡ The next hop is reachable.
¡ Traffic redirection redirects packets to the next hop.
¡ The next hop is not reachable.
¡ Traffic redirection does not redirect packets.
The packets are forwarded based on the routing table lookup result.
¡ The accessibility of the next hop is unknown.
¡ Traffic redirection redirects packets to the next hop of the unknown state.
2. Create a behavior and enter behavior view.
3. Associate Track with traffic redirection.
redirect next-hop { ipv4-add [ track track-entry-number ] [ ipv4-add [ track track-entry-number ] ] | ipv6-add [ interface-type interface-number ] [ track track-entry-number ] [ ipv6-add [ interface-type interface-number ] [ track track-entry-number ] ] }
By default, no track entry is associated with traffic redirection.
Associating Track with EAA
You can configure EAA track event monitor policies to monitor the positive-to-negative or negative-to-positive state changes of track entries.
· If you specify only one track entry for a policy, EAA triggers the policy when it detects the specified state change on the track entry.
· If you specify multiple track entries for a policy, EAA triggers the policy when it detects the specified state change on the last monitored track entry. For example, if you configure a policy to monitor the positive-to-negative state change of multiple track entries, EAA triggers the policy when the last positive track entry monitored by the policy is changed to the Negative state.
You can set a suppression time for a track event monitor policy. The timer starts when the policy is triggered. The system does not process messages that report the monitored track event until the timer times out.
For more information about EAA, see Network Management and Monitoring Configuration Guide.
2. Create a CLI-defined monitor policy and enter its view, or enter the view of an existing CLI-defined monitor policy.
rtm cli-policy policy-name
3. Configure a track event.
event track track-entry-number-list state { negative | positive } [ suppress-time suppress-time ]
By default, a monitor policy does not monitor any track event.
Task |
Command |
Display information about track entries. |
display track { track-entry-number | all [ negative | positive ] } [ brief ] |
Track configuration examples
As shown in Figure 2:
· Host A requires access to Host B. The default gateway of Host A is 10.1.1.10/24.
· Switch A and Switch B belong to VRRP group 1. The virtual IP address of VRRP group 1 is 10.1.1.10.
Configure VRRP-Track-NQA collaboration to monitor the uplink on the master and meet the following requirements:
· When Switch A operates correctly, Switch A forwards packets from Host A to Host B.
· When NQA detects a fault on the uplink of Switch A, Switch B forwards packets from Host A to Host B.
1. Create VLANs and assign ports to them. Configure the IP address of each VLAN interface, as shown in Figure 2. (Details not shown.)
2. Configure an NQA operation on Switch A:
# Create an NQA operation with administrator name admin and operation tag test.
[SwitchA] nqa entry admin test
# Specify the ICMP echo operation type.
[SwitchA-nqa-admin-test] type icmp-echo
# Specify 10.1.2.2 as the destination address of ICMP echo requests.
[SwitchA-nqa-admin-test-icmp-echo] destination ip 10.1.2.2
# Configure the ICMP echo operation to repeat every 100 milliseconds.
[SwitchA-nqa-admin-test-icmp-echo] frequency 100
# Configure reaction entry 1, specifying that five consecutive probe failures trigger the Track module.
[SwitchA-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trigger-only
[SwitchA-nqa-admin-test-icmp-echo] quit
# Start the NQA operation.
[SwitchA] nqa schedule admin test start-time now lifetime forever
3. On Switch A, configure track entry 1, and associate it with reaction entry 1 of the NQA operation.
[SwitchA] track 1 nqa entry admin test reaction 1
[SwitchA-track-1] quit
4. Configure VRRP on Switch A:
# Specify VRRPv2 to run on VLAN-interface 2.
[SwitchA-Vlan-interface2] vrrp version 2
# Create VRRP group 1, and configure virtual IP address 10.1.1.10 for the group.
[SwitchA-Vlan-interface2] vrrp vrid 1 virtual-ip 10.1.1.10
# Set the priority of Switch A to 110 in VRRP group 1.
[SwitchA-Vlan-interface2] vrrp vrid 1 priority 110
# Set the authentication mode of VRRP group 1 to simple, and the authentication key to hello.
[SwitchA-Vlan-interface2] vrrp vrid 1 authentication-mode simple hello
# Configure the master to send VRRP packets every 500 centiseconds.
[SwitchA-Vlan-interface2] vrrp vrid 1 timer advertise 500
# Configure Switch A to operate in preemptive mode and set the preemption delay to 5000 centiseconds.
[SwitchA-Vlan-interface2] vrrp vrid 1 preempt-mode timer delay 5000
# Associate VRRP group 1 with track entry 1 and decrease the router priority by 30 when the state of track entry 1 changes to Negative.
[SwitchA-Vlan-interface2] vrrp vrid 1 track 1 priority reduced 30
5. Configure VRRP on Switch B:
[SwitchB-Vlan-interface2] vrrp version 2
[SwitchB-Vlan-interface2] vrrp vrid 1 virtual-ip 10.1.1.10
[SwitchB-Vlan-interface2] vrrp vrid 1 authentication-mode simple hello
[SwitchB-Vlan-interface2] vrrp vrid 1 timer advertise 500
# Configure Switch B to operate in preemptive mode and set the preemption delay to 5000 centiseconds.
[SwitchB-Vlan-interface2] vrrp vrid 1 preempt-mode timer delay 5000
# Ping Host B from Host A to verify that Host B is reachable. (Details not shown.)
# Display detailed information about VRRP group 1 on Switch A.
[SwitchA-Vlan-interface2] display vrrp verbose
Running Mode : Standard
Interface Vlan-interface2
VRID : 1 Adver Timer : 500
Admin Status : Up State : Master
Config Pri : 110 Running Pri : 110
Preempt Mode : Yes Delay Time : 5000
Auth Type : Simple Key : ******
Version : 2
Virtual IP : 10.1.1.10
Virtual MAC : 0000-5e00-0101
Master IP : 10.1.1.1
VRRP Track Information:
Track Object : 1 State : Positive Pri Reduced : 30
# Display detailed information about VRRP group 1 on Switch B.
[SwitchB-Vlan-interface2] display vrrp verbose
Admin Status : Up State : Backup
Config Pri : 100 Running Pri : 100
Become Master : 2200ms left
Version : 2
The output shows that in VRRP group 1, Switch A is the master, and Switch B is a backup. Switch A forwards packets from Host A to Host B.
# Disconnect the link between Switch A and Switch C, and verify that Host A can still ping Host B. (Details not shown.)
Config Pri : 110 Running Pri : 80
Version : 2
Master IP : 10.1.1.2
Track Object : 1 State : Negative Pri Reduced : 30
Version : 2
The output shows that Switch A becomes the backup, and Switch B becomes the master. Switch B forwards packets from Host A to Host B.
As shown in Figure 3:
· Switch A and Switch B belong to VRRP group 1. The virtual IP address of VRRP group 1 is 192.168.0.10.
· The default gateway of the hosts in the LAN is 192.168.0.10.
Configure VRRP-Track-BFD (echo mode) collaboration to monitor the master on the backup and meet the following requirements:
· When Switch A operates correctly, the hosts in the LAN access the Internet through Switch A.
· When Switch A fails, the backup (Switch B) can detect the state change of the master through the echo-mode BFD session and become the new master. The hosts in the LAN access the Internet through Switch B.
1. Create VLANs and assign ports to them. Configure the IP address of each VLAN interface, as shown in Figure 3. (Details not shown.)
2. Configure Switch A:
# Create VRRP group 1, and configure virtual IP address 192.168.0.10 for the group.
[SwitchA-Vlan-interface2] vrrp vrid 1 virtual-ip 192.168.0.10
[SwitchA-Vlan-interface2] return
3. Configure Switch B:
# Specify 10.10.10.10 as the source address of BFD echo packets.
[SwitchB] bfd echo-source-ip 10.10.10.10
# Create track entry 1, and associate it with the echo-mode BFD session to verify the reachability of Switch A.
[SwitchB] track 1 bfd echo interface vlan-interface 2 remote ip 192.168.0.101 local ip 192.168.0.102
[SwitchB-track-1] quit
[SwitchB-Vlan-interface2] vrrp vrid 1 virtual-ip 192.168.0.10
# Configure VRRP group 1 to monitor the status of track entry 1.
[SwitchB-Vlan-interface2] vrrp vrid 1 track 1 switchover
[SwitchB-Vlan-interface2] return
<SwitchA> display vrrp verbose
VRID : 1 Adver Timer : 100
Preempt Mode : Yes Delay Time : 0
Auth Type : Not supported
Version : 3
Virtual IP : 192.168.0.10
Master IP : 192.168.0.101
<SwitchB> display vrrp verbose
Version : 3
Track Object : 1 State : Positive Switchover
# Display information about track entry 1 on Switch B.
<SwitchB> display track 1
Track ID: 1
State: Positive
Tracked object type: BFD echo
Notification delay: Positive 0, Negative 0 (in seconds)
Tracked object:
BFD session mode: Echo
Outgoing interface: Vlan-interface2
VPN instance name: --
Remote IP: 192.168.0.101
Local IP: 192.168.0.102
The output shows that when the status of the track entry becomes Positive, Switch A is the master and Switch B is the backup.
# Enable VRRP state debugging and BFD event notification debugging on Switch B.
<SwitchB> terminal debugging
<SwitchB> terminal monitor
<SwitchB> debugging vrrp fsm
<SwitchB> debugging bfd ntfy
# When Switch A fails, the following output is displayed on Switch B.
*Dec 17 14:44:34:142 2019 SwitchB BFD/7/DEBUG: Notify application:TRACK State:DOWN
*Dec 17 14:44:34:144 2019 SwitchB VRRP4/7/FSM:
IPv4 Vlan-interface2 | Virtual Router 1 : Backup --> Master reason: The status of the tracked object changed
# Display detailed information about the VRRP group on Switch B.
Version : 3
Master IP : 192.168.0.102
Track Object : 1 State : Negative Switchover
The output shows that when the echo-mode BFD session detects that Switch A fails, the Track module notifies VRRP to change the status of Switch B to master. The backup can quickly preempt as the master without waiting for a period three times the advertisement interval plus the Skew_Time.
As shown in Figure 4:
Configure VRRP-Track-BFD (control mode) collaboration to monitor the master on the backup and meet the following requirements:
· When Switch A fails, the backup (Switch B) can detect the state change of the master through the control-mode BFD session and become the new master. The hosts in the LAN access the Internet through Switch B.
1. Create VLANs and assign ports to them. Configure the IP address of each VLAN interface, as shown in Figure 4. (Details not shown.)
# Create track entry 1, and associate it with the control-mode BFD session to verify the reachability of Switch B.
[SwitchA] track 1 bfd ctrl interface vlan-interface 2 remote ip 192.168.0.102 local ip 192.168.0.101
# Configure VRRP group 1 to monitor track entry 1 so Switch B can take over as the master once the track entry changes to the Negative state.
# Create track entry 1, and associate it with the control-mode BFD session to verify the reachability of Switch A.
[SwitchB] track 1 bfd ctrl interface vlan-interface 2 remote ip 192.168.0.101 local ip 192.168.0.102
Version : 3
Version : 3
Track ID: 1
State: Positive
Tracked object type: BFD ctrl
Tracked object:
BFD session mode: Ctrl
Version : 3
The output shows that when the control-mode BFD session detects that Switch A fails, the Track module notifies VRRP to change the status of Switch B to master. The backup can quickly preempt as the master without waiting for a period three times the advertisement interval plus the Skew_Time.
As shown in Figure 5:
Configure VRRP-Track-BFD (echo mode) collaboration to monitor the uplink on the master and meet the following requirements:
· When Switch A detects that the uplink is down through the echo-mode BFD session, Switch B can preempt as the master. The hosts in the LAN can access the Internet through Switch B.
1. Create VLANs and assign ports to them. Configure the IP address of each VLAN interface, as shown in Figure 5. (Details not shown.)
[SwitchA] bfd echo-source-ip 10.10.10.10
# Create track entry 1 for the echo-mode BFD session to verify the reachability of the uplink device (1.1.1.2).
[SwitchA] track 1 bfd echo interface vlan-interface 3 remote ip 1.1.1.2 local ip 1.1.1.1
# Create VRRP group 1, and specify 192.168.0.10 as the virtual IP address of the group.
# Associate VRRP group 1 with track entry 1 and decrease the router priority by 20 when the state of track entry 1 changes to Negative.
[SwitchA-Vlan-interface2] vrrp vrid 1 track 1 priority reduced 20
3. On Switch B, create VRRP group 1, and specify 192.168.0.10 as the virtual IP address of the group.
# Display detailed information about the VRRP group on Switch A.
Version : 3
Track Object : 1 State : Positive Pri Reduced : 20
# Display information about track entry 1 on Switch A.
<SwitchA> display track 1
Track ID: 1
State: Positive
Tracked object:
Remote IP: 1.1.1.2
Local IP: 1.1.1.1
Version : 3
The output shows that when the status of track entry 1 becomes Positive, Switch A is the master and Switch B is the backup.
# Display information about track entry 1 when the uplink of Switch A goes down.
Track ID: 1
State: Negative
Tracked object:
Remote IP: 1.1.1.2
Local IP: 1.1.1.1
Config Pri : 110 Running Pri : 90
Version : 3
Track Object : 1 State : Negative Pri Reduced : 20
Version : 3
The output shows that when Switch A detects that the uplink fails through the echo-mode BFD session, it decreases its priority by 20. Switch B then preempts as the master.
As shown in Figure 6:
Configure VRRP-Track-BFD (control mode) collaboration to monitor the uplink on the master and meet the following requirements:
· When Switch A detects that the uplink is down through the control-mode BFD session, Switch B can preempt as the master. The hosts in the LAN can access the Internet through Switch B.
1. Create VLANs and assign ports to them. Configure the IP address of each VLAN interface, as shown in Figure 6. (Details not shown.)
# Create track entry 1 for the control-mode BFD session to monitor the reachability of the uplink device (1.1.1.2).
[SwitchA] track 1 bfd ctrl interface vlan-interface 3 remote ip 1.1.1.2 local ip 1.1.1.1
3. On the uplink device of Switch A, create track entry 1 and associate it with the control-mode BFD session to verify the reachability of the Switch A.
<Master> system-view
[Master] track 1 bfd ctrl interface vlan-interface 3 remote ip 1.1.1.1 local ip 1.1.1.2
4. On Switch B, create VRRP group 1, and specify 192.168.0.10 as the virtual IP address of the group.
Version : 3
Track ID: 1
State: Positive
Tracked object:
Remote IP: 1.1.1.2
Local IP: 1.1.1.1
Version : 3
Track ID: 1
State: Negative
Tracked object:
Remote IP: 1.1.1.2
Local IP: 1.1.1.1
Version : 3
Version : 3
The output shows that when Switch A detects that the uplink fails through the control-mode BFD session, it decreases its priority by 20. Switch B then preempts as the master.
As shown in Figure 7:
· Switch A is the default gateway of the hosts in network 20.1.1.0/24.
· Switch D is the default gateway of the hosts in network 30.1.1.0/24.
· Hosts in the two networks communicate with each other through static routes.
To ensure network availability, configure route backup and static routing-Track-NQA collaboration on Switch A and Switch D as follows:
· On Switch A, assign a higher priority to the static route to 30.1.1.0/24 with next hop Switch B. This route is the master route. The static route to 30.1.1.0/24 with next hop Switch C acts as the backup route. When the master route is unavailable, the backup route takes effect. Switch A forwards packets to 30.1.1.0/24 through Switch C.
· On Switch D, assign a higher priority to the static route to 20.1.1.0/24 with next hop Switch B. This route is the master route. The static route to 20.1.1.0/24 with next hop Switch C acts as the backup route. When the master route is unavailable, the backup route takes effect. Switch D forwards packets to 20.1.1.0/24 through Switch C.
1. Create VLANs and assign ports to them. Configure the IP address of each VLAN interface, as shown in Figure 7. (Details not shown.)
# Configure a static route to 30.1.1.0/24 with next hop 10.1.1.2 and the default priority (60). Associate this static route with track entry 1.
[SwitchA] ip route-static 30.1.1.0 24 10.1.1.2 track 1
# Configure a static route to 30.1.1.0/24 with next hop 10.3.1.3 and priority 80.
[SwitchA] ip route-static 30.1.1.0 24 10.3.1.3 preference 80
# Configure a static route to 10.2.1.4 with next hop 10.1.1.2.
[SwitchA] ip route-static 10.2.1.4 24 10.1.1.2
# Specify 10.2.1.4 as the destination address of the operation.
[SwitchA-nqa-admin-test-icmp-echo] destination ip 10.2.1.4
# Specify 10.1.1.2 as the next hop of the operation.
[SwitchA-nqa-admin-test-icmp-echo] next-hop ip 10.1.1.2
# Configure track entry 1, and associate it with reaction entry 1 of the NQA operation.
# Configure a static route to 30.1.1.0/24 with next hop 10.2.1.4.
[SwitchB] ip route-static 30.1.1.0 24 10.2.1.4
# Configure a static route to 20.1.1.0/24 with next hop 10.1.1.1.
[SwitchB] ip route-static 20.1.1.0 24 10.1.1.1
4. Configure Switch C:
# Configure a static route to 30.1.1.0/24 with next hop 10.4.1.4.
[SwitchC] ip route-static 30.1.1.0 24 10.4.1.4
# Configure a static route to 20.1.1.0/24 with next hop 10.3.1.1.
[SwitchC] ip route-static 20.1.1.0 24 10.3.1.1
5. Configure Switch D:
# Configure a static route to 20.1.1.0/24 with next hop 10.2.1.2 and the default priority (60). Associate this static route with track entry 1.
<SwitchD> system-view
[SwitchD] ip route-static 20.1.1.0 24 10.2.1.2 track 1
# Configure a static route to 20.1.1.0/24 with next hop 10.4.1.3 and priority 80.
[SwitchD] ip route-static 20.1.1.0 24 10.4.1.3 preference 80
# Configure a static route to 10.1.1.1 with next hop 10.2.1.2.
[SwitchD] ip route-static 10.1.1.1 24 10.2.1.2
[SwitchD] nqa entry admin test
[SwitchD-nqa-admin-test] type icmp-echo
# Specify 10.1.1.1 as the destination address of the operation.
[SwitchD-nqa-admin-test-icmp-echo] destination ip 10.1.1.1
# Specify 10.2.1.2 as the next hop of the operation.
[SwitchD-nqa-admin-test-icmp-echo] next-hop ip 10.2.1.2
[SwitchD-nqa-admin-test-icmp-echo] frequency 100
[SwitchD-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trigger-only
[SwitchD-nqa-admin-test-icmp-echo] quit
[SwitchD] nqa schedule admin test start-time now lifetime forever
[SwitchD] track 1 nqa entry admin test reaction 1
[SwitchD-track-1] quit
# Display information about the track entry on Switch A.
[SwitchA] display track all
Track ID: 1
State: Positive
Tracked object type: NQA
Tracked object:
NQA entry: admin test
Reaction: 1
Remote IP/URL: 10.2.1.4
Local IP:--
Interface:--
The output shows that the status of the track entry is Positive, indicating that the NQA operation has succeeded and the master route is available.
# Display the routing table of Switch A.
Destinations : 10 Routes : 10
10.1.1.0/24 Direct 0 0 10.1.1.1 Vlan2
10.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
10.2.1.0/24 Static 60 0 10.1.1.2 Vlan2
10.3.1.0/24 Direct 0 0 10.3.1.1 Vlan3
10.3.1.1/32 Direct 0 0 127.0.0.1 InLoop0
20.1.1.0/24 Direct 0 0 20.1.1.1 Vlan6
20.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
30.1.1.0/24 Static 60 0 10.1.1.2 Vlan2
The output shows that Switch A forwards packets to 30.1.1.0/24 through Switch B.
# Remove the IP address of interface VLAN-interface 2 on Switch B.
[SwitchB-Vlan-interface2] undo ip address
Track ID: 1
State: Negative
Tracked object:
Reaction: 1
Local IP:--
Interface:--
The output shows that the status of the track entry is Negative, indicating that the NQA operation has failed and the master route is unavailable.
30.1.1.0/24 Static 80 0 10.3.1.3 Vlan3
The output shows that Switch A forwards packets to 30.1.1.0/24 through Switch C. The backup static route has taken effect.
# Verify that hosts in 20.1.1.0/24 can communicate with the hosts in 30.1.1.0/24 when the master route fails.
[SwitchA] ping -a 20.1.1.1 30.1.1.1
Ping 30.1.1.1: 56 data bytes, press CTRL_C to break
Reply from 30.1.1.1: bytes=56 Sequence=1 ttl=254 time=2 ms
Reply from 30.1.1.1: bytes=56 Sequence=2 ttl=254 time=1 ms
Reply from 30.1.1.1: bytes=56 Sequence=3 ttl=254 time=1 ms
Reply from 30.1.1.1: bytes=56 Sequence=4 ttl=254 time=2 ms
Reply from 30.1.1.1: bytes=56 Sequence=5 ttl=254 time=1 ms
--- Ping statistics for 30.1.1.1 ---
5 packet(s) transmitted, 5 packet(s) received, 0.00% packet loss
round-trip min/avg/max/std-dev = 1/1/2/1 ms
# Verify that the hosts in 30.1.1.0/24 can communicate with the hosts in 20.1.1.0/24 when the master route fails.
[SwitchB] ping -a 30.1.1.1 20.1.1.1
Ping 20.1.1.1: 56 data bytes, press CTRL_C to break
Reply from 20.1.1.1: bytes=56 Sequence=1 ttl=254 time=2 ms
Reply from 20.1.1.1: bytes=56 Sequence=2 ttl=254 time=1 ms
Reply from 20.1.1.1: bytes=56 Sequence=3 ttl=254 time=1 ms
Reply from 20.1.1.1: bytes=56 Sequence=4 ttl=254 time=1 ms
Reply from 20.1.1.1: bytes=56 Sequence=5 ttl=254 time=1 ms
--- Ping statistics for 20.1.1.1 ---
As shown in Figure 8:
· Switch B is the default gateway of the hosts in network 30.1.1.0/24.
To ensure network availability, configure route backup and static routing-Track-BFD (echo mode) collaboration on Switch A and Switch B as follows:
· On Switch A, assign a higher priority to the static route to 30.1.1.0/24 with next hop Switch B. This route is the master route. The static route to 30.1.1.0/24 with next hop Switch C acts as the backup route. When the master route is unavailable, the echo-mode BFD session can quickly detect the route failure to make the backup route take effect.
· On Switch B, assign a higher priority to the static route to 20.1.1.0/24 with next hop Switch A. This route is the master route. The static route to 20.1.1.0/24 with next hop Switch C acts as the backup route. When the master route is unavailable, the echo-mode BFD session can quickly detect the route failure to make the backup route take effect.
1. Create VLANs and assign ports to them. Configure the IP address of each VLAN interface, as shown in Figure 8. (Details not shown.)
# Configure a static route to 30.1.1.0/24 with next hop 10.2.1.2 and the default priority (60). Associate this static route with track entry 1.
[SwitchA] ip route-static 30.1.1.0 24 10.2.1.2 track 1
# Configure track entry 1, and associate it with the echo-mode BFD session to verify the connectivity between Switch A and Switch B.
[SwitchA] track 1 bfd echo interface vlan-interface 2 remote ip 10.2.1.2 local ip 10.2.1.1
# Configure a static route to 20.1.1.0/24 with next hop 10.2.1.1 and the default priority (60). Associate this static route with track entry 1.
[SwitchB] ip route-static 20.1.1.0 24 10.2.1.1 track 1
[SwitchB] ip route-static 20.1.1.0 24 10.4.1.3 preference 80
# Specify 1.1.1.1 as the source address of BFD echo packets.
[SwitchB] bfd echo-source-ip 1.1.1.1
# Configure track entry 1, and associate it with the echo-mode BFD session to verify the connectivity between Switch B and Switch A.
[SwitchB] track 1 bfd echo interface vlan-interface 2 remote ip 10.2.1.1 local ip 10.2.1.2
# Configure a static route to 30.1.1.0/24 with next hop 10.4.1.2.
[SwitchC] ip route-static 30.1.1.0 24 10.4.1.2
Track ID: 1
State: Positive
Tracked object:
Remote IP: 10.2.1.2
Local IP: 10.2.1.1
The output shows that the status of the track entry is Positive, indicating that next hop 10.2.1.2 is reachable.
Destinations : 9 Routes : 9
10.2.1.0/24 Direct 0 0 10.2.1.1 Vlan2
10.2.1.1/32 Direct 0 0 127.0.0.1 InLoop0
20.1.1.0/24 Direct 0 0 20.1.1.1 Vlan5
30.1.1.0/24 Static 60 0 10.2.1.2 Vlan2
The output shows that Switch A forwards packets to 30.1.1.0/24 through Switch B. The master static route has taken effect.
# Remove the IP address of VLAN-interface 2 on Switch B.
Track ID: 1
State: Negative
Tracked object:
Remote IP: 10.2.1.2
Local IP: 10.2.1.1
The output shows that the status of the track entry is Negative, indicating that next hop 10.2.1.2 is unreachable.
# Verify that the hosts in 20.1.1.0/24 can communicate with the hosts in 30.1.1.0/24 when the master route fails.
# Verify that the hosts in 30.1.1.0/24 can still communicate with the hosts in 20.1.1.0/24 when the master route fails.
As shown in Figure 9:
To ensure network availability, configure route backup and static routing-Track-BFD (control mode) collaboration on Switch A and Switch B as follows:
· On Switch A, assign a higher priority to the static route to 30.1.1.0/24 with next hop Switch B. This route is the master route. The static route to 30.1.1.0/24 with next hop Switch C acts as the backup route. When the master route is unavailable, the control-mode BFD session can quickly detect the route failure to make the backup route take effect.
· On Switch B, assign a higher priority to the static route to 20.1.1.0/24 with next hop Switch A. This route is the master route. The static route to 20.1.1.0/24 with next hop Switch C acts as the backup route. When the master route is unavailable, the control-mode BFD session can quickly detect the route failure to make the backup route take effect.
1. Create VLANs and assign ports to them. Configure the IP address of each VLAN interface, as shown in Figure 9. (Details not shown.)
# Configure track entry 1, and associate it with the control-mode BFD session to verify the connectivity between Switch A and Switch B.
[SwitchA] track 1 bfd ctrl interface vlan-interface 2 remote ip 10.2.1.2 local ip 10.2.1.1
# Configure track entry 1, and associate it with the control-mode BFD session to verify the connectivity between Switch B and Switch A.
[SwitchB] track 1 bfd ctrl interface vlan-interface 2 remote ip 10.2.1.1 local ip 10.2.1.2
Track ID: 1
State: Positive
Tracked object:
Remote IP: 10.2.1.2
Local IP: 10.2.1.1
Track ID: 1
State: Negative
Tracked object:
Remote IP: 10.2.1.2
Local IP: 10.2.1.1
As shown in Figure 10:
Configure VRRP-Track-interface management collaboration to monitor the uplink interface on the master and meet the following requirements:
· When VRRP detects a fault on the uplink interface of Switch A through the interface management module, Switch B forwards packets from Host A to Host B.
1. Create VLANs and assign ports to them. Configure the IP address of each VLAN interface, as shown in Figure 10. (Details not shown.)
# Configure track entry 1 and associate it with the link status of the uplink interface VLAN-interface 3.
[SwitchA] track 1 interface vlan-interface 3
# Create VRRP group 1 and configure virtual IP address 10.1.1.10 for the group.
3. On Switch B, create VRRP group 1, and configure virtual IP address 10.1.1.10 for the group.
Version : 3
Version : 3
# Shut down the uplink interface VLAN-interface 3 on Switch A.
[SwitchA-Vlan-interface2] interface vlan-interface 3
[SwitchA-Vlan-interface3] shutdown
[SwitchA-Vlan-interface3] display vrrp verbose
Version : 3
Version : 3
As shown in Figure 11:
· BGP peer relationships are established between Switch A and Switch C and between Switch B and Switch D. Switch C and Switch D advertise the default route 0.0.0.0/0 to Switch A and Switch B.
Configure VRRP-Track-route management collaboration to meet the following requirements:
· When VRRP detects the removal of the default route from the routing table of Switch A through route management, Switch B forwards packets from Host A to Host B.
1. Configure the IP address of each interface, as shown in Figure 11. (Details not shown.)
2. Establish an IBGP peer relationship between Switch A and Switch C, and configure Switch C to advertise the default route 0.0.0.0/0 to Switch A.
[SwitchA] bgp 100
[SwitchA-bgp-default] peer 10.1.2.2 as-number 100
[SwitchA-bgp-default] address-family ipv4
[SwitchC] bgp 100
[SwitchC-bgp-default] peer 10.1.2.1 as-number 100
[SwitchC-bgp-default] address-family ipv4
[SwitchC-bgp-default-ipv4] peer 10.1.2.1 default-route-advertise
3. Configure Switch B and Switch D in the same way Switch A and Switch C are configured. (Details not shown.)
4. Configure Track and VRRP on Switch A:
# Configure track entry 1, and associate it with the default route 0.0.0.0/0.
[SwitchA] track 1 ip route 0.0.0.0 0.0.0.0 reachability
# Associate VRRP group 1 with track entry 1 and decrease the Switch priority by 30 when the state of track entry 1 changes to Negative.
5. On Switch B, create VRRP group 1, and configure virtual IP address 10.1.1.10 for the group.
[SwitchA] display vrrp verbose
Version : 3
[SwitchB] display vrrp verbose
Version : 3
The output shows that in VRRP group 1, Switch A is the master and Switch B is a backup. Switch A forwards packets from Host A to Host B.
# Disable Switch C from exchanging routing information with Switch A so that the default route 0.0.0.0/0 is removed from the routing table of Switch A.
[SwitchC-bgp-default-ipv4] undo peer 10.1.2.1 enable
Version : 3
Version : 3
Network requirements
As shown in Figure 12:
· Device A is the default gateway of the hosts in network 20.1.1.0/24.
· Device B is the default gateway of the hosts in network 30.1.1.0/24.
To ensure network availability, configure route backup and static routing-Track-LLDP collaboration on Device A and Device B as follows:
· On Device A, assign a higher priority to the static route to 30.1.1.0/24 with next hop Device B. This route is the master route. The static route to 30.1.1.0/24 with next hop Device C acts as the backup route. When the master route is unavailable, the backup route takes effect. Device A forwards packets destined for 30.1.1.0/24 to Device C.
· On Device B, assign a higher priority to the static route to 20.1.1.0/24 with next hop Device A. This route is the master route. The static route to 20.1.1.0/24 with next hop Device C acts as the backup route. When the master route is unavailable, the backup route takes effect. Device B forwards packets destined for 20.1.1.0/24 to Device C.
1. Configure the IP address of each interface, as shown in Figure 12. (Details not shown.)
2. Configure Device A:
[DeviceA] ip route-static 30.1.1.0 24 10.2.1.2 track 1
[DeviceA] ip route-static 30.1.1.0 24 10.3.1.3 preference 80
# Enable LLDP globally.
[DeviceA] lldp global enable
# Enable LLDP on Ten-GigabitEthernet 1/0/1. (This step is optional because LLDP is enabled on the port by default.)
[DeviceA-Ten-GigabitEthernet1/0/1] lldp enable
# Configure track entry 1 and associate it with the availability of the neighbor for LLDP interface Gigabitethernet 1/0/1.
[DeviceA] track 1 lldp neighbor interface ten-gigabitethernet 1/0/1
[DeviceA-track-1] quit
3. Configure Device B:
[DeviceB] ip route-static 20.1.1.0 24 10.2.1.1 track 1
[DeviceB] ip route-static 20.1.1.0 24 10.4.1.3 preference 80
[DeviceB] lldp global enable
[DeviceB-Ten-GigabitEthernet1/0/1] lldp enable
# Configure track entry 1 and associate it with the availability of the neighbor for LLDP interface Ten-GigabitEthernet 1/0/1.
[DeviceB] track 1 lldp neighbor interface ten-gigabitethernet 1/0/1
[DeviceB-track-1] quit
4. Configure Device C:
<DeviceC> system-view
[DeviceC] ip route-static 30.1.1.0 24 10.4.1.2
[DeviceC] ip route-static 20.1.1.0 24 10.3.1.1
# Display track entry information on Device A.
[DeviceA] display track all
Track ID: 1
State: Positive
Tracked object type: LLDP
Tracked object:
LLDP interface: Ten-GigabitEthernet1/0/1
The output shows that the status of track entry 1 is Positive, indicating that the neighbor of LLDP interface Ten-GigabitEthernet 1/0/1 is available. The master route takes effect.
# Display the routing table of Device A.
[DeviceA] display ip routing-table
10.2.1.0/24 Direct 0 0 10.2.1.1 XGE1/0/1
10.3.1.0/24 Direct 0 0 10.3.1.1 XGE1/0/2
20.1.1.0/24 Direct 0 0 20.1.1.1 XGE1/0/3
30.1.1.0/24 Static 60 0 10.2.1.2 XGE1/0/1
The output shows that Device A forwards packets to 30.1.1.0/24 through Device B.
# On Device B, disable LLDP on Ten-GigabitEthernet 1/0/1.
[DeviceB-Ten-GigabitEthernet1/0/1] undo lldp enable
Track ID: 1
State: Negative
Tracked object:
The output shows that the status of track entry 1 is Negative, indicating that the neighbor of LLDP interface Ten-GigabitEthernet 1/0/1 is unavailable. The master route fails.
30.1.1.0/24 Static 80 0 10.3.1.3 XGE1/0/2
The output shows that Device A forwards packets destined for 30.1.1.0/24 to Device C. The backup static route has taken effect.
[DeviceA] ping -a 20.1.1.1 30.1.1.1
[DeviceB] ping -a 30.1.1.1 20.1.1.1
