- 13-High Availability Configuration Guide
- 01-Interface backup configuration
- 02-Ethernet OAM configuration
- 03-CFD configuration
- 04-DLDP configuration
- 05-Monitor Link configuration
- 06-Layer 3 connection keepalive configuration
- 07-Error code detection configuration
- 08-VRRP configuration
- 09-VSRP configuration
- 10-Failover group configuration
- 11-BFD configuration
- 12-Track configuration
- 13-RBM-based hot backup configuration
10-Failover group configuration | 61.89 KB |
Failover group operating mechanism
Restrictions and guidelines: failover group configuration
Display and maintenance commands for failover groups
Configuring failover groups
About failover groups
A failover group backs up services (such as NAT) between two CPUs to ensure service continuity. A CPU is called a node in the failover group feature.
A failover group contains one primary node and one secondary node. When a failover group is used by a service module, the primary node processes services and backs up service data to the secondary node. The secondary node does not process services, but it takes over the services when the primary node fails. When the primary node is recovered, traffic is switched back to the primary node.
For more information about the service modules that can use a failover group, see the configuration guides for specific modules.
Failover group types
A failover group can be automatically created by the system or manually configured. The device supports only manual failover groups.
Manual failover group
A manual failover group is manually created, to which you can bind one primary node and one secondary node.
Backup types
You can deployment service failover by using one, two, or multiple failover groups, as follows:
· One failover group for two nodes—Assign the two nodes to one failover group as the primary and secondary nodes. In this deployment, only one node processes services.
· Two failover groups for two nodes—Assign the primary node and the secondary node in one failover group to the other failover group as the secondary node and the primary node. In this deployment, both nodes process services and back up service data to each other.
· Multiple failover groups for more than two nodes—Include the following deployments:
¡ Centralized backup, in which one secondary node backs up multiple primary nodes. In this deployment, configure different primary nodes but the same secondary node in different failover groups.
¡ Load-balanced backup, in which a node uses one node for backup and provides backup for another node. In this deployment, you must make sure each failover group has a unique pair of nodes, avoiding using any two nodes to back up each other. For example, to deploy load-balanced backup across three nodes (nodes 1, 2, and 3), create three failover groups. Then, configure nodes 1 and 2, nodes 2 and 3, and nodes 3 and 1 as the primary and secondary nodes in the three failover groups.
As a best practice, assign two CPUs with similar performance on different cards to a failover group. This operation ensures service continuity after a primary and secondary node switchover.
Configuring a failover group
1. Enter system view.
2. Create a failover group and enter its view.
failover group group-name
By default, one or multiple automatic failover groups prefixed with AutoBackup exist, and no manual failover groups exist.
3. Assign a node to the failover group.
In standalone mode:
bind slot slot-number { primary | secondary }
In IRF mode:
bind chassis chassis-number slot slot-number { primary | secondary }
By default, a failover group does not contain nodes.
The primary and secondary nodes in a failover group cannot be the same one. Different failover groups cannot share the same primary node.
Task |
Command |
Display failover group information. |
display failover group [ group-name ] |
