01-HH3C-POSA-MIB | 160.69 KB |
HH3C-POSA-MIB
About this MIB
Use this MIB to obtain basic information, collect alarms, and configure parameters for a POS access device.
MIB file name
hh3c-posa.mib
Notifications
hh3cPosaServerStatusChange
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.92.3.0.1 |
POS access service status change. |
Informational |
Warning |
N/A |
ON |
Notification triggers
This notification is generated when the POS access service is enabled or disabled.
System impact
With the POS access service enabled, POS transactions can be processed. POS transactions cannot be processed if the POS access service is disabled.
Status control
ON
· CLI: Use the snmp-agent trap enable posa server-state-change command.
· MIB: Set hh3cPosaSrvStateChangeTrapEnable to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable posa server-state-change command.
· MIB: Set hh3cPosaSrvStateChangeTrapEnable to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.92.1.1 (hh3cPosaServerEnable) |
Enabling status of the POS access service. |
N/A |
INTEGER |
disabled(1), enabled(2) |
Recommended action
No action is required because the router runs correctly.
hh3cPosaAppAvailChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.92.3.0.2 |
State change of a POS application template. |
Informational |
Warning |
N/A |
ON |
This notification might be generated when the following events occur:
· The router is disconnected from the FEP.
· The connection between the router and the FEP is established.
· The interface through which the router connects to the FEP is down or up.
System impact
The POS transaction being processed cannot be processed correctly, and the link between the router and the FEP is disconnected.
Status control
ON
· CLI: Use the snmp-agent trap enable posa app-state-change command.
· MIB: Set hh3cPosaAppStateChangeTrapEnable to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable posa app-state-change command.
· MIB: Set hh3cPosaAppStateChangeTrapEnable to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.92.2.1.1.1 (hh3cPosaAppID) |
ID of a POS application template. |
hh3cPosaAppID |
Integer32 |
1..1024 |
1.3.6.1.4.1.25506.2.92.3.1.1 (hh3cPosaAppStateChangeObject) |
Status of the POS application template. |
N/A |
INTEGER |
available(1), unavailable(2) |
Recommended action
To resolve this issue:
1. Verify that the router connects to the FEP correctly.
2. If the issue persists, collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
hh3cPosaTerminalHangUp
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.92.3.0.3 |
POS terminal hangup. |
Informational |
Warning |
N/A |
ON |
This notification is generated when a POS application template terminates the POS connection established through an FCM interface.
System impact
No impact on services.
Status control
ON
· CLI: Use the snmp-agent trap enable posa terminal-hangup command.
· MIB: Set hh3cPosaTerminalHangUpTrapEnable to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable posa terminal-hangup command.
· MIB: Set hh3cPosaTerminalHangUpTrapEnable to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.2.1.2.2.1.1 (ifIndex) |
Index of the interface through which the POS terminal connects to the router. |
ifIndex |
InterfaceIndex |
Integer32(1..2147483647) |
1.3.6.1.2.1.2.2.1.2 (ifDescr) |
Name of the interface through which the POS terminal connects to the router. |
ifIndex |
DisplayString |
OCTET STRING (SIZE (0..255)) |
1.3.6.1.4.1.25506.2.92.2.10.1.1 (hh3cPosaCallerStatCallerID) |
POS terminal caller ID. |
hh3cPosaCallerStatCallerID |
OCTET STRING |
OCTET STRING(SIZE (0..64)) |
Recommended action
hh3cPosaFcmLinkNegoFailed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.92.3.0.4 |
Negotiation failure on the FCM link layer |
Informational |
Warning |
N/A |
ON |
This notification is generated when the link layer negotiation is failed between the POS terminal and router through an FCM interface.
System impact
POS transactions will be unavailable.
Status control
ON
· CLI: Use the snmp-agent trap enable posa fcm-link-failure command.
· MIB: Set hh3cPosaFcmLnkNegoFailTrapEnable to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable posa fcm-link-failure command.
· MIB: Set hh3cPosaFcmLnkNegoFailTrapEnable to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
ifIndex |
InterfaceIndex |
ifIndex |
DisplayString |
OCTET STRING |
Recommended action
1. Verify that the FCM interface is configured correctly.
hh3cPosaFcmPhyNegoFailed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.92.3.0.5 |
Negotiation failure on the FCM physical layer. |
Informational |
Warning |
N/A |
ON |
This notification is generated when the physical layer negotiation is failed between the POS terminal and router through an FCM interface.
System impact
Status control
ON
· CLI: Use the snmp-agent trap enable posa fcm-physical-failure command.
· MIB: Set hh3cPosaFcmPhyNegoFailTrapEnable to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable posa fcm-physical-failure command.
· MIB: Set hh3cPosaFcmPhyNegoFailTrapEnable to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
ifIndex |
InterfaceIndex |
ifIndex |
DisplayString |
OCTET STRING |
Recommended action
hh3cPosaTcpConnectionExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.92.3.0.6 |
TCP concurrent connections exceeding the threshold. |
Informational |
Major |
N/A |
ON |
This notification is generated when the number of concurrent TCP connections exceeds the threshold.
System impact
When the number of concurrent TCP connections reaches the threshold, subsequent POS transactions might fail.
Status control
ON
· CLI: Use the snmp-agent trap enable posa tcp-connection-exceed command.
· MIB: Set hh3cPosaTcpConnectionTrapEnable to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable posa tcp-connection-exceed command.
· MIB: Set hh3cPosaTcpConnectionTrapEnable to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.92.1.12 (hh3cPosaTcpConnectionThreshold) |
TCP concurrent connection threshold. |
N/A |
Integer32 |
1..4096 |
Recommended action
1. Verify that the TCP concurrent connection threshold is set to a reasonable value.
2. Execute the posa connection-threshold terminal command to increase the TCP concurrent connection threshold.
3. If the issue persists, collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
hh3cPosaFcmConnectionExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.92.3.0.7 |
FCM concurrent connections exceeding the threshold. |
Informational |
Warning |
N/A |
ON |
This notification is generated when the number of concurrent FCM connections exceeds the threshold.
System impact
When the number of concurrent FCM connections reaches the threshold, subsequent POS transactions might fail.
Status control
ON
· CLI: Use the snmp-agent trap enable posa fcm-connection-exceed command.
· MIB: Set hh3cPosaFcmConnectionTrapEnable to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable posa fcm-connection-exceed command.
· MIB: Set hh3cPosaFcmConnectionTrapEnable to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.92.1.13 (hh3cPosaFcmConnectionThreshold) |
FCM concurrent connection threshold. |
N/A |
Integer32 |
1..1024 |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
1. Verify that the FCM concurrent connection threshold is set to a reasonable value.
2. Execute the posa connection-threshold terminal command to increase the FCM concurrent connection threshold.
hh3cPosaTcpTradeExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.92.3.0.8 |
TCP concurrent transactions exceeding the threshold. |
Informational |
Major |
N/A |
ON |
This notification is generated when the number of concurrent TCP transactions over a TCP connection exceeds the threshold.
System impact
Subsequent POS transactions might fail on the TCP connection.
Status control
ON
· CLI: Use the snmp-agent trap enable posa tcp-trade-exceed command.
· MIB: Set hh3cPosaTcpTradeTrapEnable to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable posa tcp-trade-exceed command.
· MIB: Set hh3cPosaTcpTradeTrapEnable to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.92.1.16 (hh3cPosaTcpTradeLimit) |
TCP concurrent transaction threshold over a TCP connection. |
N/A |
Integer32 |
0..65535 |
1.3.6.1.4.1.25506.2.92.2.2.1.1 (hh3cPosaTerminalID) |
ID of a POS terminal template, which uniquely identifies the POS terminal. |
hh3cPosaTerminalID |
Integer32 |
1..1024 |
Recommended action
1. Verify that the TCP concurrent transaction threshold is set to a reasonable value.
hh3cPosaTradeSuccessFalling
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.92.3.0.9 |
Transaction success rate on an FEP dropping below the alarm threshold. |
Informational |
Warning |
N/A |
ON |
· Failures occur on the FEP.
· Packet loss occurs due to network errors between the router and the FEP.
· The router suffers from network attacks.
System impact
Status control
ON
· CLI: Use the snmp-agent trap enable posa trade-failing-enable command.
· MIB: Set hh3cPosaTradeSuccessFallingTrapEnable to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable posa trade-failing-enable command.
· MIB: Set hh3cPosaTradeSuccessFallingTrapEnable to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.92.2.11.1.1 (hh3cPosaNiiStatIndex) |
TPDU destination address for an FEP. |
hh3cPosaNiiStatIndex |
OCTET STRING |
OCTET STRING(SIZE (4)) |
1.3.6.1.4.1.25506.2.92.1.20 (hh3cPosaTradeSuccessFallingThreshold) |
Alarm threshold for transaction success rate on an FEP. |
N/A |
Integer32 |
1..99 |
Recommended action
1. Verify that the low alarm threshold for transaction success rate is set to a reasonable value.
2. Execute the posa trade-falling-threshold command to decrease the alarm threshold for transaction success rate.
hh3cPosaE1DailFalling
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.92.3.0.10 |
Dialup success rate on an E1POS interface dropping below the alarm threshold. |
Informational |
Major |
N/A |
ON |
· Packet loss and network latency occur in the POS connection link in FCM dial-up access mode.
System impact
Status control
ON
· CLI: Use the snmp-agent trap enable posa e1-dialing-falling command.
· MIB: Set hh3cPosaE1DailFallingTrapEnable to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable posa e1-dialing-falling command.
· MIB: Set hh3cPosaE1DailFallingTrapEnable to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
ifIndex |
InterfaceIndex |
ifIndex |
DisplayString |
1.3.6.1.4.1.25506.2.92.1.22 (hh3cPosaE1DialFallingThreshold) |
Alarm threshold for dialup success rate on an E1POS interface. |
N/A |
Integer32 |
1..99 |
Recommended action
1. Verify that the alarm threshold for dialup success rate is set to a reasonable value.
2. Execute the posa e1-dial-falling-threshold command to decrease the alarm threshold for dialup success rate.
hh3cPosaFcmTradeAbnormal
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.92.3.0.11 |
Transaction anomaly on an FCM interface. |
Informational |
Warning |
N/A |
ON |
This notification is generated when anomalies occur on the link between the POS terminal and the router.
System impact
POS transactions fail on the POS terminal.
Status control
ON
· CLI: Use the snmp-agent trap enable posa fcm-trade-abnormal command.
OFF
· CLI: Use the undo snmp-agent trap enable posa fcm-trade-abnormal command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
ifIndex |
InterfaceIndex |
ifIndex |
DisplayString |
OCTET STRING |
Recommended action
1. Verify that the link between the POS terminal and the router is normal.
