05-Layer 2—LAN Switching Configuration Guide
HomeSupportSwitchesS12500R SeriesConfigure & DeployConfiguration GuidesH3C S12500R Switch Router Series Configuration Guides(R52xx)-6W10205-Layer 2—LAN Switching Configuration Guide
12-Service loopback group configuration
12-Service loopback group configuration 56.81 KB
Configuring service loopback groups
About service loopback groups
A service loopback group contains one or multiple Ethernet ports for looping packets sent out by the device back to the device. This feature must work with other features, such as GRE. Member ports in a service loopback group are load balanced.
A service loopback group provides both unicast and multicast tunnel services.
Restrictions and guidelines: Service loopback group configuration
When you add member ports to a service loopback group, follow these restrictions and guidelines:
·     Make sure the ports support the service type of the service loopback group and are not members of any other service loopback group.
When you apply service loopback groups to features, follow these restrictions and guidelines:
·     One service loopback group can be used by multiple features.
·     Do not delete a service loopback group that is being used by a feature.
Configuring a service loopback group
2.     Create a service loopback group and specify its service type.
service-loopback group group-id type { multicast-tunnel | tunnel } *
3.     Enter Layer 2 Ethernet interface view.
4.     Assign the port to the service loopback group.
port service-loopback group group-id
By default, a port does not belong to a service loopback group.
You can add a maximum of 256 ports to a service loopback group.
CAUTION
CAUTION:
·     The configuration on a port is removed when it is assigned to a service loopback group. Make sure you fully understand the impact on your network when you assign a port to a service loopback group.
·     For correct traffic processing, make sure a service loopback group has a minimum of one member port when it is being used by a feature.
Verifying and maintaining service loopback groups
To display information about service loopback groups, execute the following command in any view:
display service-loopback group [ group-id ]
Service loopback group configuration examples
Example: Configuring a service loopback group
All Ethernet ports on the device support the tunnel service. Assign HundredGigE 1/0/1 through HundredGigE 1/0/3 to a service loopback group to loop GRE packets sent out by the device back to the device.
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
# Create service loopback group 1, and specify its service type as tunnel.
[Sysname] service-loopback group 1 type tunnel
# Assign HundredGigE 1/0/1 through HundredGigE 1/0/3 to service loopback group 1.
[Sysname-HundredGigE1/0/1] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y [Sysname-HundredGigE1/0/1] quit
[Sysname] interface hundredgige 1/0/2
[Sysname-HundredGigE1/0/2] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y [Sysname-HundredGigE1/0/2] quit
[Sysname] interface hundredgige 1/0/3
[Sysname-HundredGigE1/0/3] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y [Sysname-HundredGigE1/0/3] quit
# Create the interface Tunnel 1 and set it to GRE mode. The interface will automatically use service loopback group 1.
[Sysname] interface tunnel 1 mode gre
[Sysname-Tunnel1]
