14-Security Command Reference
HomeSupportWirelessWA6500 Series Access PointsReference GuidesCommand ReferencesH3C WA6500A Series Access Points Cloud Mode Command References(R2605P09)-6W10014-Security Command Reference
02-Time range commands
02-Time range commands 84.04 KB
Time range commands
display time-range
Use display time-range to display time range configuration and status.
display time-range { time-range-name | all }
time-range-name: Specifies a time range name, a case-insensitive string of 1 to 63 characters.
all: Displays the configuration and status of all existing time ranges.
If a time range in the display current-configuration command contains only the hour and minute, the second is 0.
# Display the configuration and status of time range t4.
<Sysname> display time-range t4
Current time is 17:12:34 11/23/2010 Tuesday
Time-range : t4 (Inactive)
 10:00 to 12:00 Mon
 14:00 to 16:00 Wed
 from 00:00:00 1/1/2011 to 00:00:00 1/1/2012
 from 00:00:00 6/1/2011 to 00:00:00 7/1/2011
# Display the configuration and status of all existing time ranges.
<Sysname> display time-range all
Current time is 17:23:41 6/28/2021 Monday
Time-range: aa (Inactive)
 Yundi Alias:AA Tenant: aa
 Monthly 12:00 1st to 13:00 11th
 from 00:00:00 6/28/2021 to 00:00:00 31/12/2021
Time-range: ee (Inactive)
 Yundi Alias:BBB Tenant: bb
 Description:aaa
Time-range: bb (Inactive)
 Yundi Alias:BB Tenant: bb
 Weekly 13:00 Mon to 13:11 Fri
Current time
Current system time.
Time-range
Configuration and status of the time range, including its name, status (active or inactive), and start time and end time.
Alias
Alias of the time range.
time-range
Use time-range to create or edit a time range.
Use undo time-range to delete a time range or a statement in the time range.
time-range time-range-name { { monthly | weekly } start-day start-time to end-day end-time [ from time1 date1 ] [ to time2 date2 ] | start-time to end-time [ days | monthly { date1 [ to date2] } &<1-31> ] *  [ from time1 date1 ] [ to time2 date2 ] | from time1 date1 [ to time2 date2 ] | to time2 date2 }
undo time-range time-range-name [ { monthly | weekly } start-day start-time to end-day end-time [ from time1 date1 ] [ to time2 date2 ] | start-time to end-time [ days | monthly { date1 [ to date2] } &<1-31> ] *  [ from time1 date1 ] [ to time2 date2 ] | from time1 date1 [ to time2 date2 ] | to time2 date2 ]
No time ranges exist.
time-range-name: Specifies a time range name. The name is a case-insensitive string of 1 to 63 characters. To avoid confusion, it cannot be all.
monthly start-day start-time to end-day end-time: Specifies a monthly time range statement. The start-day argument is the start date, and the end-day argument is the end date. The value ranges for the start-day and end-day arguments are both 1 to 31. The end date cannot be smaller than the start date. Both start-time and end-time are in hh:mm or hh:mm:ss format (24-hour clock). The value ranges for start-time and end-time are both 00:00:00 to 24:00:00. If the start date and end date are the same day, the end time must be greater than the start time.
weekly start-day start-time to end-day end-time: Specifies a weekly time range statement.
·     The start-day argument is the start day, and the end-day argument is the end day.
¡     A digit in the range of 0 to 6, for Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, and Saturday.
¡     A day of a week in abbreviated words: Sun, Mon, Tue, Wed, Thu, Fri, and Sat.
·     The value ranges for the start-day and end-day arguments are both 1 to 31. The end date cannot be smaller than the start date. Both start-time and end-time are in hh:mm or hh:mm:ss format (24-hour clock). The value ranges for start-time and end-time are both 00:00:00 to 24:00:00. If the start date and end date are the same day, the end time must be greater than the start time.
start-time to end-time: Specifies a daily time range statement. Both start-time and end-time are in hh:mm or hh:mm:ss format (24-hour clock). The value is in the range of 00:00:00 to 23:59:59 for the start time, and 00:00:00 to 24:00:00 for the end time. The end time must be greater than the start time.
days: Specifies the day or days of the week (in words or digits) on which the periodic statement is valid. If you specify multiple values, separate each value with a space, and make sure they do not overlap. These values can take one of the following forms:
·     A digit in the range of 0 to 6, for Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, and Saturday.
·     A day of a week in abbreviated words: Sun, Mon, Tue, Wed, Thu, Fri, and Sat.
·     working-day for Monday through Friday.
·     off-day for Saturday and Sunday.
·     daily for the whole week.
monthly { date1 [ to date2] } &<1-31> ]: Specifies the date or dates of the month on which the periodic statement is valid. You can specify a space-separated list of up to 31 date items. Each item specifies a date or a range of dates in the form of date1 to date2. The value for date2 must be greater than or equal to the value for date1. The value range for the date argument is 1 to 31.
from time1 date1: Specifies the start time and date of an absolute statement. The time1 argument specifies the time of the day in hh:mm or hh:mm:ss format (24-hour clock). Its value is in the range of 00:00:00 to 23:59:59. The date1 argument specifies a date in MM/DD/YYYY or YYYY/MM/DD format, where MM is the month of the year in the range of 1 to 12, DD is the day of the month with the range varying by MM, and YYYY is the year in the calendar in the range of 1970 to 2100. If you do not specify this option, the start time is 01/01/1970 00:00:00 AM, the earliest time available in the system.
to time2 date2: Specifies the end time and date of the absolute time statement. The time2 argument has the same format as the time1 argument, but its value is in the range of 00:00:00 to 24:00:00. The date2 argument has the same format and value range as the date1 argument. The end time must be greater than the start time. If you do not specify this option, the end time is 12/31/2100 24:00:00 PM, the maximum time available in the system.
If an existing time range name is provided, this command adds a statement to the time range.
You can create multiple statements in a time range. Each time statement can take one of the following forms:
·     Periodic statement in the monthly start-day start-time to end-day end-time format. The periodic statement recurs on a monthly basis.
·     Periodic statement in the weekly start-day start-time to end-day end-time format. A periodic statement recurs periodically on a weekly basis.
·     Periodic statement in the start-time to end-time days format. A periodic statement recurs on a daily basis.
·     Periodic statement in the start-time to end-time monthly { date1 [ to date2] } &<1-31> format. The periodic statement recurs on a monthly basis. This method specifies monthly effective dates, then limits daily effective times from those dates, achieving more precise control.
·     Absolute statement in the from time1 date1 to time2 date2 format. An absolute statement does not recur.
·     Compound statement in the start-time to end-time days from time1 date1 to time2 date2 format. A compound statement recurs on a day or days of the week only within the specified period. For example, to create a time range that is active from 08:00 to 12:00 on Monday between January 1, 2015, 00:00 and December 31, 2015, 23:59, use the time-range test 08:00 to 12:00 Mon from 00:00 01/01/2015 to 23:59 12/31/2015 command.
A time range can contain a maximum of 32 periodic statements and 12 absolute statements. The active period of a time range is calculated as follows:
1.     Combining all periodic statements.
2.     Combining all absolute statements.
3.     Taking the intersection of the two statement sets as the active period of the time range.
# Create a periodic time range t1, setting it to be active between 8:00 to 18:00 during working days.
[Sysname] time-range t1 08:00 to 18:00 working-day
# Create an absolute time range t2, setting it to be active in the whole year of 2011.
[Sysname] time-range t2 from 00:00 1/1/2011 to 24:00 12/31/2011
# Create a compound time range t3, setting it to be active from 08:00 to 12:00 on Saturdays and Sundays of the year 2011.
[Sysname] time-range t3 08:00 to 12:00 off-day from 00:00 1/1/2011 to 24:00 12/31/2011
# Create a compound time range t4, setting it to be active from 10:00 to 12:00 on Mondays and from 14:00 to 16:00 on Wednesdays in January and June of the year 2011.
[Sysname] time-range t4 10:00 to 12:00 1 from 00:00 1/1/2011 to 24:00 1/31/2011
[Sysname] time-range t4 14:00 to 16:00 3 from 00:00 6/1/2011 to 24:00 6/30/2011
# Create an absolute time range t5, setting it to be active between 8:00 to 18:00 on January 1st, 2018.
[Sysname] time-range t5 from 08:00:00 1/1/2018 to 18:00:00 1/1/2018
# Create a time range t6, setting it to be active from 08:00 on Mondays to 18:00 on Friday between 08:00 on January 1, 2021 and 18:00 on December 1, 2021.
[Sysname] time-range t6 weekly 1 08:00 to 5 18:00 from 08:00 1/1/2021 to 18:00 12/1/2021
# Create a time range t7, setting it to be active from 08:00 to 18:00 on the 1st through the 15th every month.
[Sysname] time-range t7 08:00 to 18:00 monthly 1 to 15
display time-range
time-range description
Use time-range description to configure a description for a time range.
Use undo time-range description to delete the description of a time range.
time-range time-range-name description text
undo time-range time-range-name description
A time range does not have a description.
time-range-name: Specifies a time range by its name, a case-insensitive string of 1 to 63 characters. To avoid confusion, it cannot be all.
text: Specifies a description for the time range, a case-sensitive string of 1 to 127 characters.
# Configure abc as the description of time range t1.
[Sysname] time-range t1 description abc
display time-range
time-range yundi
Use time-range yundi to specify a tenant for a time range.
Use undo time-range yundi to restore the default.
time-range time-range-name yundi alias alias-name tenant tenant-id
undo time-range time-range-name yundi
A time range does not belong to any tenant. The security policy of a tenant is always in effect.
alias-name: Specifies a user alias, a case-sensitive string of 1 to 63 characters.
tenant-id: Specifies a tenant by its ID, a case-sensitive string of 1 to 63 characters.
In a yundi scenario, a large number of tenants exist, and the controller assigns each tenant a unique tenant ID and deploys tenant IDs and associated time ranges to firewalls through NETCONF. A firewall generates this command based on the deployed information to make the security policy of the tenant take effect only during the time range. If the time range associated with a tenant does not exist, the system creates a new time range.
Tenant IDs are typically assigned by the controller. As a best practice, do not execute this command on the device.
A time range can be associated with only one tenant.
A tenant can be associated with multiple time ranges. The time range that takes effect is the intersection of all the time ranges.
# Specify tenant 3abcx for time range t1.
[Sysname] time-range t1 yundi alias abc tenant 3abcx
display time-range
