| Title | Size | Downloads |
| V7-IPS-1.0.353.dat | 15.98 MB |
Version number
V7-IPS-1.0.353
MD5 number
db61024a4a11ad213602d3a4f21d0649
Update time
2025-06-05
Update attack list
Key new rules:
55288 CVE-2025-32375_BentoML_Remote_Code_Execution_Vulnerability[2]
---- Category: Vulnerability
---- Description: BentoML is an open-source model service library open source for BentoML.
---- For building high-performance and scalable AI applications using Python. BentoML versions
---- prior to 1.4.8 have a code issue vulnerability due to insecure deserialization that could lead to
---- arbitrary code execution.
55284 CVE-2024-53376_CyberPanel_phpSelection_Command_Injection_Vulnerability[2]
---- Description: CyberPanel is a web hosting control panel with built-in DNS and email servers by
---- Usman Nasir Personal Developer.A security vulnerability exists in CyberPanel versions prior to 2.3.8.
---- An attacker can exploit this vulnerability to execute arbitrary commands on the website/submitWebsiteCreation
---- URI via shell metacharacters in the phpSelection field.
55286 JEEWMS_System_cgReportController.do_SQL_Injection_vulnerability[2]
---- Description: JeeWMS is a Java-based intelligent warehousing hub system, with the ability to deeply adapt to
---- multi-format warehousing scenarios.JeeWMS commonController.do interface is vulnerable to SQL injection.
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the IPS rules library file of this version, 24933 predefined rules can be generated in "Intrusion Prevention System"
[4] The device memory is less than or equal to 2GB. After loading the IPS rules library file of this version, 3286 predefined rules can be generated in "Intrusion Prevention System"
