| Title | Size | Downloads |
| V7-APR-1.0.197.dat | 2.81 MB |
Version number
V7-APR-1.0.197
MD5 number
ef0c7f8266e75cf56ae21446df9ca974
Update time
2025-05-22
Update protocol list
New protocols: [1]
----Microsoft.Auth
New protocols: [2]
----Abema
----Archero2
----BeautyPlus
----CallOfDuty
----CapCut
----Captions
----CapybaraGo
----DarkWar
----FaceApp
----Facetune
----Faceu
----FengShenYiShiLu
----GainTV
----GalaxyPlay
----HonorOfKings
----InStories
----Loklok
----Monomax
----PhotoLab
----Remini
----Standoff2
----Survivorio
----Tabii
----TODTV
----TVING
----Unext
----VieON
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the APR feature library file of this version, 9863 predefined applications can be generated
[4] The device memory is less than or equal to 2GB. After loading the APR feature library file of this version, 1572 predefined applications can be generated
