IPS Signature V7-IPS-1.0.352
Release time:2025-05-30
HomeSupportSecuritySignature Database ServicesSoftware DownloadSignature Database Services
Download
Title Size Downloads
V7-IPS-1.0.352.dat 15.96 MB
Version number
V7-IPS-1.0.352
MD5 number
5138d37ab7d9c30426e90d8e9fe68dcc
Update time
2025-05-29
Update attack list
Key new rules:
55207  CVE-2024-57606_JeecgBoot_SQL_Injection_Vulnerability[2]
---- Category: Vulnerability
---- Description: JeecgBoot is a Java low-code platform for enterprise Web applications developed by Jeecg,
---- a Chinese company. Version JeecgBoot v.3.7.2 has a security vulnerability.
---- This vulnerability stems from containing an SQL injection vulnerability that
---- allows remote attackers to obtain sensitive information through the getTotalData component.
55215  Ruijie_EWEB_dhcp.php_Arbitrary_File_Read_Vulnerability[2]
---- Description: Ruijie EWEB network management system /ddi/server/dhcp.php There is a file reading vulnerability,
---- which can be exploited by an attacker to read any file content on the device, causing sensitive information leakage.
55219  CVE-2025-31644_F5_iControl_REST_and_F5_BIG-IP_TMOS_Shell_Command_Injection_Vulnerability[2]
---- Description: F5 iControl REST and F5 BIG-IP TMOS Shell are both products of F5 in the United States.
---- F5 iControl REST is a development framework. The F5 BIG-IP TMOS Shell is a command line.
---- There is a command injection vulnerability in F5 iControl REST and F5 BIG-IP TMOS Shell,
---- which is caused by command injection and may lead to the execution of arbitrary system commands.
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the IPS rules library file of this version, 24903 predefined rules can be generated in "Intrusion Prevention System"
[4] The device memory is less than or equal to 2GB. After loading the IPS rules library file of this version, 3285 predefined rules can be generated in "Intrusion Prevention System"
