Application Signature V7-APR-1.0.196
Release time:2025-05-14
HomeSupportSecuritySignature Database ServicesSoftware DownloadSignature Database Services
Download
Title Size Downloads
V7-APR-1.0.196.dat 2.80 MB
Version number
V7-APR-1.0.196
MD5 number
007844adb4d0b8e3068a84eb19480045
Update time
2025-04-25
Update protocol list
New protocols:    [2]
----AgeOfOrigins
----Atresplayer
----Azarlive
----Bumble
----Carousell
----Cleanup
----CoinMaster
----DramaBox
----GoogleContacts
----JACO
----KalosTV
----MateLive
----Osnplus
----Pokerist
----Slotomania
----TopHeroes
----Vivamax
----WartuneUltra
----Webtoon
----WePlay
----WeTV
----Yalla
----DiDaChuXing
----CainiaoGlobal
----KingsoftResource
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the APR feature library file of this version, 9835 predefined applications can be generated
[4] The device memory is less than or equal to 2GB. After loading the APR feature library file of this version, 1571 predefined applications can be generated
