06-VPN Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath F1000[F5000] Firewalls Series Command Reference(V7)-6W90206-VPN Command Reference
04-SDWAN commands
04-SDWAN commands 306.93 KB
SDWAN commands
The following compatibility matrixes show the support of hardware platforms for SDWAN:
Series
Models
SDWAN compatibility
F5000 series
F5000-AI360, F5000-AI160, F5000-AI120, F5000-AI-40, F5000-AI-20, F5000-AI-15, F5000-CN60, F5000-CN30
Yes
F5000-CN-G85, F5000-CN-G65, F5000-CN-G55, F5000-CN160
No
F1000 series
F1000-AI-90, F1000-AI-80, F1000-AI-75, F1000-AI-70, F1000-AI-65, F1000-AI-60, F1000-AI-25
Yes
F1000-CN-G35
No
address-family ipv4 tnl-encap-ext
Use address-family ipv4 tnl-encap-ext to create the BGP IPv4 tunnel-encap-ext address family and enter BGP IPv4 tunnel-encap-ext address family view, or directly enter BGP IPv4 tunnel-encap-ext address family view if the BGP IPv4 tunnel-encap-ext address family already exists.
Use undo address-family ipv4 tnl-encap-ext to delete the BGP IPv4 tunnel-encap-ext address family and all settings in the address family.
The BGP IPv4 tunnel-encap-ext address family does not exist.
BGP instance view
context-admin
Settings in BGP IPv4 tunnel-encap-ext address family view take effect only on routes in the BGP IPv4 tunnel-encap-ext address family.
# In BGP instance view, create the BGP IPv4 tunnel-encap-ext address family and enter BGP IPv4 tunnel-encap-ext address family view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 tnl-encap-ext
[Sysname-bgp-default-tnlencap-ipv4]
display bgp routing-table ipv4 tnl-encap-ext
Use display bgp routing-table ipv4 tnl-encap-ext to display information about BGP IPv4 tunnel-encap-ext routes.
display bgp [ instance instance-name ] routing-table ipv4 tnl-encap-ext [ peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ statistics ] | [ route-type { tte | tte-ipv6 | tte-qos | saas-path } ] [ { tnlencap-route route-length | tnlencap-prefix } [ advertise-info ] ] | statistics ]
context-admin
context-operator
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays information about BGP IPv4 tunnel-encap-ext routes in the default instance.
peer: Displays BGP IPv4 tunnel-encap-ext routes advertised to or received from a peer.
ipv4-address: Specifies the peer by its IPv4 address.
Ipv6-address: Specifies the peer by its IPv6 address.
advertised-routes: Displays BGP IPv4 tunnel-encap-ext routes advertised to the specified peer.
received-routes: Displays BGP IPv4 tunnel-encap-ext routes received from the specified peer.
statistics: Displays BGP IPv4 tunnel-encap-ext route statistics.
route-type: Specifies a type of BGP IPv4 tunnel-encap-ext routes.
tte: Specifies IPv4 transport tunnel endpoint (TTE) advertisement routes.
tte-ipv6: Specifies IPv6 transport tunnel endpoint (TTE) advertisement routes.
tte-qos: Specifies QoS transport tunnel endpoint (TTE) advertisement routes.
saas-path: Specifies Software as a Service (SaaS) access path quality advertisement routes.
tnlencap-route: Displays detailed information about a BGP IPv4 tunnel-encap-ext route. The tnlencap-route argument is a string of 1 to 512 characters.
route-length: Specifies the length of the specified BGP IPv4 tunnel-encap-ext route, in bits. The value range is 0 to 65535.
tnlencap-prefix: Displays detailed information about a BGP IPv4 tunnel-encap-ext route. The tnlencap-prefix argument is a case-insensitive string of 1 to 512 characters. The string contains the route and route length in the format of tnlencap-route/route-length.
advertise-info: Displays advertisement information for BGP IPv4 tunnel-encap-ext routes.
If you do not specify any parameters, this command displays brief information about all BGP IPv4 tunnel-encap-ext routes.
# Display brief information about all BGP IPv4 tunnel-encap-ext routes.
<Sysname> display bgp routing-table ipv4 tnl-encap-ext
 Status codes: * - valid, > - best, d - dampened, h - history
               a – additional-path
Total number of routes: 2
* >i [1][10][10][100]/40
                        2.2.2.2         0          100        0       i
* >i [1][20][20][200]/40
                        1::1            0          100        0       i
* >i [3][30][30][100]/40
                        2.2.2.2         0          100        0       i
* >i [2][0x00ffffff][abc]/552
                        2.2.2.2         0          100        0       i
* >i [4][10][10][100]/40
                        2.2.2.2         0          100        0       i
* >i [5][10][10][100]/40
                        127.0.0.1       0          100        0       i
Status codes
Route state codes:
·     * – valid—Valid route.
·     > – best—Optimal route.
·     d - dampened—Dampened route.
·     h – history—History route.
·     s – suppressed—Suppressed route.
·     S – stale—Stale route.
·     i – internal—Internal route.
·     e – external—External route.
·     a – additional-path—Add-Path optimal route.
Origin
Origin of the route:
·     i – IGP—Originated in the current AS.
·     e – EGP—Learned through EGP.
·     ? – incomplete—Unknown origin.
Total number of BGP IPv4 tunnel-encap-ext routes.
Network
BGP IPv4 tunnel-encap-ext route and route length. The following BGP IPv4 tunnel-encap-ext routes are supported:
·     [1] [SiteID][DeviceID][InterfaceID]
¡     1—IPv4 TTE advertisement route.
¡     SiteID—Site ID.
¡     DeviceID—Device ID.
¡     InterfaceID—Interface ID.
·     [2][SiteAndDeviceID][SaaSName]
¡     2—SaaS access path quality advertisement route.
¡     SiteAndDeviceID—Site ID and device ID of a SaaS cloud service. A SaaS cloud service connection is identified by the site ID and device ID of the SaaS cloud service.
¡     SaaSName—Name of the SaaS cloud service.
·     [3] [SiteID][DeviceID][InterfaceID]
¡     3—IPv6 TTE advertisement route.
¡     SiteID—Site ID.
·     [4][SiteID][DeviceID][InterfaceID]
¡     4—QoS TTE advertisement route.
¡     SiteID—Site ID.
·     [5][SiteID][DeviceID][InterfaceID]
¡     5—RIR TTE advertisement route.
¡     SiteID—Site ID.
NextHop
Next hop IP address.
MED
Multi-exit discriminator (MED) attribute value.
LocPrf
Local preference value.
PrefVal
Preferred value.
Path/Ogn
AS_PATH and ORIGIN attributes of the route:
·     AS_PATH—Records the ASs the route has passed, which avoids routing loops. This field can display a maximum of 16 ASs. If the number of ASs exceeds the maximum number of ASs that can be displayed, an ellipsis (…) is displayed in place of the exceeding text. To view the complete information, display detailed information about the route.
·     ORIGIN—Identifies the origin of the route.
# Display detailed information about BGP IPv4 tunnel-encap-ext route [1][10][10][100]/40.
<Sysname> display bgp routing-table ipv4 tnl-encap-ext [1][10][10][100]/40
 BGP local router ID: 1.1.1.1
 Local AS number: 100
 Total number of routes: 1
 Paths:   1 available, 1 best
 BGP routing table information of [1][10][10][100]/40:
 Rely nexthop    : 10.1.1.2
 Original nexthop: 2.2.2.2
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : egp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 Route type      : Transport Tunnel Endpoint advertisement route
 LinkID          : 0x000a0a64
 SiteID          : 10
 DeviceID        : 10
 InterfaceID     : 100
 SiteName        : sdwan
 SystemIP        : 2.2.2.2
 SiteRole        : CPE
 EncapType       : UDP
 EncapPort       : 65535
 SourceIP        : 2.2.2.2
 TNName          : sdwan
 TNID            : 0x64
 RDName          : BGP
 RDID            : 0x64
 IPSecEnable     : Enabled
 AH SA SPI       : 0x0
 ESP SA SPI      : 0x0
 ESPEncAlg       : 0x1
 ESPAuthAlg      : 0x1
 AHAuthAlg       : 0x1
 NATEnable       : Enabled
 NATType         : Full Cone NAT
 PublicAddress   : 3.3.3.3
 PublicPort      : 179
# Display detailed information about BGP IPv4 tunnel-encap-ext route [3][10][10][200]/40.
<Sysname> display bgp routing-table ipv4 tnl-encap-ext [3][10][10][200]/40
 BGP local router ID: 50.50.50.50
 Local AS number: 200
 BGP routing table information of [3][10][10][200]/40:
 Rely nexthop    : 0::0
 Original nexthop: 1::1
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : (null)
 Origin          : igp
 State           : valid, internal, best
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 VPN-Peer UserID : N/A
 DSCP            : N/A
 EXP             : N/A
 Route type      : IPv6 transport tunnel endpoint advertisement route
 LinkID          : 0x000a0ac8
 SiteID          : 10
 DeviceID        : 10
 InterfaceID     : 200
 SiteName        : shanghai
 SystemIP        : 1::1
 SiteRole        : RR
 EncapType       : UDP IPv6
 EncapPort       : 4799
 SourceIP        : 14::1
 TNName          : tnrripv6
 TNID            : 0xc8
 RDName          : rdrr
 RDID            : 0x64
 IPSecEnable     : Disabled
 AH SA SPI       : 0x0
 ESP SA SPI      : 0x0
 ESPEncAlg       : 0x0
 ESPAuthAlg      : 0x0
 AHAuthAlg       : 0x0
 NATEnable       : Disabled
 NATType         : -
 PublicAddress   :
 PublicPort      :
# Display detailed information about BGP IPv4 tunnel-encap-ext route [4][10][10][200]/40.
<Sysname>display bgp routing-table ipv4 tnl-encap-ext [4][10][10][200]/40
 BGP routing table information of [4][10][10][200]/40:
 Rely nexthop    : 0.0.0.0
 Original nexthop: 10.10.10.10
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : (null)
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 DSCP            : N/A
 EXP             : N/A
 Route type      : Qos transport tunnel endpoint advertisement route
 LinkID          : 0x000a0ac8
 QoS TTE info    : BW:1000/PF:a
# Display detailed information about BGP IPv4 tunnel-encap-ext route [5][40][40][70]/40.
<Sysname> display bgp routing-table ipv4 tnl-encap-ext [5][40][40][70]/40
 BGP routing table information of [5][40][40][70]/40:
 Imported route.
 Original nexthop: 127.0.0.1
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : (null)
 Origin          : igp
 Attribute value : MED 0, localpref 100, pref-val 32768
 State           : valid, local, best
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 DSCP            : N/A
 EXP             : N/A
 Route type      : IPv4 transport tunnel endpoint advertisement route ext-local
 LinkID          : 0x00282846
 SiteID          : 40
 DeviceID        : 40
 InterfaceID     : 70
 SystemIP        : 7.7.7.7
Paths
Number of routes:
·     available—Number of valid routes.
·     best—Number of optimal routes.
Detailed information about BGP IPv4 tunnel-encap-ext route [1][10][10][100]/40.
From
IP address of the BGP peer that advertised the route.
Rely Nexthop
Next hop IP address after route recursion. If no next hop IP address is found, this field displays not resolved.
Original nexthop
Original next hop address of the route. If the route was obtained from a BGP update message, the original next hop address is the next hop IP address in the message.
OutLabel
Outgoing label of the route.
This field is not supported by the BGP IPv4 tunnel-encap-ext address family in the current software version.
RxPathID
Add-Path ID value of the received route.
TxPathID
Add-Path ID value of the sent route.
AS-path
AS_PATH attribute of the route. This attribute records the ASs the route has passed and avoids routing loops.
Origin
·     igp—Originated in the current AS.
·     egp—Learned through EGP.
·     incomplete—Unknown origin.
Attribute value
BGP attributes of the route:
·     MED—MED value for the destination network.
·     localpref—Local preference value.
·     pref-val—Preferred value.
·     pre—Protocol preference value.
Route state:
·     valid—Valid route.
·     internal—Internal route.
·     external—External route.
·     local—Local route.
·     best—Optimal route.
IP precedence
IP precedence of the route, in the range of 0 to 7. If the IP precedence is invalid, this field displays N/A.
QoS local ID
QoS local ID of the route, in the range of 1 to 4095. If the QoS local ID is invalid, this field displays N/A.
Traffic index
Traffic index in the range of 1 to 64. If the traffic index is invalid, this field displays N/A.
LinkID
Link ID assigned to the TTE. A link ID identifies a TTE connection.
QoS TTE info
QoS TTE information carried in the route:
·     BW—Traffic rate limit to be applied to the outbound direction of the SDWAN tunnel on the hub device.
·     PF—User profile to be applied to the outbound direction of the SDWAN tunnel on the hub device.
SiteID
Site ID.
DeviceID
Device ID.
InterfaceID
Interface ID.
SiteName
Site name.
SystemIP
Site system IP address.
SiteRole
Site role:
·     CPE.
·     RR.
·     NAT transfer.
If multiple site roles are assigned, each two roles are separated by a slash (/). For example: CPE/RR/NAT transfer.
EncapType
Encapsulation mode, which can be only UDP in the current software version.
EncapPort
Local UDP port number for SDWAN encapsulation.
SourceIP
Source IP address of the tunnel.
TNName
Transport network name.
TNID
Transport network ID.
RDName
Routing domain name.
RDID
Routing domain ID.
IPSecEnable
IPsec state:
·     Enabled—IPsec protection is enabled.
·     Disabled—IPsec protection is disabled.
AH SA SPI
AH SA SPI.
ESP SA SPI
ESP SA SPI.
ESPEncAlg
ESP encryption algorithm.
ESPAuthAlg
ESP authentication algorithm.
AHAuthAlg
AH authentication algorithm.
NATEnable
Whether NAT is deployed:
·     Enabled—NAT is deployed.
·     Disabled—NAT is not deployed.
NATType
NAT type:
·     Full Cone NAT.
·     Restricted Cone NAT.
·     Port Restricted Cone NAT.
·     Symmetric NAT.
If no NAT type exists, this field displays a hyphen (-).
PublicAddress
Public IP address after NAT.
PublicPort
Public port number after NAT.
# Display detailed information about BGP IPv4 tunnel-encap-ext route [2][16777216][abc]/296.
<Sysname> display bgp routing-table ipv4 tnl-encap-ext [2][0x00ffffff][abc]/296
 BGP routing table information of [2][0x00ffffff][abc]/296:
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : egp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 Route type      : Software as a Service access path quality advertisement route
 SiteID          : 0x00ffffff
 DeviceID        : 1
 SaaSName        : abc
 SystemIP        : 2.2.2.2
 Delay           : 20 ms
 Jitter          : 4 ms
 Loss            : 50 ‰
 CQI             : 80
Paths
Number of routes:
BGP routing table information of [2][16777216][abc]/296
Detailed information about BGP IPv4 tunnel-encap-ext route [2][0x00ffffff][abc]/296.
From
Rely Nexthop
Original nexthop
OutLabel
RxPathID
TxPathID
AS-path
Origin
Attribute value
Route state:
IP precedence
QoS local ID
Traffic index
SiteID
Site ID
DeviceID
Device ID
SaaSName
SaaS cloud service name.
SystemIP
Delay
Delay for the path used to access the SaaS cloud service, in milliseconds.
Jitter
Jitter for the path used to access the SaaS cloud service, in milliseconds.
Loss
Packet loss ratio for the path used to access the SaaS cloud service, in permillage.
CQI
Approximate Comprehensive Quality Indicator (CQI) value for the path used to access the SaaS cloud service.
# Display advertisement information for BGP IPv4 tunnel-encap-ext route [1][10][10][100]/40.
<Sysname> display bgp routing-table ipv4 tnl-encap-ext [1][10][10][100]/40 advertise-info
 Paths:   1 best
    3.3.3.3
Paths
Number of optimal routes destined for the specified destination network.
Advertisement information about BGP IPv4 tunnel-encap-ext route [1][10][10][100]/40.
Peers to which the route has been advertised and total number of the peers.
# Display statistics about BGP IPv4 tunnel-encap-ext routes advertised to peer 2.2.2.2.
<Sysname> display bgp routing-table ipv4 tnl-encap-ext peer 2.2.2.2 advertised-routes statistics
 Advertised routes total: 1
# Display statistics about BGP IPv4 tunnel-encap-ext routes received from peer 2.2.2.2.
<Sysname> display bgp routing-table ipv4 tnl-encap-ext peer 2.2.2.2 received-routes statistics
 Received routes total: 1
Table 5 Command output
Total number of routes advertised to the peer.
Total number of routes received from the peer.
# Display statistics about BGP IPv4 tunnel-encap-ext routes.
<Sysname> display bgp routing-table ipv4 tnl-encap-ext statistics
 Total number of routes: 4
Table 6 Command output
display sdwan peer-connection status
Use display sdwan peer-connection status to display SSL connection status on a CPE.
display sdwan peer-connection status [ system-ip { system-ipv4-address  | ipv6 system-ipv6-address } ] [ ipv4 | ipv6 ]
context-admin
context-operator
system-ip: Specifies an SDWAN server by its system IP address. If you do not specify an SDWAN server, this command displays status information for all SSL connections on the device.
system-ipv4-address: Specifies the system IPv4 address of the SDWAN server.
ipv6 system-ipv6-address: Specifies the system IPv6 address of the SDWAN server.
ipv4: Displays status information for IPv4 SSL connections.
ipv6: Displays status information for IPv6 SSL connections.
If you do not specify the ipv4 or ipv6 keyword, this command displays status information for both IPv4 SSL connections and IPv6 SSL connections.
# Display status information for all SSL connections on the device.
<Sysname> display sdwan peer-connection status
System IP   : 1.1.1.1
Peer IP/port: 10.0.0.1/7000
VPN instance: vpn1
Status      : Connected
System IP   : 1.1.1.1
Peer IP/port: 10::1/7000
VPN instance: vpn1
Status      : Init
Table 7 Command output
System IP
System IP address of an SDWAN server.
Peer IP/port
IP address and listening TCP port number of the SDWAN server.
VPN instance
VPN instance of the SDWAN server.
Status
SSL connection state:
·     Init.
·     Connecting.
·     Connected.
·     Close.
display sdwan server status
sdwan server
Use display sdwan server status to display SDWAN server status on an RR.
context-admin
context-operator
# Display SDWAN server status on an RR.
<Sysname> display sdwan server status
SDWAN server: Enabled
SDWAN server listening port: 10030
Table 8 Command output
SDWAN server
SDWAN server state:
·     Enabled.
·     Disabled.
TCP port number that the SDWAN server is listening to.
sdwan server enable
sdwan server port
display sdwan site-tte
Use display sdwan site-tte to display transport tunnel endpoint (TTE) information on an SDWAN device.
display sdwan site-tte [ site-id site-id ] [ verbose ] [ ipv4 | ipv6 ]
context-admin
context-operator
site-id site-id: Specifies a site by its ID, in the range of 1 to 65535. If you do not specify a site, the command displays TTE information for all sites.
verbose: Displays detailed TTE information for sites. If you do not specify this keyword, the command displays brief TTE information for sites.
ipv4: Displays TTE information for IPv4 SDWAN tunnels.
ipv6: Displays TTE information for IPv6 SDWAN tunnels.
If you do not specify the ipv4 or ipv6 keyword, this command displays TTE information for both IPv4 SDWAN tunnels and IPv6 SDWAN tunnels.
# Display brief TTE information for all sites.
<Sysname> display sdwan site-tte
Site ID: 20 (local)
Total number of TTEs: 1
DevID   SysIP           IfID   Status   Encap    NAT      SA        RDID          TNID
20      1.1.1.9         20     UP       UDP IPv4 Disabled Disabled  rda           tna
Site ID: 10
Total number of TTEs: 2
10      1.1.1.10        30     UP       UDP IPv4 Disabled Disabled  rda           tna
10      1.1.1.10        40     UP       UDP IPv4 Disabled Disabled  rda           tnb
Table 9 Command output
Site ID
Site ID. If (local) is displayed next to the site ID, the site is the local site.
Total number of TTEs at the site.
DevID
Device ID.
SysIP
System IP address of the device.
IfID
SDWAN tunnel interface ID.
Status
TTE state:
·     UP.
·     DOWN.
Encap
SDWAN tunnel encapsulation method:
·     UDP IPv4—IPv4 tunnel in UDP encapsulation.
·     UDP IPv6—IPv6 tunnel in UDP encapsulation.
NAT
NAT state:
·     Enabled.
·     Disabled.
·     N/A—The state is unknown.
SA
SA state:
·     Enabled.
·     Disabled.
·     NA—The state is unknown.
RDID
Routing domain ID of the TTE.
TNID
Transport network ID of the TTE.
# Display detailed TTE information for site 20.
<Sysname> display sdwan site-tte site-id 20 verbose
Site ID: 20 (local)
Site name: fenzhi
Site role: CPE
Device ID: 20
System IP: 1.1.1.9
Interface ID: 20
Group ID: 3
Interface name: Tunnel10
Status: UP
Encapsulation protocol: UDP IPv4
Encapsulation port: 3000
Tunnel destination VPN index: 0
Transport destination VPN index: 0
NAT: Disabled
NAT type: -
NAT public IP: -
NAT public port: -
SA: Disabled
Routing domain: rda (10)
Transport network: tna (10)
Out physical interface: GigabitEthernet1/0/3
Source IP: 172.1.1.1
Table 10 Command output
Site ID
Site role
Device role:
·     CPE.
·     RR—Route reflector.
·     NAT-transfer.
Interface ID
Group ID
SDWAN tunnel group ID.
Interface name
SDWAN tunnel interface name.
Status
TTE state:
·     UP.
·     DOWN.
Encapsulation port
Source UDP port number in SDWAN tunneled packets.
NAT
NAT state:
·     Enabled.
·     Disabled.
NAT type
NAT type:
·     Full Cone NAT.
·     Symmetric NAT.
·     NO NAT.
·     Static NAT.
The NAT type is unknown if this field displays a hyphen (-).
NAT public IP
NAT public port
TCP port number after NAT.
SA
SA state:
·     Enabled.
·     Disabled.
Routing domain
Routing domain name and ID of the TTE, in the format of domain-name (domain-id).
Transport network
Transport network name and ID of the TTE, in the format of network-name (network-id).
Local physical output interface of the TTE.
Source IP
Source IP address of the SDWAN tunnel for the TTE.
display sdwan tte connection
Use display sdwan tte connection to display TTE connection information on the device.
display sdwan tte connection [ site-id site-id | system-ip { system-ipv4-address | ipv6 system-ipv6-address } ] [ reachable | unreachable ] [ ipv4 | ipv6 ] [ collaboration ]
context-admin
context-operator
site-id site-id: Specifies a remote site by its ID, in the range of 1 to 65535. If you do not specify a remote site, this command displays TTE connection information for all sites.
system-ip: Specifies a remote device by its system IP address. If you do not specify a system IP address, this command displays TTE connection information for all system IP addresses.
system-ipv4-address: Specifies the IPv4 system IP address of the remote devicee.
ipv6 system-ipv6-address: Specifies the IPv6 system IP address of the remote device.
reachable: Displays TTE connections reachable to system IP addresses.
unreachable: Displays TTE connections unreachable to system IP addresses.
ipv4: Displays TTE connections on IPv4 SDWAN tunnels.
ipv6: Displays TTE connections on IPv6 SDWAN tunnels.
collaboration: Displays TTE connections synchronized from the remote device through a collaboration channel. If you do not specify this keyword, the command displays local TTE connections on the device.
If you do not specify the reachable or unreachable keyword, this command displays both TTE connections reachable to system IP addresses and TTE connections unreachable to system IP addresses.
If you do not specify the ipv4 or ipv6 keyword, this command displays TTE connections on both IPv4 SDWAN tunnels and IPv6 SDWAN tunnels.
# Display information about all TTE connections on the device.
<Sysname> display sdwan tte connection
Destination SiteID/DevID/IfID/SysIP: 30/50/35/50.50.50.30
Destination IP/port: 200.200.200.30/3000
Source SiteID/DevID/IfID/SysIP: 20/55/30/50.50.50.10
Source IP/port: 200.200.200.10/3000
Destination IP/port: 200::30/3000
Source SiteID/DevID/IfID/SysIP: 50/10/20/50.50.50.10
Number of connections: 2
Table 11 Command output
Site ID, device ID, tunnel interface ID, and system IP address of a peer device.
Destination IP/port
Destination IP address and TCP port number in SDWAN tunneled packets.
Site ID, device ID, tunnel interface ID, and system IP address of the local device.
Source IP/port
Source IP address and source TCP port number in SDWAN tunneled packets.
Number of TTE connections.
reset sdwan tte connection
evpn-sdwan nexthop-recursive priority-color-only
Use evpn-sdwan nexthop-recursive priority-color-only to configure the device to perform next hop recursion based on only the Priority-Color attribute for SDWAN-encapsulated IP prefix advertisement routes.
Use undo evpn-sdwan nexthop-recursive priority-color-only to restore the default.
The device performs next hop recursion first based on the NEXT_HOP attribute and then the Priority-Color attribute for an IP prefix advertisement route that has the Priority-Color attribute after it receives that route.
BGP EVPN address family view
context-admin
Application scenario
Use this command in an SDWAN scenario that uses the Priority-Color attribute for traffic rerouting or load balancing.
By default, the device performs next hop recursion for IP prefix advertisement routes based on both the NEXT_HOP and Priority-Color attributes after it receives these routes if these routes have the Priority-Color attribute. The recursion procedure is as follows for an IP prefix advertisement route:
·     Typically, the address in the NEXT_HOP attribute is the system IP address of a remote CPE. The device looks up for a matching TTE connection based on the address. The SDWAN tunnel interface of the matching TTE connection is the next hop output interface obtained through next hop recursion for the IP prefix advertisement route.
·     Each Priority-Color attribute includes the site ID information of a remote CPE or the site ID and device ID information of a remote CPE. The device looks up for matching TTE connections based on the information. The SDWAN tunnel interfaces of the matching TTE connections are the next hop output interfaces obtained through next hop recursion for the IP prefix advertisement route based on the Priority-Color attributes.
When the device receives packets that match an IP prefix advertisement route, it forwards the packets as follows:
·     If BGP load balancing is not configured, the device forwards the packets over an SDWAN tunnel obtained through next hop recursion based on the NEXT_HOP attribute of the IP prefix advertisement route. When that SDWAN tunnel is not available, the device uses the SDWAN tunnel obtained through next hop recursion based on the Priority-Color attribute to forward the packets.
·     If BGP load balancing is configured, the device can forward the packets over the following SDWAN tunnels for load balancing:
¡     The SDWAN tunnel obtained through next hop recursion based on the NEXT_HOP attribute of the IP prefix advertisement route.
¡     The SDWAN tunnels obtained through next hop recursion based on the Priority-Color attributes of the IP prefix advertisement route.
Based on the above mechanism, when the forwarding path obtained through next hop recursion based on the NEXT_HOP attribute is not available, the device still can forward VPN traffic along the forwarding path obtained through next hop recursion based on the Priority-Color attribute. The latter path is a backup for the former path. They provide rerouting and load balancing services for traffic.
The Priority-Color attribute is easy to configure, and the device can flexibly control the SDWAN forwarding path through this attribute. To perform next hop recursion for IP prefix advertisement routes that have the Priority-Color attribute based on only the Priority-Color attribute, use this command.
Working mechanism
With this command, when the device receives an IP prefix advertisement route that has the Priority-Color attribute, it does not perform next hop recursion based on the NEXT_HOP attribute. Instead, it performs next hop recursion directly based on the Priority-Color attribute. When the device receives packets that match the IP prefix advertisement route, it forwards the packets to an SDWAN tunnel obtained through next hop recursion based on only the Priority-Color attribute. In this way, the forwarding path is not restricted by the NEXT_HOP attribute of the IP prefix advertisement route. To adjust the forwarding path, you only need to modify the Priority-Color attribute.
This command takes effect only on SDWAN-encapsulated IP prefix advertisement routes that have the Priority-Color attribute.
# Configure the device to perform next hop recursion based on only the Priority-Color attribute for SDWAN-encapsulated IP prefix advertisement routes.
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-ipv6] evpn-sdwan nexthop-recursive priority-color-only
evpn sdwan routing-enable
Use evpn sdwan routing-enable to enable EVPN to advertise SDWAN routes.
Use undo evpn sdwan routing-enable to disable EVPN from advertising SDWAN routes.
EVPN does not advertise SDWAN routes.
VPN instance IPv4 address family view
VPN instance IPv6 address family view
context-admin
Non-default vSystems do not support this command.
This command enables the device to advertise VPN routes as BGP EVPN IP prefix advertisement routes in SDWAN encapsulation to peers. When the device receives BGP EVPN IP prefix advertisement routes in SDWAN encapsulation from the peers, it adds the routes to the routing table of the VPN instance.
Use this command in conjunction with the peer advertise encap-type sdwan command executed in BGP EVPN address family view.
# In IPv4 address family view of VPN instance vpna, enable EVPN to advertise SDWAN routes.
[Sysname-vpn-instance-vpna] address-family ipv4
[Sysname-vpn-ipv4-vpna] evpn sdwan routing-enable
Use reset sdwan tte connection to clear SDWAN TTE connections.
reset sdwan tte connection interface interface-type interface-number [ site-id site-id device-id device-id interface-id interface-id ]
context-admin
interface interface-type interface-number: Specifies an SDWAN tunnel interface by its type and number.
site-id site-id device-id device-id interface-id interface-id: Specifies an interface on a device at a site. The site-id argument represents the site ID, in the range of 1 to 65535. The device-id argument represents the device ID, in the range of 1 to 255. The interface-id argument represents the interface ID, in the range of 1 to 255. If you do not specify this option, the command clears all TTE connections for the specified SDWAN tunnel interface.
Clearing the TTE connections to a remote device also deletes the routes destined for the system IP address of that remote device. As a result, data packet forwarding is interrupted.
Clearing TTE connections between a CPE and an RR also interrupts the BGP sessions between them.
# Clear TTE connections for SDWAN tunnel interface Tunnel 1.
<Sysname> reset sdwan tte connection interface tunnel 1
Use peer advertise encap-type sdwan to enable advertisement of EVPN routes in SDWAN encapsulation to a peer or peer group.
Use undo peer advertise encap-type sdwan to disable advertisement of EVPN routes in SDWAN encapsulation to a peer or peer group.
peer { group name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise encap-type sdwan
undo peer { group name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise encap-type sdwan
BGP does not advertise EVPN routes in SDWAN encapsulation to a peer or peer group.
context-admin
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must already exists.
ipv4-address: Specifies a peer by its IPv4 address. The peer must already exists.
mask-length: Specifies a mask length in the range of 0 to 32. To specify a subnet, you must specify both the ipv4-address and mask-length arguments.
ipv6-address: Specifies a peer by its IPv6 address. The peer must already exists.
prefix-length: Specifies a prefix length in the range of 0 to 128. To specify an IPv6 subnet, you must specify both the ipv6-address and prefix-length arguments.
Use this command on CPEs and RRs. On a CPE, use this command in conjunction with the evpn sdwan routing-enable command executed in VPN instance IPv4 address family view.
# Configure BGP to advertise EVPN routes in SDWAN encapsulation to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 advertise encap-type sdwan
sdwan bfd enable
Use sdwan bfd enable to use BFD to test the connectivity of TTE connections on an SDWAN tunnel.
Use undo sdwan bfd enable to restore the default.
sdwan bfd enable [ template template-name ]
BFD is not used to test the connectivity of TTE connections on an SDWAN tunnel. The device uses keepalive packets to test the connectivity of TTE connections on an SDWAN tunnel.
Tunnel interface view
context-admin
template template-name: Specifies a BFD template by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a BFD template or the specified BFD template does not exist, the device uses the default BFD session parameters.
With this command, the local device periodically sends BFD control packets to the remote device over all TTE connections on an SDWAN tunnel. If the device does not receive any BFD control packets from the remote device over a TTE connection within the detection period, it determines that the TTE connection is unreachable to the remote device. For more information about BFD, see Network Management and Monintoring Configuration Guide.
If BFD is used to test the connectivity of TTE connections on an SDWAN tunnel, you must use this command at both ends of the SDWAN tunnel.
If this command is used on an SDWAN tunnel interface, the device determines the connectivity of TTE connections on that SDWAN tunnel based on the BFD detection result. If this command is not used on an SDWAN tunnel interface, the device determines the connectivity of TTE connections on that SDWAN tunnel based on the keepalive result.
# On SDWAN tunnel interface Tunnel 1, configure BFD to test the connectivity of TTE connections on the SDWAN tunnel.
[Sysname] interface tunnel 1 mode sdwan udp
[Sysname-Tunnel1] sdwan bfd enable template aa
sdwan keepalive
sdwan device-id
Use sdwan device-id to assign an ID to the device.
Use undo sdwan device-id to restore the default.
sdwan device-id device-id
No ID is assigned to the device.
context-admin
device-id: Specifies an ID for the device, in the range of 1 to 255.
The device ID uniquely identifies the device at a site.
# Assign ID 2 to the device.
[Sysname] sdwan device-id 2
The current configuration will lead to TTE offline. Continue anyway? [Y/N]:
sdwan encapsulation global-udp-port
Use sdwan encapsulation global-udp-port to specify a global source UDP port number for SDWAN tunneled packets.
Use undo sdwan encapsulation global-udp-port to restore the default.
sdwan encapsulation global-udp-port port-number
The global source UDP port number is 4799 for SDWAN tunneled packets.
context-admin
port-number: Specifies a global source UDP port number for SDWAN tunneled packets, in the range of 1 to 65535. As a best practice, do not specify a known port number in the range of 1 to 1023.
All devices that belong to the same SDWAN routing domain must use the same source UDP port number.
You can specify a source UDP port number for SDWAN tunneled packets in both system view and tunnel interface view.
·     The source UDP port number specified in system view applies to all SDWAN tunnel interfaces.
·     The source UDP port number specified in tunnel interface view applies only to one tunnel interface.
For a tunnel interface, the source UDP port number specified in tunnel interface view takes precedence over that specified in system view. If no source UDP port number is specified in tunnel interface view, the source UDP port number specified in system view applies.
# Specify port number 5000 as the global source UDP port number for SDWAN tunneled packets.
[Sysname] sdwan encapsulation global-udp-port 5000
sdwan encapsulation udp-port
Use sdwan encapsulation udp-port to specify a source UDP port number for SDWAN tunneled packets in UDP encapsulation mode.
Use undo sdwan encapsulation udp-port to restore the default.
sdwan encapsulation udp-port port-number [ dynamic [ time ] ]
The source UDP port number for SDWAN tunneled packets is the global source UDP port number for SDWAN tunneled packets.
context-admin
port-number: Specifies a source UDP port number in the range of 1 to 65535. As a best practice, do not specify a known port number in the range of 1 to 1023.
dynamic: Obtains UDP port numbers dynamically.
time: Specifies the delay time for switching the dynamic UDP port number. The value range is 30 to 1800, in seconds. The default value is 180.
If the dynamic keyword is specified, the device requests a UDP port number from the UDP protocol stack when the UDP port number specified by this command is unavailable.
You can specify a source UDP port number for SDWAN tunneled packets both in system view and in tunnel interface view.
In a full-mesh scenario, do not specify the dynamic keyword as a best practice. The dynamic mode might trigger TTE reconnections of the device with other branches, causing traffic interruption or flapping issues.
# Specify 5000 as the source UDP port number of SDWAN tunneled packets.
[Sysname-Tunnel1] sdwan encapsulation udp-port 5000
sdwan group-id
Use sdwan group-id to specify a group ID for an SDWAN tunnel.
Use undo sdwan group-id to restore the default.
sdwan group-id group-id
undo sdwan group-id
No group ID is specified for an SDWAN tunnel.
context-admin
group-id: Specifies a group ID in the range of 1 to 65535.
Use this command to control the establishment of TTE connections in a more fine and flexible manner. In the same routing domain, only tunnel interfaces that have the same group ID and belong to the same transport network can establish TTE connections.
# Specify group ID 22 for SDWAN tunnel 1.
[Sysname-Tunnel1] sdwan group-id 22
sdwan interface-id
Use sdwan interface-id to assign an interface ID to an SDWAN tunnel interface.
Use undo sdwan interface-id to restore the default.
sdwan interface-id interface-id
No interface ID is assigned to an SDWAN tunnel interface.
context-admin
interface-id: Specifies an interface ID for the SDWAN tunnel interface, in the range of 1 to 255.
The device supports multiple SDWAN tunnel interfaces. An interface ID uniquely identifies an SDWAN tunnel interface on the device.
# Assign interface ID 10 to SDWAN tunnel interface Tunnel 1.
[Sysname-Tunnel1] sdwan interface-id 10
sdwan keepalive
Use sdwan keepalive to configure SDWAN keepalive settings.
Use undo sdwan keepalive to restore the default.
sdwan keepalive interval interval [ retry retries ]
The keepalive interval is 10 seconds and the number of keepalive retries is 3 for an SDWAN tunnel.
context-admin
interval interval: Specifies the interval between sending keepalive requests, in the range of 1 to 32767 seconds.
retry retries: Specifies the number of times that the device continues to send keepalive packets without response before the TTE connection state is changed to unreachable. The value range for the retries argument is 1 to 255 and the default value is 3.
After an SDWAN tunnel is established, the local device sends keepalive requests to the remote device over all the TTE connections on the tunnel interface at the specified keepalive interval.
·     If the local device receives a keepalive response from the remote device within a keepalive interval, it determines that a TTE connection is reachable to the remote device.
·     If the local device cannot receive a keepalive response from the remote device on a TTE connection within a keepalive interval, it resends a keepalive request. If the local device still cannot receive a response within the keepalive interval multiplied by keepalive retries, it determines that the TTE connection is unreachable to the remote device. The device no longer forwards packets through the TTE connection.
In an RIR-SDWAN network, set the keepalive interval within the range of 1 to 5 seconds as a best practice.
If the sdwan bfd enable command is used on an SDWAN tunnel interface, the device determines the connectivity of TTE connections on that SDWAN tunnel based on the BFD detection result. If this command is not used on an SDWAN tunnel interface, the device determines the connectivity of TTE connections on that SDWAN tunnel based on the keepalive result.
# On SDWAN tunnel interface 1, set the keepalive interval to 30 seconds and the number of keepalive retries to 5.
[Sysname-Tunnel1] sdwan keepalive interval 30 retry 5
sdwan bfd enable
sdwan nat-global-ip
Use sdwan nat-global-ip to specify the post-NAT public IP address and port number for the source IP address and port number of tunneled packets.
Use undo sdwan nat-global-ip to restore the default.
sdwan nat-global-ip global-address global-port global-port
The post-NAT public IP address and port number are not specified for the source IP address and port number of tunneled packets.
context-admin
global-address: Specifies the post-NAT public IP address.
global-port: Specifies the post-NAT public port number, in the range of 1 to 65535.
Use this command on a CPE or RR if the CPE or RR is behind a NAT device and the NAT device is configured with static NAT. With this command, you do not need to configure STUN to detect the post-NAT public IP address and port number for the source IP address and port number of tunneled packets on the CPE or RR.
Using this command on a tunnel interface causes the device to disconnect all existing TTE connections established to the tunnel interface. The device will reestablish these TTE connections based on the specified post-NAT public IP address and port number.
As a best practice, do not use this command if the public network cannot actively access the internal network.
# Specify 10.1.1.1 and 5000 as the post-NAT public IP address and port number for the source IP address and port number of tunneled packets.
[Sysname-Tunnel1] sdwan nat-global-ip 10.1.1.1 global-port 5000
sdwan routing-domain
Use sdwan routing-domain to specify a routing domain for an SDWAN tunnel.
Use undo sdwan routing-domain to restore the default.
sdwan routing-domain domain-name id domain-id
No routing domain is specified for an SDWAN tunnel.
context-admin
domain-name: Specifies a routing domain by its name, a case-sensitive string of 1 to 31 characters. The string can contain only letters, digits, and dots (.).
domain-id: Specifies the ID of the routing domain, in the range of 1 to 65535.
Only CPEs and RRs that belong to the same routing domain can establish SDWAN tunnels with each other.
# Specify the routing domain named abc and with ID 2000 for SDWAN tunnel 1.
[Sysname-Tunnel1] sdwan routing-domain abc id 2000
sdwan server
Use sdwan server to specify an SDWAN server on a CPE.
Use undo sdwan server to remove an SDWAN server from a CPE.
sdwan server system-ip { system-ipv4-address | ipv6 system-ipv6-address } { ip ipv4-address | ipv6 ipv6-address } [ port port-number ] [ vpn-instance vpn-instance-name ]
undo sdwan server system-ip system-ip-address { ip ipv4-address | ipv6 ipv6-address } [ port port-number ] [ vpn-instance vpn-instance-name ]
No SDWAN servers are specified on a CPE.
context-admin
system-ipv4-address: Specifies an SDWAN server by its IPv4 system IP address.
ipv6 system-ipv6-address: Specifies an SDWAN server by its IPv6 system IP address.
ip ipv4-address: Specifies the IPv4 address of the SDWAN server. The IPv4 address must be reachable and must be on the RR where SDWAN server is enabled.
ipv6 ipv6-address: Specifies the IPv6 address of the SDWAN server. The IPv6 address must be reachable and must be on the RR where SDWAN server is enabled.
port port-number: Specifies a TCP port number used to establish connections with the SDWAN server. Make sure the port number is the same as the TCP listening port number configured for the SDWAN server on the RR. The value range for the port-number argument is 1 to 65535, and the default value is 2004.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the SDWAN server belongs. The vpn-instance-name argument represents the VPN instance name, which is a case-sensitive string of 1 to 31 characters. If the SDWAN server belongs to the public network, do not specify this option.
With this command, a CPE can act as an SDWAN client to establish an SSL connection with the specified SDWAN server (RR).
Repeat this command to specify multiple SDWAN servers on a CPE.
# On a CPE, specify the SDWAN server at 10.1.1.1 and with IPv4 system IP address 192.168.0.1.
[Sysname] sdwan server system-ip 192.168.0.1 ip 10.1.1.1
sdwan server enable
Use sdwan server enable to enable SDWAN server on an RR.
Use undo sdwan server enable to disable SDWAN server on an RR.
sdwan server enable
SDWAN server is disabled on an RR.
context-admin
Use this command only on an RR. With this command, the RR can listen to the CPEs for SSL connection requests and establish SSL connections with the CPEs. After SSL connection establishment, the CPEs advertise their local TTE and IPsec SA information to the RR and the RR advertises its local TTE and IPsec SA information to the CPEs. Then, the RR and CPEs can finish SDWAN tunnel establishment.
When you enable SDWAN server on an RR and the RR does not have a digital certificate, digital certificate request is triggered. It takes some time to request a digital certificate. For more information about digital certificates, see PKI configuration in Security Configuration Guide.
# Enable SDWAN server on an RR.
[Sysname] sdwan server enable
Please wait.........Done.
sdwan ssl-server-policy
sdwan server port
Use sdwan server port to specify the TCP port that the SDWAN server listens to on an RR.
Use undo sdwan server port to restore the default.
sdwan server port port-number
The SDWAN server on an RR listens to TCP port 2004.
context-admin
port-number: Specifies a port number in the range of 1 to 65535.
This command is not supported in FIPS mode.
If SDWAN server has been enabled before you change the TCP port number, the system automatically restarts the SDWAN server after you change the TCP port number. Connections that have been established between CPEs and the SDWAN server are not lost. Connections being established between CPEs and the SDWAN server are lost. To reestablish the connections, you must specify the same TCP port number as the SDWAN server on the CPEs.
# Specify 3500 as the TCP listening port number of the SDWAN server on an RR.
[Sysname] sdwan server port 3500
sdwan server enable
sdwan site-id
Use sdwan site-id to specify a site ID for the device.
Use undo sdwan site-id to restore the default.
sdwan site-id site-id
undo sdwan site-id
No site ID is specified for the device.
context-admin
site-id: Specifies a site ID for the device, in the range of 1 to 65535.
A site ID uniquely identifies a customer site in an SDWAN network.
# Specify site ID 2 for the device.
[Sysname] sdwan site-id 2
sdwan site-name
Use sdwan site-name to specify the name of the site to which the device belongs.
Use undo sdwan site-name to restore the default.
sdwan site-name site-name
No site name is specified for the device.
context-admin
site-name: Specifies a site name for the device, a case-sensitive string of 1 to 255 characters.
A site name can describe the site location and functions, which facilitates users to identify the site in an SDWAN network. A site name does not uniquely identify a site. You can specify the same site name for multiple devices.
# Specify site name fenbu for the device.
[Sysname] sdwan site-name fenbu
sdwan site-role
Use sdwan site-role to specify a site role for the device.
Use undo sdwan role to restore the default.
sdwan site-role { cpe | nat-transfer | rr } *
undo sdwan site-role
No site role is specified for the device.
context-admin
cpe: Specifies the CPE role.
nat-transfer: Specifies the NAT transfer role.
rr: Specifies the route reflector (RR) role.
IMPORTANT
IMPORTANT:
A site role change will cause SDWAN tunnel flapping and interrupt ongoing services. As a best practice, plan role configuration before you deploy the SDWAN network.
SDWAN supports the following site roles:
·     CPE—Customer-side SDWAN tunnel endpoints.
·     RR—Used to reflect TTE information and private routes among CPEs.
·     NAT transfer—Used to establish forwarding paths for CPEs that must pass through NAT devices over the public network for intercommunication.
You must specify the same site role for all SDWAN devices at the same site.
# Specify site role CPE for the device.
[Sysname] sdwan site-role cpe
Use sdwan ssl-server-policy to specify an SSL server policy on an RR for the RR to establish SSL connections with CPEs (SDWAN clients).
Use undo sdwan ssl-server-policy to restore the default.
sdwan ssl-server-policy policy-name
No SSL server policy is specified on an RR for the RR to establish SSL connections with CPEs (SDWAN clients).
context-admin
policy-name: Specifies an SSL server policy by its name, a case-sensitive string of 1 to 31 characters.
With this command, an RR uses the specified policy to establish SSL connections with CPEs. After SSL connection establishment, the CPEs advertise their local TTE and IPsec SA information to the RR and the RR advertises its local TTE and IPsec SA information to the CPEs. Then, the RR and the CPEs can finish SDWAN tunnel establishment.
Only one SSL server policy can be applied to an SSL connection. If you execute this command multiple times, the most recent configuration cannot take effect automatically. For the most recent configuration to take effect, you must execute the undo sdwan server enable command and then the sdwan server enable command to re-enable the SDWAN server.
For more information about SSL server policies, see SSL configuration in Security Configuration Guide.
If you do not specify an SSL server policy on an RR, the RR uses the self-signed certificate and the default settings of the SSL parameters to establish SSL connections with CPEs or the NAT transfer. The configuration is simple, but less secure.
# On an RR, specify SSL server policy CA_CERT for the RR to establish SSL connections with CPEs (SDWAN clients).
[Sysname] sdwan ssl-server-policy CA_CERT
sdwan server enable
sdwan server port
sdwan ssl-client-policy
Use sdwan ssl-client-policy to specify an SSL client policy on a CPE for the CPE to establish SSL connections with RRs (SDWAN servers).
Use undo sdwan ssl-client-policy to restore the default.
sdwan ssl-client-policy policy-name
No SSL client policy is specified on a CPE for the CPE to establish SSL connections with RRs (SDWAN servers).
context-admin
policy-name: Specifies an SSL client policy by its name, a case-sensitive string of 1 to 31 characters.
Only one SSL client policy can be applied to an SSL connection. If you execute this command multiple times, the most recent configuration takes effect. Modification to this command does not affect existing SDWAN SSL connections. It takes effect only on the SDWAN SSL connections established after the modification.
For more information about SSL client policies, see SSL configuration in Security Configuration Guide.
# On a CPE, specify SSL client policy abc for the CPE to establish SSL connections with RRs (SDWAN servers).
[Sysname] sdwan ssl-client-policy abc
sdwan system-ip
Use sdwan system-ip to specify a system IP address for the device.
Use undo sdwan system-ip to restore the default.
sdwan system-ip [ ipv6 ] interface-type interface-number
No system IP address is specified for the device.
context-admin
ipv6: Specifies an IPv6 system IP address for the device. To specify an IPv4 system IP address for the device, do not specify this keyword.
interface-type interface-number: Specifies an interface by its type and number. The primary IPv4 address of the specified interface is used as the system IP address of the device.
The device uses the system IP address to set up BGP sessions with other devices. In an RIR scenario, the system IP address is also used as the inner destination IP address of probe packets sent by the NQA client in NQA link connectivity probes. For more information about RIR, see Layer 3—IP Routing Configuration Guide.
For this command to take effect, you must specify a loopback interface that has an IP address.
# Specify the primary IPv4 address of Loopback 0 as the IPv4 system IP address of the device.
[Sysname] sdwan system-ip loopback 0
sdwan transport-network
Use sdwan transport-network to specify a transport network for an SDWAN tunnel.
Use undo sdwan transport-network to restore the default.
sdwan transport-network network-name id network-id [ restrict ]
No transport network is specified for an SDWAN tunnel.
context-admin
network-name: Specifies a transport network by its name, a case-sensitive string of 1 to 31 characters. The string can contain only letters, digits, and dots (.).
network-id: Specifies the ID of the transport network, in the range of 1 to 65535.
restrict: Allows only tunnel interfaces that are specified the same routing domain and the same transport network ID to set up TTE connections. If you do not specify this keyword, the system allows tunnel interfaces that are specified the same routing domain to set up TTE connections regardless of whether their transport network IDs are the same.
An SDWAN tunnel interface is connected to a transport network. The transport network is uniquely identified by its name or ID.
# Specify a transport network named abc with ID 2000 for an SDWAN tunnel.
[Sysname-Tunnel1] sdwan transport-network abc id 2000
sdwan vn-id
Use sdwan vn-id to specify a VN ID for a VPN instance.
Use undo sdwan vn-id to restore the default.
sdwan vn-id vn-id
undo sdwan vn-id
The VN ID is 0 for a VPN instance.
VPN instance view.
context-admin
Packets from different tenants can be forwarded through the same SDWAN tunnel. To isolate the tenants, assign them to different VPN instances. Their packets will be distinguished according to the VN IDs of the VPN instances.
You can specify only one VN ID for a VPN instance in the current software version.
# Specify VN ID 123 for VPN instance vpna.
[Sysname-vpn-instance-vpna]  sdwan vn-id 123
