02-HDLC commands | 175.15 KB |
HDLC commands
The following matrixes show support of hardware platform for this feature:
Models |
Feature compatibility |
MSR1008 |
No |
MSR1004-G |
No |
MSR1004-G-5GCN |
No |
MSR2630E-X1 |
Yes |
MSR3610E-X1, MSR3610E-X1-DP |
Yes |
MSR3610-G-X3-DP, MSR3610-G-X3, MSR3610-G-X3-DP-DC, MSR3610-G-X3-DC |
Yes |
Models |
MSR2660-XS |
No |
MSR2680-XS |
Yes |
Models |
MSR2600-12X-WiNet |
No |
MSR2610-13X-WiNet |
Yes |
link-protocol hdlc
Use link-protocol hdlc to enable HDLC encapsulation on an interface.
link-protocol hdlc
PPP encapsulation is enabled on an interface.
Serial interface view
HDLC can transport the network layer protocols, such as IP and IPv6.
On an AC interface of the MPLS L2VPN feature, you cannot enable HDLC encapsulation by using this command. For more information about MPLS L2VPN and AC, see MPLS L2VPN configuration in MPLS Configuration Guide.
# Enable HDLC encapsulation on Serial 0/2/0.
[Sysname] interface serial 0/2/0
[Sysname-Serial0/2/0] link-protocol hdlc
timer-hold
Use timer-hold to set the keepalive interval on an interface.
Use undo timer-hold to restore the default.
timer-hold seconds
undo timer-hold
The keepalive interval is 10 seconds on an interface.
seconds: Specifies the keepalive interval in the range 0 to 32767 seconds.
HDLC uses the polling mechanism to determine whether the link status is normal.
An HDLC-enabled interface can regularly check link status by sending keepalives to the peer at the keepalive interval at the link layer. A keepalive carries the local sender sequence number and the last received sequence number of the peer.
After sending a keepalive, an interface increments the sender sequence number by 1 in the next keepalive when the following conditions exist:
· The interface receives a response within the keepalive interval.
· The response carries the sender sequence number in the sent keepalive.
After sending a keepalive, if the interface does not receive a response within the keepalive interval, it resends the keepalive with an unchanged sequence number. When the keepalive retry limit is reached, the interface considers the link faulty and reports a link layer down event.
Link status check is disabled if you set the keepalive interval to 0.
As a best practice, set the same keepalive interval for the two ends of a link.
If the network has a long delay or is experiencing congestion, you can increase the keepalive interval to prevent the link from being closed.
# Set the keepalive interval to 100 seconds on Serial 0/2/0.
[Sysname-Serial0/2/0] timer-hold 100
timer-hold retry
timer-hold retry
Use timer-hold retry to set the keepalive retry limit on an interface.
Use undo timer-hold retry to restore the default.
timer-hold retry retries
The keepalive retry limit is 5 on an interface.
Pre-defined user roles
retries: Specifies the keepalive retry limit in the range of 1 to 255.
If the network has a long delay or is experiencing congestion, you can increase the keepalive retry limit to prevent the link from being closed.
# Set the keepalive retry limit to 10 on Serial 0/2/0.
[Sysname-Serial0/2/0] timer-hold retry 10
timer-hold
HDLC link bundling commands
bandwidth
Use bandwidth to set the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
HDLC link bundle interface view
The expected bandwidth of an interface is available for service modules (for example, affects the link costs in OSPF), and does not affect the actual interface bandwidth. For more information about link costs in OSPF, see Layer 3—IP Routing Configuration Guide.
# Set the expected bandwidth to 1000 kbps for HDLC link bundle interface 1.
[Sysname] interface hdlc-bundle 1
[Sysname-HDLC-bundle1] bandwidth 1000
bundle id
Use bundle id to assign an interface to an HDLC link bundle.
Use undo bundle id to restore the default.
bundle id bundle-id
undo bundle id
An interface is not assigned to any HDLC link bundle.
bundle-id: Specifies an HDLC link bundle by its number. The value range for this argument is 1 to 10.
An interface can be the member of only one HDLC link bundle. To move an interface from one HDLC link bundle to another HDLC link bundle, remove the interface from the current HDLC link bundle first.
You must enable HDLC encapsulation on an interface to be assigned to an HDLC link bundle. You cannot change the link layer protocol encapsulation of an HDLC link bundle member interface.
You can assign interfaces to an HDLC link bundle before you create the HDLC link bundle.
# Assign Serial 0/2/0 to HDLC link bundle 1.
[Sysname-Serial0/2/0] bundle id 1
bundle load-balance
Use bundle load-balance to set the load balancing mode for an HDLC link bundle interface.
Use undo bundle load-balance to restore the default.
bundle load-balance { per-flow | per-packet }
Per-packet load balancing is used.
per-flow: Specifies per-flow load balancing.
per-packet: Specifies per-packet load balancing.
The following load balancing modes are available:
· Per-flow load balancing—Forwards packets of the same flow out of the same Selected interface. A flow is identified by match criteria.
¡ For IPv4 and IPv6 packets, the match criteria include source IP address and destination IP address.
¡ For MPLS packets, the match criteria are MPLS labels.
· Per-packet load balancing—Distributes packets evenly across all Selected interfaces by using the round-robin method.
When per-packet load balancing is used, the packets sent might be out of order. In contrast, per-flow load balancing prevents this issue.
# Set per-flow load balancing mode for HDLC link bundle interface 1.
[Sysname-HDLC-bundle1] bundle load-balance per-flow
bundle max-active links
Use bundle max-active links to set the maximum number of Selected interfaces allowed in an HDLC link bundle.
Use undo bundle max-active links to restore the default.
bundle max-active links number
The maximum number of Selected interfaces allowed in an HDLC link bundle is the maximum number supported by the device.
number: Specifies the maximum number of Selected interfaces allowed in an HDLC link bundle. The value range for this argument is 1 to 16.
The value specified by using this command cannot be smaller than the value specified by using the bundle min-active links command.
Use the bundle max-active links command together with the bundle member-priority command to make sure both ends of a link always have the same Selected status. The communication fails when one end is Selected but the other end is Unselected.
# Set the maximum number of Selected interfaces allowed in HDLC link bundle 1 to 8.
[Sysname-HDLC-bundle1] bundle max-active links 8
Use bundle member-priority to set the bundling priority value for an HDLC-enabled interface.
Use undo bundle member-priority to restore the default.
bundle member-priority priority
The bundling priority value of an HDLC-enabled interface is 32768.
priority: Specifies the bundling priority value of an HDLC-enabled interface. The value range for this argument is 1 to 65535. A higher priority value means a lower bundling priority.
# Set the bundling priority value to 1 for HDLC-enabled interface Serial 0/2/0.
[Sysname-Serial0/2/0] bundle member-priority 1
bundle min-active bandwidth
Use bundle min-active bandwidth to set the minimum bandwidth required for bringing up an HDLC link bundle interface.
Use undo bundle min-active bandwidth to restore the default.
bundle min-active bandwidth bandwidth
The minimum bandwidth required for bringing up an HDLC link bundle is not set.
bandwidth: Specifies the minimum bandwidth (in kbps) required for bringing up an HDLC link bundle interface. The value range for this argument is 64 to 1342177280.
# Set the minimum bandwidth required for bringing up HDLC link bundle 1 to 1000 kbps.
[Sysname-HDLC-bundle1] bundle min-active bandwidth 1000
Use bundle min-active links to set the minimum number of Selected interfaces required for bringing up an HDLC link bundle interface.
Use undo bundle min-active links to restore the default.
bundle min-active links number
The minimum number of Selected interfaces required for bringing up an HDLC link bundle is not set.
number: Specifies the minimum number of Selected interfaces required for bringing up an HDLC link bundle interface. The value range for this argument is 1 to 16.
The value specified by using this command cannot be greater than the value specified by using the bundle max-active links command.
# Set the minimum number of Selected interfaces required for bringing up HDLC link bundle 1 to 5.
[Sysname-HDLC-bundle1] bundle min-active links 5
default
Use default to restore the default settings for an HDLC link bundle interface.
default
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network. |
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for HDLC link bundle interface 1.
[Sysname-HDLC-bundle1] default
description
The description of an interface is the interface name followed by the Interface string, for example, Hdlc-bundle1 Interface.
text: Specifies an interface description, a case-sensitive string of 1 to 255 characters.
# Set the description of HDLC link bundle interface 1 to HDLC-bundle interface.
[Sysname-HDLC-bundle1] description HDLC-bundle interface
display bundle hdlc-bundle
Use display bundle hdlc-bundle to display information about an HDLC link bundle.
display bundle hdlc-bundle [ bundle-id ] slot slot-number
bundle-id: Specifies an HDLC link bundle by its number. If this argument is not specified, this command displays information for all HDLC link bundles.
slot slot-number: Specifies a card by its slot number.
# Display information about HDLC link bundle 1 on the interface card in 0IRF member device 2.
<Sysname> display bundle hdlc-bundle 1 slot 0
Bundle: HDLC-bundle1, slot 0
max-active links: 2, min-active links: 2, min-active bandwidth: 1000000 kbps
Selected members: 2, Total bandwidth: 1244160 kbps
Member State Bandwidth(kbps) Priority
Serial0/2/0 Selected 622080 1
Serial0/2/1 Selected 622080 2
Bundle |
Name of the HDLC link bundle. |
max-active links |
Maximum number of Selected interfaces allowed in the HDLC link bundle interface. This field will not be displayed if you have not set the limit. |
min-active links |
Minimum number of Selected interfaces required for bringing up the HDLC link bundle interface. This field will not be displayed if you have not set the limit. |
min-active bandwidth |
Minimum bandwidth required for bringing up the HDLC link bundle interface. This field will not be displayed if you have not set the limit. |
Selected members |
Current number of Selected interfaces. |
Total bandwidth |
Total actual bandwidth of all the Selected interfaces in the HDLC link bundle. |
Member |
Name of a member interface. |
State |
State of a member interface: · Selected—On an interface card, only information about Selected interfaces is displayed. · Ready. · Negotiated. · Initial. |
Bandwidth(kbps) |
Actual bandwidth (in kbps) of a member interface. |
Priority |
Bundling priority of a member interface. |
display interface hdlc-bundle
Use display interface hdlc-bundle to display information about an HDLC link bundle interface.
display interface [ hdlc-bundle [ bundle-id ] ] [ brief [ description | down ] ]
hdlc-bundle [ bundle-id ]: Specifies an HDLC link bundle interface by its number. If you do not specify the hdlc-bundle keyword, this command displays information about all interfaces except VA interfaces. If you specify the hdlc-bundle keyword without any HDLC link bundle interface number, this command displays information about all HDLC link bundle interfaces.
brief: Displays brief interface information. If you do not specify this keyword, this command displays detailed interface information.
down: Displays information about interfaces in DOWN state and the link down causes. If you do not specify this keyword, the command displays information about interfaces in all states.
# Display detailed information about HDLC link bundle interface 1.
<Sysname> display interface hdlc-bundle 1
HDLC-bundle1
Current state: UP
Line protocol state: UP
Description: HDLC-bundle1 Interface
Bandwidth: 128kbps
Maximum Transmit Unit: 1500
Hold timer: 10 seconds, retry times: 5
Internet address: 1.1.1.1/24 (primary)
Link layer protocol: HDLC
Physical: HDLC-BUNDLE, baudrate: 128000 bps
Output queue - Urgent queuing: Size/Length/Discards 0/1024/0
Input: 32 packets, 1842 bytes, 0 drops
Output: 27 packets, 1512 bytes, 0 drops
# Display brief information about HDLC link bundle interface 1.
<Sysname> display interface hdlc-bundle 1 brief
Protocol: (s) - spoofing
HDLC-B1 UP UP 1.1.1.2
# Display information about all HDLC link bundle interfaces in down state and the link down reasons.
<Sysname> display interface hdlc-bundle brief down
Interface Link Cause
HDLC-B2 ADM Administratively
Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · UP—The interface is both administratively and physically up. |
Line protocol state |
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer. · UP—The data link layer protocol is up. · DOWN—The data link layer protocol is down. |
Description of the interface. |
Bandwidth |
Expected bandwidth of the interface. |
Maximum Transmit Unit |
MTU on the interface. |
Hold timer |
Keepalive transmission interval of the interface. This field is ineffective for an HDLC link bundle interface because an HDLC link bundle interface does not transmit keepalives. |
Retry times |
Maximum number of keepalive retransmission attempts. A link is removed after the maximum number of retransmission attempts is reached. |
Internet protocol processing: Disabled |
The interface is not assigned an IP address and cannot process IP packets. |
Internet address: ip-address/mask-length (Type) |
IP address of the interface and type of the address in parentheses. Possible IP address types include: · Primary—Manually configured primary IP address. · Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed. · DHCP-allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3—IP Services Configuration Guide. · BOOTP-allocated—BOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3—IP Services Configuration Guide. · PPP-negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2—WAN Access Configuration Guide. · Unnumbered—IP address borrowed from another interface. · Cellular-allocated—IP address allocated through the modem-manufacturer's proprietary protocol. For more information, see mobile communication modem management in Layer 2—WAN Access Configuration Guide. · MTunnel—IP address of the multicast tunnel interface (MTI), which is the same as the IP address of the MVPN source interface. For more information, see multicast VPN configuration in IP Multicast Configuration Guide. |
Link layer protocol |
Link layer protocol encapsulation on the HDLC link bundle interface. |
Physical |
Physical type of the HDLC link bundle interface. |
Baudrate |
Baudrate of the HDLC link bundle interface. |
Output queue - Urgent queuing: Size/Length/Discards 0/1024/0 Output queue - Protocol queuing: Size/Length/Discards 0/500/0 Output queue - FIFO queuing: Size/Length/Discards 0/75/0 |
Traffic statistics for each output queue on the HDLC link bundle interface, including: · The number of packets in the queue (the queue size). · The maximum number of packets that the queue can hold (queue length). · The number of dropped packets. The output queues on the HDLC link bundle interface include the following types: · Urgent queue. · Protocol queue. · FIFO queue. |
Last clearing of counters |
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup. |
Last 300 seconds input rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Last 300 seconds output rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec |
Average incoming and outgoing traffic rates on the interface in the last 300 seconds. |
Input: 32 packets, 1842 bytes, 0 drops |
Incoming traffic size in packets and bytes and the number of dropped incoming packets on the interface. |
Output: 27 packets, 1512 bytes, 0 drops |
Outgoing traffic size in packets and bytes and the number of dropped outgoing packets on the interface. |
Brief information on interfaces in route mode |
Brief information about Layer 3 interfaces. |
Abbreviated interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · DOWN—The data link layer protocol of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces. |
Primary IP |
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address. |
Cause |
Cause for the physical link state of an interface to be DOWN. Administratively indicates that the interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. |
Use interface hdlc-bundle to create an HDLC link bundle interface and enter its view, or enter the view of an existing HDLC link bundle interface.
Use undo interface hdlc-bundle to delete an HDLC link bundle interface.
interface hdlc-bundle bundle-id
undo interface hdlc-bundle bundle-id
No HDLC link bundle interface exists.
# Create HDLC link bundle interface 1 and enter its view.
mtu
Use mtu to set the MTU size for an HDLC link bundle interface.
mtu size
undo mtu
The MTU size of an HDLC link bundle interface is 1500 bytes.
size: Specifies the MTU in bytes for an HDLC link bundle interface. The value range for this argument is 46 to 9600.
The MTU size of an interface affects IP packet fragmentation and reassembly on the interface.
To make the MTU configuration take effect on an interface, you must re-enable the interface by using the shutdown command and the undo shutdown command.
# Set the MTU size of HDLC link bundle interface 1 to 1430 bytes.
[Sysname-HDLC-bundle1] mtu 1430
reset counters interface hdlc-bundle
Use reset counters interface hdlc-bundle to clear the statistics of an HDLC link bundle interface.
reset counters interface [ hdlc-bundle [ bundle-id ] ]
hdlc-bundle [ bundle-id ]: Specifies an HDLC link bundle interface by its number. The value range for this argument is 1 to 10.If you do not specify hdlc-bundle, this command clears the statistics of all interfaces except VA interfaces. If you specify hdlc-bundle but not bundle-id, this command clears the statistics of all HDLC link bundle interfaces. If you specify both hdlc-bundle and bundle-id, this command clears the statistics of the specified HDLC link bundle interface.
Before collecting traffic statistics within a period of time on an interface, you must clear the existing statistics.
# Clear the statistics of HDLC link bundle interface 1.
<Sysname> reset counters interface hdlc-bundle 1
shutdown
Use shutdown to shut down an HDLC link bundle interface.
Use undo shutdown to bring up an HDLC link bundle interface.
shutdown
An HDLC link bundle interface is up.
Executing this command to shut down an interface will make HDLC based on this interface become unavailable. As a best practice, make sure you fully understand the impact before executing this command.
# Shut down HDLC link bundle interface 1.
[Sysname-HDLC-bundle1] shutdown
