- 05-Layer 2—LAN Switching Configuration Guide
- 01-Hardware compatibility with Layer 2 and Layer 3 Ethernet interfaces
- 02-MAC address table configuration
- 03-Ethernet link aggregation configuration
- 04-Port isolation configuration
- 05-VLAN configuration
- 06-VLAN termination configuration
- 07-Loop detection configuration
- 08-Spanning tree configuration
- 09-LLDP configuration
- 10-Layer 2 forwarding configuration
01-Hardware compatibility with Layer 2 and Layer 3 Ethernet interfaces | 49.98 KB |
Interfaces operate differently depending on the hardware structure. For a device:
· Some Ethernet interfaces can operate only as Layer 2 Ethernet interfaces (in bridge mode).
· Some Ethernet interfaces can operate only as Layer 3 Ethernet interfaces (in route mode).
· Some Ethernet interfaces can operate either as Layer 2 or Layer 3 Ethernet interfaces. You can use the port link-mode command to set the link mode to bridge or route for these Ethernet interfaces.
Layer 2 Ethernet interfaces support Layer 2 features, such as MAC address table, port isolation, virtual local area network (VLAN), spanning tree, and more.
Layer 3 Ethernet interface supports Layer 3 features, such as static routing, Open Shortest Path First (OSPF), Intermediate System to Intermediate System (IS-IS), Border Gateway Protocol (BGP), and more.
When you execute the port link-mode command on an interface that supports link mode switchover, the command can be issued correctly. When you execute the port link-mode command on an interface that does not support link mode switchover, the system will print a prompt message.
Support of fixed interfaces on a device for link mode switchover varies by device model. If the device has interface modules installed, see the interface module manuals for information about the interfaces modules and their compatibility with link mode switchover.
Table 1 Support of fixed interfaces on different hardware platforms for link mode switchover
Hardware |
Compatibility |
MSR1008 |
· The following interfaces can operate only in Layer 3 mode: Combo 0 (GE0, SFP0) and Combo 1 (GE1, SFP1). · The following interfaces support link mode switchover: GE2 through GE5, SFP+10, and SFP+11. · The following interfaces can operate only in Layer 2 mode: GE6 through GE9. |
MSR1004-G |
· The following interfaces can operate only in Layer 3 mode: GE0. · The following interfaces support link mode switchover: GE1 through GE4, SFP5, and SFP6. |
MSR1004-G-5GCN |
MSR2630E-X1 |
· The following interfaces can operate only in Layer 3 mode: Combo 0 (GE0, SFP0), Combo 1 (GE1, SFP1), and SFP+10. · The following interfaces support link mode switchover: GE2 through GE5, SFP+11, and SFP+12. · The following interfaces can operate only in Layer 2 mode: GE6 through GE9. |
MSR3610E-X1, MSR3610E-X1-DP |
· The following interfaces can operate only in Layer 3 mode: Combo 0 (GE0, SFP0), Combo 1 (GE1, SFP1), and SFP+10. · The following interfaces support link mode switchover: 10/100/1000BASE-T copper ports 2 through 5, SFP+11, and SFP+12. · The following interfaces can operate only in Layer 2 mode: 10/100/1000BASE-T copper ports 6 through 9. |
MSR3610-G-X3-DP, MSR3610-G-X3, MSR3610-G-X3-DP-DC, MSR3610-G-X3-DC |
The following interfaces can operate only in Layer 3 mode: GE2 through GE5, SFP+6, SFP+7, Combo 0 (GE0, SFP0), Combo 1 (GE1, SFP1). |
Hardware |
Compatibility |
MSR2660-XS |
MSR2680-XS |
Hardware |
Compatibility |
MSR2600-12X-WiNet |
MSR2610-13X-WiNet |
