H3C S6116 Ultra-Low Latency Switch Series Command References-Release 671x-6W101
HomeSupportSwitchesS6116 SeriesReference GuidesCommand ReferencesH3C S6116 Ultra-Low Latency Switch Series Command References-Release 671x-6W101
01-Interface forwarding commands
01-Interface forwarding commands 440.50 KB
connection-interface
Use connection-interface to connect a pair of interfaces.
Use undo connection-interface to remove the configuration.
connection-interface interface-type interface-number1 interface-type interface-number2
undo connection-interface interface-type interface-number1 interface-type interface-number2
No connection is established between interfaces.
This command connects a pair of interfaces. After you execute this command, each interface will be configured as a source interface and a destination interface of the other interface. A packet received Command a source interface will be forwarded out its destination interface.
The source and destination interfaces must be on the same device.
To avoid congestion when traffic is forwarded from a source interface to a destination interface, make sure they are installed with transceiver modules operating at the same speed.
After the connection-interface command is executed, the source-interface command will be issued on the two connected interfaces. After the undo destination-interface command is executed, the source-interface command will be deleted from the two connected interfaces.
In R6712P02 and later versions, the connection-interface command is mutually exclusive with the enhanced-connection destination-interface or enhanced-connection source-interface command.
# Connect interface Ten-GigabitEthernet1/0/1 and Ten-GigabitEthernet1/0/2.
[sysname] connection-interface Ten-GigabitEthernet 1/0/1 Ten-GigabitEthernet 1/0/2
enhanced-connection destination-interface (supported only in R6712P02 and later versions)
enhanced-connection source-interface (supported only in R6712P02 and later versions)
source-interface
demux
Use demux to create a Demux group and enter its view, or enter the view of an existing Demux group.
Use undo demux to restore the default.
demux demux-id fpga fpga-number
undo demux demux-id fpga fpga-number
No Demux group exists.
demux-id: Specifies a Demux group by its ID. In enhanced SecurityMux mode, the value is 1. In multi-group SecurityMux mode, the value range is 1 to 4.
fpga fpga-number: Specifies the FPGA associated with the Demux group. The fpga-number argument specifies an FPGA firmware number.
A Demux group can achieve ultra-low latency traffic forwarding. Packets received from a downstream interface are forwarded out of multiple upstream interfaces.
A Mux group and a Demux group are used together. A Mux group is used to process upstream traffic, and a Demux group is used to process downstream traffic.
Before you can configure a Demux group, you must configure a Mux group.
# Create Demux group 1 and enter its view.
[Sysname] demux 1 fpga 0
[Sysname-demux-group-1-fpga-0]
downstream-port
upstream-port
Use destination-interface to specify the destination interface.
Use undo destination-interface to cancel the configuration.
destination-interface interface-list
undo destination-interface interface-list
No destination interface is specified.
interface-list: Specifies an interface list in the format of interface-list = { interface-type interface-number1 [ to interface-type interface-number2 ] }&<1-24>. The interface-type interface-number argument specifies an interface by its type and number. The & <1- 24> argument indicates that you can specify the preceding parameter for up to 24 times. The value of the interface-type interface-number2 argument cannot be smaller than the value of the interface-type interface-number1 argument. The selected interfaces must reside on the same interface module or submodule.
To enable fast forwarding of packets, you can execute this command to specify a destination interface for the current interface. When the current interface receives a packet, the packet will be forwarded out the specified destination interface. With multiple destination interfaces specified for a source interface, when the source interface receives a packet, a copy of the packet will be forwarded out each of the specified destination interfaces.
The specified destination interface must be on the same device as the current interface.
After the destination-interface command is executed on an interface, the source-interface command will be issued on the specified destination interface. After the undo destination-interface command is executed on an interface, the source-interface command will be deleted from the specified destination interface.
In R6712P02 and later versions, the destination-interface command is mutually exclusive with the enhanced-connection destination-interface or enhanced-connection source-interface command.
# Configure the Ten-GigabitEthernet1/0/2 as the destination interface of Ten-GigabitEthernet1/0/1.
[sysname] interface Ten-GigabitEthernet 1/0/1
[sysname-Ten-GigabitEthernet1/0/1] destination-interface Ten-GigabitEthernet 1/0/2
source-interface
display interface connection
Use display interface connection to display interface connection information.
display interface [ interface-type interface-number ] connection [ source | destination ]
interface-type interface-number: Displays connection information for the specified interface. The interface-type interface-number option specifies an interface by its type and number. If you do not specify this option, the command displays connection information for all interfaces.
source: Displays the source interface connection information for the specified interface. If you specify this keyword, this command displays the source interface connection information only for common L1 connections, rather than enhanced connections. This keyword is supported only in R6712P02 and later versions.
destination: Displays the destination interface connection information for the specified interface. This keyword is supported only in R6712P02 and later versions.
If you do not specify the source or destination keyword, this command displays both source interface connection information and destination interface connection information for the specified interface.
# Display connection information for interface Ten-GigabitEthernet1/0/1.
<Sysname> display interface Ten-GigabitEthernet 1/0/1 connection
Connection(s):
XGE1/0/1 <-> XGE1/0/3
XGE1/0/1 --> XGE1/0/4
# Display connection information for all interfaces.
<Sysname> display interface connection
Connection(s):
         --> XGE1/0/4
XGE1/0/2 --> XGE1/0/5
         <-- XGE1/0/6
XGE1/0/3 <-> XGE1/0/1
XGE1/0/4 <-- XGE1/0/1
XGE1/0/5 <-- XGE1/0/2
XGE1/0/6 --> XGE1/0/2
# Display source interface connection information for all interfaces. (Supported only in R6712P02 and later versions.)
<Sysname> display interface connection source
Port        Status      Speed       Transceiver       Source      State       Tx_fault     Rx_los      Tx_disable     Description
XGE1/0/1    UP          10G         STACK_SFP_PLUS    XGE1/0/2    Present     Normal       Normal      Enabled        --
XGE1/0/2    UP          10G         STACK_SFP_PLUS    XGE1/0/1    Present     Normal       Normal      Enabled        switch1_port1
XGE1/0/3    DOWN        --          No connector      XGE1/0/1    Absent      Normal       Fault       Disabled       port
XGE1/0/4    DOWN        --          No connector      XGE1/0/2    Absent      Normal       Fault       Disabled       --
XGE1/0/5    DOWN        --          No connector      --          Absent      Normal       Fault       Disabled       --
XGE1/0/6    DOWN        --          No connector      --          Absent      Normal       Fault       Disabled       --
XGE1/0/7    DOWN        --          No connector      --          Absent      Normal       Fault       Disabled       --
XGE1/0/8    DOWN        10G         STACK_SFP_PLUS    --          Present     Normal       Normal      Enabled        --
XGE1/0/9    DOWN        --          No connector      --          Absent      Normal       Fault       Disabled       --
XGE1/0/10   DOWN        --          No connector      XGE1/0/10   Absent      Normal       Fault       Disabled       12343455
# Display the source interface connection information for interface Ten-GigabitEthernet 1/0/1. (Supported only in R6712P02 and later versions.)
<Sysname> display interface Ten-GigabitEthernet 1/0/1 connection source
# Display the destination interface connection information for all interfaces. (Supported only in R6712P02 and later versions.)
<Sysname> display interface connection destination
Connection(s):
XGE1/0/1 --> XGE1/0/3, XGE1/0/4
XGE1/0/3 --> XGE1/0/1
XGE1/0/6 --> XGE1/0/2*
# Display the destination interface connection information for Ten-GigabitEthernet 1/0/1. (Supported only in R6712P02 and later versions.)
<Sysname> display interface Ten-GigabitEthernet 1/0/1 connection destination
Connection(s):
# Display the destination interface connection information for interface Ten-GigabitEthernet 1/0/4.
<Sysname> display interface Ten-GigabitEthernet 1/0/4 connection destination
No connection information, or no connected interface.
Connection(s)
Interface connection information:
·     <->—The two interfaces are source and destination interfaces.
·     -->—The interface on the left is the source interface of the interface on the right.
·     <--—The interface on the left is the destination interface of the interface on the right.
·     No connection information, or no connected interface—No source or destination interface is specified for this interface.
·     *—An enhanced connection is established between two interfaces.
source-interface
display interface connection pathed
Use display interface connection pathed to display the connections for two interfaces that act as both the source and destination interfaces of each other.
This command is supported only in R6712P02 and later versions.
# Display the connections for two interfaces that act as both the source and destination interfaces of each other.
<Sysname> display interface connection pathed
Connection(s):
Connection(s)
Interface interconnect information:
·     <->—The two interfaces act as both the source and destination interfaces of each other.
·     No connection information, or no connected interface—No source or destination interface is specified.
display interface transceiver
Use display interface transceiver to display the transceiver modules and source interfaces of interfaces.
# Display the transceiver modules and source interfaces of all interfaces.
<Sysname> display interface transceiver
Interface                    Transceiver type               Source interface
XGE1/0/1                     1000_BASE_SX_SFP(D)            XGE1/0/2
XGE1/0/2                     --                             XGE1/0/1
XGE1/0/3                     --(D)                          XGE1/0/4
XGE1/0/5                     Unknown                        XGE1/0/6
Abbreviated interface name.
Transceiver
Model of the transceiver module.
This field displays if no transceiver module is installed. This field displays (D) if the transceiver tx-disable command has been executed on the interface. This field displays Unknown if no transceiver module information is detected.
Source interface
Abbreviated name of the source interface.
display mux
Use display mux to display information about FastMux, Mux, and Demux groups.
display mux [ mode { fast-mux | mux | demux } [ mux-id fpga fpga-number ] ]
mode: Specifies a Mux type. If you do not specify this keyword, the command displays information for all FastMux, Mux, and Demux groups.
fast-mux: Displays FastMux group information.
mux: Displays Mux group information.
demux: Displays Demux group information.
mux-id: Specifies a FastMux, Mux, or Demux group by its ID. The value range for this argument is 1 to 4. If you do not specify this argument, the command displays information about all FastMux, Mux, and Demux groups.
fpga fpga-number: Specifies the FPGA associated with the group. The fpga-number argument specifies an FPGA firmware number.
# Display information about all FastMux groups.
<Sysname> display mux mode fast-mux
Fast multiplex group 1 fpga 0 (7:1):
Upstream interface: Ten-GigabitEthernet1/0/1
Active Downstream interfaces: Ten-GigabitEthernet1/0/2 to Ten-GigabitEthernet1/0/8
Inactive Downstream interfaces: Ten-GigabitEthernet1/0/9 to Ten-GigabitEthernet1/0/10
Fast multiplex group 2 fpga 0 (7:1):
Upstream interface: Ten-GigabitEthernet1/0/11
Active Downstream interfaces: Ten-GigabitEthernet1/0/12 to Ten-GigabitEthernet1/0/13
Fast multiplex group ID
FastMux group ID and the maximum ratio between the downstream and upstream interfaces in the group.
Multiplex group ID
Mux group ID.
Demultiplex group ID
Demux group ID.
fpga number
Firmware number of the FPGA associated with the FastMux, Mux, or Demux group.
Upstream interface
Upstream interface name.
Name of the downstream interface that takes effect.
Name of the downstream interface that does not take effect.
display this interface connection
Use display this interface connection to display interconnection information of an interface.
# Display interconnection information of interface Ten-GigabitEthernet1/0/1.
[sysname-Ten-GigabitEthernet1/0/1] display this interface connection
Connection(s):
Table 5 Command output
Connection(s)
Interface interconnection information:
downstream-port
Use downstream-port to configure downstream interfaces.
Use undo downstream-port to remove downstream interfaces.
downstream-port interface-list
undo downstream-port [ interface-list ]
No downstream interface exists.
FastMux group view
Mux group view
Demux group view
If you configure an interface as a downstream interface, you cannot configure it as the following interfaces:
·     Upstream interface (configured by using the upstream-port command).
·     Monitor port (configured by using the upstream-port monitportlist command).
·     Monitor port for a local mirroring group (configured by using the mirroring-group monitor-port command).
# In FastMux group view, configure Ten-GigabitEthernet1/0/1 as a downstream interface.
[Sysname] fast-mux 1 type 1 fpga 0
[Sysname-fast-mux-group-1-fpga-0] downstream-port Ten-GigabitEthernet 1/0/1
upstream-port
Use enhanced-connection destination-interface to establish enhanced connections between an interface and the specified destination interfaces.
Use undo enhanced-connection destination-interface to remove enhanced connections between an interface and the specified destination interfaces.
enhanced-connection destination-interface interface-list
undo enhanced-connection destination-interface interface-list
Enhanced connections are not established between an interface and the specified destination interfaces.
interface-list: Specifies a space-separated list of up to 24 destination interface items. Each item specifies an interface by its type and number or specifies a range of interfaces in the form of { interface-type interface-number1 [ to interface-type interface-number2 ] }. When you specify a range of interfaces, the start interface number must be identical to or lower than the end interface number. The selected interfaces must reside on the same interface module or submodule.
Application scenarios
When you configure the patch panel feature, you can use the connection-interface, source-interface, or destination-interface command to establish a forwarding relationship between the source and destination interfaces to enable traffic exchange between these interfaces.
However, in the multi-tier device cascading scenario, the signals might gradually attenuate during the tier-by-tier forwarding process. For example, when a tier-2 device connects to a tier-3 device in a 3-tier network, the signals must be first transmitted from the source interface to the destination interface on the tier-2 device before the signals are sent to the tier-3 device. During this process, signal attenuation might lead to data packet loss, which can affect the normal transmission of packets to the tier-3 device.
Use this feature to resolve the preceding issue.
Operating mechanism
When an interface with this command executed receives packets, the packets will be directly forwarded out the specified destination interface. With multiple destination interfaces specified for a source interface, when the source interface receives a packet, a copy of the packet will be forwarded out each of the specified destination interfaces. At the same time, the device establishes enhanced connections between the current interface and the destination interfaces and modifies the connections in the hardware to change the internal traffic route of the interface. This feature amplifies the signals and ensures no packet loss after multiple tiers of devices are cascaded.
The specified destination interface must be on the same device as the current interface and they must be of the same interface type.
Establishing an enhanced connection consumes one pipe statistics port resource. Because a device has only 13 such resources, you can configure a maximum of 13 enhanced connections between interfaces. Any attempt to create more than 13 enhanced connections will fail.
Do not include the current interface in the specified destination interface list.
After you execute the enhanced-connection destination-interface command, the device will automatically issue the enhanced-connection source-interface command to the destination interfaces.
After you execute the undo enhanced-connection destination-interface command, the device will automatically issue the undo enhanced-connection source-interface command to the destination interfaces to remove the enhanced connections between the current interface and the destination interfaces.
The enhanced-connection destination-interface command is mutually exclusive with any of the following commands:
·     connection-interface
·     destination-interface
·     source-interface
To change the destination interfaces for the enhanced connections between the current interface and the specified destination interfaces:
1.     First, execute the undo enhanced-connection destination-interface command to remove the enhanced connections.
2.     Then, execute the enhanced-connection destination-interface command to establish new enhanced connections.
When you execute this command in interface view, make sure traffic statistics collection has been enabled on the interface by using the counter enable command. After you execute this command, you cannot disable traffic statistics collection on the interface.
# Establish an enhanced connection between interface Ten-GigabitEthernet 1/0/1 and destination interface Ten-GigabitEthernet 1/0/2.
[Sysname] interface Ten-GigabitEthernet 1/0/1
[Sysname-Ten-GigabitEthernet1/0/1] enhanced-connection destination-interface Ten-GigabitEthernet 1/0/2
Use enhanced-connection source-interface to establish an enhanced connection between an interface and the specified source interface.
Use undo enhanced-connection source-interface to remove an enhanced connection between an interface and the specified source interface.
enhanced-connection source-interface interface-type interface-number
An enhanced connection is not established between an interface and the specified source interface.
Operating mechanism
With this command executed on an interface, when the specified source interface receives packets, the packets will be directly forwarded out the current interface. At the same time, the device establishes enhanced connections between the current interface and the source interfaces and modifies the connections in the hardware to change the internal traffic route of the interface. This feature amplifies the signals and ensures no packet loss after multiple tiers of devices are cascaded.
The specified source interface must be on the same device as the current interface and they must be of the same interface type.
Do not configure the current interface as the source interface.
The enhanced-connection source-interface command is mutually exclusive with any of the following commands:
·     source-interface
To change the source interface for the enhanced connection between the current interface and the specified source interface:
1.     First, execute the undo enhanced-connection source-interface command to remove the enhanced connection.
2.     Then, execute the enhanced-connection source-interface command to establish a new enhanced connection.
# Establish an enhanced connection between interface Ten-GigabitEthernet 1/0/2 and destination interface Ten-GigabitEthernet 1/0/1.
[Sysname] interface Ten-GigabitEthernet 1/0/2
[Sysname-Ten-GigabitEthernet1/0/2] enhanced-connection source-interface Ten-GigabitEthernet 1/0/1
fast-mux
Use fast-mux to create a FastMux group and enter its view, or enter the view of an existing FastMux group.
Use undo fast-mux to delete a FastMux group.
fast-mux fast-mux-id type type-id fpga fpga-number
undo fast-mux fast-mux-id [ type type-id ] fpga fpga-number
No FastMux group exists.
fast-mux-id: Specifies a FastMux group by its ID in the range of 1 to 4.
type type-id: Specifies a FastMux group type by its ID in the range of 1 to 2. 1 represents the 7:1 resource group type, and 2 represents the 15:1 resource group type.
fpga fpga-number: Specifies the FPGA associated with the FastMux group. The fpga-number argument specifies an FPGA firmware number.
Configure a FastMux group to implement ultra-low latency traffic forwarding. You can add an upstream interface and multiple downstream interfaces to a FastMux group. Packets from the downstream interfaces are sent to the upstream interface, which lowers latency.
# Create FastMux group 1 and enter its view.
downstream-port
upstream-port
firmware update
Use firmware update to upgrade firmware.
firmware update slot slot-number fpga fpga-number { fast-mux | multi-sec-mux | sec-mux-enhance | tapping-aggr }
slot slot-number: Specifies a device by its number, which is fixed at 1.
fpga fpga-number: Specifies an FPGA by its firmware number.
fast-mux: Specifies a FastMux mode. This application supports four FastMux groups, which separately implement 15:1, 15:1, 7:1, and 7:1 upstream traffic multiplexing ratios with a minimum latency of 35 ns.
multi-sec-mux: Specifies the multi-group SecurityMux mode. It supports four Mux groups and four Demux groups. A Mux group can have one upstream interface. The groups separately implement 7:1, 7:1, 13:1, and 15:1 upstream traffic multiplexing ratios, and 1:7, 1:7, 1:13, 1:15 downstream traffic demultiplexing ratios. This application supports ACL-based packet forwarding control on the outgoing interfaces of downstream traffic. Two monitor ports are used to monitor the traffic of Mux groups.
sec-mux-enhance: Specifies the enhanced SecurityMux mode. In this mode, a Mux group can have two upstream interfaces. This application supports a maximum upstream traffic multiplexing ratio of 46:2 and a maximum downstream demultiplexing ratio of 2:46. This application supports ACL-based packet forwarding control on the outgoing interfaces of upstream or downstream traffic.
tapping-aggr: Specifies the tapping aggregation mode, which supports mirroring traffic to other interfaces.
If a switch has two FPGAs, you can specify different modes for them. For the H3C developed modes (multi-sec-mux, fast-mux, sec-mux-enhance, and tapping-aggr), the first FPGA supports all modes, and the second FPGA supports only the tapping aggregation mode. The device does not support user-developed modes.
To successfully change the FPGA mode, first delete the FastMux groups, Mux groups, Demux groups, monitor ports for tapping aggregation, applied QoS policies, and packet filters (packet-filter) in the current mode.
To upgrade the FPGA by using an H3C developed mode, specify the multi-sec-mux, fast-mux, sec-mux-enhance, or tapping-aggr keyword.
# Upgrade the FPGA firmware to the FastMux mode.
<Sysname> firmware update slot 1 fpga 0 fast-mux
Updating firmware for FPGA on the specified card or subcard. Continue?[Y/N]:y
Updating the firmware.............................Done.
mux
Use mux to create a Mux group and enter its view, or enter the view of an existing Mux group.
Use undo mux to restore the default.
mux mux-id fpga fpga-number
undo mux mux-id fpga fpga-number
No Mux group exists.
mux-id: Specifies a Mux group by its ID. In enhanced SecurityMux mode, the value is 1. In multi-group SecurityMux mode, the value range is 1 to 4.
fpga fpga-number: Specifies the FPGA associated with the Mux group. The fpga-number argument specifies an FPGA firmware number.
A Mux group can achieve ultra-low latency traffic forwarding. You can add one upstream interface and multiple downstream interfaces to a Mux group. Packets from the downstream interfaces are sent to the upstream interface, which lowers latency.
Before you can modify or delete a Mux group, you must delete all Demux groups on the switch.
Before you modify a Mux group, first delete the existing Demux groups from the device. Deleting a Mux group will also delete the existing Demux groups from the device.
# Create Mux group 1 and enter its view.
[Sysname] mux 1 fpga 0
[Sysname-mux-group-1-fpga-0]
downstream-port
upstream-port
source-interface
Use source-interface to specify the source interface.
Use undo source-interface to restore the default.
No source interface is specified.
To enable fast forwarding of packets, you can execute this command to specify a source interface for the current interface. When the source interface receives a packet, the packet will be directly forwarded out the current interface.
The specified source interface must be on the same device as the current interface.
As a best practice, do not configure multiple interfaces for cascading. If you do that, interfaces might flap. For example, after you use the source-interface command to configure interface B as the source interface for interface A, do not configure interface A as the source interface for other interfaces.
In R6712P02 and later versions, the source-interface command is mutually exclusive with the enhanced-connection destination-interface or enhanced-connection source-interface command.
# Configure Ten-GigabitEthernet1/0/2 as the source interface of Ten-GigabitEthernet1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] source-interface Ten-GigabitEthernet 1/0/2
Use transceiver tx-disable to disable the transceiver module installed in an interface from sending packets.
Use transceiver tx-enable to enable the transceiver module installed in an interface to send packets.
transceiver { tx-disable | tx-enable }
A transceiver module installed in an interface can send packets.
After a connection is established, executing the transceiver tx-disable command will interrupt the connection.
·     When a 10-Gbps transceiver module is installed in an SFP+ interface, both the local and peer interface will go down.
·     When a 1-Gbps transceiver module is installed in an SFP+ interface, the local interface status will not change, while the peer interface will go down.
# Disable the transceiver module installed in interface Ten-GigabitEthernet1/0/1 from sending packets.
[Sysname-Ten-GigabitEthernet1/0/1] transceiver tx-disable
# Enable the transceiver module installed in interface Ten-GigabitEthernet1/0/1 to send packets.
[Sysname-Ten-GigabitEthernet1/0/1] transceiver tx-enable
upstream-port
Use upstream-port to configure upstream interfaces.
Use undo upstream-port to delete upstream interfaces.
FastMux group view/Mux group view:
upstream-port interface-list [ monitportlist interface-list | redirect-mode mode-number ]
undo upstream-port interface-list [ monitportlist interface-list | redirect-mode mode-number ]
Demux group view:
No upstream interfaces exist.
FastMux group view
Mux group view
Demux group view
monitportlist interface-list: Specifies the monitor port list. If you do not specify this option, the traffic is forwarded to only upstream interfaces.
redirect-mode mode-number: Specifies a redirection mode by its number in the range of 0 to 1. The default value for the mode-number argument is 0. The redirection modes are as follows:
·     0—Forwards packets to the upstream interface and copies them to the monitor ports. These interfaces use the same FPGA.
·     1—Forwards packets to the upstream interface and copies them to the monitor ports and the internal interface on the FPGA in tapping aggregation mode. Traffic on the internal interface of the FPGA in tapping aggregation mode is forwarded out of monitor ports on the FPGA.
Redirection mode 1 is supported only on devices that have two FPGAs.
You can execute this command multiple times to configure multiple upstream interfaces or configure the mapping interface list and redirection mode for an upstream interface.
If you configure an interface as an upstream interface, you cannot configure it as the following interfaces:
·     Monitor port (configured by using the monitportlist interface-list option in the upstream-port command).
·     Downstream interface.
If you configure an interface as a monitor port by using the monitportlist interface-list option in the upstream-port command, you cannot configure it as the following interfaces:
·     Upstream interface.
·     Source interface.
·     Destination interface.
·     Monitor port for another upstream port (configured by using the upstream-port interface-list monitportlist interface-list command).
In R6712P02 and later versions, when the L1 forwarding source interface (source-interface) and the L1 forwarding destination interface (destination-interface) are the same, do not configure the interface as the upstream interface (upstream-port interface-list) of a Mux or Demux group.
The upstream interface statistics of a FastMux group occupy pipe port statistics resources. If L1 interfaces use all 13 pipe port statistics resources, traffic statistics cannot be collected for upstream interfaces in a FastMux group.
# In FastMux group view, configure Ethernet interface Ten-GigabitEthernet1/0/1 as an upstream interface.
[Sysname-fast-mux-group-1] upstream-port Ten-GigabitEthernet 1/0/1
downstream-port
Port mirroring
display mirroring-group
Use display mirroring-group to display mirroring group information.
display mirroring-group { group-id [ interface interface-type interface-number ] | all | local }
group-id: Specifies a mirroring group by its number. The value range for this argument is 1.
interface interface-type interface-number: Displays the statistics of an interface specified by its type and number in a mirroring group. If this option is not specified, this command displays the mirroring group information. This option is supported only in R6712P02 and later versions. Specifying this option will display statistics for the specified interface in the mirroring group only when the FPGA mode is set to tapping-aggr (FPGA aggregation mode).
all: Specifies all mirroring groups.
local: Specifies local mirroring groups.
Mirroring group information includes the type, status, and content of a mirroring group. It is sorted by mirroring group number.
# Display information about all mirroring groups.
<Sysname> display mirroring-group all
Mirroring group 1:
    FPGA: 1
    Type: Local
    Status: Active
    Mirroring mux group:
        Mux-downstream 1 FPGA 0  Inbound
          Input : 0 packets, 0 bytes
                  0 unicasts, 0 broadcasts, 0 multicasts
                  0 drops, 0 CRC
    Monitor port:
          Output: 0 packets, 0 bytes
# Display information about the specified source interface of mirroring group 1. (Supported only in R6712P02 and later versions.)
<Sysname> display mirroring-group 1 interface Ten-GigabitEthernet1/0/5
Ten-GigabitEthernet1/0/5:
  mirroring-group 1 mirroring-port inbound
  Input:
Total: 0 packets, 0 bytes
       0 drops, 0 CRC
1519-n   : 0 packets
1024-1518: 0 packets
512-1023 : 0 packets
256-511  : 0 packets
128-255  : 0 packets
65-127   : 0 packets
n-64     : 0 packets
Table 6 Command output
Mirroring group
Number of the mirroring group.
Type of the mirroring group:
·     Local.
·     Remote source.
·     Remote destination.
Status
Status of the mirroring group:
·     Active—The mirroring group has taken effect.
·     Incomplete—The mirroring group configuration is not complete and does not take effect.
FPGA
FPGA associated with a mirroring group.
Mirroring port
Source port.
Mirroring mux group
Source mux group.
Mux-downstream 1 FPGA 0 inbound
Mirrors only packets received on downstream interfaces in mux group 1 associated with FPGA 0.
Monitor port
Destination port.
Input
Input mirrored packets. This field is supported only in R6712P02 and later versions.
Output
Output mirrored packets. This field is supported only in R6712P02 and later versions.
Inbound
Packets received on interfaces are mirrored. This field is supported only in R6712P02 and later versions.
Total
Interface traffic statistics for the mirroring group. This field is supported only in R6712P02 and later versions.
packets
Total number of packets. This field is supported only in R6712P02 and later versions.
bytes
Total number of bytes. This field is supported only in R6712P02 and later versions.
unicasts
Number of unicast packets. This field is supported only in R6712P02 and later versions.
broadcasts
Number of broadcast packets. This field is supported only in R6712P02 and later versions.
multicasts
Number of multicast packets. This field is supported only in R6712P02 and later versions.
drops
Number of dropped packets. This field is supported only in R6712P02 and later versions.
CRC
Number of CRC error packets. This field is supported only in R6712P02 and later versions.
1519-n
Number of packets larger than 1519 bytes. This field is supported only in R6712P02 and later versions.
n-64
Number of packets smaller than 64 bytes. This field is supported only in R6712P02 and later versions.
1024-1518
Number of packets with lengths in the range of 1024 to 1518 bytes. This field is supported only in R6712P02 and later versions.
512-1023
Number of packets with lengths in the range of 512 to 1023 bytes. This field is supported only in R6712P02 and later versions.
256-511
Number of packets with lengths in the range of 256 to 511 bytes. This field is supported only in R6712P02 and later versions.
128-255
Number of packets with lengths in the range of 128 to 255 bytes. This field is supported only in R6712P02 and later versions.
65-127
Number of packets with lengths in the range of 65 to 127 bytes. This field is supported only in R6712P02 and later versions.
mirroring-group
Use mirroring-group to create a mirroring group.
Use undo mirroring-group to delete mirroring groups.
mirroring-group group-id local fpga fpga-number
undo mirroring-group { group-id | all | local }
No mirroring groups exist.
group-id: Specifies a mirroring group ID. The value range for this argument is fixed at 1.
fpga fpga-number: Specifies a Field Programmable Gate Array (FPGA). The fpga-number argument specifies an FPGA firmware number. You must specify an FPGA firmware number in multi-group SecurityMux mode or tapping aggregation mode.
Only one mirroring group is supported.
# Create local mirroring group 1.
[Sysname] mirroring-group 1 local fpga 1
mirroring-group mirroring-mux
Use mirroring-group mirroring-mux to configure a source mux group for a local FPGA mirroring group.
Use undo mirroring-group mirroring-mux to delete the specified source mux group from a local FPGA mirroring group.
mirroring-group group-id mirroring-mux { demux-downstream demux-id | fast-mux-downstream fast-mux-id| mux-downstream mux-id } fpga fpga-number inbound
undo mirroring-group group-id mirroring-mux { fast-mux-downstream fast-mux-id| mux-downstream mux-id } fpga fpga-number
No source mux group is configured for a local FPGA mirroring group.
group-id: Specifies a mirroring group by its ID. The mirroring group ID is fixed at 1, and the mirroring group must have been created.
demux-downstream demux-id: Specifies downstream interfaces in a Demux group. The demux-id argument specifies a Demux group by its ID in the range of 1 to 4.
fast-mux-downstream fast-mux-id: Specifies downstream interfaces in a FastMux group. The fast-mux-id argument specifies a FastMux group by its ID in the range of 1 to 4.
mux-downstream mux-id: Specifies downstream interfaces in a Mux group. The mux-id argument specifies a mux group by its ID in the range of 1 to 4.
inbound: Mirrors only incoming packets of downstream interfaces.
In R6712P02 and later versions, if you configure an interface as a source interface of a mirroring group, the interface can come up without L1 or L1.5 connection configuration.
# Create local mirroring group 1, configure downstream interfaces in the FastMux group as the source interfaces of the mirroring group, and mirrors only incoming packets of downstream interfaces.
[Sysname] mirroring-group 1 fast-mux-downstream 1 fpga 0 inbound
mirroring-group
mirroring-group mirroring-port (interface view)
Use mirroring-group mirroring-port to configure a port as a source port for a mirroring group.
Use undo mirroring-group mirroring-port to restore the default.
mirroring-group group-id mirroring-port inbound
undo mirroring-group group-id mirroring-port
A port does not act as a source port for any mirroring groups.
Interface view
inbound: Mirrors only received packets.
A source port cannot be used as the monitor port of its mirroring group. A monitor port cannot be used as a source port.
# Create local mirroring group 1, configure Ten-GigabitEthernet1/0/1 as its source interface, and mirrors only received packets.
[Sysname-Ten-GigabitEthernet1/0/1] mirroring-group 1 mirroring-port inbound
mirroring-group
mirroring-group mirroring-port (system view)
Use mirroring-group mirroring-port to configure source ports for a mirroring group.
Use undo mirroring-group mirroring-port to remove source ports from a mirroring group.
mirroring-group group-id mirroring-port interface-list inbound
undo mirroring-group group-id mirroring-port interface-list
No source port is configured for a mirroring group.
interface-list: Specifies a space-separated list of up to eight interface items. Each item specifies an interface by its type and number or specifies a range of interfaces in the form of interface-type interface-number1 to interface-type interface-number2. When you specify a range of interfaces, the interfaces must be of the same type and on the same slot. The start interface number must be identical to or lower than the end interface number.
[Sysname] mirroring-group 1 mirroring-port ten-gigabitethernet 1/0/1 inbound
mirroring-group
mirroring-group monitor-port (interface view)
Use mirroring-group monitor-port to configure a port as the monitor port for a mirroring group.
Use undo mirroring-group monitor-port to restore the default.
mirroring-group group-id monitor-port
undo mirroring-group group-id monitor-port
A port does not act as the monitor port for any mirroring groups.
Interface view
A maximum of four mirroring destination interfaces are supported.
If you configure an interface as the monitor port in a mirroring group, you cannot configure it as the following interfaces:
·     Source interface.
·     Monitor port (configured by using the upstream-port interface-list monitportlist interface-list command).
·     Source port of the mirroring group (configured by using the mirroring-group group-id mirroring-port interface-type interface-number command).
# Create local mirroring group 1, and specify Ten-GigabitEthernet1/0/1 as the destination interface.
[Sysname-Ten-GigabitEthernet1/0/1] mirroring-group 1 monitor-port
mirroring-group
mirroring-group monitor-port (system view)
Use mirroring-group monitor-port to configure the monitor ports for a mirroring group.
Use undo mirroring-group monitor-port to remove the monitor ports from a mirroring group.
mirroring-group group-id monitor-port interface-type interface-number
undo mirroring-group group-id monitor-port interface-type interface-number
No monitor port is configured for a mirroring group.
·     Source interface.
[Sysname] mirroring-group 1 monitor-port ten-gigabitethernet 1/0/1
mirroring-group
Traffic filtering commands
acl
Use acl to create an ACL and enter its view, or enter the view of an existing ACL.
Use undo acl to delete the specified or all ACLs.
Command for creating an IPv4 ACL by specifying a number:
acl { name acl-name | number acl-number [ name acl-name ] [ match-order config ] }
undo acl { all | name acl-name | number acl-number }
Command for creating an IPv4 ACL by specifying the advanced keyword:
acl { advanced } { acl-number | name acl-name } [ match-order config ]
undo acl { all | { advanced } { acl-number | name acl-name } }
No ACLs exist.
advanced: Specifies the advanced ACL type.
acl-number: Assigns a number to the ACL. The value range is 3000 to 3999 for advanced ACLs.
name acl-name: Assigns a name to the ACL. The acl-name argument is a case-insensitive string of 1 to 63 characters. It must start with an English letter and to avoid confusion, it cannot be all.
match-order config: Compares ACL rules against packets in ascending order of rule ID.
all: Specifies all ACLs of the specified type.
If you create a numbered ACL, you can enter the view of the ACL by using either of the following commands:
·     acl number acl-number
·     acl advanced acl-number
If you create an ACL by using the acl number acl-number name acl-name command, you can enter the view of the ACL by using either of the following commands:
·     acl name acl-name (you can use this command to enter only the view of an existing ACL)
·     acl number acl-number [ name acl-name ]
·     acl advanced  name acl-name
If you create a named ACL by using the acl advanced name acl-name command, you can enter the view of the ACL by using either of the following commands:
You can change the match order only for ACLs that do not contain any rules.
# Create IPv4 advanced ACL 3000 and enter its view.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000]
display acl
display acl
Use display acl to display ACL configuration and match statistics.
display acl { acl-number | all | name acl-name }
acl-number: Specifies an advanced ACL by its number in the range of 3000 to 3999.
name acl-name: Specifies an ACL by its name. The acl-name argument is a case-insensitive string of 1 to 63 characters.
This command displays ACL rules in config or auto order, whichever is configured.
# Display configuration and match statistics for IPv4 advanced ACL 3001.
<Sysname> display acl 3001
Advanced IPv4 ACL 3000, 1 rule,
ACL's step is 5, start ID is 0
 rule 0 deny tcp source 100.1.1.1 0
display buffer usage interface
Use display buffer usage interface to display buffer usage statistics for interfaces.
display buffer usage interface [ interface-type [ interface-number ] ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify the interface-type argument, this command displays buffer usage statistics for all Ethernet interfaces. If you specify the interface-type argument without the interface-number argument, this command displays buffer usage statistics for all Ethernet interfaces of the specified type.
# Display brief buffer usage statistics for GigabitEthernet 1/0/1.
<Sysname> display buffer usage interface ten-gigabitethernet 1/0/1
Interface              QueueID Total       Used        Threshold(%) Violations
XGE1/0/1               0       65536       0           60           0
                       1       0           0           60           0
                       2       0           0           60           0
                       3       0           0           60           0
                       4       0           0           60           0
                       5       0           0           60           0
                       6       0           0           60           0
                       7       0           0           60           0
Table 7 Command output
Interface name.
QueueID
Queue number. The device currently only supports queue 0.
Total
Data buffer size in bytes allowed for a queue.
Used
Data buffer size in bytes that has been used by a queue.
Threshold(%)
Buffer usage threshold for a queue. The threshold value is the same as the per-interface threshold value. This field is fixed at 60 and does not support modification currently.
Violations
Number of threshold violations for a queue.
The value of this field is reset upon a switch reboot.
display qos policy interface
Use display qos policy interface to display the QoS policies applied to interfaces.
display qos policy interface [ interface-type interface-number ] [ outbound ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays QoS policies applied to all interfaces.
outbound: Specifies the QoS policies applied to the outbound direction.
# Display the QoS policy applied to the outgoing traffic of Ten-GigabitEthernet1/0/1.
<Sysname> display qos policy interface ten-gigabitethernet 1/0/1
  Direction: Outbound
  Policy: p1
   Classifier: c1
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: b1
      Filter enable: Deny
   Classifier: c2
     Operator: AND
     Rule(s) :
      If-match acl 3000
     Behavior: b2
      Filter enable: Permit
filter
Use filter to configure a traffic filtering action in a traffic behavior.
Use undo filter to restore the default.
filter { deny | permit }
undo filter
No traffic filtering action is configured.
Traffic behavior view
deny: Drops packets.
permit: Transmits packets.
# Configure a traffic filtering action as deny in traffic behavior database.
if-match
Use if-match to define a match criterion.
Use undo if-match to delete a match criterion.
if-match match-criteria
undo if-match match-criteria
No match criterion is configured.
Traffic class view
match-criteria: Specifies a match criterion. Table 8 shows the available match criteria.
Table 8 Available match criteria
Value
acl { acl-number | name acl-name }
Matches an ACL.
·     The acl-number argument is an integer in the range of 3000 to 3999.
·     The acl-name argument is a case-insensitive string of 1 to 63 characters, which must start with an English letter. To avoid confusion, make sure the argument is not all.
any
Matches all packets.
In a traffic class, you can configure multiple if match commands for any of the available match criteria.
When you configure ACL-based match criteria, make sure the ACL used as a match criterion already exists.
When the action of the ACL rule used by an if-match criterion is deny, the ACL rule action does not take effect, and the action defined in the traffic behavior is used.
# Define a match criterion for traffic class class1 to match ACL 3101.
qos apply policy (interface view)
Use qos apply policy to apply a QoS policy to an interface.
Use undo qos apply policy to remove an applied QoS policy.
qos apply policy policy-name outbound
undo qos apply policy policy-name outbound
No QoS policy is applied.
Interface view
policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters.
outbound: Applies the QoS policy to the outbound direction.
If you apply QoS policies both globally and to an interface, the QoS configuration on the interface takes priority. If no configuration is applied to an interface, the global configuration will be used.
In versions earlier than R6712P03, each interface supports a maximum of eight ACL rules. In the allowlist feature, the rule used to deny all traffic is also counted as one ACL rule.
In R6712P03 and later versions, each interface supports up to four ACL rules. In the allowlist feature, the rule used to deny all traffic is also counted as one ACL rule.
If you perform either of the following operations when continuous traffic exists on the device, the actions on the packets passed will not match correctly within a short period of time:
·     Apply a QoS policy globally and then apply it to an interface.
·     Apply a QoS policy to an interface and then apply it globally.
# Apply QoS policy TEST1 to the outgoing traffic of Ten-GigabitEthernet1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply policy TEST1 outbound
qos apply policy global
Use qos apply policy global to apply a QoS policy globally.
Use undo qos apply policy global to remove a globally applied QoS policy.
qos apply policy policy-name global outbound
undo qos apply policy policy-name global outbound
No QoS policy is applied globally.
A QoS policy applied globally takes effect on traffic of all interfaces.
# Globally apply generic QoS policy user1 to the outgoing traffic.
[Sysname] qos apply policy user1 global outbound
qos policy
Use qos policy to create a QoS policy and enter its view, or enter the view of an existing QoS policy.
Use undo qos policy to delete a QoS policy.
qos policy policy-name
undo qos policy policy-name
No QoS policies exist.
policy-name: Specifies a name for the QoS policy, a case-sensitive string of 1 to 31 characters.
To delete a QoS policy that has been applied to an object, you must first remove the QoS policy from the object.
# Create a generic QoS policy named user1.
[Sysname] qos policy user1
[Sysname-qospolicy-user1]
qos apply policy
rule (IPv4 advanced ACL view)
Use rule to create or edit an IPv4 advanced ACL rule.
Use undo rule to delete an entire IPv4 advanced ACL rule or some attributes in the rule.
rule [ rule-id ] { deny | permit } protocol [ destination dest-address dest-wildcard | destination-port operator port1 [ port2 ] | source source-address source-wildcard  | source-port operator port1 [ port2 ] ]*
undo rule [ rule-id ] { deny | permit } protocol [ destination dest-address dest-wildcard | destination-port operator port1 [ port2 ] | source source-address source-wildcard | source-port operator port1 [ port2 ] ]*
No IPv4 advanced ACL rules exist.
rule-id:: Specifies a rule ID in the range of 0 to 65534. If you do not specify a rule ID when creating an ACL rule, the system automatically assigns it a rule ID. This rule ID is the nearest higher multiple of the numbering step to the current highest rule ID, starting from the start rule ID. For example, if the rule numbering step is 5 and the current highest rule ID is 28, the rule is numbered 30.
deny: Denies matching packets.
permit: Allows matching packets to pass.
protocol: Specifies a protocol carried over IPv4 by its number in the range of 0 to 255 or by its keyword, as shown in Table 9. Versions earlier than R6712P02 only support matching TCP and UDP protocol packets.
Table 9 Protocols carried over IPv4
Number
Keyword
N/A
ip
Matches IPv4 packets. (Supported only in R6712P03 and later versions.)
1
icmp
Matches ICMP packets. (Supported only in R6712P02 and later versions.)
2
igmp
Matches IGMP packets. (Supported only in R6712P02 and later versions.)
4
ipinip
Matches IP-in-IP packets. (Supported only in R6712P02 and later versions.)
6
tcp
Matches TCP packets.
17
udp
Matches UDP packets.
47
gre
Matches GRE packets. (Supported only in R6712P02 and later versions.)
89
ospf
Matches OSPF packets. (Supported only in R6712P02 and later versions.)
Table 10 describes the parameters that you can specify, regardless of the value for the protocol argument.
Table 10 Match criteria and other rule information for IPv4 advanced ACL rules
Function
Specifies a source IPv4 address.
The source-address argument specifies an IPv4 source address.
The source-wildcard argument specifies the wildcard mask of the source address. 0 represents host address.
Specifies a destination IPv4 address.
The dest-address argument specifies a destination IPv4 address.
The dest-wildcard argument specifies the wildcard mask of the destination address. 0 represents host address.
Table 11 TCP/UDP-specific parameters for IPv4 advanced ACL rules
Function
Specifies one or more UDP or TCP source ports.
The operator argument can be lt (lower than), gt (greater than), eq (equal to), or range (inclusive range).
The port1 and port2 arguments are TCP or UDP port numbers in the range of 0 to 65535. The port2 argument is needed only when the operator argument is range.
TCP port numbers can be represented as: chargen (19), bgp (179), cmd (514), daytime (13), discard (9), dns (53), domain (53), echo (7), exec (512), finger (79), ftp (21), ftp-data (20), gopher (70), hostname (101), irc (194), klogin (543), kshell (544), login (513), lpd (515), nntp (119), pop2 (109), pop3 (110), smtp (25), sunrpc (111), tacacs (49), talk (517), telnet (23), time (37), uucp (540), whois (43), and www (80).
UDP port numbers can be represented as: biff (512), bootpc (68), bootps (67), discard (9), dns (53), dnsix (90), echo (7), mobilip-ag (434), mobilip-mn (435), nameserver (42), netbios-dgm (138), netbios-ns (137), netbios-ssn (139), ntp (123), rip (520), snmp (161), snmptrap (162), sunrpc (111), syslog (514), tacacs-ds (65), talk (517), tftp (69), time (37), who (513), and xdmcp (177).
Specifies one or more UDP or TCP destination ports.
If the specified rule does not exist when you execute the rule command, the command automatically creates the rule. If the specified rule already exists, the command appends the new configuration to the rule.
Within an ACL, the permit or deny statement of each rule must be unique. If the rule you are creating or editing has the same deny or permit statement as another rule in the ACL, the rule will not be created or changed.
You can edit ACL rules only when the match order is config.
To view the existing IPv4 advanced ACL rules, use the display acl all command.
An ACL supports matching only the 5-tuple (source IP, destination IP, source port, destination port, and protocol type).
The undo rule rule-id command without any optional parameters deletes an entire rule. If you specify optional parameters, the undo rule rule-id command deletes the specified attributes for a rule.
The undo rule { deny | permit } command can only be used to delete an entire rule. You must specify all the attributes of the rule for the command.
When you configure the denylist feature, you cannot configure permit rules. For the allowlist feature, you must configure the first rule as rule 0 deny ip, and you can configure only permit rules subsequently.
To configure an IPv4 allowlist:
1.     In the same ACL, configure the first rule as rule 0 deny ip, and configure permit rules subsequently.
2.     Reference the IPv4 ACL in the traffic or packet filtering feature.
After you configure the ACL allowlist feature, rule 0 deny ip will filter all packets, including IPv4 packets and those not of the 0x0800 type.
# Create an IPv4 advanced ACL rule to permit devices in the 129.9.0.0/16 network to establish connections with devices (WWW port 80) in the 202.38.160.0/24 network.
[Sysname-acl-ipv4-adv-3000] rule permit tcp source 129.9.0.0 0.0.255.255 destination 202.38.160.0 0.0.0.255 source-port eq 80 destination-port eq 80
acl
display acl
classifier behavior
Use classifier behavior to associate a traffic behavior with a traffic class in a QoS policy.
Use undo classifier to delete a class-behavior association from a QoS policy.
classifier classifier-name behavior behavior-name
No traffic behavior is associated with a traffic class.
QoS policy view
classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters.
behavior-name: Specifies a traffic behavior by its name, a case-sensitive string of 1 to 31 characters.
A traffic class can be associated only with one traffic behavior in a QoS policy.
If the specified traffic class or traffic behavior does not exist, the system defines a null traffic class or traffic behavior.
# Associate traffic class database with traffic behavior test in QoS policy user1.
qos policy
traffic classifier
Use traffic classifier to create a traffic class and enter traffic class view, or enter the view of an existing traffic class.
Use undo traffic classifier to delete a traffic class.
No traffic class exists.
operator: Sets the operator to logic AND (the default) or OR for the traffic class.
and: Specifies the logic AND operator. The traffic class matches the packets that match all its criteria.
or: Specifies the logic OR operator. The traffic class matches the packets that match any of its criteria.
# Create a traffic class named class1.
Ethernet interface commands
counter enable
Use counter enable to enable traffic statistics collection on an interface.
Use undo counter enable to disable traffic statistics collection on an interface.
counter enable
undo counter enable
Traffic statistics collection is enabled on an interface.
This command can count the numbers of incoming packets and outgoing packets on an interface. You can use the display counters command to display the statistics.
This command occupies statistics resources (13 in total) of the device, which are assigned by chips. After the device reboots or performs a configuration rollback, statistics resources might not be released and allocation of statistics resources might be affected.
As a best practice to prevent the peer interface from failing to come up, do not disable this feature.
To successfully execute the following commands, make sure traffic statistics collection is enabled:
·     enhanced-connection destination-interface
·     enhanced-connection source-interface
# Enable traffic statistics collection on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] counter enable
display counters
description
Use description to configure a description for the interface.
Use undo description  to restore the default.
The description of an interface is interface-name Interface, for example, Ten-GigabitEthernet1/0/1  Interface.
text: Specifies an interface description, a case-sensitive string of 1 to 255 characters.
# Configure lan-interface as the description of interface Ten-GigabitEthernet1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] description lan-interface
display counters
Use display counters to display traffic statistics information about an interface.
display counters { inbound | outbound } [ packet-size ] interface [ interface-type [ interface-number] ]
inbound: Displays incoming packet statistics information.
outbound: Displays outgoing packet statistics information.
packet-size: Displays packet length statistics. If you do not specify this keyword, this command does not display packet length statistics.
If you do not specify an interface type, this command displays traffic statistics information about all interfaces.
If you specify an interface type without specifying an interface number, this command displays traffic statistics information about all interfaces of the specified type.
If you specify an interface type and an interface number, this command displays traffic statistics information about the specified interface.
# Display incoming packet statistics information.
<Sysname> display counters inbound interface
Interface            Total (pkts)    Broadcast (pkts)    Multicast (pkts)  Err (pkts)
XGE1/0/1                      100                 100                   0           0
XGE1/0/2                 Overflow            Overflow            Overflow    Overflow
 Overflow: More than 14 digits (7 digits for column "Err").
       --: Not supported.
# Display the packet length statistics of inbound traffic on the specified interface.
<Sysname> display counters inbound  packet-size interface Ten-GigabitEthernet1/0/15
Interface         Total(pkts)         64(pkts)     65-127(pkts)
                                 128-255(pkts)    256-511(pkts)
                                512-1023(pkts)  1024-1518(pkts)
                                                   1519-n(pkts)
XGE1/0/15          2291577996                0         59734692
                                     200264828        400496210
                                     801023051        774421193
                                                       55521782
 Overflow: More than 14 digits.
       --: Not supported.
Table 12 Command output
Total (pkts)
Total number of packets received or sent by the interface.
Broadcast (pkts)
Number of broadcast packets received or sent by the interface.
Multicast (pkts)
Number of multicast packets received or sent by the interface.
Err (pkts)
Number of error packets received or sent by the interface.
If the length of the value for a statistics item exceeds the display limit, the value for the statistics item displays Overflow.
·     For the Err item, the display limit is 7 decimal digits.
·     For other items, the display limit is 14 decimal digits.
--: Not supported.
If statistics for a field is not supported, the value for this field displays --.
64 (pkts)
Number of packets no longer than 64 bytes. This field is supported only in R6712P02 and later versions.
65-127 (pkts)
128-255 (pkts)
256-511 (pkts)
512-1023 (pkts)
1024-1518 (pkts)
1519-n (pkts)
display counters rate
Use display counters rate to display traffic rate statistics for interfaces in up state within the most recent statistics polling interval.
display counters rate { inbound | outbound } interface [ interface-type [ interface-number ] ]
inbound: Displays inbound traffic rate statistics.
outbound: Displays outbound traffic rate statistics.
If you do not specify an interface type, this command displays traffic rate statistics for all up interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number, this command displays traffic rate statistics for all up interfaces of the specified type.
If you specify an interface type and an interface number, this command displays traffic rate statistics for the specified interface.
If an interface that you specify is always down for the most recent statistics polling interval, the system prompts that the interface does not support the command.
On the device, the statistics polling interval is fixed at 5 minutes.
# Display the inbound and outbound traffic rate statistics.
<Sysname> display counters rate inbound interface
Usage: Bandwidth utilization in percentage
Interface            Usage (%)   Total (pps)   Broadcast (pps)   Multicast (pps)
XGE1/0/1                    0             0                --               --
       --: Not supported.
Table 13 Command output
Usage(%)
Bandwidth usage (in percentage) of the interface within the most recent statistics polling interval.
Total(pps)
Average receiving or sending rate (in pps) for all packets within the most recent statistics polling interval.
Broadcast(pps)
Average receiving or sending rate (in pps) for broadcast packets within the most recent statistics polling interval. On an RPR physical port, all broadcast and multicast packets received or sent are displayed as multicast packets.
Multicast(pps)
Average receiving or sending rate (in pps) for multicast packets within the most recent statistics polling interval. On an RPR physical port, all broadcast and multicast packets received or sent are displayed as multicast packets.
Overflow: more than 14 decimal digits
The command displays Overflow if the data length of a statistical item is greater than 14 decimal digits.
--: not supported
The statistical item is not supported.
display interface
Use display interface to display interface information.
display interface [ interface-type [ interface-number ] ] [ brief [ description | down ] ]
interface-type: : Specifies an interface type.
interface-number: : Specifies an interface number.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 25 characters of each interface description.
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify an interface type, this command displays information about all interfaces.
If you specify an interface type but do not specify an interface number, this command displays information about all interfaces of the specified type.
# Display information about Ethernet interface Ten-GigabitEthernet 1/0/1.
Current state: UP
Line protocol state: UP
Description: Ten-GigabitEthernet1/0/1 Interface
Bandwidth: 10000000 kbps
Forbid jumbo frames to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
Known-unicast max-ratio: 100%
IP packet frame type: Ethernet II, hardware address: 0000-0000-0000
IPv6 packet frame type: Ethernet II, hardware address: 0000-0000-0000
Last link flapping: 0 hours 0 minutes 10 seconds
Last clearing of counters: 13:42:51 Sun 01/06/2013
Current system time:2013-01-06 19:59:30
Last time when physical state changed to up:2013-01-06 19:59:21
Last time when physical state changed to down:2013-01-06 13:38:46
 Peak input rate: 0 bytes/sec, at 00-00-00 00:00:00
 Peak output rate: 0 bytes/sec, at 00-00-00 00:00:00
 Last 300 seconds input: 0 packets/sec 0 bytes/sec 0%
 Last 300 seconds output: 0 packets/sec 0 bytes/sec 0%
 Input (total):  0 packets, 0 bytes
 Input (normal):  0 packets, - bytes
 - unicasts, - broadcasts, - multicasts, 0 pauses
         0 CRC, 0 frame, - overruns, 0 aborts
 0 ignored, - parity errors
 Output (normal): 0 packets, - bytes
 0 lost carrier, - no carrier
Table 14 Command output
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
·     UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces.
Description information of the interface.
Bandwidth
Expected bandwidth of the interface.
MTU of the interface.
Broadcast max-
Broadcast storm suppression threshold. This field is not supported in the current software version.
Multicast max-
Multicast storm suppression threshold. This field is not supported in the current software version.
Unicast max-
Unknown unicast storm suppression threshold. This field is not supported in the current software version.
Known-unicast max-
Known unicast storm suppression threshold. This field is not supported in the current software version.
The interface is not assigned an IP address. This field is not supported in the current software version.
IPv4 packet framing format. This field is not supported in the current software version.
hardware address
MAC address of the interface. This field is not supported in the current software version.
IPv6 packet framing format. This field is not supported in the current software version.
Last link flapping
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup.
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
Current system time
Current system time in the YYYY/MM/DD HH:MM:SS format. If the time zone is configured, this field is in the YYYY/MM/DD HH:MM:SS zone-name±HH:MM:SS format, where the zone-name argument is the local time zone.
Last time when the physical state of the interface changed to up.
A hyphen (-) indicates that the physical state of the interface has never changed.
Last time when the physical state of the interface changed to down.
Peak input rate
Peak rate of inbound traffic in Bps, and the time when the peak inbound traffic rate occurred.
Peak output rate
Peak rate of outbound traffic in Bps, and the time when the peak outbound traffic rate occurred.
Last interval seconds input:  0 packets/sec 0 bytes/sec 0%
Last interval seconds output:  0 packets/sec 0 bytes/sec 0%
Average inbound or outbound traffic rate (in pps and Bps) in the last statistics polling interval, and the ratio of the actual rate to the interface bandwidth.
A hyphen (-) indicates that the statistical item is not supported.
The two fields on the first line represent the inbound traffic statistics (in packets and bytes) for the interface. All inbound normal packets, abnormal packets, and normal pause frames were counted.
The four fields on the second line represent:
·     Number of inbound unicast packets.
·     Number of inbound broadcasts.
·     Number of inbound multicasts.
·     Number of inbound pause frames.
The two fields on the first line represent the inbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of inbound normal unicast packets.
·     Number of inbound normal broadcasts.
·     Number of inbound normal multicasts.
·     Number of inbound normal pause frames.
input errors
Statistics of incoming error packets.
runts
Number of inbound frames meeting the following conditions:
·     Shorter than 64 bytes.
·     In correct format.
·     Containing valid CRCs.
giants
Number of inbound giants. Giants refer to frames larger than the maximum frame length supported on the interface.
For an Ethernet interface that does not permit jumbo frames, the maximum frame length is 1518 bytes.
For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface.
throttles
Number of inbound frames that had a non-integer number of bytes.
CRC
Total number of inbound frames that had a normal length, but contained CRC errors.
frame
Total number of inbound frames that contained CRC errors and a non-integer number of bytes.
overruns
Number of packets dropped because the input rate of the port exceeded the queuing capability.
aborts
Total number of illegal inbound packets:
·     Fragment frames—CRC error frames shorter than 64 bytes. The length (in bytes) can be an integral or non-integral value.
·     Jabber frames—CRC error frames greater than the maximum frame length supported on the Ethernet interface (with an integral or non-integral length).
¡     For an Ethernet interface that does not permit jumbo frames, the maximum frame length is 1518 bytes.
¡     For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface.
·     Symbol error frames—Frames that contained a minimum of one undefined symbol.
·     Unknown operation code frames—Non-pause MAC control frames.
·     Length error frames—Frames whose 802.3 length fields did not match the actual frame length (46 to 1500 bytes).
ignored
Number of inbound frames dropped because the receiving buffer of the port ran low.
parity errors
Total number of frames with parity errors.
The two fields on the first line represent the outbound traffic statistics (in packets and bytes) for the interface. All outbound normal packets, abnormal packets, and normal pause frames were counted.
·     Number of outbound unicast packets.
·     Number of outbound broadcasts.
·     Number of outbound multicasts.
·     Number of outbound pause frames.
The two fields on the first line represent the outbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of outbound normal unicast packets.
·     Number of outbound normal broadcasts.
·     Number of outbound normal multicasts.
·     Number of outbound normal pause frames.
output errors
Number of outbound packets with errors.
underruns
Number of packets dropped because the output rate of the interface exceeded the output queuing capability. This is a low-probability hardware anomaly.
buffer failures
Number of packets dropped because the transmitting buffer of the interface ran low.
aborts
Number of packets that failed to be transmitted, for example, because of Ethernet collisions.
deferred
Number of frames that the interface deferred to transmit because of detected collisions.
collisions
Number of frames that the interface stopped transmitting because Ethernet collisions were detected during transmission.
late collisions
Number of frames that the interface deferred to transmit after transmitting their first 512 bits because of detected collisions.
lost carrier
Number of carrier losses during transmission. This counter increases by one when a carrier is lost, and applies to serial WAN interfaces.
no carrier
Number of times that the port failed to detect the carrier when attempting to send frames. This counter increases by one when a port failed to detect the carrier, and applies to serial WAN interfaces.
# Display brief information about all interfaces.
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP        Description
InLoop0              UP   UP(s)    --
MGE0/0/0             UP   UP       192.168.1.113
NULL0                UP   UP(s)    --
XGE1/0/1             ADM  DOWN     1.1.1.1
# Display information about interfaces in DOWN state and the causes.
XGE1/0/1             DOWN Not connected
Table 15 Command output
Brief information about Layer 3 interfaces.
Interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Description of the interface.
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Not connected—No physical connection exists (for example, the network cable is disconnected or faulty, or no forwarding related configuration exists).
·     Storm-Constrain—The storm control feature has detected that unknown unicast traffic, multicast traffic, or broadcast traffic exceeded the upper threshold.
display interface counter status
Use display interface counter status to display the status of the traffic statistics collection feature on each interface.
This command is supported only in R6712P02 and later versions.
# Display the status of the traffic statistics collection feature on each interface.
<Sysname> display interface counter status
Counter resources total: 13   Resource allocate: 1
Interface                    Status     Resource allocate
XGE1/0/1                     Enabled    Yes
XGE1/0/2                     Enabled    No
Table 16 Command output
The total number of statistics resources and the number of statistics resources that have been occupied.
Status
Indicates whether traffic statistics collection is enabled.
Resource allocate
Indicates whether the interface occupies statistics resources.
display packet-drop
Use display packet-drop to display information about packets dropped on an interface.
This command is supported only in R6712P03 and later versions.
display packet-drop { interface [ interface-type [ interface-number ] ] | summary }
interface-type: Specifies an interface type. If you do not specify an interface type, this command displays information about dropped packets on all interfaces on the device.
interface-number: Specifies an interface number. If you do not specify an interface number, this command displays information about dropped packets on all interfaces of the specified type.
summary: Displays the summary of dropped packets on all interfaces.
# Display information about dropped packets on Ten-GigabitEthernet 1/0/1.
<Sysname> display packet-drop interface ten-gigabitethernet 1/0/1
Ten-GigabitEthernet1/0/1:
 Packets dropped due to insufficient data buffer: 11758878
 Packets dropped due to Acl Filter: 73351548
 Packets dropped due to Mirror: 162764420
# Display the summary of dropped packets on all interfaces.
<Sysname> display packet-drop summary
All interfaces:
 Packets dropped due to Acl Filter: 738751750
 Packets dropped due to Mirror: 166391290
Table 17 Command output
Packets dropped due to insufficient data buffer. :0
Number of packets dropped due to insufficient data buffer.
Number of packets dropped due to packet filtering.
Number of packets dropped due to insufficient data buffer of the mirroring source interfaces.
display packet-filter
Use display packet-filter to display ACL application information for packet filtering.
display packet-filter { global | interface [ interface-type interface-number ] } [ outbound ]
global: Specifies all physical interfaces.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If you do not specify an interface, this command displays ACL application information for packet filtering on all interfaces.
outbound: Specifies the outbound direction.
# Display ACL application information for outbound packet filtering on interface Ten-GigabitEthernet 1/0/1.
<Sysname> display packet-filter interface ten-gigabitethernet 1/0/1 outbound
 Outbound policy:
  IPv4 ACL 3001
  MAC ACL 4003
# Display ACL application information for outbound packet filtering on all physical interfaces.
<Sysname> display packet-filter global
Global:
 Outbound policy:
  IPv4 ACL 3001
  IPv4 default action: Deny (Failed)
Table 18 Command output
Interface to which the ACL applies.
Global
ACL application for packet filtering on all physical interfaces.
IPv4 ACL 3001
Advanced IPv4 ACL 3001 has been successfully applied.
IPv4 default action
Packet filter default action for packets that do not match any IPv4 ACLs:
·     Deny—The default action deny has been successfully applied for packet filtering.
·     Deny (Failed)—The device has failed to apply the default action deny for packet filtering. The action permit still functions.
·     Permit—The default action permit has been successfully applied for packet filtering.
display packet-filter verbose
Use display packet-filter verbose to display ACL application details for packet filtering.
display packet-filter verbose { global | interface interface-type interface-number } outbound [ { acl-number | name acl-name } ]
acl-number: Specifies an advanced ACL by its number, in the range of 3000 to 3999.
If acl-number or name acl-name is not specified, this command displays application details of all IPv4 ACLs for packet filtering.
# Display application details of all ACLs for outbound packet filtering on Ten-GigabitEthernet 1/0/1.
<Sysname> display packet-filter verbose interface ten-gigabitethernet 1/0/1 outbound
 Outbound policy:
  IPv4 ACL 3001
   rule 0 permit
   rule 5 permit source 1.1.1.1 0 (Failed)
Table 19 Command output
Global
ACL application details for packet filtering on all physical interfaces.
Outbound policy
ACL used for filtering outgoing traffic.
IPv4 ACL 3001
IPv4 basic ACL 3001 has been successfully applied.
The device has failed to apply rule 5.
IPv4 default action
flow-interval
Use flow-interval to set the statistics polling interval.
Use undo flow-interval to restore the default.
flow-interval interval
undo flow-interval
The statistics polling interval is 300 seconds.
Ethernet interface view
interval: Sets the statistics polling interval in the range of 5 to 300 seconds.
# Set the statistics polling interval to 100 seconds on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] flow-interval 100
packet-filter (interface view)
Use packet-filter to apply an ACL to an interface to filter packets.
Use undo packet-filter to remove an ACL from an interface.
This command is supported only in R6712P03 and later.
packet-filter { acl-number | name acl-name } outbound
undo packet-filter { acl-number | name acl-name } outbound
No ACL is applied to an interface to filter packets.
Interface view
name acl-name: Specifies an advanced ACL by its name. The acl-name argument is a case-insensitive string of 1 to 63 characters.
outbound: Filters outgoing packets.
If you use the acl-number argument to specify an ACL, to specify an IPv4 ACL, use the acl-number argument directly.
If you use the name acl-name option to specify an ACL, to specify an IPv4 ACL, use the name acl-name option.
When you reference an ACL, if the ACL does not exist or contains no rules, it does not take effect.
To the outbound direction of an interface, you can apply a maximum of four ACLs.
If you apply packet filters both globally and to an interface, the packet filter on the interface takes priority. If no configuration is applied to an interface, the global configuration will be used.
This feature and traffic filtering are mutually exclusive on the device.
# Apply IPv4 advanced ACL 3001 to filter outgoing traffic on Ten-GigabitEthernet 1/0/1s.
[Sysname-Ten-GigabitEthernet1/0/1] undo shutdown
[Sysname-Ten-GigabitEthernet1/0/1] packet-filter 3001 outbound
Use packet-filter global to apply an ACL to filter packets globally.
Use undo packet-filter global to remove an ACL for global packet filtering.
No ACL is applied to filter packets globally.
# Apply IPv4 advanced ACL 3001 to filter outgoing traffic on all physical interfaces.
[Sysname] packet-filter 3001 global outbound
shutdown
Use shutdown to shut down an Ethernet interface.
Use undo shutdown to bring up an Ethernet interface.
shutdown
By default, an Ethernet interface is down.
CAUTION
CAUTION:
Executing the shutdown command on an interface will disconnect the link of the interface and interrupt communication. Use this command with caution.
In some scenarios (such as editing the interface operating parameters), the interface modifications cannot take effect immediately. You must shut down and then bring up the interface for the modifications to take effect.
# Shut down and then bring up Ethernet interface Ten-GigabitEthernet1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] shutdown
