13-Network Management and Monitoring Configuration Guide
HomeSupportSwitchesS12500G-AF SeriesConfigure & DeployConfiguration GuidesH3C S12500G-AF Switch Series Configuration Guides-Release7639Pxx-6W10013-Network Management and Monitoring Configuration Guide
20-IPv6 NetStream configuration
20-IPv6 NetStream configuration 226.62 KB
Configuring IPv6 NetStream
About IPv6 NetStream
IPv6 NetStream is an accounting technology that provides statistics on a per-flow basis. An IPv6 flow is defined by the following 8-tuple elements:
·     Destination IPv6 address.
·     Source IPv6 address.
·     Destination port number.
·     Source port number.
·     Protocol number.
·     Traffic class.
·     Flow label.
·     Input or output interface.
IPv6 NetStream architecture
A typical IPv6 NetStream system includes the following elements:
·     NetStream data exporter—A device configured with IPv6 NetStream. The NDE provides the following functions:
¡     Classifies traffic flows by using the 8-tuple elements.
¡     Collects data from the classified flows.
¡     Aggregates the data.
¡     Exports the data to the NSC.
·     NetStream collector—A program running in a Unix or Windows operating system. The NSC parses the packets received from the NDEs, and saves the data to its database.
·     NetStream data analyzer—A network traffic analyzing tool. Based on the data in NSC, the NDA generates reports for traffic billing, network planning, and attack detection and monitoring. The NDA can collect data from multiple NSCs. Typically, the NDA features a Web-based system for easy operation.
NSC and NDA are typically integrated into a NetStream server.
Figure 1 IPv6 NetStream system
IPv6 NetStream flow aging
IPv6 NetStream uses flow aging to enable the NDE to export IPv6 NetStream data to NetStream servers. IPv6 NetStream creates an IPv6 NetStream entry for each flow for storing the flow statistics in the cache.
When a flow is aged out, the NDE performs the following operations:
·     Exports the summarized data to NetStream servers in a specific format.
·     Clears IPv6 NetStream entry information in the cache.
IPv6 NetStream supports the following flow aging methods:
·     Periodical aging.
·     Forced aging.
Periodical aging
Periodical aging uses the following methods:
·     Inactive flow aging—A flow is inactive if no packet arrives for the IPv6 NetStream entry within the inactive flow aging timer. When the timer expires, the following events occur:
¡     The inactive flow entry is aged out.
¡     The statistics of the flow are sent to NetStream servers and are cleared in the cache. The statistics can no longer be displayed by using the display ipv6 netstream cache command.
This method ensures that inactive flow entries are cleared from the cache in a timely manner so new entries can be cached.
·     Active flow aging—A flow is active if packets arrive for the IPv6 NetStream entry within the active flow aging timer. When the timer expires, the statistics of the active flow are exported to NetStream servers. The device continues to collect its statistics, which can be displayed by using the display ipv6 netstream cache command.
The active flow aging method periodically exports the statistics of active flows to NetStream servers.
Forced aging
Execute the reset ipv6 netstream statistics command to clear the IPv6 NetStream cache immediately and export the cached entries to NetStream servers.
IPv6 NetStream data export
Traditional data export
IPv6 NetStream collects the statistics of each flow and exports the statistics to NetStream servers.
This method consumes a lot of bandwidth and CPU usage, and requires a large cache size. In addition, you do not need all of the data in most cases.
Aggregation data export
An IPv6 NetStream aggregation mode merges the flow statistics according to the aggregation criteria of the aggregation mode, and it sends the summarized data to NetStream servers. The IPv6 NetStream aggregation data export uses less bandwidth than the traditional data export.
Table 1 lists the available IPv6 NetStream aggregation modes. In each mode, the system merges multiple flows with the same values for all aggregation criteria into one aggregate flow. The system records the statistics for the aggregate flow. These aggregation modes work independently and can take effect concurrently.
Table 1 IPv6 NetStream aggregation modes
Aggregation mode
Aggregation criteria
AS aggregation
·     Source AS number
·     Destination AS number
·     Input interface index
·     Output interface index
Protocol-port aggregation
·     Protocol number
·     Source port
·     Destination port
Source-prefix aggregation
·     Source AS number
·     Source mask
·     Source prefix (source network address)
Destination-prefix aggregation
·     Destination mask
·     Destination prefix (destination network address)
Source-prefix and destination-prefix aggregation
·     Source AS number
·     Source mask
·     Destination mask
BGP-nexthop
·     BGP next hop
·     Output interface index‌
If IPv6 packets are not forwarded according to the BGP routing table, the AS number or BGP next hop cannot be obtained.
IPv6 NetStream data export format
IPv6 NetStream exports data in the version 9 or version 10 format.
Both formats are template-based and support exporting the IPv6 NetStream aggregation data and collecting statistics about BGP next hop.
The version 10 export format is compliant with the IPFIX standard.
IPv6 NetStream mirroring
IPv6 NetStream mirroring copies packets that pass through the device to an IPv6 NetStream module for collecting traffic statistics. The forwarding performance of the device is not affected.
IPv6 NetStream supports port mirroring. IPv6 NetStream port mirroring copies the packets passing through an interface to an IPv6 NetStream module.
IPv6 NetStream filtering
IPv6 NetStream filtering uses an ACL to identify packets. Whether IPv6 NetStream collects data for identified packets depends on the action in the matching rule.
·     IPv6 NetStream collects data for packets that match permit rules in the ACL.
·     IPv6 NetStream does not collect data for packets that match deny rules in the ACL.
For more information about ACLs, see ACL and QoS Configuration Guide.
IPv6 NetStream sampling
IPv6 NetStream sampling collects statistics on fewer packets and is useful when the network has a large amount of traffic. IPv6 NetStream on sampled traffic lessens the impact on the device's performance. For more information about sampling, see "Configuring samplers."
Protocols and standards
RFC 5101, Specification of the IP Flow Information Export (IPFIX) Protocol for the Exchange of IP Traffic Flow Information
Restrictions: Hardware compatibility with IPv6 NetStream
Only TE interface modules with FPGA cards support IPv6 NetStream.
The TE interface modules without FPGA cards can use IPv6 NetStream port mirroring to mirror traffic to TE interface modules with FPGA cards for processing.
TD interface modules do not support IPv6 NetStream.
IPv6 NetStream tasks at a glance
To configure IPv6 NetStream, perform the following tasks:
1.     Enabling IPv6 NetStream
2.     (Optional.) Configuring IPv6 NetStream mirroring
3.     (Optional.) Configuring IPv6 NetStream filtering
4.     (Optional.) Configuring IPv6 NetStream sampling
5.     (Optional.) Configuring the IPv6 NetStream data export format
6.     (Optional.) Configuring the refresh rate for IPv6 NetStream version 9 or version 10 template
7.     (Optional.) Configuring IPv6 NetStream flow aging
8.     Configuring the IPv6 NetStream data export
a.     Configuring the IPv6 NetStream traditional data export
b.     (Optional.) Configuring the IPv6 NetStream aggregation data export
9.     (Optional.) Enabling SNMP notifications for IPv6 NetStream
Enabling IPv6 NetStream on an interface
IPv6 NetStream cannot collect statistics on outbound packets generated by the device itself, such as the ping packets sent by the device.
You cannot enable IPv6 NetStream on Layer 3 Ethernet interfaces and their subinterfaces simultaneously.
If you have enabled IPv6 NetStream on a Layer 3 Ethernet interface, statistics of their subinterface collected by IPv6 NetStream will be counted as statistics for its main interface.
The device does not support IPv6 NetStream statistics collection on Layer 3 Ethernet subinterfaces in the outbound direction.
If a Layer 3 Ethernet subinterface is enabled with IPv6 NetStream and configured as the public network output interface for a VXLAN tunnel simultaneously, IPv6 NetStream will not take effect.
2.     Enter interface view.
3.     Enable IPv6 NetStream on the interface.
ipv6 netstream { inbound | outbound }
By default, IPv6 NetStream is disabled on an interface.
Configuring IPv6 NetStream port mirroring
Restrictions and guidelines for cards:
·     The interface configured with this feature must be on a TE interface module without any FPGA card. The card to which traffic is mirrored to must be a TE interface module with an FPGA card.
·     The card where the interface configured with this feature resides and the target card must be in the same MDC and chassis. To change the MDC for the target card, first delete IPv6 NetStream port mirroring configuration for the interface configured with this feature.
·     You can specify only the active target card or specify both the active and standby target cards. Make sure the specified cards are enabled with IPv6 NetStream.
Restrictions and guidelines for interfaces:
·     The interface configured with this feature must be a physical interface and cannot be a Layer 3 Ethernet subinterface.
·     When you configure this feature on an interface, you must also enable IPv6 NetStream in the same direction on that interface. For example, if you execute the ipv6 netstream inbound mirror-to command on an interface, you must also execute the ipv6 netstream inbound command on that interface.
·     After you configure this feature on an interface, both inbound and outbound IPv4 and IPv6 traffic are mirrored to the specified slot.
3.     Mirror traffic on the interface to a slot.
In standalone mode:
ip netstream { inbound | outbound } mirror-to service slot slot-number [ backup slot slot-number ]
In IRF mode:
ip netstream { inbound | outbound } mirror-to service chassis chassis-number slot slot-number [ backup chassis chassis-number slot slot-number ]
By default, traffic of an interface is not mirrored to a slot.
For more information about this command, see "Configuring NetStream."
·     To enable IPv6 NetStream to collect statistics for specific flows, use the ACL permit statements to identify these flows
·     To disable IPv6 NetStream from collecting statistics for specific flows, use the ACL deny statements to identify these flows.
If IPv6 NetStream filtering and sampling are both configured, IPv6 packets are filtered first, and then the permitted packets are sampled.
If the referenced ACL does not exist or does not have any rules, this feature will fail to be configured.
3.     Configure IPv6 NetStream filtering on the interface.
ipv6 netstream inbound filter acl acl-number
By default, IPv6 NetStream filtering is disabled. IPv6 NetStream collects statistics of all IPv6 packets passing through the interface.
By default, IPv6 NetStream collects all data of target flows. If the flow traffic is heavy, IPv6 NetStream is resource-consuming and can cause high CPU usage, which impacts the device forwarding performance. IPv6 NetStream sampling is helpful to decrease the IPv6 NetStream traffic volume. If the collected statistics can basically reflect the network status, you can enable this feature and set a proper sampling rate. The higher the sampling rate, the less impact on device performance.
If IPv6 NetStream sampling and filtering are both configured, IPv6 packets are filtered first, and then the permitted packets are sampled.
2.     Create a sampler.
sampler sampler-name mode random packet-interval n-power rate
For more information about samplers, see "Configuring samplers."
3.     Enter interface view.
4.     Configure IPv6 NetStream sampling.
ipv6 netstream [ inbound | outbound ] sampler sampler-name
By default, IPv6 NetStream sampling is disabled.
When you configure the IPv6 NetStream data export format, you can also specify the following settings:
·     Whether or not to export the BGP next hop and serial number information.
·     How to export the autonomous system (AS) information: origin-as or peer-as.
¡     origin-as—Records the original AS numbers for the flow source and destination.
¡     peer-as—Records the peer AS numbers for the flow source and destination.
For example, as shown in Figure 2, a flow starts at AS 20, passes AS 21 through AS 23, and then reaches AS 24. IPv6 NetStream is enabled on the device in AS 22.
·     Specify the origin-as keyword to export AS 20 as the source AS and AS 24 as the destination AS.
·     Specify the peer-as keyword to export AS 21 as the source AS and AS 23 as the destination AS.
Figure 2 Recorded AS information varies by different keyword configurations
2.     Configure the IPv6 NetStream data export format, and configure the AS, BGP next hop, and serial number export attributes.
¡     Configure the version 9 format.
ipv6 netstream export version 9 { origin-as | peer-as } [ bgp-nexthop ] [ serial-number ]
¡     Configure the version 10 format.
ipv6 netstream export version 10 [ origin-as | peer-as ] [ bgp-nexthop ] [ serial-number ]
By default:
¡     The version 9 format is used to export IPv6 NetStream data.
¡     The peer AS numbers for the flow source and destination are exported.
¡     The BGP next hop and serial number information is not exported.
Version 9 and version 10 are template-based and support user-defined formats. An IPv6 NetStream device must send the updated template to NetStream servers regularly, because the servers do not permanently save templates.
For a NetStream server to use the correct version 9 or version 10 template, configure the time-based or packet count-based refresh rate. If both settings are configured, the template is sent when either of the conditions is met.
2.     Configure the refresh rate for the IPv6 NetStream version 9 or version 10 template.
ipv6 netstream export template refresh-rate { packet packets | time minutes }
By default, the packet count-based refresh rate is 20 packets, and the time-based refresh interval is 30 minutes.
Configuring periodical flow aging
2.     Set the aging timer for active flows.
ipv6 netstream timeout active minutes
By default, the aging timer for active flows is 5 minutes.
3.     Set the aging timer for inactive flows.
ipv6 netstream timeout inactive seconds
By default, the aging timer for inactive flows is 300 seconds.
The value range for this timer is 30 to 320000 seconds.
Configuring forced flow aging
Execute the following command in user view to clear the cache, including the cached IPv6 NetStream entries and the related statistics:
2.     Specify a destination host for IPv6 NetStream traditional data export.
ipv6 netstream export host { ipv4-address | ipv6-address } udp-port [ vpn-instance vpn-instance-name ]
By default, no destination host is specified.
1.     (Optional.) Specify the source interface for IPv6 NetStream data packets sent to the NetStream servers.
ipv6 netstream export source interface interface-type interface-number
By default, no source interface is specified for IPv6 NetStream data packets. The packets take the IPv6 address of the output interface (interface that is connected to the NetStream server) as the source IPv6 address.
As a best practice, connect the management Ethernet interface to a NetStream server, and configure the interface as the source interface.
2.     (Optional.) Limit the IPv6 NetStream data export rate.
ipv6 netstream export rate rate
By default, the data export rate is not limited.
The IPv6 NetStream aggregation can be implemented by software or hardware. Unless otherwise noted, NetStream aggregation refers to software NetStream aggregation.
IPv6 NetStream hardware aggregation uses hardware to directly merge the flow statistics according to the aggregation mode criteria, and stores the data in the cache. The aging of IPv6 NetStream hardware aggregation entries is the same as the aging of IPv6 NetStream traditional data entries. When a hardware aggregation entry is aged out, the data is exported.
IPv6 NetStream hardware aggregation reduces resource consumption.
The IPv6 NetStream hardware aggregation does not take effect in the following situations:
·     The destination host is configured for NetStream traditional data export.
·     The configured aggregation mode is not supported by IPv6 NetStream hardware aggregation.
Configurations in IPv6 NetStream aggregation mode view apply only to the IPv6 NetStream aggregation data export. Configurations in system view apply to the IPv6 NetStream traditional data export. When no configuration in IPv6 NetStream aggregation mode view is provided, the configurations in system view apply to the IPv6 NetStream aggregation data export.
2.     Enable IPv6 NetStream hardware aggregation.
ipv6 netstream aggregation advanced
By default, IPv6 NetStream hardware aggregation is disabled.
3.     Specify an IPv6 NetStream aggregation mode and enter its view.
ipv6 netstream aggregation { as | bgp-nexthop | destination-prefix | prefix | protocol-port | source-prefix }
By default, no IPv6 NetStream aggregation mode is specified.
4.     Enable the IPv6 NetStream aggregation mode.
enable
By default, the IPv6 NetStream aggregation is disabled.
5.     Specify a destination host for IPv6 NetStream aggregation data export.
If you expect only IPv6 NetStream aggregation data, specify the destination host only in the related IPv6 NetStream aggregation mode view.
By default, no source interface is specified for IPv6 NetStream data packets. The packets take the IPv6 address of the output interface as the source IPv6 address.
You can configure different source interfaces in different IPv6 NetStream aggregation mode views.
If no source interface is configured in IPv6 NetStream aggregation mode view, the source interface configured in system view applies.
Use this feature to report important events for IPv6 NetStream through SNMP notifications. The generated alarm information will be sent to the SNMP module on the device and you can configure the SNMP notification sending parameters to determine the export attributes of the alarm information. For more information, see "Configuring SNMP."
2.     Enable SNMP notifications for IPv6 NetStream.
snmp-agent trap enable ipv6 netstream [ entry-limit ]
By default, SNMP notifications are enabled for IPv6 NetStream.
Display and maintenance commands for IPv6 NetStream
Display IPv6 NetStream entry information.
In standalone mode:
display ipv6 netstream cache [ verbose ] [ type { ip | ipl2 | l2 } ] [ destination destination-ipv6 | interface interface-type interface-number | source source-ipv6 ] * [ slot slot-number ]
In IRF mode:
display ipv6 netstream cache [ verbose ] [ type { ip | ipl2 | l2 } ] [ destination destination-ipv6 | interface interface-type interface-number | source source-ipv6 ] * [ chassis chassis-number slot slot-number ]
Display information about the IPv6 NetStream data export.
display ipv6 netstream export
Display IPv6 NetStream template information.
In standalone mode:
display ipv6 netstream template [ slot slot-number ]
In IRF mode:
display ipv6 netstream template [ chassis chassis-number slot slot-number ]
Age out, export all IPv6 NetStream data, and clear the cache.
IPv6 NetStream configuration examples
Example: Configuring IPv6 NetStream traditional data export
As shown in Figure 3, configure IPv6 NetStream on the device to collect statistics on packets passing through the device.
·     Enable IPv6 NetStream for incoming and outgoing traffic on HundredGigE 3/0/1.
·     Configure the device to export the IPv6 NetStream traditional data to UDP port 5000 of the NetStream server.
Figure 3 Network diagram
# Assign an IP address to each interface, as shown in Figure 3. (Details not shown.)
# Enable IPv6 NetStream for incoming and outgoing traffic on HundredGigE 3/0/1.
[Device] interface hundredgige 3/0/1
[Device-HundredGigE3/0/1] ipv6 netstream inbound
[Device-HundredGigE3/0/1] ipv6 netstream outbound
[Device-HundredGigE3/0/1] quit
# Specify 40::1 as the IP address of the destination host and UDP port 5000 as the export destination port number.
[Device] ipv6 netstream export host 40::1 5000
# Display information about IPv6 NetStream entries.
<Device> display ipv6 netstream cache
IPv6 NetStream cache information:
  Active flow timeout             : 5 min
  Inactive flow timeout           : 300 sec
  Max number of entries           : 1000
  IPv6 active flow entries        : 2
  MPLS active flow entries        : 0
  IPL2 active flow entries        : 0
  IPv6 flow entries counted       : 10
  MPLS flow entries counted       : 0
  IPL2 flow entries counted       : 0
  Last statistics resetting time  : 01/01/2019 at 00:01:02
IPv6 packet size distribution (1103746 packets in total):
1-32   64   96  128  160  192  224  256  288  320  352  384  416  448  480
.249 .694 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
512  544  576 1024 1536 2048 2560 3072 3584 4096 4608 >4608
.000 .000 .027 .000 .027 .000 .000 .000 .000 .000 .000 .000
Protocol          Total Packets    Flows  Packets Active(sec) Idle(sec)
                  Flows /sec       /sec   /flow   /flow       /flow
TCP-Telnet      2656855     372        4       86        49         27
TCP-FTP         5900082      86        9        9        11         33
TCP-FTPD        3200453    1006        5      193        45         33
TCP-WWW       546778274   11170      887       12         8         32
TCP-other      49148540    3752       79       47        30         32
UDP-DNS       117240379     570      190        3         7         34
UDP-other      45502422    2272       73       30         8         37
ICMP           14837957     125       24        5        12         34
IP-other          77406       5        0       47        52         27
 Type DstIP(Port)        SrcIP(Port)      Pro TC  FlowLbl If(Direct)   Pkts
      DstMAC(VLAN)       SrcMAC(VLAN)
      TopLblType(IP/MASK)Lbl-Exp-S-List
IP   2001::1(1024)      2002::1(21)        6   0   0x0     HGE3/0/1(I) 42996
IP   2002::1(21)        2001::1(1024)      6   0   0x0     HGE3/0/1(O) 42996
 # Display information about the IPv6 NetStream data export.
[Device] display ipv6 netstream export
IPv6 export information:
  Flow source interface                           : Not specified
  Flow destination VPN instance                   : Not specified
  Flow destination IP address (UDP)               : 40::1 (5000)
  Version 9 exported flow number                  : 10
  Version 9 exported UDP datagram number (failed) : 10 (0)
Example: Configuring IPv6 NetStream aggregation data export
As shown in Figure 4, all routers in the network are running IPv6 EBGP. Configure IPv6 NetStream on the device to meet the following requirements:
·     Export the IPv6 NetStream traditional data to port 5000 of the NetStream server.
·     Perform the IPv6 NetStream aggregation in the modes of protocol-port, source-prefix, destination-prefix, and prefix.
·     Export the aggregation data of different modes to the UDP ports 3000, 4000, 6000, and 7000.
Figure 4 Network diagram
# Assign an IP address to each interface, as shown in Figure 4. (Details not shown.)
# Set the aggregation mode to protocol-port, and specify the destination host for the aggregation data export.
[Device] ipv6 netstream aggregation protocol-port
[Device-ns6-aggregation-protport] enable
[Device-ns6-aggregation-protport] ipv6 netstream export host 40::1 3000
[Device-ns6-aggregation-protport] quit
# Set the aggregation mode to source-prefix, and specify the destination host for the aggregation data export.
[Device] ipv6 netstream aggregation source-prefix
[Device-ns6-aggregation-srcpre] enable
[Device-ns6-aggregation-srcpre] ipv6 netstream export host 40::1 4000
[Device-ns6-aggregation-srcpre] quit
# Set the aggregation mode to destination-prefix, and specify the destination host for the aggregation data export.
[Device] ipv6 netstream aggregation destination-prefix
[Device-ns6-aggregation-dstpre] enable
[Device-ns6-aggregation-dstpre] ipv6 netstream export host 40::1 6000
[Device-ns6-aggregation-dstpre] quit
# Set the aggregation mode to prefix, and specify the destination host for the aggregation data export.
[Device] ipv6 netstream aggregation prefix
[Device-ns6-aggregation-prefix] enable
[Device-ns6-aggregation-prefix] ipv6 netstream export host 40::1 7000
[Device-ns6-aggregation-prefix] quit
as aggregation export information:
  Flow destination IP address (UDP)               : 40::1 (2000)
  Version 9 exported flow number                  : 0
  Version 9 exported UDP datagram number (failed) : 0(0)
protocol-port aggregation export information:
  Flow destination IP address (UDP)               : 40::1 (3000)
  Version 9 exported UDP datagram number (failed) : 0 (0)
source-prefix aggregation export information:
  Flow destination IP address (UDP)               : 40::1 (4000)
destination-prefix aggregation export information:
  Flow destination IP address (UDP)               : 40::1 (6000)
  Flow destination IP address (UDP)               : 40::1 (7000)
