- 04-Layer 2—LAN Switching Configuration Guide
- 01-MAC address table configuration
- 02-Ethernet link aggregation configuration
- 03-M-LAG configuration
- 04-VLAN configuration
- 05-MVRP configuration
- 06-VLAN mapping configuration
- 07-VLAN termination configuration
- 08-Loop detection configuration
- 09-Spanning tree configuration
- 10-LLDP configuration
- 11-PFC configuration
- 12-Service loopback group configuration
- 13-Cut-through Layer 2 forwarding configuration
| 11-PFC configuration | 102.36 KB |
Configuring PFC on an Ethernet interface
Configuring PFC deadlock detection
Configuring the early warning thresholds for PFC packets
Configuring PFC
About PFC
Priority-based flow control (PFC) provides a finer flow control mechanism to implement lossless packet transmission on Ethernet.
PFC performs flow control for packets based on the 802.1p priorities carried in packets. As shown in Figure 1, PFC establishes eight virtual channels over an Ethernet link, each corresponding to an 802.1p priority. Any virtual channel can be paused or restarted independent of the other channels. This mechanism allows multiple types of traffic to coexist on and share an Ethernet link.
Figure 1 How PFC works
When congestion occurs on the local end, the device determines how to process received packets based on the 802.1p priorities carried in packets as follows:
· If PFC is enabled for the 802.1p priority carried in a packet, the local end accepts the packet and sends PFC pause frames to notify the remote end to stop sending packets carrying the 802.1p priority. The remote end stops sending packets carrying the 802.1p priority after receiving the PFC pause frames. This process is repeated until congestion is eliminated.
· If PFC is not enabled for the 802.1p priority carried in a packet, the local end drops the packet.
If you do not enable PFC on an interface, the interface can receive but cannot process PFC pause frames. To make PFC take effect, you must enable PFC on both ends.
To avoid packet loss, apply the same PFC configuration to all interfaces that the packets pass through.
Generic flow control and PFC are mutually exclusive on an interface. For more information about generic flow control, see Ethernet interface configuration in Interface Configuration Guide.
1. Enter system view.
2. Enable PFC on all Ethernet interfaces.
priority-flow-control { auto | enable [ receive | send ] }
By default, PFC is disabled on all Ethernet interfaces.
3. Enable PFC for 802.1p priorities on all Ethernet interfaces.
priority-flow-control no-drop dot1p dot1p-list
By default, PFC is disabled for all 802.1p priorities on all Ethernet interfaces.
4. Enter Ethernet interface view.
5. Enable PFC on the Ethernet interface.
By default, PFC is disabled.
6. Enable PFC for 802.1p priorities.
By default, PFC is disabled for all 802.1p priorities.
Setting PFC thresholds
About PFC thresholds
The storage spaces for an interface include the following types:
· Headroom storage space.
· Shared storage space.
· Guaranteed storage space.
Setting PFC thresholds enables flexible control over PFC and can make good use of the storage spaces. The device supports the following PFC thresholds:
· Headroom buffer threshold—Maximum number of cell resources that can be used by packets with a specific 802.1p priority value in a headroom storage space. An interface drops received packets once this threshold is reached.
· Back pressure frame triggering threshold—Maximum number of cell resources that can be used by packets with a specific 802.1p priority value in a shared storage space. PFC is triggered once this threshold is reached. The back pressure frame triggering threshold includes the following types:
¡ Dynamic back pressure frame triggering threshold—Maximum cell resources set in percentage.
¡ Static back pressure frame triggering threshold—Maximum cell resources set in an absolute value.
· Offset between the back pressure frame stopping threshold and triggering threshold—When the number of cell resources used by packets with a specific 802.1p priority value decreases by this offset after PFC is triggered, PFC will be stopped.
· PFC reserved threshold—Number of cell resources reserved for packets with a specific 802.1p priority value in a guaranteed storage space.
WARNING! After PFC is enabled for 802.1p priorities, the PFC thresholds use the default values, which are adequate in typical network environments. As a practice, change the thresholds only when necessary. |
You must enable PFC for 802.1p priorities before setting the PFC thresholds.
If you cancel PFC threshold settings on an interface, the PFC thresholds are restored to the state when only the priority-flow-control no-drop dot1p command is executed.
This feature does not support preprovisioning. For more information about preprovisioning, see Fundamentals Configuration Guide.
2. Enter Ethernet interface view.
3. Set the maximum number of resources that can be used in the headroom storage space for a service pool.
priority-flow-control poolid service-pool-id headroom headroom-number
By default, the maximum number of resources that can be used in the headroom storage space for a service pool is not set.
4. (Optional.) Configure the display style for the PFC configuration for 802.1p priorities.
priority-flow-control config-style { individual | unified }
By default, the display style is unified for the PFC configuration for 802.1p priorities.
5. Set the PFC thresholds.
priority-flow-control no-drop dot1p dot1p-list [ pause-threshold { threshold-value | ratio threshold-ratio } [ headroom headroom-value | pause-threshold-offset offset-value | reserved-buffer reserved-value ] * ]
By default, PFC is disabled for all 802.1p priority values on an interface.
6. (Optional.) Set the headroom buffer threshold.
priority-flow-control dot1p dot1p headroom headroom-number
By default, the headroom buffer threshold is not set.
If you execute this command or the priority-flow-control no-drop dot1p (Ethernet interface view) command multiple times for the same 802.1p priority, the headroom-number argument in the most recent command takes effect.
7. (Optional.) Set the back pressure frame triggering thresholds.
¡ Set the dynamic back pressure frame triggering threshold.
priority-flow-control dot1p dot1p ingress-buffer dynamic ratio
By default, the dynamic back pressure frame triggering threshold is not set.
¡ Set the static back pressure frame triggering threshold.
priority-flow-control dot1p dot1p ingress-buffer static threshold
By default, the static back pressure frame triggering threshold is not set.
8. (Optional.) Set the offset between the back pressure frame stopping threshold and triggering threshold.
priority-flow-control dot1p dot1p ingress-threshold-offset offset-number
By default, the offset between the back pressure frame stopping threshold and triggering threshold is not set.
9. (Optional.) Set the PFC reserved threshold.
priority-flow-control dot1p dot1p reserved-buffer reserved-number
By default, the PFC reserved threshold is not set.
If you execute this command or the priority-flow-control no-drop dot1p (Ethernet interface view) command multiple times for the same 802.1p priority, the reserved-number argument in the most recent command takes effect.
When packets carrying the specified 802.1p priority are transmitted in a loop, packets in the data buffer cannot be forwarded and PFC frames are repeatedly transmitted between devices. As a result, the cell resources in the buffer for device interfaces always cannot be released. In this case, the device enters the PFC deadlock state.
This feature periodically detects whether the device is in the PFC deadlock state. If an interface is always in the PFC XOFF state within the PFC deadlock detection interval, the device enters the PFC deadlock state. If PFC deadlock detection is recovered in automatic mode, the device automatically releases the deadlock state and recovers PFC and PFC deadlock detection after the delay timer expires. During the delay timer period, the device disables PFC and PFC deadlock detection on the interface, so that packets can be forwarded properly.
After the PFC deadlock state is released, the PFC deadlock detection feature can be recovered on the interface in automatic or manual mode. Recovering this feature enables the PFC feature again at the same time. Use the automatic recovery mode when no serious failures occur.
When a packet loop cannot be eliminated and the device enters PFC deadlock state frequently, manually recover PFC deadlock detection on the interface as follows:
1. Perform troubleshooting and set the manual recovery mode for PFC deadlock detection.
2. Execute the priority-flow-control deadlock recover command to recover the PFC deadlock detection and PFC features.
The specified CoS value must be within the 802.1p priority list specified by using the priority-flow-control no-drop dot1p command. To view the 802.1p priority for each CoS value, execute the display qos map-table dot1p-lp command.
Before you configure PFC deadlock detection on an Ethernet interface, complete the following tasks:
· Enable PFC in auto mode or forcibly on the Ethernet interface.
· Enable PFC for 802.1p priorities on the Ethernet interface.
2. Set the precision for the PFC deadlock detection timer.
priority-flow-control deadlock precision { high | normal | low }
By default, the PFC deadlock detection timer uses normal precision.
3. Set the PFC deadlock detection interval for the specified CoS value.
priority-flow-control deadlock cos cos-value interval interval [ pause-recover ]
By default, the PFC deadlock detection interval is not set.
4. Configure the delay timer for PFC deadlock detection automatic recovery.
priority-flow-control deadlock auto-recover cos cos-value delay delay-time
By default, the delay timer for PFC deadlock detection automatic recovery is not configured.
5. Configure the action to take on packets during the delay timer period for PFC deadlock detection automatic recovery.
priority-flow-control deadlock auto-recover action { discard | forwarding }
By default, the device forwards received packets during the delay timer period for PFC deadlock detection automatic recovery.
6. Configure the upper threshold for PFC deadlock times during the specified period.
priority-flow-control deadlock threshold cos cos-value period period count count
By default, the upper threshold for PFC deadlock times during the specified period is not configured.
7. Enter Ethernet interface view.
8. Set the recovery mode for PFC deadlock detection on the Ethernet interface.
priority-flow-control deadlock recover-mode { auto | manual }
By default, PFC deadlock detection recovers in automatic mode.
9. Enable PFC deadlock detection on the Ethernet interface.
priority-flow-control deadlock enable
By default, PFC deadlock detection is disabled.
10. (Optional.) Recover PFC deadlock detection on the Ethernet interface.
You can use only this command to recover PFC deadlock detection if you set the manual recovery mode for PFC deadlock detection on the Ethernet interface.
You can configure the early warning threshold for incoming or outgoing PFC packets of an interface as needed. The early warning threshold notifies a situation where the PFC packet transmission rate is still within a normal range but needs attention.
When the rate of PFC packets that an interface sends or receives reaches the early warning threshold, the system generates traps and logs to notify the user. According to the traps and logs, the user can discover some exceptions in the network, for example:
· The NIC of the peer device fails and continuously sends PFC packets at a high speed. In this case, you can set the early warning threshold for incoming PFC packets.
· The device fails and continuously sends PFC frames. In this case, you can set the early warning threshold for outgoing PFC packets.
To monitor bidirectional PFC packets, you can set the early warning thresholds for incoming packets and outgoing packets separately.
The number of PFC pause frames that an interface sends or receives is counted and the early warning threshold configuration takes effect only when PFC is enabled.
3. Configure the early warning threshold for incoming PFC packets.
priority-flow-control early-warning dot1p dot1p-list inpps pps-value
By default, no early warning threshold is configured for incoming PFC packets.
4. Configure the early warning threshold for outgoing PFC packets.
priority-flow-control early-warning dot1p dot1p-list outpps pps-value
By default, no early warning threshold is configured for outgoing PFC packets.
Verifying and maintaining PFC
To display the PFC information of interfaces, execute the following command in any view:
display priority-flow-control interface [ interface-type [ interface-number ] ]
