| 01-HH3C-IKE-MONITOR-MIB | 70.46 KB |
About this MIB
Use this MIB to obtain IKE monitor information, including IKE tunnel, IKE trap, and IKE MIB version information.
MIB file name
hh3c-ike-monitor.mib
Notifications
hh3cIKETunnelStart
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506. 2.30.1.6.1.1 |
IKE tunnel created. |
Informational |
Warning |
N/A |
OFF |
Notification triggers
This notification is generated when an IKE tunnel is created.
System impact
No impact on services.
Status control
ON
· CLI: Use the snmp-agent trap enable ike tunnel-start command.
· MIB: Set hh3cIKETunnelStartTrapCntl to enabled(1).
OFF
· CLI: Use the undo snmp-agent trap enable ike tunnel-start command
· MIB: Set hh3cIKETunnelStartTrapCntl to disabled(2).
Objects
OID(object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.30.1.1.1.5 (hh3cIKETunLocalAddr) |
IP address of the tunnel local end. |
hh3cIKETunIndex |
IpAddress |
Standard MIB values. |
1.3.6.1.4.1.25506.2.30.1.1.1.9 (hh3cIKETunRemoteAddr) |
IP address of the tunnel remote end. |
hh3cIKETunIndex |
IpAddress |
1.3.6.1.4.1.25506.2.30.1.1.1.16 (hh3cIKETunLifeTime) |
Lifetime of the IKE tunnel. |
hh3cIKETunIndex |
Integer32 |
1..2147483647 |
1.3.6.1.4.1.25506.2.30.1.1.1.1 (hh3cIKETunIndex) |
Index of a tunnel. |
hh3cIKETunIndex |
Integer32 |
1..2147483647 |
1.3.6.1.4.1.25506.2.30.1.1.1.23 (hh3cIKETunLocalInetAddrType) |
IP address type of the tunnel local end. |
hh3cIKETunIndex |
InetAddressType |
1.3.6.1.4.1.25506.2.30.1.1.1.24 (hh3cIKETunLocalInetAddr) |
hh3cIKETunIndex |
InetAddress |
1.3.6.1.4.1.25506.2.30.1.1.1.25 (hh3cIKETunRemoteInetAddrType) |
IP address type of the tunnel remote end. |
hh3cIKETunIndex |
InetAddressType |
1.3.6.1.4.1.25506.2.30.1.1.1.26 (hh3cIKETunRemoteInetAddr) |
hh3cIKETunIndex |
InetAddress |
Recommended action
No action is required.
