01-Device Login
HomeSupportConfigure & DeployConfiguration ExamplesH3C Routers Easy and Effortless Routing Feature Configuration Examples-6W10101-Device Login
05-MSR Routers SSH Server Configuration Examples
05-MSR Routers SSH Server Configuration Examples 184.17 KB
MSR Routers
Introduction
The following information provides an example for using SSH to implement secure remote access or file management on the MSR router series.
The following information applies to Comware 7-based MSR router series. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of SSH.
Example: Configuring the device as an Stelnet server (password authentication)
As shown in Figure 1, establish an Stelnet connection between the host and the device to remotely log in to the device to manage the campus network. Configure the entities in the network to meet the following requirements:
·     The device uses local password authentication.
·     The login username and password are client001 and 123456TESTplat&!, respectively.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·     To ensure correct SSH version negotiation and algorithm negotiation, and to ensure that the server can pass the client's authentication, generate DSA and RSA key pairs on the server.
·     To perform local authentication, create a local user and configure a password for the local user on the Stelnet server.
·     Because the Stelnet client accesses the device through VTY user lines, the authentication mode for Stelnet user lines must be AAA (scheme).
·     To enable an SSH user to use all commands after login, set the user role of the local user to network-admin. By default, the user role of a local user is network-operator.
Software versions used
This document applies to Comware 7-based MSR router series. This configuration example was created and verified on R6749P14 of the MSR3610-X1 router.
# Generate a RSA key pair.
[Device] public-key local create rsa
If the key modulus is greater than 512, it will take a few minutes.
Press CTRL+C to abort.
Generating Keys...
# Generate a DSA key pair.
[Device] public-key local create dsa
Generating Keys...
# Enable the SSH server.
[Device] ssh server enable
# Assign an IP address to GigabitEthernet 1/0/1. The Stelnet client uses this IP address to connect to the Stelnet server.
[Device] interface GigabitEthernet 1/0/1
[Device-GigabitEthernet1/0/1] ip address 192.168.1.40 255.255.255.0
# Set the authentication mode to AAA (scheme) for the user lines.
[Device] line vty 0 63
[Device-line-vty0-63] authentication-mode scheme
[Device-line-vty0-63] quit
# Create local user client001, specify the user password, service type, and user role.
[Device] local-user client001 class manage
New local user added.
[Device-luser-manage-client001] password simple 123456TESTplat&!
[Device-luser-manage-client001] service-type ssh
[Device-luser-manage-client001] authorization-attribute user-role network-admin
[Device-luser-manage-client001] quit
There are different types of Stelnet client software, such as PuTTY and OpenSSH. This example uses an Stelnet client that runs Putty version 0.60.
To log in to the Stelnet server from the Stelnet client:
1.     Launch PuTTY.exe.
2.     From the navigation pane, click Session.
The client configuration interface opens, as shown in Figure 2.
3.     Configure the following parameters:
a.     .       Enter 192.168.1.40 in the Host Name (or IP address) field.
b.     Enter 22 in the Port field.
c.     Select SSH for Connection type.
Figure 2 SSH client configuration interface
4.     Click Open. The PuTTY Security Alert dialog box appears.
Figure 3 PuTTY Security Alert dialog box
5.     Click Yes.
6.     Enter username client001 and password 123456TESTplat&! to log in to the Stelnet server. You can log in to the device successfully and use all commands on the device.
login as: client001
[email protected]'s password:
* Copyright (c) 2004-2023 Hangzhou H3C Tech. Co., Ltd. All rights reserved.  *
<Device>
Configuration files
 port link-mode route
line vty 0 63
ssh server enable
 password hash $h$6$CqMnWdX6LIW/hz2Z$4+0Pumk+A98VlGVgqN3n/mEi7hJka9fEZpRZIpSNi9bcBEXhpvIqaYTvIVBf7ZUNGnovFsqW7nYxjoToRDvYBg==
 service-type ssh
Related documentation
·     Security Configuration Guide in H3C MSR Router Series Comware 7 Configuration Guides
·     Security Command Reference in H3C MSR Router Series Comware 7 Command References
