- 21-WLAN Configuration Guide
- 01-AP management configuration
- 02-WIPS configuration
- 03-WLAN IP snooping configuration
- 04-WLAN QoS configuration
- 05-WLAN access configuration
- 06-WLAN roaming configuration
- 07-WLAN security configuration
- 08-WLAN authentication configuration
- 09-WLAN load balancing configuration
- 10-WLAN high availability configuration
- 11-Channel scanning configuration
- 12-Radio management configuration
- 13-WLAN radio resource measurement configuration
- 14-WLAN probe configuration
- 15-WLAN multicast optimization configuration
- 16-Band navigation configuration
- 17-Spectrum management configuration
| 00-Preface | 111.04 KB |
Preface
· This configuration guide describes the fundamentals and configuration procedures for WLAN features.
· Security zones, security policies, object groups, object policies, APR, and session management.
· User access and authentication features (such as AAA, portal, user identification, password control, and PKI).
· Data security features (such as public key management, SSL, SSH, and crypto engine).
· Attack protection features (such as ASPF, connection limit, IP source guard, ARP attack protection, ND attack defense, uRPF, attack detection and prevention, and IP-MAC binding).
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
