- 12-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-iNQA commands
- 04-NTP commands
- 05-PTP commands
- 06-Network synchronization commands
- 07-PoE commands
- 08-SNMP commands
- 09-RMON commands
- 10-NETCONF commands
- 11-SmartMC commands
- 12-EPA commands
- 13-CWMP commands
- 14-EAA commands
- 15-Process monitoring and maintenance commands
- 16-Sampler commands
- 17-Mirroring commands
- 18-NetStream commands
- 19-IPv6 NetStream commands
- 20-NetAnalysis commands
- 21-sFlow commands
- 22-Information center commands
- 23-GOLD commands
- 24-Packet capture commands
- 25-VCF fabric commands
- 26-Cloud connection commands
- 27-EPS agent commands
- 28-eMDI commands
- 29-SQA commands
- 30-Performance management commands
- 31-TCP connection trace commands
| 20-NetAnalysis commands | 141.43 KB |
display netanalysis rocev2 cache
display netanalysis rocev2 statistics
netanalysis rocev2 ai-ecn enable
netanalysis rocev2 drop global
netanalysis rocev2 report-interval
netanalysis rocev2 timeout inactive
netanalysis rocev2 vxlan statistics
netanalysis rocev2 vxlan drop global
netanalysis rocev2 vxlan-ip statistics
netanalysis rocev2 vxlan-ip drop global
reset netanalysis rocev2 statistics
Use display netanalysis rocev2 cache to display the configuration and status of the RoCEv2 cache.
display netanalysis rocev2 cache [ destination destination-ip | dstvxlan-id dstvxlan-id | source source-ip | srcvxlan-id srcxlan-id ]*
destination destination-ip: Specifies a server IP address.
dstvxlan-id dstvxlan-id: Specifies the destination VXLAN ID for the RoCEv2 flow. The value range of the dstvxlan-id argument is 0 to 16777215.
source source-ip: Specifies a client IP address.
srcvxlan-id srcvxlan-id: Specifies the source VXLAN ID for the RoCEv2 flow. The value range of the srcvxlan-id argument is 0 to 16777215.
The device uses the RoCEv2 cache to save RoCEv2 traffic statistics after receiving RoCEv2 flows. When an RoCEv2 flow ages out, the device deletes the related traffic statistics from the RoCEv2 cache.
# Display the configuration and status of the RoCEv2 cache when bidirectional mode is used for RoCEv2 traffic analysis.
<Sysname> display netanalysis rocev2 cache source 1.1.1.2 destination 2.2.2.1
S2D: source to destination D2S: destination to source
RTT: round trip time RPT: packet throughput in read mode
WPT: packet throughput in write mode SPT: packet throughput in send mode
I: input O: output L: local R: remote
NetAnalysis cache information:
Flow created at Service type
Src IP Src QP S2D RTT S2D RPT S2D SPT/WPT
S2D NAK Pkts S2D Interface(I) S2D Interface(O)
S2D Src VXLAN ID S2D Dst VXLAN ID
Dst IP Dst QP D2S RTT D2S RPT D2S SPT/WPT
D2S NAK Pkts D2S Interface(I) D2S Interface(O)
D2S Src VXLAN ID D2S Dst VXLAN ID
01/22/2019 09:08:15 RC
1.1.1.2 93309 50 11 11
2 XGE3/0/1(L) XGE3/0/2(L)
2.2.2.1 85353 50 11 11
8373 XGE3/0/2(L) XGE3/0/1(L)
NOTE: S2D: source to destination D2S: destination to source RTT: round trip time RPT: packet throughput in read mode WPT: packet throughput in write mode SPT: packet throughput in send mode I: input O: output L: local R: remote |
Meanings of the acronyms: · S2D—Statistics about an RoCEv2 flow sent from a client to a server. · D2S—Statistics about an RoCEv2 flow sent from a server to a client. · RTT—RTT for an RoCEv2 flow. · RPT—Read packet throughput. · WPT—Write packet throughput. · SPT—Send packet throughput. · I—Incoming interface for an RoCEv2 flow. · O—Outgoing interface for an RoCEv2 flow. · L—Local interface. · R—Interface on an M-LAG peer. |
NetAnalysis cache information |
Configuration and status of the RoCEv2 cache. |
Flow created at |
Time when the RoCEv2 flow was created. |
Service type |
Service type of the RoCEv2 flow: · RC—Reliable connection. · UC—Unreliable connection. This type is not supported in the current software version. · RD—Reliable datagram. This type is not supported in the current software version. · UD—Unreliable datagram. · XRC—Extended reliable connection. This type is not supported in the current software version. |
Src IP |
Client IP address for the RoCEv2 flow. |
Dst IP |
Server IP address for the RoCEv2 flow. |
Src QP |
Client QP for the RoCEv2 flow. |
Dst QP |
Server QP for the RoCEv2 flow. |
S2D RPT |
Throughput in KBps for the Read packets sent from the client. |
D2S RPT |
Throughput in KBps for the Read packets sent from the server. If the service type of the RoCEv2 flow is UD, this field displays 0. |
S2D SPT/WPT |
Throughput in KBps for the Send and Write packets sent from the client. If the device is configured with the mirror-to cpu command or the INT feature, the value for this field might be incorrect. |
D2S SPT/WPT |
Throughput in KBps for the Send and Write packets sent from the server. If the service type of the RoCEv2 flow is UD, this field displays 0. If the device is configured with the mirror-to cpu command or the INT feature, the value for this field might be incorrect. |
S2D RTT |
RTT in microseconds for the RoCEv2 flow sent from the client. If the service type of the RoCEv2 flow is UD, this field displays 0. |
D2S RTT |
RTT in microseconds for the RoCEv2 flow sent from the server. If the service type of the RoCEv2 flow is UD, this field displays 0. |
S2D NAK Pkts |
Number of NAK packets sent from the client. Packet loss has occurred if this field is not 0. |
D2S NAK Pkts |
Number of NAK packets sent from the server. Packet loss has occurred if this field is not 0. |
S2D Interface(I) |
Incoming interface for the RoCEv2 flow sent from the client. |
S2D Interface(O) |
Outgoing interface for the RoCEv2 flow sent from the client. |
D2S Interface(I) |
Incoming interface for the RoCEv2 flow sent from the server. If the service type of the RoCEv2 flow is UD, this field displays N/A. |
D2S Interface(O) |
Outgoing interface for the RoCEv2 flow sent from the server. If the service type of the RoCEv2 flow is UD, this field displays N/A. |
S2D Src VXLAN ID |
Source VXLAN ID of the RoCEv2 flow sent from the client. A value of N/A indicates non-VXLAN flow table. |
S2D Dst VXLAN ID |
Destination VXLAN ID for the RoCEv2 flow originating from the client. A value of N/A indicates non-VXLAN flow table. |
D2S Src VXLAN ID |
Source VXLAN ID for the RoCEv2 flow returned from the server. This field displays N/A in one of the following conditions: · Non-VXLAN flow table. · The service type of the RoCEv2 flow is UD. |
D2S Dst VXLAN ID |
Destination VXLAN ID for the RoCEv2 flow returned from the server. This field displays N/A in one of the following conditions: · Non-VXLAN flow table. · The service type of the RoCEv2 flow is UD. |
# Display the configuration and status of the RoCEv2 cache when unidirectional mode is used for RoCEv2 traffic analysis.
<sysname> display netanalysis rocev2 cache source 1.1.1.2 destination 2.2.2.1
Src IP Dst IP Src QP Dst QP
Interface(I) Interface(O) RPT SPT/WPT
Src VXLAN ID Dst VXLAN ID
1.1.1.2 2.2.2.1 N/A 8373
XGE3/0/1(L) XGE3/0/2(L) 11 11
NOTE: RPT: packet throughput in read mode WPT: packet throughput in write mode SPT: packet throughput in send mode I: input O: output L: local R: remote |
Meanings of the acronyms: · RPT—Read packet throughput. · WPT—Write packet throughput. · SPT—Send packet throughput. · I—Incoming interface for an RoCEv2 flow. · O—Outgoing interface for an RoCEv2 flow. · L—Local interface. · R—Interface on an M-LAG peer. |
Flow created at |
Service type |
Src IP |
Source IP address for the RoCEv2 flow. |
Dst IP |
Destination IP address for the RoCEv2 flow. |
Src QP |
Source QP for the RoCEv2 flow. |
Dst QP |
Destination QP for the RoCEv2 flow. |
RPT |
Throughput in KBps for Read packets. |
SPT/WPT |
Throughput in KBps for the Send and Write packets. If the device is configured with the mirror-to cpu command or the INT feature, the value for this field might be incorrect. |
NAK Pkts |
Number of NAK packets. Packet loss has occurred if this field is not 0. |
Interface(I) |
Incoming interface for the RoCEv2 flow. |
Interface(O) |
Outgoing interface for the RoCEv2 flow. |
Src VXLAN ID |
Source VXLAN ID for the RoCEv2 flow. A value of N/A indicates non-VXLAN flow table. |
Dst VXLAN ID |
Destination VXLAN ID for the RoCEv2 flow. A value of N/A indicates non-VXLAN flow table. |
Use display netanalysis rocev2 statistics to display RoCEv2 traffic statistics.
# Display RoCEv2 traffic statistics when bidirectional mode is used for RoCEv2 traffic analysis.
<Sysname> display netanalysis rocev2 statistics
Last statistics resetting time: Never
Received packets: 1833088
Active Aged Created Reported
(Sessions) (Sessions) (Sessions) (Sessions)
RoCEv2
2 0 2 10
# Display RoCEv2 traffic statistics when unidirectional mode is used for RoCEv2 traffic analysis.
Received packets: 2833088
(Flows) (Flows) (Flows) (Flows)
RoCEv2
4 0 2 20
Last statistics resetting time |
Time when the RoCEv2 traffic statistics were last cleared. |
Received packets |
Number of received RoCEv2 packets. |
Type |
Flow type. The current software version supports only the RoCEv2 flow type. |
Active (Flows) |
Number of active flows. |
Aged (Flows) |
Number of aged flows. |
Created (Flows) |
Number of created flows. |
Reported (Flows) |
Number of flows reported to the NDA. |
Active (Sessions) |
Number of active sessions. |
Aged (Sessions) |
Number of aged sessions. |
Created (Sessions) |
Number of created sessions. |
Reported (Sessions) |
Number of sessions reported to the NDA. |
Use netanalysis rocev2 ai-ecn enable to enable AI ECN for RoCEv2 traffic statistics collection.
Use undo netanalysis rocev2 ai-ecn enable to disable AI ECN for RoCEv2 traffic statistics collection.
AI ECN is disabled for RoCEv2 traffic statistics collection.
AI ECN allows the device to collect RoCEv2 traffic statistics on a per-session basis on the outgoing interfaces for RoCEv2 traffic and send the RoCEv2 traffic statistics to the NDA. Based on the RoCEv2 traffic statistics, the NDA automatically adjusts the ECN threshold for lossless queues to ensure low latency and high throughput for lossless traffic. For more information about ECN, see QoS configuration in ACL and QoS Configuration Guide.
# Enable AI ECN for RoCEv2 traffic statistics collection.
[Sysname] netanalysis rocev2 ai-ecn enable
netanalysis rocev2 mode
Use netanalysis rocev2 drop global to enable RoCEv2 packet loss analysis globally.
Use undo netanalysis rocev2 drop global to disable RoCEv2 packet loss analysis globally.
RoCEv2 packet loss analysis is disabled globally.
For RoCEv2 packet loss analysis to take effect, first enable bidirectional mode for RoCEv2 traffic analysis.
This command enables the device to perform RoCEv2 packet loss analysis for all received RoCEv2 packets.
To view RoCEv2 packet loss statistics, examine the S2D NAK Pkts and D2S NAK Pkts fields in the output from the display netanalysis rocev2 cache command.
# Enable RoCEv2 packet loss analysis globally.
[Sysname] netanalysis rocev2 drop global
Use netanalysis rocev2 mode to set the mode of RoCEv2 traffic analysis.
Use undo netanalysis rocev2 mode to restore the default.
netanalysis rocev2 mode { bidir | single }
RoCEv2 traffic analysis is disabled, and the mode of RoCEv2 traffic analysis is not set.
bidir: Specifies bidirectional mode. In this mode, NetAnalysis collects RoCEv2 traffic statistics based on RoCEv2 sessions and provides the RTT and lost packet count for each RoCEv2 session.
single: Specifies unidirectional mode. In this mode, NetAnalysis collects RoCEv2 traffic statistics based on RoCEv2 flows and does not provides the flow-specific RTT or lost packet count.
For NetAnalysis features to take effect, first set the mode of RoCEv2 traffic analysis.
When you change the mode of RoCEv2 traffic analysis, all NetAnalysis configuration and the RoCEv2 cache are cleared. Make sure you are fully aware of the impact of this operation when you perform it on a live network.
When multiple paths exist between an RDMA client and an RDMA server, set the mode of RoCEv2 traffic analysis as follows to ensure correct RoCEv2 traffic analysis:
· Enable bidirectional mode on the devices attached to the server and the client.
· Enable unidirectional mode on the intermediate devices.
# Enable unidirectional RoCEv2 traffic analysis.
[Sysname] netanalysis rocev2 mode single
This operation will erase all the net analysis configuration.
Continue?[Y/N]:y
# Enable bidirectional RoCEv2 traffic analysis.
[Sysname] netanalysis rocev2 mode bidir
Continue?[Y/N]:y
Use netanalysis rocev2 report-interval to set the interval for reporting RoCEv2 traffic statistics to the NDA.
Use undo netanalysis rocev2 report-interval to restore the default.
netanalysis rocev2 report-interval interval
The device reports RoCEv2 traffic statistics to the NDA at an interval of 10 seconds.
seconds: Specifies an interval value in seconds, in the range of 5 to 500.
Use this command to adjust the interval at which the device reports RoCEv2 traffic statistics to the NDA.
# Configure the device to report RoCEv2 traffic statistics to the NDA at an interval of 15 seconds.
[Sysname] netanalysis rocev2 report-interval 15
Use netanalysis rocev2 statistics to enable RoCEv2 traffic statistics collection.
Use undo netanalysis rocev2 statistics to disable RoCEv2 traffic statistics collection.
netanalysis rocev2 statistics { global | acl name acl-name }
RoCEv2 traffic statistics collection is disabled.
global: Specifies all received RoCEv2 traffic.
acl name acl-name: Specifies an advanced ACL for filtering RoCEv2 traffic by its name, a case-insensitive string of 1 to 63 characters. The ACL name must begin with an uppercase or lowercase letter and cannot be all.
Use this command to enable NetAnalysis to analyze RoCEv2 traffic and send the analysis results to the NAP. You can use an ACL to match the RoCEv2 traffic of interest. The deny or permit action in the ACL does not take effect. NetAnalysis supports the following rules of advanced ACLs:
· Rule 1—Matches the UDP protocol and destination IPv4 address.
· Rule 2—Matches the UDP protocol and source IPv4 address.
· Rule 3—Matches the UDP protocol and source and destination IPv4 addresses.
To ensure correct collection and reporting of RoCEv2 traffic statistics, use the rules supported by NetAnalysis. For more information about ACLs, see ACL and QoS Configuration Guide.
If the specified ACL does not exist or does not contain any rules, this command does not take effect.
In an ACL, rules do not support the vpn-instance criterion, and the rule applies to both public network traffic and VPN traffic.
# Enable NetAnalysis to collect statistics about all received RoCEv2 traffic.
[Sysname] netanalysis rocev2 statistics global
# Enable NetAnalysis to collect statistics about the received RoCEv2 traffic that matches ACL abc.
[Sysname] netanalysis rocev2 statistics acl name abc
Use netanalysis rocev2 timeout inactive to set the aging timer for inactive RoCEv2 flows.
Use undo netanalysis rocev2 timeout inactive to restore the default.
netanalysis rocev2 timeout inactive seconds
The aging timer for inactive RoCEv2 flows is set to 30 seconds.
seconds: Sets the aging timer for inactive RoCEv2 flows, in seconds. The value range for this argument is 5 to 500 seconds.
When an inactive RoCEv2 flow ages out, the device outputs the related traffic statistics to the NDA and deletes these traffic statistics from the RoCEv2 cache.
# Set the aging timer for inactive RoCEv2 flows to 10 seconds.
[Sysname] netanalysis rocev2 timeout inactive 10
Use netanalysis rocev2 vxlan statistics to enable the NetAnalysis statistics feature for RoCEv2 traffic on VXLAN tunnel intermediate nodes.
Use undo netanalysis rocev2 vxlan statistics to disable the NetAnalysis statistics feature for RoCEv2 traffic on VXLAN tunnel intermediate nodes.
netanalysis rocev2 vxlan statistics { acl name acl-name | global }
The NetAnalysis statistics feature is disabled for RoCEv2 traffic on VXLAN tunnel intermediate nodes.
acl name acl-name: Specifies the name of an advanced ACL. The acl-name represents the ACL name, a case-insensitive string of 1 to 63 characters. The string must start with a letter but cannot be all. If you do not specify this option, the command enables the statistics feature for all RoCEv2 flows on the intermediate nodes. If the specified ACL does not exist or the specified ACL does not contain valid rules, the configuration does not take effect and the command does not enable the statistics feature for any RoCEv2 flows on the intermediate nodes.
global: Enables NetAnalysis statistics for all RoCEv2 flows on the intermediate nodes.
Application scenarios
To understand and optimize network performance, and to enhance the transmission speed and reliability, you can configure the NetAnalysis statistics feature for RoCEv2 traffic within a VXLAN tunnel.
Operating mechanism
With this feature enabled, the device performs NetAnalysis statistical analysis on RoCEv2 traffic on VXLAN tunnel intermediate nodes. It characterizes each traffic flow's data, including volume, bandwidth, and latency, and uploads the analysis results to the Net-analysis Processor (NAP) for further processing.
The specified RoCEv2 traffic is matched through ACL rules, but the designated deny or permit actions do not take effect. Currently, only the following advanced ACL rules are supported:
· rule1—Configures only the UDP protocol and destination IPv4 address.
· rule2—Configures only the UDP protocol and source IPv4 address.
· rule3—Configures only the UDP protocol, source IPv4 address, and destination IPv4 address.
Unsupported ACL rules do not take effect, preventing NAP from receiving the matched traffic flows. For more information about ACL rule configuration, see ACL and QoS Configuration Guide.
# Enable the NetAnalysis statistics feature for RoCEv2 traffic matching ACL abc on VXLAN tunnel intermediate nodes
[Sysname] netanalysis rocev2 vxlan statistics acl name abc
# Enable the NetAnalysis statistics feature for all RoCEv2 traffic on VXLAN tunnel intermediate nodes.
[Sysname] netanalysis rocev2 vxlan statistics global
Use netanalysis rocev2 vxlan drop global to enable the global packet loss analysis feature for RoCEv2 traffic on VXLAN tunnel intermediate nodes.
Use undo netanalysis rocev2 vxlan drop global to disable the global packet loss analysis feature for RoCEv2 traffic on VXLAN tunnel intermediate nodes.
The global packet loss analysis feature is disabled for RoCEv2 traffic on VXLAN tunnel intermediate nodes.
For this feature to take effect, you must first set the mode of RoCEv2 traffic analysis to bidirectional.
In a VXLAN network with RoCEv2, ensuring zero packet loss for network traffic is crucial. You can configure this feature to analyze packet loss for decapsulated RoCEv2 traffic on intermediate nodes within the VXLAN tunnel.
You can execute the display netanalysis rocev2 cache command and view the S2D NAK Pkts and D2S NAK Pkts fields in the command output to view packet loss information.
# Enable the global packet loss analysis feature for RoCEv2 traffic on VXLAN tunnel intermediate nodes.
[Sysname] netanalysis rocev2 vxlan drop global
Use netanalysis rocev2 vxlan-ip statistics to enable the NetAnalysis statistics feature for RoCEv2 traffic at the VXLAN tunnel edges.
Use undo netanalysis rocev2 vxlan-ip statistics to disable the NetAnalysis statistics feature for RoCEv2 traffic at the VXLAN tunnel edges.
netanalysis rocev2 vxlan-ip statistics { acl name acl-name | global }
The NetAnalysis statistics feature is disabled for RoCEv2 traffic at the edges of a VXLAN tunnel.
acl name acl-name: Specifies the name of an advanced ACL. The acl-name represents the ACL name, a case-insensitive string of 1 to 63 characters. The string must start with a letter but cannot be all. If you do not specify this option, the command enables the statistics feature for all RoCEv2 flows at the VXLAN tunnel edges. If the specified ACL does not exist or the specified ACL does not contain valid rules, the configuration does not take effect and the command does not enable the statistics feature for any RoCEv2 flows at the VXLAN tunnel edges.
global: Enables NetAnalysis statistics for all RoCEv2 flows at the VXLAN tunnel edges.
Operating mechanism
With this feature enabled, the device performs NetAnalysis statistical analysis on RoCEv2 traffic at VXLAN tunnel edges. It characterizes each traffic flow's data, including volume, bandwidth, and latency, and uploads the analysis results to the Net-analysis Processor (NAP) for further processing.
# Enable the NetAnalysis statistics feature for RoCEv2 traffic matching ACL abc at the VXLAN tunnel edges.
[Sysname] netanalysis rocev2 vxlan-ip statistics acl name abc
# Enable the NetAnalysis statistics feature for all RoCEv2 traffic at the VXLAN tunnel edges.
[Sysname] netanalysis rocev2 vxlan-ip statistics global
Use netanalysis rocev2 vxlan-ip drop global to enable the global packet loss analysis feature for RoCEv2 traffic at the VXLAN tunnel edges.
Use undo netanalysis rocev2 vxlan-ip drop global to disable the global packet loss analysis feature for RoCEv2 traffic at the VXLAN tunnel edges.
The global packet loss analysis feature is disabled for RoCEv2 traffic at the VXLAN tunnel edges.
In a VXLAN network with RoCEv2, ensuring zero packet loss for network traffic is crucial. You can configure this feature to analyze packet loss for decapsulated RoCEv2 traffic at the edges of the VXLAN tunnel.
# Enable the global packet loss analysis feature for RoCEv2 traffic at the VXLAN tunnel edges.
[Sysname] netanalysis rocev2 vxlan-ip drop global
Use reset netanalysis rocev2 statistics to clear RoCEv2 traffic statistics.
Use this command to clear RoCEv2 traffic statistics if you want to collect RoCEv2 traffic statistics for a specific time period.
You cannot recover cleared RoCEv2 traffic statistics. Make sure you are fully aware of the impact of this command when you use it on a live network.
# Clear RoCEv2 traffic statistics.
<Sysname> reset netanalysis rocev2 statistics
