- 05-Layer 3—IP Routing Configuration Guide
- 01-Basic IP routing configuration
- 02-Static routing configuration
- 03-RIP configuration
- 04-OSPF configuration
- 05-IS-IS configuration
- 06-BGP configuration
- 07-Policy-based routing configuration
- 08-IPv6 static routing configuration
- 09-RIPng configuration
- 10-OSPFv3 configuration
- 11-IPv6 policy-based routing configuration
- 12-Routing policy configuration
11-IPv6 policy-based routing configuration | 159.35 KB |
IPv6 packet forwarding process
Restrictions and guidelines: IPv6 PBR configuration
Setting match criteria for an IPv6 node
Configuring actions for an IPv6 node
Specifying a policy for IPv6 PBR
Specifying an IPv6 policy for IPv6 local PBR
Specifying an IPv6 policy for IPv6 interface PBR
Specifying an IPv6 policy for IPv6 global PBR
Display and maintenance commands for IPv6 PBR
IPv6 PBR configuration examples
Example: Configuring packet type-based IPv6 local PBR
Example: Configuring packet type-based IPv6 interface PBR
Configuring IPv6 PBR
About IPv6 PBR
IPv6 policy-based routing (PBR) uses user-defined policies to route IPv6 packets. A policy can specify parameters for packets that match specific criteria such as ACLs or service chains. The parameters include the next hop or output interface.
When the device receives an IPv6 packet, the device searches the IPv6 PBR policy for a matching node to forward that packet.
· If a matching node is found and its match mode is permit, the device performs the following operations:
a. Uses the next hops or output interfaces specified on the node to forward the packet.
b. Searches the routing table for a route to forward the packet if one of the following conditions exists:
- No next hops or output interfaces are specified on the node.
- Forwarding failed based on the next hops or output interfaces.
· The device perfoms routing table lookup to forward the packet in either of the following conditions:
¡ No matching node is found.
¡ A matching node is found, but its match mode is deny.
IPv6 PBR types
IPv6 PBR includes the following types:
· Local PBR—Guides the forwarding of locally generated packets, such as the ICMP packets generated by using the ping command.
· Interface PBR—Guides the forwarding of packets received on an interface only.
Policy
An IPv6 policy includes match criteria and actions to be taken on the matching packets. A policy can have one or multiple nodes as follows:
· Each node is identified by a node number. A smaller node number has a higher priority.
· A node contains if-match and apply clauses. An if-match clause specifies a match criterion, and an apply clause specifies an action.
· A node has a match mode of permit or deny.
An IPv6 policy compares packets with nodes in priority order. If a packet matches the criteria on a node, it is processed by the action on the node. If the packet does not match any criteria on the node, it goes to the next node for a match. If the packet does not match the criteria on any node, the device performs a routing table lookup for the packet.
Relationship between if-match clauses
On a node, you can specify multiple types of if-match clauses, but only one if-match clause for each type. For a specific type of if-match clause, the most recent configuration overwrites the previous one. A packet that matches all the if-match clauses of a node matches the node.
Relationship between apply clauses
You can specify multiple apply clauses for a node, but some of them might not be executed. For more information about the relationship between the apply clauses, see "Configuring actions for an IPv6 node."
Relationship between the match mode and clauses on the node
Match mode |
In permit mode |
In deny mode |
Yes |
· If the node contains apply clauses, IPv6 PBR executes the apply clauses on the node. ¡ If IPv6 PBR-based forwarding succeeds, IPv6 PBR does not compare the packet with the next node. ¡ If IPv6 PBR-based forwarding fails, IPv6 PBR compares the packet with the next node. · If the node does not contain apply clauses, the device performs a routing table lookup for the packet. |
The device performs a routing table lookup for the packet. |
No |
IPv6 PBR compares the packet with the next node. |
NOTE: A node that has no if-match clauses matches any packet. |
IPv6 PBR and Track
IPv6 PBR can work with the Track feature to dynamically adapt the availability status of an apply clause to the link status of a tracked object. The tracked object can be a next hop or output interface.
· When the track entry associated with an object changes to Negative, the apply clause is invalid.
· When the track entry changes to Positive or NotReady, the apply clause is valid.
For more information about Track and IPv6 PBR collaboration, see High Availability Configuration Guide.
If a packet destined for the local device matches an IPv6 PBR policy, IPv6 PBR will execute the apply clauses in the policy, including the clause for forwarding. When you configure an IPv6 PBR policy, be careful to avoid this situation.
IPv6 PBR tasks at a glance
To configure IPv6 PBR, perform the following tasks:
b. Setting match criteria for an IPv6 node
c. Configuring actions for an IPv6 node
2. Specifying a policy for IPv6 PBR
¡ Specifying an IPv6 policy for IPv6 local PBR
¡ Specifying an IPv6 policy for IPv6 interface PBR
¡ Specifying an IPv6 policy for IPv6 global PBR
Configuring an IPv6 policy
Creating an IPv6 node
1. Enter system view.
2. Create an IPv6 policy or policy node and enter its view.
3. (Optional.) Configure a description for the IPv6 policy node.
By default, no description is configured for an IPv6 policy node.
When setting an ACL match criterion, follow these restrictions and guidelines:
· If the specified ACL does not exist or has no rules configured, all packets will match the ACL.
· If the vpn-instance keyword is specified for an ACL rule, the ACL does not take effect. If the vpn-instance keyword is not specified, the rule applies to both public network and private network packets.
2. Enter IPv6 policy node view.
3. Set match criteria.
¡ Set an ACL match criterion.
By default, no ACL match criterion is set.
The ACL match criterion cannot match Layer 2 information.
When using the ACL to match packets, IPv6 PBR ignores the action (permit or deny) and time range settings in the ACL.
The apply clauses allow you to specify actions to take on matching packets on a node.
The following apply clauses determine the packet forwarding paths in a descending order:
· apply next-hop
· apply output-interface
IPv6 PBR supports the apply clauses in Table 1.
Table 1 Apply clauses supported in IPv6 PBR
Clause |
Meaning |
Remarks |
apply loadshare next-hop |
Enables load sharing among multiple next hops. |
Multiple next hop options operate in either primary/backup or load sharing mode. · Primary/backup mode—One option is selected from all options in configuration order for packet forwarding, with all remaining options as backups. For example, if multiple next hops are configured, the first configured next hop is selected. When the selected next hop fails, the next available next hop takes over. · Load sharing mode—Matching traffic is distributed across the available options. Multiple next hops load share traffic in round robin manner, starting from the first configured option. They perform per-packet load sharing for traffic that does not match any fast forwarding entry, and perform per-flow load sharing for traffic that matches a fast forwarding entry. By default, the primary/backup mode applies. For the load sharing mode to take effect, make sure multiple next hops are set in the policy. |
apply next-hop and apply output-interface |
Sets next hops and sets output interfaces. |
If both clauses are configured, only the apply next-hop clause is executed. |
apply service-chain |
Sets service chain information. |
For this clause to take effect, you must also use the apply next-hop clause to specify a reachable next hop. |
Restrictions and guidelines for action configuration
If you specify a next hop, IPv6 PBR periodically performs FIB table lookup to determine its availability. Temporary service interruption might occur if IPv6 PBR does not update the route immediately after its availability status changes.
Configuring actions for a node
3. Configure actions for a node.
¡ Set next hops for permitted IPv6 packets.
apply next-hop [ vpn-instance vpn-instance-name ] { ipv6-address [ direct ] [ track track-entry-number ] [ service-chain path-id service-path-id [ path-index service-path-index ] ] } &<1-6>
By default, no next hops are specified.
You can specify multiple next hops for backup in one command line or by executing this command multiple times. You can specify a maximum of eight next hops for a node.
If multiple next hops on the same subnet are specified for backup, the device first uses the subnet route for the next hops to forward packets when the primary next hop fails. If the subnet route is not available, the device selects a backup next hop.
¡ Enable load sharing among multiple next hops.
By default, the next hops operate in primary/backup mode.
¡ Set output interfaces.
apply output-interface null 0
By default, no output interfaces are specified.
¡ Set service chain information.
apply service-chain path-id service-path-id [ path-index service-path-index ]
By default, no service chain information is set.
This clause does not apply to software forwarded packets.
Perform this task to specify an IPv6 policy for IPv6 local PBR to guide the forwarding of locally generated packets.
You can specify only one policy for IPv6 local PBR and must make sure the specified policy already exists. Before you apply a new policy, you must first remove the current policy.
IPv6 local PBR might affect local services, such as ping and Telnet. When you use IPv6 local PBR, make sure you fully understand its impact on local services of the device.
2. Specify an IPv6 policy for IPv6 local PBR.
By default, IPv6 local PBR is not enabled.
Perform this task to apply an IPv6 policy to an interface to guide the forwarding of packets received on the interface only.
You can apply only one policy to an interface and must make sure the specified policy already exists. Before you apply a new policy, you must first remove the current policy from the interface.
You can apply a policy to multiple interfaces.
2. Enter interface view.
3. Specify an IPv6 policy for IPv6 interface PBR.
By default, no IPv6 policy is applied to the interface.
Perform this task to apply an IPv6 policy to all interfaces on the device to guide the forwarding of packets received on the interfaces.
You can apply only one IPv6 policy for IPv6 global PBR and the specified IPv6 policy must already exist. Before you can apply a new IPv6 policy, you must first remove the current IPv6 policy.
IPv6 interface PBR takes precedence over IPv6 global PBR on an interface. When they are both configured and packets fail to match the IPv6 interface PBR policy, IPv6 global PBR applies.
2. Specify an IPv6 policy for IPv6 global PBR.
ipv6 global policy-based-route policy-name
By default, no IPv6 policy is specified for IPv6 global PBR.
Task |
Command |
Display IPv6 PBR policy information. |
display ipv6 policy-based-route [ policy policy-name ] |
Display IPv6 global PBR configuration and statistics. |
display ipv6 policy-based-route global [ slot slot-number ] |
Display IPv6 interface PBR configuration and statistics. |
display ipv6 policy-based-route interface interface-type interface-number [ slot slot-number ] |
Display IPv6 local PBR configuration and statistics. |
display ipv6 policy-based-route local [ slot slot-number ] |
Display IPv6 PBR configuration. |
display ipv6 policy-based-route setup |
Clear IPv6 PBR statistics. |
reset ipv6 policy-based-route statistics [ policy policy-name ] |
As shown in Figure 1, Switch B and Switch C are connected through Switch A. Switch B and Switch C do not have a route to reach each other.
Configure IPv6 PBR on Switch A to forward all TCP packets to the next hop 1::2 (Switch B).
1. Configure Switch A:
# Create VLAN 10 and VLAN 20.
[SwitchA] vlan 10
[SwitchA-vlan10] quit
[SwitchA] vlan 20
[SwitchA-vlan20] quit
# Configure the IPv6 addresses of VLAN-interface 10 and VLAN-interface 20.
[SwitchA-Vlan-interface10] ipv6 address 1::1 64
[SwitchA-Vlan-interface20] ipv6 address 2::1 64
# Configure ACL 3001 to match TCP packets.
[SwitchA] acl ipv6 advanced 3001
[SwitchA-acl-ipv6-adv-3001] rule permit tcp
[SwitchA-acl-ipv6-adv-3001] quit
# Configure Node 5 for policy aaa to forward TCP packets to next hop 1::2.
[SwitchA] ipv6 policy-based-route aaa permit node 5
[SwitchA-pbr6-aaa-5] if-match acl 3001
[SwitchA-pbr6-aaa-5] apply next-hop 1::2
[SwitchA-pbr6-aaa-5] quit
# Configure IPv6 local PBR by applying policy aaa to Switch A.
[SwitchA] ipv6 local policy-based-route aaa
2. Configure Switch B:
# Create VLAN 10.
[SwitchB] vlan 10
[SwitchB-vlan10] quit
# Configure the IPv6 address of VLAN-interface 10.
[SwitchB-Vlan-interface10] ipv6 address 1::2 64
3. Configure Switch C:
# Create VLAN 20.
[SwitchC] vlan 20
[SwitchC-vlan20] quit
# Configure the IPv6 address of VLAN-interface 20.
[SwitchC] interface vlan-interface 20
[SwitchC-Vlan-interface20] ipv6 address 2::2 64
1. Perform telnet operations to verify that IPv6 local PBR on Switch A operates as configured to forward the matching TCP packets to the next hop 1::2 (Switch B), as follows:
# Verify that you can telnet to Switch B from Switch A successfully. (Details not shown.)
# Verify that you cannot telnet to Switch C from Switch A. (Details not shown.)
2. Verify that Switch A forwards packets other than TCP packets through VLAN-interface 20. For example, verify that you can ping Switch C from Switch A. (Details not shown.)
As shown in Figure 2, Switch B and Switch C do not have a route to reach each other.
Configure IPv6 PBR on Switch A to forward all TCP packets received on VLAN-interface 11 to the next hop 1::2 (Switch B).
1. Configure IPv6 addresses and unicast routing protocol settings to make sure that Switch B and Switch C each have a route to reach Host A. (Details not shown.)
2. Configure Switch A:
# Configure IPv6 interface PBR by applying policy aaa to VLAN-interface 11.
[SwitchA-Vlan-interface11] ipv6 policy-based-route aaa
1. Enable IPv6 and configure the IPv6 address 10::3 for Host A.
C:\>ipv6 install
Installing...
Succeeded.
C:\>ipv6 adu 4/10::3
2. Perform telnet operations to verify that IPv6 interface PBR on Switch A operates as configured to forward the matching TCP packets to the next hop 1::2 (Switch B), as follows:
# Verify that you can telnet to Switch B from Host A successfully. (Details not shown.)
# Verify that you cannot telnet to Switch C from Host A. (Details not shown.)
3. Verify that Switch A forwards packets other than TCP packets through VLAN-interface 20. For example, verify that you can ping Switch C from Host A. (Details not shown.)
